[Mapbender-commits] r6975 - in branches/mapbender/http: frames php
svn_mapbender at osgeo.org
Wed Sep 29 14:40:14 EDT 2010
Author: christoph
Date: 2010-09-29 18:40:14 +0000 (Wed, 29 Sep 2010)
New Revision: 6975
branches/mapbender/http/frames/index.php
branches/mapbender/http/frames/login.php
branches/mapbender/http/php/mb_getGUIs.php
branches/mapbender/http/php/mb_listGUIs.php
pdo
Modified: branches/mapbender/http/frames/index.php
--- branches/mapbender/http/frames/index.php 2010-09-29 15:26:36 UTC (rev 6974)
+++ branches/mapbender/http/frames/index.php 2010-09-29 18:40:14 UTC (rev 6975)
@@ -24,7 +24,6 @@
Mapbender::session()->set("mb_user_gui",$gui_id);
-print_r($_SESSION);
// check if user is allowed to access current GUI;
// if not, return to login screen
Modified: branches/mapbender/http/frames/login.php
--- branches/mapbender/http/frames/login.php 2010-09-29 15:26:36 UTC (rev 6974)
+++ branches/mapbender/http/frames/login.php 2010-09-29 18:40:14 UTC (rev 6975)
@@ -166,7 +166,7 @@
if($row){
setSession();
include(dirname(__FILE__)."/../../conf/session.conf");
if(Mapbender::session()->get("mb_user_id")){
if($row["mb_user_login_count"] <= MAXLOGIN){
$sql_del_cnt = "UPDATE mb_user SET mb_user_login_count = 0 WHERE mb_user_id = $1";
@@ -199,7 +199,7 @@
$myURL .= "&".$cleanUrl;
session_write_close();
- header ($myURL);
+# header ($myURL);
die;
# list all guis of this user and his groups
Modified: branches/mapbender/http/php/mb_getGUIs.php
--- branches/mapbender/http/php/mb_getGUIs.php 2010-09-29 15:26:36 UTC (rev 6974)
+++ branches/mapbender/http/php/mb_getGUIs.php 2010-09-29 18:40:14 UTC (rev 6975)
@@ -26,8 +26,8 @@
$t = array('i');
$res_groups = db_prep_query($sql_groups,$v,$t);
$cnt_groups = 0;
- while(db_fetch_row($res_groups)){
- $mb_user_groups[$cnt_groups] = db_result($res_groups,$cnt_groups,"fkey_mb_group_id");
+ while($row = db_fetch_row($res_groups)){
+ $mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
$cnt_groups++;
$count_g = 0;
@@ -44,8 +44,8 @@
$sql_g .= "))";
$res_g = db_prep_query($sql_g,$v,$t);
- while(db_fetch_row($res_g)){
- $arrayGuis[$count_g] = db_result($res_g, $count_g, "gui_id");
+ while($row = db_fetch_row($res_g)){
+ $arrayGuis[$count_g] = $row["gui_id"];
$count_g++;
@@ -56,9 +56,9 @@
$t = array('i');
$res_guis = db_prep_query($sql_guis,$v,$t);
$count_guis = 0;
- while(db_fetch_row($res_guis)){
- if( !in_array(db_result($res_guis,$count_guis,"gui_id"),$arrayGuis)){
- $arrayGuis[$count_g] = db_result($res_guis,$count_guis,"gui_id");
+ while($row = db_fetch_row($res_guis)){
+ if( !in_array($row["gui_id"],$arrayGuis)){
$count_g++;
$count_guis++;
Modified: branches/mapbender/http/php/mb_listGUIs.php
--- branches/mapbender/http/php/mb_listGUIs.php 2010-09-29 15:26:36 UTC (rev 6974)
+++ branches/mapbender/http/php/mb_listGUIs.php 2010-09-29 18:40:14 UTC (rev 6975)
@@ -125,4 +125,4 @@
echo "</div>";
\ No newline at end of file
More information about the Mapbender_commits
