[Mapbender-commits] r7780 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Apr 19 01:48:35 EDT 2011
Author: armin11
Date: 2011-04-18 22:48:35 -0700 (Mon, 18 Apr 2011)
New Revision: 7780
   trunk/mapbender/http/classes/class_SaveLegend.php
Bugfix for saving legends for the print module. Sometimes it is not possible to get the size of the image by url - therefor the image must be stored as a file before extracting the size!
Modified: trunk/mapbender/http/classes/class_SaveLegend.php
--- trunk/mapbender/http/classes/class_SaveLegend.php	2011-04-18 16:00:33 UTC (rev 7779)
+++ trunk/mapbender/http/classes/class_SaveLegend.php	2011-04-19 05:48:35 UTC (rev 7780)
@@ -33,27 +33,40 @@
 		if(!$url || $url == ""){
 			$e = new mb_exception("SaveLegend: no legendurl delivered");
-		#$obj1 = new stripRequest($url);
-		$size = getimagesize($url);
+		$x = new connector($url);
+		//save file in tmp folder to extract right size - sometimes the size could not be detected by url!
+		if($legendFileHandle = fopen($legend_filename, "w")){
+			fwrite($legendFileHandle,$x->file);
+			fclose($legendFileHandle);
+			$e = new mb_notice("SaveLegend: new legend file created: ".$legend_filename);
+		} else {
+			$e = new mb_exception("SaveLegend: legend file ".$legend_filename." could not be created!");
+		//get size of image
+		$size = getimagesize($legend_filename);
 		$width = $size[0];
 		$height = $size[1];
 		$image = imagecreatetruecolor($width, $height);
 		$white = ImageColorAllocate($image,255,255,255);
-		ImageFilledRectangle($image,0,0,$width,$height,$white);
-			$img = $this->loadpng($url);
-			if($img != false){
-				imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
-			}else{
-				$e = new mb_exception("SaveLegend: unable to load image: " . $url);
+		ImageFilledRectangle($image,0,0,$width,$height,$white);
+		//load image from url to create new image
+		$img = $this->loadpng($url);
+		if($img != false){
+			imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
+		}else{
+			$e = new mb_exception("SaveLegend: unable to load image: " . $url);
+		//save image to same filename as before
 		imagepng($image,$legend_filename);
 		imagedestroy($img);
 	function loadpng ($imgurl) {
 		$x = new connector($imgurl);
-		$im = @imagecreatefromstring($x->file);
+		try {
+			$im = imagecreatefromstring($x->file);
+		}catch(Exception $E){
+			$e = new mb_exception("Can't read image from string: ".$E->getmessage);
 		if(!$im){
 			$im = false;
 			$e = new mb_exception("SaveLegend: unable to load image: ".$imgurl);
More information about the Mapbender_commits mailing list
