[Mapbender-commits] r6983 - in trunk/mapbender: http/css http/img http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Sep 30 07:28:04 EDT 2010
Author: kmq
Date: 2010-09-30 11:28:04 +0000 (Thu, 30 Sep 2010)
New Revision: 6983
Added:
   trunk/mapbender/http/css/feedtree.css
   trunk/mapbender/http/img/georss_logo.png
   trunk/mapbender/http/img/georss_logo_folder.png
   trunk/mapbender/http/img/kml_logo.png
   trunk/mapbender/http/plugins/feedTree.js
   trunk/mapbender/lib/mb.ui.displayFeatures.js
New feature: A treeview for GeoRSS feeds
Added: trunk/mapbender/http/css/feedtree.css
--- trunk/mapbender/http/css/feedtree.css	                        (rev 0)
+++ trunk/mapbender/http/css/feedtree.css	2010-09-30 11:28:04 UTC (rev 6983)
@@ -0,0 +1,126 @@
+li{ border: 1px solid black; }
+ul{ border: 1px dotted blue; }
+a{ border: 1px dotted red; }
+/* The Whole feed Tree */
+ul.feedtree {
+	overflow: auto;
+	width: 10em;
+/*	background-image: url("http://localhost:8888/vertical_dots.png");*/
+	background-repeat: repeat-y	;
+	background-position: 20px;
+ul.feedtree, ul.feedtree ul {
+	list-style-type: none;
+	margin-left: 0;
+	padding-left: 0;
+ul.feedtree a{
+	font-size: x-small;
+ul.feedtree  li{
+	padding-left: 16px;
+	margin-left: 1em;
+ul.feedtree button {
+	padding: 0;
+	margin-left: 0;
+	background-color: transparent;
+	width: 20px;
+	height: 20px;
+	vertical-align: middle;
+	border: none;
+ul.feedtree a:link, ul.feedtree a:visited, ul.feedtree a:hover, ul.feedtree a:active {
+	text-decoration: none;
+	color: black;
+/* a Root Node  */
+ul.feedtree  li.rss.open{
+	padding-left: 0;
+ul.feedtree li.rss ul li{
+	margin-left:  0.2em;
+ul.feedtree li.open.rss > button.toggle{
+	background-image: url("../img/georss_logo_folder.png");
+	background-repeat: no-repeat;
+	background-position: 0 0;
+ul.feedtree li.closed.rss > button.toggle{
+ul.feedtree li.rss.open, ul.feedtree li.rss.closed {
+	background-image: none;
+/*  a Feed Node */
+ul.feedtree li.open > button.toggle{
+	background-image: url("../img/tree_new/expanded_folder.png");
+ul.feedtree li.closed >  button.toggle{
+	background-image: url("../img/tree_new/closed_folder.png");
+ul.feedtree li button.remove{
+	background-image: url("../img/button_digitize/geomRemove.png");
+ul.feedtree li.open, ul.feedtree li.closed {
+	background-repeat: repeat-x	;
+	background-position: 10px 10px;
+ul.feedtree li.closed >ul{
+	display: none;
+ul.feedtree li.rss  li input{
+/* a FeedItem Node */
+ul.feedtree  ul ul {
+	padding: 0;
+ul.feedtree  ul ul li {
+	padding: 0;
+	border: 1px solid transparent;
+ul.feedtree  ul ul li:hover {
+	border: 1px dotted gray;
Added: trunk/mapbender/http/img/georss_logo.png
(Binary files differ)
Property changes on: trunk/mapbender/http/img/georss_logo.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/mapbender/http/img/georss_logo_folder.png
Property changes on: trunk/mapbender/http/img/georss_logo_folder.png
Added: trunk/mapbender/http/img/kml_logo.png
Property changes on: trunk/mapbender/http/img/kml_logo.png
Added: trunk/mapbender/http/plugins/feedTree.js
--- trunk/mapbender/http/plugins/feedTree.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/feedTree.js	2010-09-30 11:28:04 UTC (rev 6983)
@@ -0,0 +1,117 @@
+var $feedTree = $(this);
+var FeedTree = function(o){
+	$feedTree.children().remove();
+	$feedTree.addClass('feedtree');
+	$addButton = $("<button>addGeoRSS</button>");
+	$feedTree.after($addButton);
+	$addButton.after('<input id="feedurl"  value="http://localhost:8888/georss.example.xml" />');
+	$addButton.click(function(){
+		$('#mapframe1').georss({ url: $('#feedurl').val()});
+	var $RSSfolder = $('<li class="open rss"><button class="toggle" name="toggle" value="toggle"></button><a href="#">RSS</a><ul></ul></li>');
+	$feedTree.append($RSSfolder);
+//	var $KMLfolder = $('<li class="open rss"><img src="../img/kml_logo.png" /><a href="#">KML</a><ul></ul></li>');
+//	$feedTree.append($KMLfolder);
+	o.$target.bind('georss:loaded',function(e,obj){
+		//console.log(obj);
+		var checked = obj.display ? 'checked="checked"':'';
+		title = obj.url;
+		abbrevTitle = title.length < 20 ?  title : title.substr(0,17) + "...";
+		$rssEntry = $('<li title="'+ title +'" class="open"><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"'+checked  +'/><button class="remove" name="remove" value="remove" ></button><a href="#">'+abbrevTitle+'</a></li>');
+		$RSSfolder.children("ul").append($rssEntry);
+		$rssEntry.find("a").bind("click",(function(jsonFeatureCollection){return function(){
+				var map = o.$target.mapbender();
+				var g = new GeometryArray();
+				g.importGeoJSON(jsonFeatureCollection,false);
+				var bbox = g.getBBox();
+				var bufferFloat = parseFloat(0.1);
+				var buffer = new Point(bufferFloat,bufferFloat);
+				bbox[0] = bbox[0].minus(buffer);
+				bbox[1] = bbox[1].plus(buffer);
+				map.calculateExtent(
+				  new Mapbender.Extent(bbox[0], bbox[1])
+				map.setMapRequest();
+		})(obj.data));
+		$featureList = $("<ul />");
+		$rssEntry.append($featureList);
+		for(var i = 0;i < obj.data.features.length;i++){
+			title = obj.data.features[i].properties.title;
+			$feature = $('<li title="'+ title +'"><a href="#" >'+ abbrevTitle + '</li>');
+			$featureList.append($feature);
+			$feature.bind('click',(function(jsonFeature){return function(){
+				g.importGeoJSON(jsonFeature,false);
+				feature = g.get(0);
+				var bbox = feature.getBBox();
+			})(obj.data.features[i]));
+		$("*:checkbox",$rssEntry).bind('click', function(){
+			if($(this).attr('checked')){
+				o.$target.georss('show',obj.url);
+			}else{
+				o.$target.georss('hide',obj.url);
+		$("button.toggle",$rssEntry).bind('click', function(){
+			if($(this).parent().hasClass("open")){
+				$(this).parent().removeClass("open");
+				$(this).parent().addClass("closed");
+			}else{
+				$(this).parent().removeClass("closed");
+				$(this).parent().addClass("open");
+		$("button.remove",$rssEntry).bind('click', function(){
+			o.$target.georss('remove',obj.url);
+			$(this).parent().remove();
+Mapbender.events.init.register(function(){
+	$feedTree.mapbender(new FeedTree(options));
Modified: trunk/mapbender/lib/mb.ui.displayFeatures.js
--- trunk/mapbender/lib/mb.ui.displayFeatures.js	2010-09-30 10:19:19 UTC (rev 6982)
+++ trunk/mapbender/lib/mb.ui.displayFeatures.js	2010-09-30 11:28:04 UTC (rev 6983)
@@ -1,3 +1,6 @@
+// events
+// 	geojson:loaded  	- a georssfeed was loaded from a server and is now available: function(url,geojson)
+// 	georss:error	- a georssfeed failed to load: function(url,error);
 var originalI18nObject = {
 	"labelLoadError" : "Could not load Document",
@@ -23,22 +26,25 @@
-var translatedI18nObject = Mapbender.cloneObject(originalI18nObject);
+//var translatedI18nObject = Mapbender.cloneObject(originalI18nObject);
+var translatedI18nObject = originalI18nObject;
 var displayFeatures = {
 	options: {
 		url: "",
-		position: 'right'
+		position: 'right',
+		autoOpen: true,
+		autoDisplay: true
 	_feeds: {},
 	_popup : null,
 	_create: function(){
-		var that = this, o = this.options;
-		this.element.click( function(e){
-			var map = that.element.mapbender();
+		var self = this, o = this.options;
+		this.element.bind('click', function(e){
+			var map = self.element.mapbender();
 			var pos = map.getMousePosition(e);
 			var clickPoint =  map.convertPixelToReal(new Point(pos.x,pos.y));
 			var feed = null;
@@ -49,10 +55,10 @@
 			// after that's finished the results are merged and displayed in a box
 			var pointGeometries = {};
 			var g,h,nodes = null;
-			$("*",that._popup).remove();
+			$("*",self._popup).remove();
 			var $tabs = $("<ul></ul>");
-			for (var i in that._feeds){
-				feed = that._feeds[i] ;
+			for (var i in self._feeds){
+				feed = self._feeds[i] ;
 				requestGeometries = [];
 				for(var j = 0; j < feed.geomArray.count(); j++){
@@ -115,15 +121,15 @@
 						description = g.e.getElementValueByName("description");
 						$tabs.append('<li><a href="#rsspopup_'+ i +'">'+ title + '</a></li>');
-						that._popup.append('<div id="rsspopup_'+ i +'"><h1>'+ title +'</h1><p>'+ description +'</p></h1>');
+						self._popup.append('<div id="rsspopup_'+ i +'"><h1>'+ title +'</h1><p>'+ description +'</p></h1>');
 						if($tabs.children().size() > 1){
 							var $tabcontainer = $("<div><div>");
 							$tabcontainer.append($tabs);
-							$tabcontainer.append($('div',that._popup));
-							that._popup.append($tabcontainer);
+							$tabcontainer.append($('div',self._popup));
+							self._popup.append($tabcontainer);
 							$tabcontainer.tabs();
-						that._popup.dialog('open');
+						self._popup.dialog('open');
@@ -134,155 +140,168 @@
+		self.element.bind('georss:loaded',function(event,obj){
+			if(o.autoOpen){
+				self._display(obj);
+		self.element.bind('georss:error',function(event,message){
+			alert(message);
 	_init: function(){
 		this._popup = $('<div></div>').dialog({autoOpen : false, height: 500, width: 500});
 		if(o.url){
-			that._load(o.url);
+			self._load(o.url);
 	_load : function(url){
-		var loadError = function(message){
-				$("<div class='labelLoadError'>"+ translatedI18nObject.labelLoadError +"</div>").dialog({ buttons: {"OK":function(){ $(this).dialog("close");  }} });
-		$.ajax({ url: that._endpointURL,
+		if(self._feeds[o.url]){
+			//not adding feed twice
+			return;
+		$.ajax({ url: self._endpointURL,
 			data: {url: o.url},
 			type: 'POST',
 			dataType: "json",
 			success : function(data,textStatus,xhr){
 				if(!data){
-					loadError('request returned no data');
-				if(data.errorMessage){
-					loadError(data.errorMessage);
-					return;
+					self.element.trigger('georss:error',"request returned no data");
-				that._display(data,url);
+				else if(data.errorMessage){
+					self.element.trigger('georss:error',data.errorMessage);
+				}else{
+					self._feeds[o.url] = {type:"geojson",data:data,url:o.url,display: o.autoDisplay};
+					self.element.trigger('georss:loaded',{type:"geojson",data:data,url:o.url,display: o.autoDisplay});
 			error: function(XMLHttpRequest, textStatus, errorThrown){
-				loadError("could not load "+o.url);
+				self.element.trigger('georss:error',"Problem talking to server: " + errorThrown);
+	show : function(url){
+		this._feeds[url].display = true;
+		var $map = $(this.element).mapbender();
+		var extent = $map.getExtentInfos();
+		$map.calculateExtent(extent);
+		$map.setMapRequest();
+		$(this.element).mapbender().setMapRequest();
-	_display : function(geoJSON,url){
+	hide : function(url){
+		this._feeds[url].display = false;
-		var $map = $(that.element).mapbender();
-		var markers = [];
-		var title = "";
-		var $table = $("<table><thead><tr><th class='labelName'>"+ translatedI18nObject.labelName  +"</th></tr></thead><tbody></tbody></table>");
+	remove: function(url){
+		// nrgh there are still references to the highlightobjects somewhere!
+		for(var i in this._feeds[url].highlightArray){
+			this._feeds[url].highlightArray[i].clean();
+		delete(this._feeds[url]);
-		if(geoJSON.features){
-			// we always transform _from_ 4326 geoRSS and KML use this as their default
-			var projSrc = new Proj4js.Proj('EPSG:4326');
-			var projDest = new Proj4js.Proj($map.epsg);
-			var markeroptions = {width: "19px", height: "34px"};
-			var g = null;
-			var geomArray = new GeometryArray();
-			var highlightArray = [];
-			geomArray.importGeoJSON(geoJSON);
-			for(var i =0; i < geomArray.count(); i++){
-				var h = new Highlight([this.element.attr('id')], "mapframe1_" + parseInt(Math.random()*100000,10),{
-					"position":"absolute",
-					"top": "0px",
-					"left": "0px",
-					"z-index": "80" },1);
-				g = geomArray.get(i);
-				icon = g.e.getElementValueByName("Mapbender:icon");
-				title = g.e.getElementValueByName("title");
-				name = g.e.getElementValueByName("name");
+	_display : function(mapitem){
+		// getting the mapitem from the events bre
+		var mapitem = self._feeds[mapitem.url];
+		var geojson = mapitem.data;
+		if(typeof(Mapbender) != "undefined"){
+			var $map = $(self.element).mapbender();
+			var markers = [];
+			var title = "";
+			if(geojson.features){
+				// we always transform _from_ 4326 geoRSS and KML use this as their default
+//				var projSrc = new Proj4js.Proj('EPSG:4326');
+//				var projDest = new Proj4js.Proj($map.epsg);
+				var markeroptions = {width: "19px", height: "34px"};
+				var g = null;
-				if(name != "false" && name !== false){
-					title = name;
-				if(icon == "false" || icon === false){
-					g.e.setElement("Mapbender:iconOffsetX", -10);
-					g.e.setElement("Mapbender:iconOffsetY", -34);
-					g.e.setElement("Mapbender:icon","../img/marker/red.png");
+				mapitem.geomArray = new GeometryArray();
+				mapitem.highlightArray = [];
+				mapitem.geomArray.importGeoJSON(geojson);
+				for(var i =0; i < mapitem.geomArray.count(); i++){
+					var h = new Highlight([self.element.attr('id')], "mapframe1_" + parseInt(Math.random()*100000,10),{
+						"position":"absolute",
+						"top": "0px",
+						"left": "0px",
+						"z-index": "80" },1);
+					g = mapitem.geomArray.get(i);
+					icon = g.e.getElementValueByName("Mapbender:icon");
+					title = g.e.getElementValueByName("title");
+					name = g.e.getElementValueByName("name");
+					if(name != "false" && name !== false){
+						title = name; // use for tooltip
+					if(icon == "false" || icon === false){
+						g.e.setElement("Mapbender:iconOffsetX", -10);
+						g.e.setElement("Mapbender:iconOffsetY", -34);
+						g.e.setElement("Mapbender:icon","../img/marker/red.png");
-				description = g.e.getElementValueByName("description");
-				$row = $("<tr><td>"+ title  +"</td></tr>");
-				$row.css("cursor","pointer");
-				$row.click((function(title,description){
-					return function(){
-						description = description.replace('<a ','<a target="_new" ');
-						that._popup.append($("<div><h1>"+title+"</h1><p>"+description +"</p></div>")).dialog('open');
-				})(title,description));
-				$("tbody",$table).append($row);
-				h.add(g);
-				highlightArray.push(h);
-				title = "";
-				name = "";
-			for(var i in highlightArray){
-				highlightArray[i].paint();
-			$map.events.afterMapRequest.register(function () {
+					h.add(g);
+					mapitem.highlightArray.push(h);
+					title = "";
+					name = "";
-			that._feeds[url] = {
-				geomArray: geomArray,
-				highlightArray: highlightArray
-		var $tableDialog = $("<div></div>").dialog({
-			width: "450",
-			height: "500",
-			autoOpen: true,
-			position: o.position,
-			beforeclose: (function(url){
-					delete that._feeds[url];
-						highlightArray[i].clean();
+				if(mapitem.display){
+					for(var j in mapitem.highlightArray){
+						mapitem.highlightArray[j].paint();
-				})(url),
-			buttons: {"Close": function(){
-					$(this).dialog('close');
-					$(this).dialog('destroy');
+				}else{
+						mapitem.highlightArray[j].hide();
+				self.element.mapbender().events.afterMapRequest.register(function () {
+						for(var i in mapitem.highlightArray){
+							mapitem.highlightArray[i].paint();
+					}else{
+							mapitem.highlightArray[i].hide();
-		$tableDialog.append($table);
-		$table.dataTable({"bJQueryUI": true ,
-			"oLanguage":{
-				"sUrl":"../extensions/dataTables-1.5/lang/"+Mapbender.languageId +".txt"
 var displayGeoRSS =  $.extend({},displayFeatures,{
-	_endpointURL: "../php/geoRSSToGeoJSON.php"
+	_endpointURL: "../php/geoRSSToGeoJSON.php",
+	_eventNamespace : "georss"
 $.widget('ui.georss',displayGeoRSS);
 var displayKML = $.extend({},displayFeatures, {
-	_endpointURL: "../php/kmlToGeoJSON.php"
+	_endpointURL: "../php/kmlToGeoJSON.php",
+	_eventNamespace : "kml"
 $.widget('ui.kml',displayKML);
More information about the Mapbender_commits mailing list
