[Mapbender-commits] r6986 - in trunk/mapbender: http/classes
http/plugins lib
svn_mapbender at osgeo.org
Thu Sep 30 09:31:20 EDT 2010
Author: kmq
Date: 2010-09-30 13:31:20 +0000 (Thu, 30 Sep 2010)
New Revision: 6986
trunk/mapbender/http/classes/class_gml.php
trunk/mapbender/http/classes/class_gml_feature_collection.php
trunk/mapbender/http/plugins/feedTree.js
trunk/mapbender/lib/class_Filter.php
trunk/mapbender/lib/mb.ui.wfsGazetteer.js
trunk/mapbender/lib/wizard.js
highlights for geometries other than pointhttp/plugins/feedTree.js
Modified: trunk/mapbender/http/classes/class_gml.php
--- trunk/mapbender/http/classes/class_gml.php 2010-09-30 12:43:13 UTC (rev 6985)
+++ trunk/mapbender/http/classes/class_gml.php 2010-09-30 13:31:20 UTC (rev 6986)
@@ -20,7 +20,9 @@
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/../classes/class_connector.php");
require_once(dirname(__FILE__)."/../classes/class_json.php");
+ $e = new mb_exception("BB");
require_once(dirname(__FILE__)."/../classes/class_gml_feature_collection.php");
+ $e = new mb_exception("DD");
abstract class Gml {
var $featureCollection = null;
@@ -109,4 +111,4 @@
\ No newline at end of file
Modified: trunk/mapbender/http/classes/class_gml_feature_collection.php
--- trunk/mapbender/http/classes/class_gml_feature_collection.php 2010-09-30 12:43:13 UTC (rev 6985)
+++ trunk/mapbender/http/classes/class_gml_feature_collection.php 2010-09-30 13:31:20 UTC (rev 6986)
@@ -1,4 +1,5 @@
<?php
+ $e = new mb_exception("CC");
# $Id: class_gml2.php 3099 2008-10-02 15:29:23Z nimix $
# http://www.mapbender.org/index.php/class_gml2.php
# Copyright (C) 2002 CCGIS
@@ -25,10 +26,11 @@
class FeatureCollection {
var $type = "FeatureCollection";
+ var $title = "";
var $featureArray = array();
- public function __construct() {
+ public function __construct($title="") {
+ $this->title = $title;
public function addFeature ($aFeature) {
@@ -49,7 +51,9 @@
- $str .= "]}";
+ $str .= "]";
+ $str .= $this->title ? ',"properties": { "title": "' . $this->title . '"} ': "";
+ $str .= "}";
return $str;
@@ -78,4 +82,4 @@
return count($this->featureArray);
Modified: trunk/mapbender/http/plugins/feedTree.js
--- trunk/mapbender/http/plugins/feedTree.js 2010-09-30 12:43:13 UTC (rev 6985)
+++ trunk/mapbender/http/plugins/feedTree.js 2010-09-30 13:31:20 UTC (rev 6986)
@@ -2,10 +2,7 @@
var FeedTree = function(o){
$feedTree.children().remove();
$feedTree.addClass('feedtree');
var $RSSfolder = $('<li class="open rss"><button class="toggle" name="toggle" value="toggle"></button><a href="#">RSS</a><ul></ul></li>');
$feedTree.append($RSSfolder);
@@ -72,7 +69,7 @@
var map = o.$target.mapbender();
var g = new GeometryArray();
g.importGeoJSON(jsonFeature,false);
- feature = g.get(0);
+ var feature = g.get(0);
var bbox = feature.getBBox();
var bufferFloat = parseFloat(0.1);
@@ -88,8 +85,33 @@
})(obj.data.features[i]));
+ $feature.bind('mouseover',(function(jsonFeature){return function(){
+ var me = $feedTree.mapbender();
+ var g = new GeometryArray();
+ g.importGeoJSON(jsonFeature,false);
+ console.log(feature);
+ if(feature.geomType != "point"){
+ feature = feature.getBBox4();
+ me.resultHighlight = new Highlight(
+ [o.target],
+ "FeedTreeHighlight",
+ {"position":"absolute", "top":"0px", "left":"0px", "z-index":100},
+ 2);
+ me.resultHighlight.add(feature, "#ff0000");
+ me.resultHighlight.paint();
+ else if(feature.geomType == "point"){
+ })(obj.data.features[i]));
$("*:checkbox",$rssEntry).bind('click', function(){
Modified: trunk/mapbender/lib/class_Filter.php
--- trunk/mapbender/lib/class_Filter.php 2010-09-30 12:43:13 UTC (rev 6985)
+++ trunk/mapbender/lib/class_Filter.php 2010-09-30 13:31:20 UTC (rev 6986)
@@ -138,4 +138,4 @@
Modified: trunk/mapbender/lib/mb.ui.wfsGazetteer.js
--- trunk/mapbender/lib/mb.ui.wfsGazetteer.js 2010-09-30 12:43:13 UTC (rev 6985)
+++ trunk/mapbender/lib/mb.ui.wfsGazetteer.js 2010-09-30 13:31:20 UTC (rev 6986)
@@ -2,7 +2,8 @@
$.widget("mb.wfsGazetteer", {
options: {
- geometry : null
+ geometry : null,
+ wfsConf: null
_create: function () {
@@ -78,7 +79,6 @@
search : function(filter) {
- $('.error',this.element).css('border','');
$('.error',this.element).removeClass('error');
this._status('Searching');
@@ -107,7 +107,6 @@
// check if field is mandatory
if(el.f_min_input > value.length){
$('#'+id).addClass('error');
- $(".error",this.element).css('border','2px inset red');
this._status('Errors in search');
return;
Modified: trunk/mapbender/lib/wizard.js
--- trunk/mapbender/lib/wizard.js 2010-09-30 12:43:13 UTC (rev 6985)
+++ trunk/mapbender/lib/wizard.js 2010-09-30 13:31:20 UTC (rev 6986)
@@ -20,7 +20,6 @@
that._trigger("to" + $t.attr("id").toLowerCase(), null, {});
that._trigger("to", null, {});
that.options.onClickLink(path);
More information about the Mapbender_commits
