[Mapbender-commits] r6917 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 15 05:24:08 EDT 2010
Author: christoph
Date: 2010-09-15 09:24:08 +0000 (Wed, 15 Sep 2010)
New Revision: 6917
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
added column homepage
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql	2010-09-15 07:41:32 UTC (rev 6916)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql	2010-09-15 09:24:08 UTC (rev 6917)
@@ -2777,7 +2777,6 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT DISTINCT gui_element.fkey_gui_id, gui_element.e_id, 'css' AS var_name, '../extensions/jquery.layout.all-1.2.0/jquery.layout.css' AS var_value, '' AS context, 'file/css' AS var_type FROM gui_element, gui_element_vars WHERE fkey_e_id = e_id AND gui_element.e_js_file = '../plugins/mb_pane.js';
 -- Move CSS from configuration to file (frame)
@@ -2802,5 +2801,8 @@
+-- Add homepage to mb_group
+ALTER TABLE mb_group ADD COLUMN mb_group_homepage VARCHAR(255);
More information about the Mapbender_commits mailing list
