[Mapbender-commits] r7757 -
branches/metador/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Fri Apr 8 07:36:02 EDT 2011
Author: apour
Date: 2011-04-08 04:36:02 -0700 (Fri, 08 Apr 2011)
New Revision: 7757
branches/metador/resources/db/pgsql/UTF-8/update/update_2.7_metador_pgsql_UTF-8.sql
bugfix - metador sql
Modified: branches/metador/resources/db/pgsql/UTF-8/update/update_2.7_metador_pgsql_UTF-8.sql
--- branches/metador/resources/db/pgsql/UTF-8/update/update_2.7_metador_pgsql_UTF-8.sql 2011-04-07 07:35:35 UTC (rev 7756)
+++ branches/metador/resources/db/pgsql/UTF-8/update/update_2.7_metador_pgsql_UTF-8.sql 2011-04-08 11:36:02 UTC (rev 7757)
@@ -390,7 +390,6 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('MeTaDor','editFilteredUser',5,1,'save, edit, delete user where this admin is owner','Bearbeitung von Kontaktdatensätzen meiner Benutzer','div','','data="{path:''#mb_md_selectAction/#editFilteredUser''}"',NULL ,NULL,NULL ,NULL,NULL ,'display:none;height:100%','','div','../plugins/bw_editUserGroupSelf.js','','','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('MeTaDor','editFilteredUser','src','../php/mod_editFilteredUser.php?sessionID','','var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('MeTaDor','editFilteredUser','withPasswordInsertion','true','define if admin can set the new user','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('MeTaDor','opencms',5,0,'includes opencms elemets','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../x_geoportal/opencms.php','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('MeTaDor','metadata_create_data',5,1,'Metadatenerfassung für Geodaten','','div','','class="metadata-editor"',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../MeTaDor/mb_metadata_create_data.js','../extensions/ajaxChange-0.1/ajaxChange-0.2.js,../MeTaDor/jquery.bw.datepicker.js','','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('MeTaDor','metadata_create_data','inputs','[
More information about the Mapbender_commits
