[Mapbender-commits] r6948 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Mon Sep 27 08:44:46 EDT 2010
Author: christoph
Date: 2010-09-27 12:44:46 +0000 (Mon, 27 Sep 2010)
New Revision: 6948
trunk/mapbender/http/plugins/mb_print.js
http://trac.osgeo.org/mapbender/ticket/708
overview URL is also requested in hq
Modified: trunk/mapbender/http/plugins/mb_print.js
--- trunk/mapbender/http/plugins/mb_print.js 2010-09-27 11:38:42 UTC (rev 6947)
+++ trunk/mapbender/http/plugins/mb_print.js 2010-09-27 12:44:46 UTC (rev 6948)
@@ -271,13 +271,29 @@
- var replaceMapFileForHighQualityPrint = function (currentMapUrl) {
+ var getCurrentResolution = function (type) {
+ // default resolution is 72 dpi
+ var dpi = 72;
+ // set resolution according to map configuration in template
+ for (var i in actualConfig.pages) {
+ var page = actualConfig.pages[i];
+ for (var j in page.elements) {
+ var el = page.elements[j];
+ if (type === el.type && typeof el.res_dpi === "number") {
+ dpi = el.res_dpi;
+ // set resolution according to resolution select box (if present)
// check if hq print is requested
var resolutionControl = null;
for (var i in actualConfig.controls) {
var c = actualConfig.controls[i];
- if ($.isPlainObject(c.pageElementsLink)) {
+ try {
for (var j in c.pageElementsLink) {
if (c.pageElementsLink[j] === "res_dpi") {
resolutionControl = typeof c.id === "string" &&
@@ -285,34 +301,39 @@
+ catch (e) {
if (resolutionControl !== null && resolutionControl.size() === 1) {
- var dpi = resolutionControl.val();
+ dpi = resolutionControl.val();
+ return parseInt(dpi, 10);
- // replace map file with hq map file (if configured)
- var hqmapfiles = $.isArray(options.highqualitymapfiles) ?
- options.highqualitymapfiles : [];
- for (var i = 0; i < hqmapfiles.length; i++) {
- var exp = new RegExp(hqmapfiles[i].pattern);
- if (hqmapfiles[i].pattern && typeof currentMapUrl === "string" && currentMapUrl.match(exp)) {
- // check if mapping in current resolution exists
- var resolutions = hqmapfiles[i].replacement;
- var resolutionExists = false;
- for (var r in resolutions) {
- if (r === dpi) {
- resolutionExists = true;
+ var replaceMapFileForHighQualityPrint = function (currentMapUrl, type) {
+ var dpi = getCurrentResolution(type);
+ // replace map file with hq map file (if configured)
+ var hqmapfiles = $.isArray(options.highqualitymapfiles) ?
+ options.highqualitymapfiles : [];
+ for (var i = 0; i < hqmapfiles.length; i++) {
+ var exp = new RegExp(hqmapfiles[i].pattern);
+ if (hqmapfiles[i].pattern && typeof currentMapUrl === "string" && currentMapUrl.match(exp)) {
+ // check if mapping in current resolution exists
+ var resolutions = hqmapfiles[i].replacement;
+ var resolutionExists = false;
+ for (var r in resolutions) {
+ if (parseInt(r, 10) === dpi) {
+ resolutionExists = true;
- if (resolutionExists) {
- // replace with hqmapfile
- var hqmapfile = resolutions[dpi];
- currentMapUrl = currentMapUrl.replace(exp, hqmapfile);
+ if (resolutionExists) {
+ // replace with hqmapfile
+ var hqmapfile = resolutions[dpi];
+ currentMapUrl = currentMapUrl.replace(exp, hqmapfile);
return currentMapUrl;
@@ -343,7 +364,7 @@
var currentMapUrl = mb_mapObj[ind].getMapUrl(i, mb_mapObj[ind].getExtentInfos(), scale);
- currentMapUrl = replaceMapFileForHighQualityPrint(currentMapUrl);
+ currentMapUrl = replaceMapFileForHighQualityPrint(currentMapUrl, "map");
f.map_url.value += currentMapUrl
var wmsLegendObj = [];
@@ -386,7 +407,7 @@
var overviewUrl = mb_mapObj[ind_overview].mapURL;
overviewUrl = $.isArray(overviewUrl) ? overviewUrl[0] : overviewUrl;
- f.overview_url.value = replaceMapFileForHighQualityPrint(overviewUrl);
+ f.overview_url.value = replaceMapFileForHighQualityPrint(overviewUrl, "overview");
updateFormField(formData, "overview_url", f.overview_url.value);
More information about the Mapbender_commits
