[Mapbender-commits] r8041 - branches/mobile/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Aug 2 05:04:18 EDT 2011
Author: pschmidt
Date: 2011-08-02 02:04:17 -0700 (Tue, 02 Aug 2011)
New Revision: 8041
Added:
   branches/mobile/http/javascripts/mod_box1_mobile.js
Module f?\195?\188r iPad
Added: branches/mobile/http/javascripts/mod_box1_mobile.js
--- branches/mobile/http/javascripts/mod_box1_mobile.js	                        (rev 0)
+++ branches/mobile/http/javascripts/mod_box1_mobile.js	2011-08-02 09:04:17 UTC (rev 8041)
@@ -0,0 +1,220 @@
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+Mapbender.BoxMobile = function (options) {
+    var map = (typeof options.target !== "undefined") ?
+    getMapObjByName(options.target) : null;
+    var color = (typeof options.color !== "undefined") ?
+    options.color : "#ff0000";
+    var isActive = false;
+    var top = 0;
+    var topSuffix = "_l_top";
+    var topNode;
+    var left = 0;
+    var leftSuffix = "_l_left";
+    var leftNode;
+    var bottom = 0;
+    var bottomSuffix = "_l_bottom";
+    var bottomNode;
+    var right = 0;
+    var rightSuffix = "_l_right";
+    var rightNode;
+    var startPos = null;
+    var stopPos = null;
+    var exists = false;
+    var that = this;
+    this.start = function (startPosition, stopPosition) {
+        startPos = startPosition;
+        stopPos = stopPosition;
+        isActive = true;
+        top = startPos.y;
+        left = startPos.y;
+        bottom = startPos.y;
+        right = startPos.x;
+        return true;
+    this.run = function (startPosition, stopPosition) {
+        if (startPosition !== null && stopPosition != null) {
+            var width = map.width;
+            var height = map.height;
+            if (startPos.x > stopPos.x) {
+                left = stopPos.x;
+            else {
+                left = startPos.x;
+                right = stopPos.x;
+            if (startPos.y > stopPos.y) {
+                top = stopPos.y;
+            else {
+                top = startPos.y;
+                bottom = stopPos.y;
+            if (!startPos.equals(stopPos)) {
+                this.draw();
+        return true;
+    this.stop = function (callback) {
+        hideElement(topNode);
+        hideElement(leftNode);
+        hideElement(rightNode);
+        hideElement(bottomNode);
+        if (isActive) {
+            isActive = false;
+            if (typeof callback === "function") {
+                return callback(getExtent());
+            return getExtent();
+        isActive = false;
+    var arrangeBox = function (node, left, top, right, bottom) {
+        var el = node.style;
+        el.height = Math.abs(bottom - top) + "px";
+        el.width = Math.abs(right - left) + "px";
+        el.top = top + "px";
+        el.left = left + "px";
+    var displayElement = function (node) {
+        node.style.visibility = "visible";
+    var hideElement = function (node) {
+        node.style.visibility = "hidden";
+    var domElementsExist = function () {
+        if (!map) {
+            return;
+        return map.getDomElement(
+            ).ownerDocument.getElementById(
+            map.elementName + topSuffix
+            ) !== null;
+    var createDomElements = function () {
+        if (!map) {
+            return;
+        var map_el = map.getDomElement();
+        topNode = map_el.ownerDocument.createElement("div");
+        topNode.style.position = "absolute";
+        topNode.style.top = "0px";
+        topNode.style.left = "0px";
+        topNode.style.width = "0px";
+        topNode.style.height = "0px";
+        topNode.style.overflow = "hidden";
+        //		topNode.style.zIndex = parseInt(map_el.style.zIndex, 10) + 1;
+        topNode.style.zIndex = 100;
+        topNode.style.visibility = "visible";
+        topNode.style.cursor = "crosshair";
+        topNode.style.backgroundColor = color;
+        leftNode = topNode.cloneNode(false);
+        rightNode = topNode.cloneNode(false);
+        bottomNode = topNode.cloneNode(false);
+        topNode.id = map.elementName + topSuffix;
+        leftNode.id = map.elementName + leftSuffix;
+        rightNode.id = map.elementName + rightSuffix;
+        bottomNode.id = map.elementName + bottomSuffix;
+        map_el.appendChild(topNode);
+        map_el.appendChild(leftNode);
+        map_el.appendChild(rightNode);
+        map_el.appendChild(bottomNode);
+        exists = true;
+    this.draw = function (extent) {
+        if (!map) {
+            return;
+        if (typeof extent === "object"
+            && extent.constructor === Mapbender.Extent) {
+            left = extent.min.x;
+            right = extent.max.x;
+            bottom = extent.min.y;
+            top = extent.max.y;
+        arrangeBox(topNode, left, top, right, top + 2);
+        arrangeBox(leftNode, left, top, left + 2, bottom);
+        arrangeBox(rightNode, right - 2, top, right, bottom);
+        arrangeBox(bottomNode, left, bottom - 2, right, bottom);
+        displayElement(topNode);
+        displayElement(leftNode);
+        displayElement(rightNode);
+        displayElement(bottomNode);
+    var getExtent = function () {
+        if (!map) {
+            return null;
+        var x1 = startPos.x;
+        var x2 = stopPos.x;
+        var y1 = startPos.y;
+        var y2 = stopPos.y;
+        var minx = x2;
+        var maxx = x1;
+        if(x1 < x2){
+            minx = x1;
+            maxx = x2;
+        var miny = y1;
+        var maxy = y2;
+        if(y1 < y2){
+            miny = y2;
+            maxy = y1;
+        // area or clickpoint ?
+        var posMin = map.convertPixelToReal(new Point(minx,miny));
+        if((maxx - minx) > 3 && (miny - maxy) > 3){
+            var posMax = map.convertPixelToReal(new Point(maxx,maxy));
+            return new Mapbender.Extent(posMin, posMax);
+        return posMin;
+    if (!domElementsExist()) {
+        createDomElements();
+    else {
+        topNode = document.getElementById(map.elementName + topSuffix);
+        leftNode = document.getElementById(map.elementName + leftSuffix);
+        rightNode = document.getElementById(map.elementName + rightSuffix);
+        bottomNode = document.getElementById(map.elementName + bottomSuffix);
More information about the Mapbender_commits mailing list
