[Mapbender-commits] r7789 - branches/metador/http/MeTaDor/json
svn_mapbender at osgeo.org
Fri Apr 29 04:20:32 EDT 2011
Author: apour
Date: 2011-04-29 01:20:32 -0700 (Fri, 29 Apr 2011)
New Revision: 7789
branches/metador/http/MeTaDor/json/metadata_service.json
bugfix in service json
Modified: branches/metador/http/MeTaDor/json/metadata_service.json
--- branches/metador/http/MeTaDor/json/metadata_service.json 2011-04-29 06:30:48 UTC (rev 7788)
+++ branches/metador/http/MeTaDor/json/metadata_service.json 2011-04-29 08:20:32 UTC (rev 7789)
@@ -209,79 +209,40 @@
"Räumliche Angaben": {
- "Horizontales Referenzsystem": {
+ "Geografische Ausdehnung über Begrenzungsrechteck": {
"multi": "{NUM}",
- "Identifikator des horizontalen Referenzsystems": {
- "xpath_w": "/gmd:MD_Metadata/gmd:referenceSystemInfo[1]/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier/gmd:code/gco:CharacterString",
- "xpath": "gmd:referenceSystemInfo{NUM}/*/gmd:referenceSystemIdentifier/gmd:RS_Identifier/gmd:code",
- "dataType": "CharacterString"
+ "Westliche Begrenzung (geographische Länge)": {
+ "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent[1]/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:westBoundLongitude/gco:Decimal",
+ "xpath": "gmd:identificationInfo/*/srv:extent{NUM}/*/gmd:geographicElement/*/gmd:westBoundLongitude",
+ "dataType": "Decimal"
- "Bezeichnung der für den Identifikator zuständigen Organisation": {
- "xpath_w": "/gmd:MD_Metadata/gmd:referenceSystemInfo[1]/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString",
- "xpath": "gmd:referenceSystemInfo{NUM}/*/gmd:referenceSystemIdentifier/gmd:RS_Identifier/gmd:codeSpace",
- "Vertikales Referenzsystem": {
- "multi": "{NUM}",
- "Identifikator des vertikalen Referenzsystems": {
- "xpath_w": "/gmd:MD_Metadata/gmd:referenceSystemInfo[2]/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier/gmd:code/gco:CharacterString",
+ "Östliche Begrenzung (geographische Länge)": {
+ "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent[1]/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:eastBoundLongitude/gco:Decimal",
+ "xpath": "gmd:identificationInfo/*/srv:extent{NUM}/*/gmd:geographicElement/*/gmd:eastBoundLongitude",
- "xpath_w": "/gmd:MD_Metadata/gmd:referenceSystemInfo[2]/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString",
+ "Südliche Begrenzung (geographische Breite)": {
+ "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent[1]/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:southBoundLatitude/gco:Decimal",
+ "xpath": "gmd:identificationInfo/*/srv:extent{NUM}/*/gmd:geographicElement/*/gmd:southBoundLatitude",
+ "Nördliche Begrenzung (geographische Breite)": {
+ "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent[1]/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:northBoundLatitude/gco:Decimal",
+ "xpath": "gmd:identificationInfo/*/srv:extent{NUM}/*/gmd:geographicElement/*/gmd:northBoundLatitude",
- "Geographische Ausdehnung": {
- "Geografische Ausdehnung über Angabe einer Gebietseinheit": {
- "multi": "{NUM}",
- "Bezeichnung der Gebietseinheit": {
- "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent/gmd:EX_Extent[1]/gmd:geographicElement/gmd:EX_GeographicDescription/gmd:geographicIdentifier/gmd:MD_Identifier/gmd:code/gco:CharacterString",
- "xpath": "gmd:identificationInfo/*/gmd:extent/gmd:EX_Extent{NUM}/gmd:geographicElement/gmd:EX_GeographicDescription/gmd:geographicIdentifier/gmd:MD_Identifier/gmd:code",
- "Geodaten innerhalb der Gebietseinheit": {
- "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent/gmd:EX_Extent[1]/gmd:geographicElement/gmd:EX_GeographicDescription/srv:extentTypeCode/gco:Boolean",
- "xpath": "gmd:identificationInfo/*/gmd:extent/gmd:EX_Extent{NUM}/gmd:geographicElement/gmd:EX_GeographicDescription/gmd:extentTypeCode",
- "dataType": "Boolean"
+ "Räumliche Auflösung" : {
+ "Vergleichsmaßstab": {
+ "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/gmd:spatialResolution/gmd:MD_Resolution[1]/gmd:equivalentScale/gmd:MD_RepresentativeFraction/gmd:denominator/gco:Integer",
+ "xpath": "gmd:identificationInfo/*/gmd:spatialResolution/*/gmd:equivalentScale/*/gmd:denominator",
+ "dataType": "Integer"
- "Geografische Ausdehnung über Begrenzungsrechteck": {
- "multi": "{NUM}",
- "Westliche Begrenzung (geographische Länge)": {
- "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent[1]/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:westBoundLongitude/gco:Decimal",
- "xpath": "gmd:identificationInfo/*/gmd:extent{NUM}/*/gmd:geographicElement/*/gmd:westBoundLongitude",
- "dataType": "Decimal"
- "Östliche Begrenzung (geographische Länge)": {
- "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent[1]/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:eastBoundLongitude/gco:Decimal",
- "xpath": "gmd:identificationInfo/*/gmd:extent{NUM}/*/gmd:geographicElement/*/gmd:eastBoundLongitude",
- "Südliche Begrenzung (geographische Breite)": {
- "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent[1]/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:southBoundLatitude/gco:Decimal",
- "xpath": "gmd:identificationInfo/*/gmd:extent{NUM}/*/gmd:geographicElement/*/gmd:southBoundLatitude",
- "Nördliche Begrenzung (geographische Breite)": {
- "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent[1]/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:northBoundLatitude/gco:Decimal",
- "xpath": "gmd:identificationInfo/*/gmd:extent{NUM}/*/gmd:geographicElement/*/gmd:northBoundLatitude",
- "Geodaten innerhalb des Begrenzungsrechtecks": {
- "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent[1]/gmd:EX_Extent/gmd:geographicElement/gmd:EX_BoundingPolygon/srv:extentTypeCode/gco:Boolean",
- "xpath": "gmd:identificationInfo/*/gmd:extent{NUM}/*/gmd:geographicElement/gmd:EX_BoundingPolygon/gmd:extentTypeCode",
- "Beschreibung der Geographischen Ausdehnung": {
- "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:extent/gmd:EX_Extent/gmd:description/gco:CharacterString",
- "xpath": "gmd:identificationInfo/*/gmd:extent/*/gmd:description",
+ "Gitterweite": {
+ "xpath_w": "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/gmd:spatialResolution/gmd:MD_Resolution[2]/gmd:distance/gco:Distance",
+ "xpath": "gmd:identificationInfo/srv:SV_ServiceIdentification/gmd:spatialResolution/gmd:MD_Resolution[2]/gmd:distance/gco:Distance",
+ "dataType": "Value"
"Zeitliche Angaben": {
More information about the Mapbender_commits
