[Mapbender-commits] r8045 - in branches/mobile: http/javascripts http/plugins log
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Aug 2 08:15:18 EDT 2011
Author: pschmidt
Date: 2011-08-02 05:15:18 -0700 (Tue, 02 Aug 2011)
New Revision: 8045
Removed:
   branches/mobile/http/javascripts/mod_box1_mobile.js
   branches/mobile/http/javascripts/mod_coords_div_mobile.php
   branches/mobile/http/javascripts/mod_dragMapSize_mobile.php
   branches/mobile/http/javascripts/mod_featureInfoTunnel_mobile.php
   branches/mobile/http/javascripts/mod_pan_mobile.js
   branches/mobile/http/javascripts/mod_selArea_mobile.js
   branches/mobile/http/javascripts/requestGeometryConstructor_mobile.js
   branches/mobile/http/plugins/mb_overview_mobile.js
   branches/mobile/log/mb_error_2011_08_02.log
Module f?\195?\188r iPad
Deleted: branches/mobile/http/javascripts/mod_box1_mobile.js
--- branches/mobile/http/javascripts/mod_box1_mobile.js	2011-08-02 12:12:12 UTC (rev 8044)
+++ branches/mobile/http/javascripts/mod_box1_mobile.js	2011-08-02 12:15:18 UTC (rev 8045)
@@ -1,220 +0,0 @@
- * License:
- * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
- * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-Mapbender.BoxMobile = function (options) {
-    var map = (typeof options.target !== "undefined") ?
-    getMapObjByName(options.target) : null;
-    var color = (typeof options.color !== "undefined") ?
-    options.color : "#ff0000";
-    var isActive = false;
-    var top = 0;
-    var topSuffix = "_l_top";
-    var topNode;
-    var left = 0;
-    var leftSuffix = "_l_left";
-    var leftNode;
-    var bottom = 0;
-    var bottomSuffix = "_l_bottom";
-    var bottomNode;
-    var right = 0;
-    var rightSuffix = "_l_right";
-    var rightNode;
-    var startPos = null;
-    var stopPos = null;
-    var exists = false;
-    var that = this;
-    this.start = function (startPosition, stopPosition) {
-        startPos = startPosition;
-        stopPos = stopPosition;
-        isActive = true;
-        top = startPos.y;
-        left = startPos.y;
-        bottom = startPos.y;
-        right = startPos.x;
-        return true;
-    this.run = function (startPosition, stopPosition) {
-        if (startPosition !== null && stopPosition != null) {
-            var width = map.width;
-            var height = map.height;
-            if (startPos.x > stopPos.x) {
-                left = stopPos.x;
-            else {
-                left = startPos.x;
-                right = stopPos.x;
-            if (startPos.y > stopPos.y) {
-                top = stopPos.y;
-            else {
-                top = startPos.y;
-                bottom = stopPos.y;
-            if (!startPos.equals(stopPos)) {
-                this.draw();
-        return true;
-    this.stop = function (callback) {
-        hideElement(topNode);
-        hideElement(leftNode);
-        hideElement(rightNode);
-        hideElement(bottomNode);
-        if (isActive) {
-            isActive = false;
-            if (typeof callback === "function") {
-                return callback(getExtent());
-            return getExtent();
-        isActive = false;
-    var arrangeBox = function (node, left, top, right, bottom) {
-        var el = node.style;
-        el.height = Math.abs(bottom - top) + "px";
-        el.width = Math.abs(right - left) + "px";
-        el.top = top + "px";
-        el.left = left + "px";
-    var displayElement = function (node) {
-        node.style.visibility = "visible";
-    var hideElement = function (node) {
-        node.style.visibility = "hidden";
-    var domElementsExist = function () {
-        if (!map) {
-            return;
-        return map.getDomElement(
-            ).ownerDocument.getElementById(
-            map.elementName + topSuffix
-            ) !== null;
-    var createDomElements = function () {
-        if (!map) {
-            return;
-        var map_el = map.getDomElement();
-        topNode = map_el.ownerDocument.createElement("div");
-        topNode.style.position = "absolute";
-        topNode.style.top = "0px";
-        topNode.style.left = "0px";
-        topNode.style.width = "0px";
-        topNode.style.height = "0px";
-        topNode.style.overflow = "hidden";
-        //		topNode.style.zIndex = parseInt(map_el.style.zIndex, 10) + 1;
-        topNode.style.zIndex = 100;
-        topNode.style.visibility = "visible";
-        topNode.style.cursor = "crosshair";
-        topNode.style.backgroundColor = color;
-        leftNode = topNode.cloneNode(false);
-        rightNode = topNode.cloneNode(false);
-        bottomNode = topNode.cloneNode(false);
-        topNode.id = map.elementName + topSuffix;
-        leftNode.id = map.elementName + leftSuffix;
-        rightNode.id = map.elementName + rightSuffix;
-        bottomNode.id = map.elementName + bottomSuffix;
-        map_el.appendChild(topNode);
-        map_el.appendChild(leftNode);
-        map_el.appendChild(rightNode);
-        map_el.appendChild(bottomNode);
-        exists = true;
-    this.draw = function (extent) {
-        if (!map) {
-            return;
-        if (typeof extent === "object"
-            && extent.constructor === Mapbender.Extent) {
-            left = extent.min.x;
-            right = extent.max.x;
-            bottom = extent.min.y;
-            top = extent.max.y;
-        arrangeBox(topNode, left, top, right, top + 2);
-        arrangeBox(leftNode, left, top, left + 2, bottom);
-        arrangeBox(rightNode, right - 2, top, right, bottom);
-        arrangeBox(bottomNode, left, bottom - 2, right, bottom);
-        displayElement(topNode);
-        displayElement(leftNode);
-        displayElement(rightNode);
-        displayElement(bottomNode);
-    var getExtent = function () {
-        if (!map) {
-            return null;
-        var x1 = startPos.x;
-        var x2 = stopPos.x;
-        var y1 = startPos.y;
-        var y2 = stopPos.y;
-        var minx = x2;
-        var maxx = x1;
-        if(x1 < x2){
-            minx = x1;
-            maxx = x2;
-        var miny = y1;
-        var maxy = y2;
-        if(y1 < y2){
-            miny = y2;
-            maxy = y1;
-        // area or clickpoint ?
-        var posMin = map.convertPixelToReal(new Point(minx,miny));
-        if((maxx - minx) > 3 && (miny - maxy) > 3){
-            var posMax = map.convertPixelToReal(new Point(maxx,maxy));
-            return new Mapbender.Extent(posMin, posMax);
-        return posMin;
-    if (!domElementsExist()) {
-        createDomElements();
-    else {
-        topNode = document.getElementById(map.elementName + topSuffix);
-        leftNode = document.getElementById(map.elementName + leftSuffix);
-        rightNode = document.getElementById(map.elementName + rightSuffix);
-        bottomNode = document.getElementById(map.elementName + bottomSuffix);
Deleted: branches/mobile/http/javascripts/mod_coords_div_mobile.php
--- branches/mobile/http/javascripts/mod_coords_div_mobile.php	2011-08-02 12:12:12 UTC (rev 8044)
+++ branches/mobile/http/javascripts/mod_coords_div_mobile.php	2011-08-02 12:15:18 UTC (rev 8045)
@@ -1,93 +0,0 @@
-<?php
-# $Id: mod_coords_div.php 6888 2010-09-03 14:52:08Z christoph $
-# http://www.mapbender.org/index.php/mod_coords_div.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-echo "var mod_showCoords_div_target = '".$e_target[0]."';";
-include '../include/dyn_js.php';
-var displayTarget = displayTarget ? displayTarget : "dependentDiv";
-var mod_showCoords_div_win = null;
-var mod_showCoords_div_elName = "showCoords_div";
-var mod_showCoords_div_frameName = "";
-var mod_showCoords_div_img_on = new Image(); mod_showCoords_div_img_on.src = "<?php  echo preg_replace("/_off/","_on",$e_src);  ?>";
-var mod_showCoords_div_img_off = new Image(); mod_showCoords_div_img_off.src = "<?php  echo $e_src;  ?>";
-var mod_showCoords_div_img_over = new Image(); mod_showCoords_div_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-var mod_showCoords_div_fix = "";
-var mod_showCoords_div_mapObj = null;
-function init_mod_showCoords_div(ind){
-	mod_showCoords_div_mapObj = getMapObjByName(mod_showCoords_div_target );
-	mb_button[ind] = document.getElementById(mod_showCoords_div_elName);
-	mb_button[ind].img_over = mod_showCoords_div_img_over.src;
-	mb_button[ind].img_on = mod_showCoords_div_img_on.src;
-	mb_button[ind].img_off = mod_showCoords_div_img_off.src;
-	mb_button[ind].status = 0;
-	mb_button[ind].elName = mod_showCoords_div_elName;
-	mb_button[ind].fName = mod_showCoords_div_frameName;
-	mb_button[ind].go = mod_showCoords_div_run;
-	mb_button[ind].stop = mod_showCoords_div_disable;
-function mod_showCoords_div_run(){
-        if ($.extend(mod_showCoords_div_mapObj).defaultTouch) {
-            $.extend(mod_showCoords_div_mapObj).defaultTouch.deactivate();
-	var $map = $(mod_showCoords_div_mapObj.getDomElement());
-	$map.bind("mousemove", mod_showCoords_div_display);
-	$map.bind("click", mod_showCoords_div_click);
-function mod_showCoords_div_disable(){
-	$map.unbind("mousemove", mod_showCoords_div_display);
-	$map.unbind("click", mod_showCoords_div_click);
-	if(document.getElementById(displayTarget)){
-		writeTag("",displayTarget,"");
-            $.extend(mod_showCoords_div_mapObj).defaultTouch.activate();
-function mod_showCoords_div_click(e){
-	var click = mod_showCoords_div_mapObj.getMousePosition(e);
-	if (click === null) {
-		return;
-	var pos = mod_showCoords_div_mapObj.convertPixelToReal(click);
-	mod_showCoords_div_fix = "Selection: " + pos.x + " / " +  pos.y;
-	mod_showCoord_write(pos.x,pos.y);
-function mod_showCoords_div_display(e){
-		return;
-	var pos = makeClickPos2RealWorldPos(mod_showCoords_div_target, click.x, click.y);
-	mod_showCoord_write(pos[0],pos[1]);
-function mod_showCoord_write(x,y){
-		var str = x + " / " +  y;
-		if(mod_showCoords_div_fix != ""){
-			str += "<div>" + mod_showCoords_div_fix + "</div>";
-		writeTag("",displayTarget, str);
Deleted: branches/mobile/http/javascripts/mod_dragMapSize_mobile.php
--- branches/mobile/http/javascripts/mod_dragMapSize_mobile.php	2011-08-02 12:12:12 UTC (rev 8044)
+++ branches/mobile/http/javascripts/mod_dragMapSize_mobile.php	2011-08-02 12:15:18 UTC (rev 8045)
@@ -1,287 +0,0 @@
-<?php
-# $Id: mod_dragMapSize.php 6673 2010-08-02 13:52:19Z christoph $
-# http://www.mapbender.org/index.php/mod_dragMapSize.php
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-echo "var mod_dragMapSize_target = '".$e_target[0]."';";
-var mod_dragMapSize_offset  = 15;
-var mod_dragMapSize_active  = false;
-var isTouchable = false;
-var isMainTouchActiv = false;
-try {document.createEvent("TouchEvent"); isTouchable = true; } catch(e){}
-eventInit.register(function () {
-	mod_dragMapSize_init();
-eventAfterMapRequest.register(function () {
-	mod_dragMapSize_arrange()
-function mod_dragMapSize_init(){
-    var el = document.getElementById("dragMapSize_Mobile");
-    if (isTouchable) {
-        $('.ui-icon').css({width:'30px',height:'30px'});
-        el.addEventListener("mousedown", mod_dragMapSize_touchOn, true);
-        el.addEventListener("mouseup", mod_dragMpaSize_touchOff, true);
-        el.addEventListener("touchstart", mod_dragMapSize_touchOn, true);
-    } else {
-//        $('.ui-icon').css({width:'30px',height:'30px'});
-        el.onmousedown = mod_dragMapSize_down;
-    $(el).hover(function () {
-                    $(this).addClass("ui-state-hover");
-            function () {
-                    $(this).removeClass("ui-state-hover");
-    mod_dragMapSize_arrange();
-function mod_dragMapSize_arrange(){
-	var left = parseInt(document.getElementById(mod_dragMapSize_target).style.left, 10) +
-                        parseInt(document.getElementById(mod_dragMapSize_target).style.width, 10) +
-                        mod_dragMapSize_offset -
-                        (parseInt(document.getElementById('dragMapSize_Mobile').style.width, 10)/2);
-	var top = parseInt(document.getElementById(mod_dragMapSize_target).style.top, 10) +
-                        parseInt(document.getElementById(mod_dragMapSize_target).style.height, 10) +
-                        (parseInt(document.getElementById('dragMapSize_Mobile').style.height, 10)/2);
-	mb_arrangeElement('','dragMapSize_Mobile' , left, top);
-function mod_dragMapSize_touchOn(e){
-    body.addEventListener("touchstart", mod_dragMapSize_touch_down, true);
-    body.addEventListener("touchmove", mod_dragMapSize_touch_drag, true);
-    body.addEventListener("touchend", mod_dragMapSize_touch_up, true);
-    mod_dragMapSize_touch_down(e);
-function mod_dragMpaSize_touchOff(e){
-    body.removeEventListener("touchstart", mod_dragMapSize_touch_down, true);
-    body.removeEventListener("touchmove", mod_dragMapSize_touch_drag, true);
-    body.removeEventListener("touchend", mod_dragMapSize_touch_up, true);
-function mod_dragMapSize_touch_down(e){
-    e.preventDefault();
-    var elm = findElement(e, "");
-    if(mod_dragMapSize_active == false && isSingleTouch(e)){
-        mb_start_x = e.touches[0].pageX;
-        mb_start_y = e.touches[0].pageY;
-        mb_end_x = mb_start_x;
-        mb_end_y = mb_start_y;
-        mod_dragMapSize_active = true;
-        //create a div that catches all mouse interactions
-        var dragElement = document.getElementById("dragMapSize_Mobile");
-        $('.ui-state-active').css({width:'30px',height:'30px'});
-        $(dragElement).addClass("ui-state-active");
-        var mouseCatcher = dragElement.parentNode.appendChild(document.createElement('div'));
-        mouseCatcher.setAttribute("id", "dragMapSize_helper");
-        mouseCatcher.style.position = "absolute";
-        mouseCatcher.style.cursor = "move";
-        mouseCatcher.style.width = "200px";
-        mouseCatcher.style.height = "200px";
-        mouseCatcher.style.zIndex = 160;
-        if($.browser.msie)
-                mouseCatcher.style.background = "url(../img/transparent.gif)";
-        mouseCatcher.style.left=(mb_start_x-parseInt(mouseCatcher.style.width)) + "px";
-        mouseCatcher.style.top=(mb_start_x-parseInt(mouseCatcher.style.height)) + "px";
-    return true;
-function mod_dragMapSize_touch_drag(e){
-    if(mod_dragMapSize_active && isSingleTouch(e)){
-//        var x, y;
-        mb_end_x = e.touches[0].pageX;
-        mb_end_y = e.touches[0].pageY;
-        var dif_x = mb_end_x - (parseInt(document.getElementById('dragMapSize_Mobile').style.width)/2);
-        var dif_y = mb_end_y - (parseInt(document.getElementById('dragMapSize_Mobile').style.height)/2);
-        mb_arrangeElement('', "dragMapSize_Mobile", dif_x, dif_y);
-        var mouseCatcher = document.getElementById("dragMapSize_helper");
-        mb_arrangeElement('', "dragMapSize_helper", mb_end_x-parseInt(mouseCatcher.style.width), mb_end_y-parseInt(mouseCatcher.style.height));
-function mod_dragMapSize_touch_up(e){
-//    if (isMainTouchActiv) {
-//            $.extend(Mapbender.modules.mobile_Map).defaultTouch.activate();
-//    if (isSingleTouch(e)) {
-//        mb_end_x = e.touches[0].pageX;
-//        mb_end_y = e.touches[0].pageY;
-        $(dragElement).removeClass("ui-state-active");
-        mouseCatcher.parentNode.removeChild(mouseCatcher);
-        mod_dragMapSize_active = false;
-        targetObject = getMapObjByName(mod_dragMapSize_target);
-        var dif_x = (parseFloat(mb_end_x) - parseFloat(mb_start_x));
-        var dif_y = (parseFloat(mb_end_y) - parseFloat(mb_start_y));
-        if(parseFloat(targetObject.width) + parseFloat(dif_x)<0 ||
-            parseFloat(targetObject.height) + parseFloat(dif_y)<0){
-            var dif_x = mb_start_x - (parseInt(document.getElementById('dragMapSize_Mobile').style.width) / 2);
-            var dif_y = mb_start_y - (parseInt(document.getElementById('dragMapSize_Mobile').style.height) / 2);
-            return true;
-        var newX = (parseFloat(targetObject.width) + parseFloat(dif_x));
-        var newY = (parseFloat(targetObject.height) + parseFloat(dif_y));
-        var pos =  makeClickPos2RealWorldPos(mod_dragMapSize_target, newX, newY);
-        targetObject.setWidth(targetObject.getWidth() + parseFloat(dif_x));
-        targetObject.setHeight(targetObject.getHeight() + parseFloat(dif_y));
-        var mybbox = targetObject.getExtent().split(",");
-        if (typeof mybbox !== "object" || mybbox.length !== 4) {
-                return;
-        targetObject.setExtent(mybbox[0], pos[1], pos[0], mybbox[3]);
-        targetObject.setMapRequest();
-        eventResizeMap.trigger();
-    return true;
-function findElement(event, tagName) {
-    var element = getElement(event);
-    while (element.parentNode && (!element.tagName ||
-          (element.tagName.toUpperCase() != tagName.toUpperCase()))){
-        element = element.parentNode;
-        return element;
-function getElement(event) {
-    return event.target || event.srcElement;
-function isSingleTouch(event) {
-    return event.touches && event.touches.length == 1;
-function isMultiTouch(event) {
-    return event.touches && event.touches.length > 1;
-function mod_dragMapSize_down(e){
-	if(mod_dragMapSize_active == false){
-                document.onmouseup = mod_dragMapSize_up;
-                document.onmousemove = mod_dragMapSize_drag;
-                mb_getMousePos(e);
-                mb_start_x = clickX;
-                mb_start_y = clickY;
-                mb_end_x = clickX;
-                mb_end_y = clickY;
-//                $('.ui-state-active').css({width:'30px',height:'30px'});
-		mouseCatcher.style.width = "500px";
-		mouseCatcher.style.height = "500px";
-		return false;
-function mod_dragMapSize_up(e){
-        document.onmouseup = null;
-        document.onmousemove = null;
-		return;
-		return;
-function mod_dragMapSize_drag(e){
-	if(mod_dragMapSize_active){
-            var x, y;
-            if (!e)
-            e = window.event;
-            x = clickX;
-            y = clickY;
-            var dif_x = x - (parseInt(document.getElementById('dragMapSize_Mobile').style.width)/2);
-            var dif_y = y - (parseInt(document.getElementById('dragMapSize_Mobile').style.height)/2);
-            mb_arrangeElement('', "dragMapSize_helper", x-250, y-250);
Deleted: branches/mobile/http/javascripts/mod_featureInfoTunnel_mobile.php
--- branches/mobile/http/javascripts/mod_featureInfoTunnel_mobile.php	2011-08-02 12:12:12 UTC (rev 8044)
+++ branches/mobile/http/javascripts/mod_featureInfoTunnel_mobile.php	2011-08-02 12:15:18 UTC (rev 8045)
@@ -1,192 +0,0 @@
-<?php
-# $Id: mod_featureInfoTunnel.php 7663 2011-02-28 12:44:13Z verenadiewald $
-# http://www.mapbender.org/index.php/mod_featureInfoTunnel.php
-//defaults for element vars
-if(typeof(featureInfoLayerPopup)==='undefined')
-	var featureInfoLayerPopup = 'false';
-if(typeof(featureInfoPopupHeight)==='undefined')
-	var featureInfoPopupHeight = '200';
-if(typeof(featureInfoPopupWidth)==='undefined')
-	var featureInfoPopupWidth = '270';
-if(typeof(featureInfoPopupPosition)==='undefined')
-	var featureInfoPopupPosition = 'center';
-if(typeof(featureInfoNoResultPopup)==='undefined')
-	var featureInfoNoResultPopup = 'false';
-var mod_featureInfoTunnel_elName = "featureInfoTunnel";
-var mod_featureInfoTunnel_frameName = "";
-var mod_featureInfoTunnel_target = "<?php echo $e_target[0]; ?>";
-var mod_featureInfoTunnel_map = null;
-var mod_featureInfoTunnel_img_on = new Image(); mod_featureInfoTunnel_img_on.src =  "<?php  echo preg_replace("/_off/","_on",$e_src);  ?>";
-var mod_featureInfoTunnel_img_off = new Image(); mod_featureInfoTunnel_img_off.src ="<?php  echo $e_src;  ?>";
-var mod_featureInfoTunnel_img_over = new Image(); mod_featureInfoTunnel_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-function init_featureInfoTunnel(ind){
-	mod_featureInfoTunnel_map = getMapObjByName(mod_featureInfoTunnel_target);
-        if ($.extend(mod_featureInfoTunnel_map).defaultTouch) {
-            $.extend(mod_featureInfoTunnel_map).defaultTouch.deactivate();
-	mb_button[ind] = document.getElementById(mod_featureInfoTunnel_elName);
-	mb_button[ind].img_over = mod_featureInfoTunnel_img_over.src;
-	mb_button[ind].img_on = mod_featureInfoTunnel_img_on.src;
-	mb_button[ind].img_off = mod_featureInfoTunnel_img_off.src;
-	mb_button[ind].elName = mod_featureInfoTunnel_elName;
-	mb_button[ind].fName = mod_featureInfoTunnel_frameName;
-	mb_button[ind].go = new Function ("mod_featureInfoTunnel_click()");
-	mb_button[ind].stop = new Function ("mod_featureInfoTunnel_disable()");
-function mod_featureInfoTunnel_click(){
-	var domNode = mod_featureInfoTunnel_map.getDomElement();
-	if (domNode) {
-		$(domNode).bind("click", mod_featureInfoTunnel_event);
-	mod_featureInfoTunnel_map.getDomElement().style.cursor = "help";
-function mod_featureInfoTunnel_disable(){
-	if (domNode) {
-		$(domNode).unbind("click", mod_featureInfoTunnel_event);
-	mod_featureInfoTunnel_map.getDomElement().style.cursor = "default";
-            $.extend(mod_featureInfoTunnel_map).defaultTouch.activate();
-function removeProgressWheel () {
-	$("#" + mod_featureInfoTunnel_map.elementName + "_progressWheel").empty();
-	$("#" + mod_featureInfoTunnel_map.elementName + "_progressWheel").css("visibility","hidden");
-function mod_featureInfoTunnel_event(e){
-	eventBeforeFeatureInfo.trigger({"fName":mod_featureInfoTunnel_target});
-	//create progress wheel element
-	var map_el = mod_featureInfoTunnel_map.getDomElement();
-	if (!map_el.ownerDocument.getElementById(mod_featureInfoTunnel_map.elementName + "_progressWheel")) {
-		var $div = $("<div id='" + mod_featureInfoTunnel_map.elementName + "_progressWheel'></div>");
-		map_el.appendChild($div.get(0));
-	var point = mod_featureInfoTunnel_map.getMousePosition(e);
-	var path = '../extensions/ext_featureInfoTunnel.php';
-//TODO that code should go to featureInfo Redirect module
-	var ind = getMapObjIndexByName(mod_featureInfoTunnel_target);
-	if(document.getElementById("FeatureInfoRedirect")){
-		//fill the frames
-		for(var i=0; i<mod_featureInfoTunnel_map.wms.length; i++){
-			var req = mod_featureInfoTunnel_map.wms[i].getFeatureInfoRequest(mb_mapObj[ind], point);
-			if(req)
-				window.frames.FeatureInfoRedirect.document.getElementById(mod_featureInfoTunnel_map.wms[i].wms_id).src = path+"?url="+escape(req);
-	else{
-		urls = mod_featureInfoTunnel_map.getFeatureInfoRequests(point);
-		if(urls){
-			for(var i=0;i<urls.length;i++){
-				(function () {
-					var currentMapObjWidth = point.x;
-					var currentMapObjHeight = point.y;
-					$("#" + mod_featureInfoTunnel_map.elementName + "_progressWheel").html("<img src='../img/indicator_wheel.gif'/>");
-					$("#" + mod_featureInfoTunnel_map.elementName + "_progressWheel").css({
-						position: "absolute",
-						top: currentMapObjHeight,
-						left: currentMapObjWidth,
-						visibility: "visible",
-						zIndex: 100
-					window.setTimeout("removeProgressWheel()", 10000);
-					var currentRequest = urls[i];
-					var cnt = i;
-					if(featureInfoPopupPosition.length == 2 && !isNaN(featureInfoPopupPosition[0]) && !isNaN(featureInfoPopupPosition[1])) {
-						var dialogPosition = [];
-						dialogPosition[0] = featureInfoPopupPosition[0]+cnt*25;
-						dialogPosition[1] = featureInfoPopupPosition[1]+cnt*25;
-					else {
-						var dialogPosition = featureInfoPopupPosition;
-					$(".fiResultFrame").remove();
-					mb_ajax_post(path, {'url':currentRequest},function(js_code,status){
-						if(js_code){
-							if(featureInfoLayerPopup == 'true') {
-								$("<div><iframe frameborder=0 class='fiResultFrame' id='featureInfo_"+ i + "' style='width:100%;height:100%;' src='" + path + "?url=" + encodeURIComponent(currentRequest) + "'></iframe></div>").dialog({
-									bgiframe: true,
-									autoOpen: true,
-									title: '<?php echo _mb("Information");?>',
-									modal: false,
-									width:parseInt(featureInfoPopupWidth, 10),
-									height:parseInt(featureInfoPopupHeight, 10),
-									position:dialogPosition,
-// This is a workaround if dialogs don't have the appropriate height
-//									height: 450,
-//									open: function(){
-//										$(this).css({
-//											"height": parseInt(featureInfoPopupHeight, 10)+ "px"
-									close: function() {
-										$(this).remove();
-								$(".noResultFound").dialog("close");
-							else{
-								window.open(path+"?url=" + encodeURIComponent(currentRequest), "" , "width="+featureInfoPopupWidth+",height="+featureInfoPopupHeight+",scrollbars=yes,resizable=yes");
-						if(featureInfoNoResultPopup == 'true' && featureInfoLayerPopup == 'true') {
-							if($(".fiResultFrame").size() === 0) {
-								$("<div class='noResultFound'><?php echo _mb("No result");?></div>").dialog({
-									bgiframe: true,
-									title: "<?php echo _mb("Information");?>",
-									autoOpen: true,
-									modal: false,
-									width:300,
-									height:200,
-									position:[600,200]
-						removeProgressWheel();
-		else
-			alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
Deleted: branches/mobile/http/javascripts/mod_pan_mobile.js
--- branches/mobile/http/javascripts/mod_pan_mobile.js	2011-08-02 12:12:12 UTC (rev 8044)
+++ branches/mobile/http/javascripts/mod_pan_mobile.js	2011-08-02 12:15:18 UTC (rev 8045)
@@ -1,124 +0,0 @@
- * Package: selArea
- * Description:
- * Zoom by rectangle
- * Files:
- *  - http/javascripts/mod_selArea.js
- * SQL:
- * > <SQL for element>
- * > <SQL for element var>
- * Help:
- * http://www.mapbender.org/SelArea1
- * Maintainer:
- * http://www.mapbender.org/User:Christoph_Baudson
- * License:
-var that = this;
-Mapbender.events.init.register(function () {
-	var mb_panActive = false;
-	var startPos, stopPos;
-	var map = Mapbender.modules[options.target];
-        var isTouchable = false;
-        var touch;
-        try {
-            document.createEvent("TouchEvent");
-            isTouchable = true;
-        } catch(e){}
-	var button = new Mapbender.Button({
-		domElement: that,
-		over: options.src.replace(/_off/, "_over"),
-		on: options.src.replace(/_off/, "_on"),
-		off: options.src,
-		name: options.id,
-		go: function () {
-			if (!map) {
-				new Mb_exception(options.id + ": " +
-					options.target + " is not a map!");
-				return;
-                        if(isTouchable) {
-                            $(map.getDomElement()).css("cursor", "crosshair");
-                            if ($.extend(map).defaultTouch) {
-                                $.extend(map).defaultTouch.deactivate();
-                            touch = new MapTouch(map, $(map.getDomElement()), map.getDomElement());
-                            touch.activate();
-                        } else {
-                                    .css("cursor", "move")
-                                    .mousedown(function (e) {
-                                    mb_panActive = true;
-                                    startPos = map.getMousePosition(e);
-                                    stopPos = new Point(startPos);
-                                    return false;
-                            }).mousemove(function (e) {
-                                    if (!mb_panActive) {
-                                            return false;
-                                    stopPos = map.getMousePosition(e);
-                                    var dif = stopPos.minus(startPos);
-                                    map.moveMap(dif.x, dif.y);
-                                    if (!$.browser.msie){
-                                            return true;
-                                    return false;
-                            }).mouseup(function (e) {
-                                            return false;
-                                    if (!map) {
-                                            return false;
-                                    mb_panActive = false;
-                                    var widthHeight = new Mapbender.Point(
-                                            map.getWidth(),
-                                            map.getHeight()
-                                    var center = widthHeight.times(0.5).minus(dif);
-                                    var realCenter = map.convertPixelToReal(center);
-                                    map.moveMap();
-                                    map.zoom(false, 1.0, realCenter);
-                                    return false;
-		stop: function () {
-			if (!map) {
-				return false;
-                        if(isTouchable) {
-                            $(map.getDomElement()).css("cursor", "default");
-                            touch.deactivate();
-                            touch = null;
-                                $.extend(map).defaultTouch.activate();
-                        } else {
-                                            .css("cursor", "default")
-                                            .unbind("mousedown")
-                                            .unbind("mouseup")
-                                            .unbind("mousemove");
Deleted: branches/mobile/http/javascripts/mod_selArea_mobile.js
--- branches/mobile/http/javascripts/mod_selArea_mobile.js	2011-08-02 12:12:12 UTC (rev 8044)
+++ branches/mobile/http/javascripts/mod_selArea_mobile.js	2011-08-02 12:15:18 UTC (rev 8045)
@@ -1,204 +0,0 @@
- * Description:
- * Files:
- * SQL:
- * Help:
- * Maintainer:
- * License:
-var that = this;
-    var touch;
-    var box;
-    try {
-    } catch(e){}
-        domElement: that,
-        off: options.src,
-        name: options.id,
-        go: function () {
-            if (!map) {
-                return;
-            if(isTouchable) {
-                box = new Mapbender.BoxMobile({
-                    target: options.target
-                touch = new selAreaTouch(map,$(map.getDomElement()), map.getDomElement(), box);
-                touch.activate();
-            } else {
-                box = new Mapbender.Box({
-                    "cursor", "crosshair"
-                    ).mousedown(function (e) {
-                    box.start(e);
-                    return false;
-                    box.stop(e, function (extent) {
-                        if (typeof extent === "undefined") {
-                            return false;
-                        if (extent.constructor === Mapbender.Extent) {
-                            var xt = map.calculateExtent(extent);
-                            map.setMapRequest();
-                        else if (extent.constructor === Mapbender.Point) {
-                            map.setCenter(extent);
-                    return false;
-            if (!map) {
-                return;
-            if(isTouchable) {
-                touch = null;
-                box = null;
-            } else {
-                box = null;
-    function selAreaTouch(map, $map, mapDom, box){
-        this.map = map;
-        this.$elm = $map;
-        this.elm = mapDom;
-        this.box = box;
-        this.startPos = null;
-        this.activate = function() {
-            this.elm.addEventListener("touchstart", touch.startTouch, true);
-            this.elm.addEventListener("touchmove", touch.moveTouch, true);
-            this.elm.addEventListener("touchend", touch.endTouch, true);
-        this.deactivate = function() {
-            this.elm.removeEventListener("touchstart", touch.startTouch, true);
-            this.elm.removeEventListener("touchmove", touch.moveTouch, true);
-            this.elm.removeEventListener("touchend", touch.endTouch, true);
-        this.startTouch = function(event) {
-            event.preventDefault();
-            var elm = findElement(event, "");
-            if (isSingleTouch(event)) {
-                touch.startPos = new Point(
-                    event.touches[0].pageX - touch.$elm.offset().left,
-                    event.touches[0].pageY - touch.$elm.offset().top);
-                var stopPos = new Point(touch.startPos.x, touch.startPos.y);
-                touch.box.start(touch.startPos, stopPos);
-            } else if (isMultiTouch(event)) {
-                var startPos = new Point(
-                    event.touches[1].pageX - touch.$elm.offset().left,
-                    event.touches[1].pageY - touch.$elm.offset().top);
-                touch.box.start(startPos, stopPos);
-            return true;
-        this.moveTouch = function(event) {
-                touch.box.run(touch.startPos, stopPos);
-                touch.box.run(startPos, stopPos);
-            return true;
-        this.endTouch = function(event) {
-            return touch.box.stop(function (extent) {
-                    return false;
-                    var xt = touch.map.calculateExtent(extent);
-                    touch.map.setMapRequest();
-                    touch.map.setCenter(extent);
-        function findElement(event, tagName) {
-                return element;
-        function getElement(event) {
-        function isSingleTouch (event) {
-        function isMultiTouch(event) {
Deleted: branches/mobile/http/javascripts/requestGeometryConstructor_mobile.js
--- branches/mobile/http/javascripts/requestGeometryConstructor_mobile.js	2011-08-02 12:12:12 UTC (rev 8044)
+++ branches/mobile/http/javascripts/requestGeometryConstructor_mobile.js	2011-08-02 12:15:18 UTC (rev 8045)
@@ -1,435 +0,0 @@
-* $Id: requestGeometryConstructor.js 1882 2007-12-03 09:01:24Z verenadiewald $
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-//http://www.mapbender.org/index.php/requestGeometryConstructor.js
- * @class A class representing a constructor for a geometry/WFS request.
- * @constructor
- * @param {String} geomType type of the {@link RequestGeometryConstructor}
- * @param {String} geomType target of the {@link RequestGeometryConstructor}
-function RequestGeometryConstructor(geomTarget){
- 	 * geomTarget target of the {@link RequestGeometryConstructor}
-	 * @type String
-    this.geomTarget = geomTarget;
-    var that = this;
-    var ind = getMapObjIndexByName(this.geomTarget);
-    var myMapObj = mb_mapObj[ind];
-    var map_el = myMapObj.getDomElement();
-    var box;
-    var touch;
-    try {
-    } catch(e){}
-    if(!map_el.ownerDocument.getElementById(myMapObj.elementName+"_request_geometry_polygon")){
-        //create Box Elements
-        var el_top = map_el.ownerDocument.createElement("div");
-        el_top.style.position = "absolute";
-        el_top.style.top = "0px";
-        el_top.style.left = "0px";
-        el_top.style.zIndex = "500";
-        el_top.style.fontSize = "10px";
-        el_top.id = myMapObj.elementName+"_request_geometry_polygon";
-        map_el.appendChild(el_top);
-    if(!map_el.ownerDocument.getElementById(myMapObj.elementName+"_measure_display")){
-        el_top.style.zIndex = "510";
-        el_top.id = myMapObj.elementName+"_measure_display";
-    this.getGeometry = function(queryType,callbackFunction){
-        var target = this.geomTarget;
-        s = new Snapping(this.geomTarget);
-        callback = callbackFunction;
-        var ind = getMapObjIndexByName(target);
-        var el = mb_mapObj[ind].getDomElement();
-        $(el).unbind("mousedown")
-        .unbind("mouseover")
-        if (queryType == "point") {
-            if ($.extend(myMapObj).defaultTouch) {
-                $.extend(myMapObj).defaultTouch.deactivate();
-            queryGeom = new Geometry(geomType.point);
-            $(el).mousedown(function (e) {
-                realWorldPos = mapToReal(target,myMapObj.getMousePosition(e));
-                queryGeom.addPoint(realWorldPos);
-                callback(target, queryGeom);
-                queryGeom = null;
-                    $.extend(myMapObj).defaultTouch.activate();
-        else if (queryType == "polygon") {
-            queryGeom = new Geometry(geomType.polygon);
-            if(isTouchable){
-                    wfsSpatialRequestStart(e);
-            } else {
-                    wfsSpatialRequestRun(e);
-        else if (queryType == "rectangle") {
-            if(isTouchable) {
-                    target: geomTarget
-                touch = new selAreaTouch(myMapObj,$(myMapObj.getDomElement()), myMapObj.getDomElement(), box);
-                touch.activate();
-                queryGeom = new Geometry(geomType.line);
-//                $(el).mousedown(function (e) {
-//                    box.start(e);
-//                    return false;
-//                }).mouseup(function (e) {
-//                    var targetMap = Mapbender.modules[that.geomTarget];
-//                    if (!targetMap) {
-//                        return false;
-//                    box.stop(e, function (extent) {
-//                        if (typeof extent === "undefined") {
-//                            return false;
-//                        if (extent.constructor === Mapbender.Extent) {
-//                            queryGeom = new Geometry(geomType.line);
-//                            queryGeom.addPoint(extent.min);
-//                            queryGeom.addPoint(extent.max);
-//                            queryGeom.close();
-//                            callback(that.geomTarget,queryGeom);
-//                            $(el)
-//                            .css("cursor", "default")
-//                            .unbind("mousedown")
-//                            .unbind("mouseup")
-//                            .unbind("mousemove");
-//                            box = null;
-//                    return false;
-            } else {
-                    box.start(e);
-                    return false;
-                    var targetMap = Mapbender.modules[that.geomTarget];
-                    if (!targetMap) {
-                        return false;
-                            return false;
-                            queryGeom.addPoint(extent.min);
-                            queryGeom.addPoint(extent.max);
-                            queryGeom.close();
-                            callback(that.geomTarget,queryGeom);
-                            $(el)
-                            box = null;
-                    return false;
-        else if (queryType == "extent") {
-            var p0 = mapToReal(target, new Point(0,0));
-            var p1 = mapToReal(target, new Point(mb_mapObj[ind].width,mb_mapObj[ind].height));
-            queryGeom.addPoint(p0);
-            queryGeom.addPoint(p1);
-            queryGeom = null;
-    var s;
-    var callback;
-    var wfsSpatialRequestStart = function(e){
-        var that = this;
-        var realWorldPos;
-        if(isTouchable) {
-            if (queryGeom.count() >= 3) {
-            var pos = myMapObj.getMousePosition(e);
-                s.check(pos);
-        if (s.isSnapped() == true) {
-            realWorldPos = s.getSnappedPoint();
-            s.clean();
-        else {
-            realWorldPos = mapToReal(that.geomTarget,myMapObj.getMousePosition(e));
-        if (queryGeom.count() == 1) {
-            s.add(queryGeom.get(0));
-        if (s.isSnapped() && queryGeom.count() >= 3 && queryGeom.get(-1).equals(queryGeom.get(0))) {
-            writeTag(myMapObj.frameName, myMapObj.elementName+"_request_geometry_polygon", "");
-            writeTag(myMapObj.frameName, myMapObj.elementName+"_measure_display", "");
-            var ind = getMapObjIndexByName("mapframe1");
-            queryGeom = null;
-            return;
-        drawDashedLineExt();
-    var wfsSpatialRequestRun = function(e){
-        var that = this;
-            s.check(pos);
-    var drawDashedLineExt = function(e){
-        var that = this;
-        var ind = getMapObjIndexByName(that.geomTarget);
-        var str_mPoints = "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='"+mb_mapObj[ind].width+"' height='0'></div>";
-        str_mPoints += "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='0' height='"+mb_mapObj[ind].height+"'></div>";
-        if (queryGeom != null) {
-            for(var i=0; i<queryGeom.count(); i++){
-                var pos = realToMap(that.geomTarget,queryGeom.get(i));
-                str_mPoints += "<div style='font-size:1px;position:absolute;top:"+(pos.y-2)+"px;left:"+(pos.x-2)+"px;width:3px;height:3px;background-color:#ff0000'></div>";
-            if(queryGeom.count()>1){
-                for(var k=1; k<queryGeom.count(); k++){
-                    var pos0 = realToMap(that.geomTarget,queryGeom.get(k));
-                    var pos1 = realToMap(that.geomTarget,queryGeom.get(k-1));
-                    str_mPoints += evaluateDashesExt(pos1,pos0,k);
-        writeTag(myMapObj.frameName, myMapObj.elementName+"_request_geometry_polygon", str_mPoints);
-    var evaluateDashesExt = function(p1,p0,count){
-        var that = this;
-        var str_dashedLine = "";
-        var d = p0.dist(p1);
-        var n = Math.round(d);
-        var s =  p0.minus(p1).dividedBy(n);
-        for(var i=1; i<n; i++){
-            var currPoint = p1.plus(s.times(i)).minus(new Point(2,2)).round(0);
-            if(currPoint.x >= 0 && currPoint.x <= mb_mapObj[ind].width && currPoint.y >= 0 && currPoint.y <= mb_mapObj[ind].height){
-                str_dashedLine += "<div style='font-size:1px;position:absolute;top:"+currPoint.y+"px;left:"+currPoint.x+"px;width:3px;height:3px;background-color:#ff0000'></div>";
-        return str_dashedLine;
-    var selAreaExtInit = function(e){
-        mb_isBF = that.geomTarget;
-        mb_zF = that.geomTarget;
-    var selAreaExtGet = function(e){
-        selAreaExtSetValidClipping(mod_box_stop(e));
-    var selAreaExtSetValidClipping = function(coords){
-        var that = this;
-            queryGeom.addPoint(new Point(coords[0],coords[1]));
-            queryGeom.addPoint(new Point(coords[2],coords[3]));
-            if(queryGeom.count() == 2){
-                queryGeom = null;
-            else{
-        this.map = map;
-        this.$elm = $map;
-        this.box = box;
-            return true;
-            return true;
-            box = null;
-                function (extent) {
-                        return false;
-            touch.box = null;
-            touch = null;
-                return element;
Deleted: branches/mobile/http/plugins/mb_overview_mobile.js
--- branches/mobile/http/plugins/mb_overview_mobile.js	2011-08-02 12:12:12 UTC (rev 8044)
+++ branches/mobile/http/plugins/mb_overview_mobile.js	2011-08-02 12:15:18 UTC (rev 8045)
@@ -1,283 +0,0 @@
- * Package: Overview
- * Description:
- * Use the overview map to navigate the main map window. You can select a new
- * rectangle in the overview map, the details will be displayed in the main
- * map window. Recenter the main map window section by just clicking a new
- * position in the overview map (the scale will not change).
- * Files:
- *  - http/javascripts/mod_overview.js
- * SQL:
- * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
- * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>','overview',
- * > 2,1,'OverviewFrame','Overview','div','','',15,25,150,150,2,
- * > 'overflow:hidden;',
- * > '<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>',
- * > 'div','../plugins/mb_overview.js','mod_box1.js','mapframe1','mapframe1',
- * > 'http://www.mapbender.org/index.php/Overview');
- * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
- * > var_value, context, var_type) VALUES ('<app_id>', 'overview',
- * > 'overview_wms', '0', 'wms that shows up as overview' ,'var');
- * > 'skipWmsIfSrsNotSupported', '0',
- * > 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,
- * > 'var');
- * Help:
- * http://www.mapbender.org/Overview
- * Maintainer:
- * Parameters:
- * overview_wms                - wms that shows up as overview
- * skipWmsIfSrsNotSupported    - *[optional]* if set to 1, it skips the WMS
- * 			request if the current SRS is not supported by the WMS; if set
- * 			to 0, the WMS is always queried. Default is 0, because of
- * 			backwards compatibility
- * License:
-if (typeof options.overview_wms === "undefined") {
-	options.overview_wms = 0;
-if (typeof options.enable_mouse === "undefined") {
-	options.enable_mouse = 1;
-options.overview_wms = parseInt(options.overview_wms, 10);
-if (!options.target) {
-	new Mb_exception(options.id + " needs a target.");
-	return;
-var box;
-var map;
-var $this = $(this);
-Mapbender.events.initMaps.register(function () {
-        var touch;
-        try {document.createEvent("TouchEvent"); isTouchable = true; } catch(e){}
-	$this.data("isMap", true);
-	$this.mapbender(new Mapbender.Map({
-		id: options.id,
-		width: options.width,
-		height: options.height,
-		wms: wms,
-		wmsIndexOverview: options.overview_wms
-	map = Mapbender.modules[options.id];
-	map.isOverview = true;
-	map.skipWmsIfSrsNotSupported =
-		options.skipWmsIfSrsNotSupported === 1 ? true : false;
-	// this line is for backwards compatibility
-	mb_mapObj.push(map);
-            box = new Mapbender.BoxMobile({target: options.id});
-            touch = new mapTouch(map,$(map.getDomElement()), map.getDomElement(), box);
-            touch.activate();
-        } else {
-            // add select area behaviour
-                    target: options.id
-            $(map.getDomElement()).mousedown(function (e) {
-                    if (options.enable_mouse == '0') {
-                            return false;
-                    box.start(e);
-                    return false;
-                    var targetMap = Mapbender.modules[options.target];
-                    if (!targetMap) {
-                            return false;
-                                    return false;
-                                    targetMap.calculateExtent(extent);
-                                    targetMap.setMapRequest();
-                                    targetMap.setCenter(extent);
-                    return false;
-	// if the setBackground module is active,
-	// the overview wms might be hidden.
-	// so we activate it here.
-	var ovWmsArray = map.wms;
-	if (typeof ovWmsArray !== "object" || ovWmsArray.length === 0) {
-		return;
-	ovWmsArray[0].gui_wms_visible = 1;
-        function mapTouch(map, $map, mapDom, box){
-            this.map = map;
-            this.$elm = $map;
-            this.box = box;
-                        return false;
-                return true;
-                return true;
-                if (!targetMap) {
-                        return false;
-                                return false;
-                return element;
-// update the rectangle indicating the current extent
-// of the target map after each map request in the target
-	options.$target.mapbender(function () {
-		var targetMap = this;
-		targetMap.events.afterMapRequest.register(function () {
-			var min = map.convertRealToPixel(targetMap.extent.min);
-			var max = map.convertRealToPixel(targetMap.extent.max);
-			if (min.x < 0) {
-				min.x = 0;
-			if (max.x > map.getWidth()) {
-				max.x = map.getWidth();
-			if (min.y > map.getHeight()) {
-				min.y = map.getHeight();
-			if (max.y < 0) {
-				max.y = 0;
-			var diffX = max.x - min.x;
-			if (diffX < 8) {
-				var centerX = 0.5 * (max.x + min.x);
-				min.x = centerX - 4;
-				max.x = centerX + 4;
-			var diffY = min.y - max.y;
-			if (diffY < 8) {
-				var centerY = 0.5 * (max.y + min.y);
-				min.y = centerY + 4;
-				max.y = centerY - 4;
-			var extent = new Mapbender.Extent(min, max);
-			box.draw(extent);
\ No newline at end of file
Deleted: branches/mobile/log/mb_error_2011_08_02.log
--- branches/mobile/log/mb_error_2011_08_02.log	2011-08-02 12:12:12 UTC (rev 8044)
+++ branches/mobile/log/mb_error_2011_08_02.log	2011-08-02 12:15:18 UTC (rev 8045)
@@ -1,41 +0,0 @@
-2011.08.02, 13:11:56,ERROR: mb_validateSession.php: Invalid user:
-2011.08.02, 13:52:30,ERROR: connector: unable to load: http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=Topographie,Grenze,Bundeslaender,Staedte,Postleitzahlbereiche,Bahnlinien,Strassen,Staedtepunkte,Staedtenamen,Bundeslaendernamen&QUERY_LAYERS=Postleitzahlbereiche,Staedtepunkte&WIDTH=525&HEIGHT=450&SRS=EPSG:4326&BBOX=-111.58333333333334,-80,85.58333333333334,89&STYLES=,,,,,,,,,&FORMAT=image/png&INFO_FORMAT=text/html&EXCEPTIONS=application/vnd.ogc.se_xml&X=103&Y=105&FEATURE_COUNT=100&=
-2011.08.02, 13:52:33,ERROR: connector: unable to load: http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=Topographie,Grenze,Bundeslaender,Staedte,Postleitzahlbereiche,Bahnlinien,Strassen,Staedtepunkte,Staedtenamen,Bundeslaendernamen&QUERY_LAYERS=Postleitzahlbereiche,Staedtepunkte&WIDTH=525&HEIGHT=450&SRS=EPSG:4326&BBOX=-111.58333333333334,-80,85.58333333333334,89&STYLES=,,,,,,,,,&FORMAT=image/png&INFO_FORMAT=text/html&EXCEPTIONS=application/vnd.ogc.se_xml&X=395&Y=205&FEATURE_COUNT=100&=
-2011.08.02, 13:52:36,ERROR: connector: unable to load: http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=Topographie,Grenze,Bundeslaender,Staedte,Postleitzahlbereiche,Bahnlinien,Strassen,Staedtepunkte,Staedtenamen,Bundeslaendernamen&QUERY_LAYERS=Postleitzahlbereiche,Staedtepunkte&WIDTH=525&HEIGHT=450&SRS=EPSG:4326&BBOX=-111.58333333333334,-80,85.58333333333334,89&STYLES=,,,,,,,,,&FORMAT=image/png&INFO_FORMAT=text/html&EXCEPTIONS=application/vnd.ogc.se_xml&X=352&Y=374&FEATURE_COUNT=100&=
-2011.08.02, 13:56:38,ERROR: connector: unable to load: http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=Topographie,Grenze,Bundeslaender,Staedte,Postleitzahlbereiche,Bahnlinien,Strassen,Staedtepunkte,Staedtenamen,Bundeslaendernamen&QUERY_LAYERS=Postleitzahlbereiche,Staedtepunkte&WIDTH=525&HEIGHT=450&SRS=EPSG:4326&BBOX=-259,-180.5,71,102.5&STYLES=,,,,,,,,,&FORMAT=image/png&INFO_FORMAT=text/html&EXCEPTIONS=application/vnd.ogc.se_xml&X=302&Y=95&FEATURE_COUNT=100&=
-2011.08.02, 13:56:46,ERROR: connector: unable to load: http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=Topographie,Grenze,Bundeslaender,Staedte,Postleitzahlbereiche,Bahnlinien,Strassen,Staedtepunkte,Staedtenamen,Bundeslaendernamen&QUERY_LAYERS=Postleitzahlbereiche,Staedtepunkte&WIDTH=525&HEIGHT=450&SRS=EPSG:4326&BBOX=-259,-180.5,71,102.5&STYLES=,,,,,,,,,&FORMAT=image/png&INFO_FORMAT=text/html&EXCEPTIONS=application/vnd.ogc.se_xml&X=356&Y=230&FEATURE_COUNT=100&=
-2011.08.02, 13:57:44,ERROR:
-2011.08.02, 13:58:05,ERROR: Javascript not found: MapTouch.js
-2011.08.02, 13:58:16,ERROR: Javascript not found: MapTouch.js
-2011.08.02, 14:08:27,ERROR:
-2011.08.02, 14:08:34,ERROR:
-2011.08.02, 14:08:35,ERROR:
-2011.08.02, 14:08:40,ERROR:
-2011.08.02, 14:09:09,ERROR:
-2011.08.02, 14:09:10,ERROR:
-2011.08.02, 14:09:28,ERROR:
-2011.08.02, 14:09:30,ERROR:
-2011.08.02, 14:09:53,ERROR:
-2011.08.02, 14:09:54,ERROR:
-2011.08.02, 14:10:10,ERROR:
-2011.08.02, 14:10:11,ERROR:
-2011.08.02, 14:10:20,ERROR:
-2011.08.02, 14:10:26,ERROR:
-2011.08.02, 14:10:32,ERROR:
More information about the Mapbender_commits mailing list
