[Mapbender-commits] r6964 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 29 08:51:59 EDT 2010
Author: christoph
Date: 2010-09-29 12:51:59 +0000 (Wed, 29 Sep 2010)
New Revision: 6964
Removed:
   trunk/mapbender/lib/database-mysql.php
   trunk/mapbender/lib/database-mysqli.php
no more mysql in Mapbender
Deleted: trunk/mapbender/lib/database-mysql.php
--- trunk/mapbender/lib/database-mysql.php	2010-09-29 12:47:35 UTC (rev 6963)
+++ trunk/mapbender/lib/database-mysql.php	2010-09-29 12:51:59 UTC (rev 6964)
@@ -1,426 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/database-mysql.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
- * \file
- * \brief MySQL database connection/querying layer
- * MySQL database connection/querying layer
- * example:
- * \code
- * include_once(dirname(__FILE__)."/afwphp/database-mysql.php");
- * $sys_dbhost=...
- * $sys_dbuser=...
- * $sys_dbpasswd=...
- * $sys_dbname=...
- * db_connect();
- * $rs = db_query("select * from table");
- * while($row = db_fetch_array($rs));
- * \endcode
- * System-wide database type
- * @var	constant		$sys_database_type
-$sys_database_type='mysql';
- *  Connect to the database
- *  Notice the global vars that must be set up
- *  Notice the global vars $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname that must be set up
- *  in other functions in this library
-include_once(dirname(__FILE__)."/../http/classes/class_mb_exception.php");
-include_once(dirname(__FILE__)."/../http/classes/class_checkInput.php");
-function db_escapestring($unescaped_string){
-	return @mysql_escape_string($unescaped_string);
-function db_escape_string($unescaped_string){
-function db_connect($DBSERVER="",$OWNER="",$PW="") {
-	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,
-		$conn,$conn_update,$sys_db_use_replication,$sys_dbreadhost;
-	if ($DBSERVER)
-		$sys_dbhost = $DBSERVER;
-	if ($OWNER)
-		$sys_dbuser = $OWNER;
-	if ($PW)
-		$sys_dbpasswd = $PW;
-	if (PORT!=''){
-		$sys_dbport = ':'.PORT;
-	else{
-		$sys_dbport = '';
-	if ($sys_db_use_replication) {
-		//  if configured for replication, $conn is the read-only host
-		//  we do not connect to update server until needed
-		$conn = mysql_connect($sys_dbreadhost,$sys_dbuser,$sys_dbpasswd);
-		$conn_update= mysql_connect($sys_dbhost,$sys_dbuser,$sys_dbpasswd);
-	else {
-		# Create a new connection...
-		if( version_compare( PHP_VERSION, '4.2.0', 'ge' ) ) {
-			$conn = mysql_connect( $sys_dbhost,$sys_dbuser,$sys_dbpasswd, true );
-		else {
-			# On PHP 4.1 the new_link parameter is not available. We cannot
-			# guarantee that we'll actually get a new connection, and this
-			# may cause some operations to fail possibly.
-			$conn = mysql_connect( $sys_dbhost,$sys_dbuser,$sys_dbpasswd );
-	if ($sys_dbname)
-		@mysql_select_db($sys_dbname);
-	return $conn;
-function db_select_db($DB,$con="") {
-	global $conn,$sys_dbname;
-	$sys_dbname = $DB;
-	$_con = $con ? $con : $conn;
-	$ret = @mysql_select_db($sys_dbname,$_con);
-	if ($ret){
-		return true;
-	else {
-		return false;
-//	echo "$ret=@mysql_select_db($sys_dbname,$_con);";
- *  Query the database
- *  @param		$qstring (string)	SQL statement
- *  @param		$limit (int)		How many rows do you want returned
- *  @param		$offset (int)		Of matching rows, return only rows starting here
-function db_query($qstring,$limit='-1',$offset=0) {
-	global $QUERY_COUNT,$sys_db_use_replication,$sys_db_is_dirty,$DB,
-		$sys_dbname,$conn,$conn_update,$sys_dbhost,$sys_dbuser,$sys_dbpasswd;
-	$QUERY_COUNT++;
-	if(!$sys_dbname && $DB)
-	db_select_db($sys_dbname,$conn);
-	if ($limit > 0) {
-		if (!$offset || $offset < 0) {
-			$offset=0;
-		$qstring=$qstring." LIMIT $offset,$limit";
-//	if ($GLOBALS['IS_DEBUG'])
-		$GLOBALS['G_DEBUGQUERY'] .= $qstring . "<P><BR>\n";
-	//are we configured to try to use replication?
-		//if we haven't yet done an insert/update,
-		//read from the read-only db
-		if (!$sys_db_is_dirty && mb_eregi("^( )*(select)",$qstring)) {
-			if ($QUERY_COUNT%3==0) {
-				// 1/3rd of read queries go to master for now
-				return @mysql_db_query($sys_dbname,$qstring,$conn_update);
-			} else {
-				return @mysql_db_query($sys_dbname,$qstring,$conn);
-		} else {
-			//must be an update/insert/delete query - go to master server
-			$sys_db_is_dirty=true;
-	} else {
-		$ret = @mysql_db_query($sys_dbname,$qstring,$conn);
-//		echo "@mysql_db_query($sys_dbname,$qstring,$conn); ret=$ret<br>";
-		if(!$ret){
-			$e = new mb_exception("db_query($qstring)=$ret db_error=".db_error());
-		return $ret;
-	//echo "SQL__".$qstring;
- *  prepare and query the database
- *  @param		$params (array string params)
- *  @param		$types (array string types)
-function db_prep_query($qstring, $params, $types){
-	$orig_qstring = $qstring;
-	$ci = new checkInput($qstring,$params,$types);
-	$params = $ci->v;
-	for ($i=0; $i<count($params); $i++){
-		$needle = "$".strval($i+1);
-		$tmp = '';
-		if($params[$i] !== NULL){
-			if($types[$i] == 's'){ $tmp .= "'"; }
-			$tmp .= $params[$i];
-		else{
-			$tmp .= "NULL";
-		$posa = mb_strpos($qstring, $needle);
-		if(!$posa) {
- 			$e = new mb_exception("Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME']. ": Sql :". $orig_qstring .",Error: parameter '$needle' not found ");
-		$posb = mb_strlen($needle);
-		$qstring = mb_substr($qstring,0,$posa).$tmp.mb_substr($qstring,($posa + $posb));
-	$r = db_query($qstring);
-	return $r;
- *	Begin a transaction
- *	Begin a transaction for databases that support them
- *	may cause unexpected behavior in databases that don't
-function db_begin() {
-	return db_query("BEGIN WORK");
- * Commit a transaction
- * Commit a transaction for databases that support them
-function db_commit() {
-	return db_query("COMMIT");
- * Roll back a transaction
- * Rollback a transaction for databases that support them
-function db_rollback() {
-	$str = db_error();
-	db_query("ROLLBACK");
-	die('sql error: ' . $str . " ROLLBACK performed....");
- * Returns the number of rows in this result set
- *  @param		$qhandle (string)	Query result set handle
- * (!!! Deprecated? Changed the MySQL-Command to match the current syntax)
-function db_numrows($qhandle) {
-	// return only if qhandle exists, otherwise 0
-	if ($qhandle) {
-		return @mysql_num_rows($qhandle);
-	} else {
-		return 0;
- * php 3,4,5
-function db_num_rows($qhandle) {
-	if ($qhandle) {
-	} else {
-		return 0;
- *  Frees a database result properly
-function db_free_result($qhandle) {
-	return @mysql_free_result($qhandle);
- *  Reset a result set.
- *  Reset is useful for db_fetch_array sometimes you need to start over
- *  @param		$row (int)		Row number
-function db_reset_result($qhandle,$row=0) {
-	return mysql_data_seek($qhandle,$row);
- *  Returns a field from a result set
- *  @param		$field (string)	Field name
-function db_result($qhandle,$row,$field) {
-	return @mysql_result($qhandle,$row,$field);
- *  Returns the number of fields in this result set
- *  @param		$lhandle (string)	Query result set handle
-function db_numfields($lhandle) {
-	return @mysql_num_fields($lhandle);
- * php 3,4,5
-function db_num_fields($lhandle) {
- *  Returns the number of rows changed in the last query
- *  @param		$fnumber (int)	Column number
-function db_fieldname($lhandle,$fnumber) {
-	   return @mysql_fieldname($lhandle,$fnumber);
-function db_affected_rows($qhandle) {
-	return @mysql_affected_rows();
- *  Fetch an array
- *  Returns an associative array from
- *  the current row of this database result
- *  Use db_reset_result to seek a particular row
-function db_fetch_array($qhandle) {
-	return @mysql_fetch_array($qhandle);
- * fetch a row into an array
-function db_fetch_row($qhandle,$fnumber=0) {
-	  return @mysql_fetch_row($qhandle);
- *  Returns the last primary key from an insert
- *  @param		$table_name (string)	Is the name of the table you inserted into
- *  @param		$pkey_field_name (string)	Is the field name of the primary key
-function db_insertid($qhandle="",$table_name="",$pkey_field_name="") {
-	return @mysql_insert_id();
-function db_insert_id($qhandle="",$table_name="",$pkey_field_name="") {
- * Returns the last error from the database
-function db_error() {
-	return @mysql_error();
- * Get the flags associated with the specified field in a result
- * 					Examples: "not_null", "primary_key", "unique_key", "multiple_key",
- *                    "blob", "unsigned", "zerofill","binary", "enum",
- *                    "auto_increment", "timestamp"
-function db_field_flags($lhandle,$fnumber) {
-	   return @mysql_field_flags($lhandle,$fnumber);
- * Get the type of the specified field
-function db_field_type($lhandle,$fnumber) {
-	   return @mysql_field_type($lhandle,$fnumber);
- * Get the length of the specified field
-function db_field_len($lhandle,$fnumber) {
-	   return @mysql_field_len($lhandle,$fnumber);
Deleted: trunk/mapbender/lib/database-mysqli.php
--- trunk/mapbender/lib/database-mysqli.php	2010-09-29 12:47:35 UTC (rev 6963)
+++ trunk/mapbender/lib/database-mysqli.php	2010-09-29 12:51:59 UTC (rev 6964)
@@ -1,485 +0,0 @@
-<?php
-$sys_database_type='mysqli';
-include_once(dirname(__FILE__)."/../../http/classes/class_mb_exception.php");
-include_once(dirname(__FILE__)."/../../http/classes/class_checkInput.php");
-	global $conn;
-	return mysqli_escape_string($conn, $unescaped_string);
-	global $conn;
-	if ($DBSERVER)
-	if ($OWNER)
-	if ($PW)
-	if (PORT!=''){
-	else{
-		$sys_dbport = '';
-		$conn = mysqli_connect($sys_dbreadhost,$sys_dbuser,$sys_dbpasswd);
-		$conn_update=mysqli_connect($sys_dbhost,$sys_dbuser,$sys_dbpasswd);
-	} else {
-		$conn = mysqli_connect($sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,intval($sys_dbport));
-		#echo "@mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd)";
-	if ($sys_dbname)
-		mysqli_select_db($conn, $sys_dbname);
-	return $conn;
-	$ret = mysqli_select_db($_con, $sys_dbname);
-	if ($ret){
-		return true;
-	else {
-		return false;
-	/* Ausmisten! Der Code ist unübersichtlich, und bei manchen Zweigen ist nicht klar,
-	 * ob sie überhaupt ausgeführt werden...
-	$QUERY_COUNT++;
-	if ($limit > 0) {
-			$offset=0;
-				return mysqli_query($sys_dbname,$qstring,$conn_update);
-			} else {
-				return mysqli_query($sys_dbname,$qstring,$conn);
-		} else {
-	} else {
-		$ret = mysqli_query($conn, $qstring);
-		if(!$ret){
-		return $ret;
-function db_prepare_typestr($types) {
-	$result = '';
-	foreach ($types as $current_type) {
-		$result .= $current_type;
-	return $result;
-	// Beim Umschreiben an der PostGreSQL-Bibliothek orientieren
-	global $conn, $stmt;
-	@mysqli_stmt_close($stmt);
-	$params = $ci->v;
-	if(PREPAREDSTATEMENTS == false){
-			$tmp = '';
-			else{
-				$tmp .= "NULL";
-			if(!$posa) {
-		if(!$r){
-			$e = new mb_exception("Error while executing sql statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-	else{
-		if (!$conn) {
-			$e = new mb_exception("Error while connecting to the database in ".$_SERVER['SCRIPT_FILENAME'].", Error: ".db_error());
-		echo $qstring;
-		$qstring = preg_replace('/\$[0-9]+/', '?', $qstring);
-		echo $qstring;
-		$stmt = mysqli_prepare($conn, $qstring);
-		//echo $result;
-		if(!$stmt){
-			echo "Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error();
-			$e = new mb_exception("Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-		$type_string = '"';
-		$param_string = '';
-		$val_def_string = '';
-		$val_string = '';
-		/*for ($i = 0; $i < count($params); $i++) {
-			if ($params[$i] !== NULL) {
-				$type_string .= $types[$i];
-				if ($i > 0) {
-					$param_string .= ', ';
-					$val_string .= ', ';
-				$param_string .= '"'.$params[$i].'"';
-				if ($types[$i] == 's')
-					$val_def_string .= '$val'.$i.'="'.$params[$i].'";';
-				else
-					$val_def_string .= '$val'.$i.'='.$params[$i].';';
-				$val_string .= '$val'.$i;
-				//mysqli_stmt_bind_param($result, $types[$i], $params[$i]);
-		for( $i = 0; $i < count($params); ++$i ) {
-			$thisVar = "v$i";
-			$variadicParams .= '$' . $thisVar;
-			if( $i != count($params) - 1 ) // don't append a comma on the last variable
-				$variadicParams .= ', ';
-			$variadicExtVars[ $thisVar ] = $params[ $i ];
-		echo $variadicParams;
-		$bindParamFunc = create_function( '$vars, &$stmt','extract( $vars ); $stmt->bind_param( \'' . implode($types) . '\', ' . $variadicParams . ' );' );
-		$bindParamFunc( $variadicExtVars, $stmt );
-		/* $typeStr = call_user_func_array( 'db_prepare_typestr', $types );
-      	array_unshift( $params, $typeStr );
-      	call_user_func_array( array( 'mysqli_bind_param', $qstring  ), $params ); */
-		/*$type_string .= '"';
-		$eval_string = $val_def_string.'mysqli_stmt_bind_param($result,'.$type_string.','.$val_string.');';
-		$xyz=1;
-		//$eval_string = 'eead results, this function cancelcho $result;';
-		//$eval_string = 'return mysqli_stmt_bind_param($result,'.$type_string.',$xyz);';
-		echo $eval_string;
-		//echo "mysqli_stmt_bind_param($result,$type_string,$param_string)";
-		eval($eval_string);*/
-		$r = mysqli_stmt_execute($stmt);
-		if(!$r){
-			$e = new mb_exception("Error while executing prepared statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
-		$result2 = $stmt;
-	return $stmt;
-	if ($qhandle) {
-		return mysqli_num_rows($qhandle);
-	} else {
-		return 0;
-	return mysqli_free_result($qhandle);
-	return mysqli_data_seek($qhandle,$row);
-	//return mysqli_result($qhandle,$row,$field);
-	if( mysqli_num_rows( $qhandle ) ) {
-		$x = 0;
-		while( $array = mysqli_fetch_array( $qhandle, MYSQLI_NUM ) ) {
-			if( $row == $x++ ) {
-				return isset( $array[ $field ] ) ? $array[ $field ] : '';
-	return mysqli_num_fields($lhandle);
- * php 3,4,5
-	   return mysql_field_name($lhandle,$fnumber);
-	return mysqli_affected_rows($qhandle);
- *  Fetch an array
-	global $conn;
-	$data = mysqli_stmt_result_metadata($qhandle);
-        $fields = array();
-        $out = array();
-        $fields[0] = &$qhandle;
-        $count = 1;
-        while($field = mysqli_fetch_field($data)) {
-            $fields[$count] = &$out[$field->name];
-            $count++;
-        call_user_func_array(mysqli_stmt_bind_result, $fields);
-        mysqli_stmt_fetch($qhandle);
-        return (count($out) == 0) ? false : $out;
-	/*if (!$qhandle)
-		return NULL;
-	else
-		return mysqli_fetch_array($conn); */
-	  global $stmt;
-	  if ($qhandle)
-	  	return mysqli_fetch_row($stmt);
-	  else
-	  	return NULL;
-	return mysqli_insert_id();
-	global $conn;
-	return mysqli_error($conn);
-	   return mysqli_field_flags($lhandle,$fnumber);
-	   return mysqli_field_type($lhandle,$fnumber);
-	   return mysqli_field_len($lhandle,$fnumber);
\ No newline at end of file
More information about the Mapbender_commits mailing list
