[Mapbender-commits] r8090 - in trunk/mapbender/http/print: . classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Aug 31 08:17:04 EDT 2011
Author: verenadiewald
Date: 2011-08-31 05:17:04 -0700 (Wed, 31 Aug 2011)
New Revision: 8090
   trunk/mapbender/http/print/classes/mbMeasureDecorator.php
   trunk/mapbender/http/print/print_functions.php
http://trac.osgeo.org/mapbender/ticket/855
Modified: trunk/mapbender/http/print/classes/mbMeasureDecorator.php
--- trunk/mapbender/http/print/classes/mbMeasureDecorator.php	2011-08-31 12:15:28 UTC (rev 8089)
+++ trunk/mapbender/http/print/classes/mbMeasureDecorator.php	2011-08-31 12:17:04 UTC (rev 8090)
@@ -3,23 +3,23 @@
 	protected $pageElementType = "measure";
 	protected $elementId;
 	public function __construct($pdfObj, $elementId, $mapConf, $controls) {
 		parent::__construct($pdfObj, $mapConf, $controls);
 		$this->elementId = $elementId;
-		$this->override();
+		$this->override();
 		$this->decorate();
 	public function override() {}
 	public function decorate() {
 		include (dirname(__FILE__)."/../print_functions.php");
 		global $mapOffset_left, $mapOffset_bottom, $map_height, $map_width, $coord;
 		global $yAxisOrientation;
 		$yAxisOrientation = 1;
 		if (isset($_REQUEST["measured_x_values"]) && $_REQUEST["measured_x_values"] != "") {
 			$x_value_str = $_REQUEST["measured_x_values"];
 			$y_value_str = $_REQUEST["measured_y_values"];
@@ -29,7 +29,7 @@
 		else {
 			return "No measurements found.";
 		$coord = mb_split(",",$this->pdf->getMapExtent());
 		$mapInfo = $this->pdf->getMapInfo();
 		foreach ($mapInfo as $k => $v) {
@@ -39,18 +39,18 @@
 		$mapOffset_bottom = $mapInfo["y_ul"];
 		$map_height = $mapInfo["height"];
 		$map_width = $mapInfo["width"];
 		// get the arrays, be aware of the different y-axis values
-		$theFullArr = makeCoordPairs($x_value_str, $y_value_str);
+		$theFullArr = makeCoordPairsForFpdi($x_value_str, $y_value_str);
 		foreach ($theFullArr as $oneFullArr) {
 			$e = new mb_notice("mbMeasureDecorator: coordinates: ".implode(" ",array_values($oneFullArr)));
     	$thePolyArr = makePolyFromCoord($theFullArr);
     	$e = new mb_notice("mbMeasureDecorator: coordinates: ".implode(" ",$thePolyArr));
 		if (isClosedPolygon($theFullArr)) {
 			$isClosed = TRUE;
 		else {
 			$isClosed = FALSE;
@@ -60,9 +60,9 @@
 		$this->pdf->objPdf->ClippingRect($mapOffset_left, $mapOffset_bottom, $map_width, $map_height, false);
 		if ($isClosed) {
 			$this->pdf->objPdf->Polygon($thePolyArr);
 		else {
-			$theStrokePointPairs = makeStrokePointPairs($theFullArr);
+                	$theStrokePointPairs = makeStrokePointPairs($theFullArr);
 			for($i = 0; $i < count($theStrokePointPairs); $i++) {
 				$line = $theStrokePointPairs[$i];
 				$e = new mb_notice("mbMeasureDecorator: line coordinates: ".implode(" ",$line));
@@ -74,8 +74,8 @@
 		$this->pdf->objPdf->UnsetClipping();
\ No newline at end of file
Modified: trunk/mapbender/http/print/print_functions.php
--- trunk/mapbender/http/print/print_functions.php	2011-08-31 12:15:28 UTC (rev 8089)
+++ trunk/mapbender/http/print/print_functions.php	2011-08-31 12:17:04 UTC (rev 8090)
@@ -1,58 +1,76 @@
 <?php
  * $Id$
  * converts the coordinates created via the JavaScript
- * functions in 'mod_measure.php' into an array which
+ * functions in 'mod_measure.php' into an array which
  * then holds both X- ans Y-values for each point in
- * the formats 'realworld coordinate' and 'pdf_coordinate'
+ * the formats 'realworld coordinate' and 'pdf_coordinate'
  * @param string commaseperated X-values of the points (realworld coordinate)
  * @param string commaseperated Y-values of the points (realworld coordinate)
  * @return array Array looking like 0 => array(
  *                                         'real_x' => 1234567,
  *                                         'real_y' => 7654321,
  *                                         'pdf_x'  => 451.12,
- *                                         'pdf_y'  => 254.7
+ *                                         'pdf_y'  => 254.7
  * @see transformForPDF
  * @author M. Jansen <jansen at terrestris.de>, 2006-05-26
 function makeCoordPairs($x_values, $y_values) {
-  $arr_x = explode(",", $x_values);
+        $arr_x = explode(",", $x_values);
 	$arr_y = explode(",", $y_values);
 	$x_elems = count($arr_x);
 	$y_elems = count($arr_y);
 	$the_return_arr = array();
 	if ($x_elems == $y_elems) {
 	  for ($i = 0; $i < $x_elems; $i ++) {
-		  $the_return_arr[$i] = array(
-			                        "real_x" => $arr_x[$i],
-															"real_y" => $arr_y[$i],
-															"pdf_x"  => transformForPDF($arr_x[$i], "x"),
-															"pdf_y"  => transformForPDF($arr_y[$i], "y")
+            $the_return_arr[$i] = array(
+                "real_x" => $arr_x[$i],
+                "real_y" => $arr_y[$i],
+                "pdf_x"  => transformForPDF($arr_x[$i], "x"),
+                "pdf_y"  => transformForPDF($arr_y[$i], "y"));
 	return $the_return_arr;
 } // end of function makeCoordPairs
+function makeCoordPairsForFpdi($x_values, $y_values) {
+	$arr_y = explode(",", $y_values);
+	$x_elems = count($arr_x);
+	$y_elems = count($arr_y);
+	$the_return_arr = array();
+	if ($x_elems == $y_elems) {
+	  for ($i = 0; $i < $x_elems; $i ++) {
+                "pdf_x"  => transformForPDFFpdi($arr_x[$i], "x"),
+                "pdf_y"  => transformForPDFFpdi($arr_y[$i], "y"));
+	return $the_return_arr;
+} // end of function makeCoordPairsForFpdi
- * Transforms given realworld-coordinate according to its type (X or Y)
+ * Transforms given realworld-coordinate according to its type (X or Y)
  * into a pdf-coordinate. Needs the variables $mapOffset_left, $mapOffset_bottom,
  * $map_height, $map_width, $coord to be defined in a global scope.
  * @param float the realworld coordinate
  * @param string type of coordinate either 'X' or 'Y'
  * @see makeCoordPairs [needs this function]
  * @return float the pdf-coordinate
@@ -61,9 +79,9 @@
 function transformForPDF ($theRealCoord, $theType) {
 	$thePDFvalue = "";
 	switch (mb_strtolower($theType)) {
 	  case 'x':
 		  // calculate pdf x-pos:
@@ -75,7 +93,7 @@
 		case 'y':
 		  // calculate pdf y-pos:
 			$real_shown_height = $coord[3] - $coord[1];
-			$ratio_to_display  = $map_height / $real_shown_height;
+			$ratio_to_display  = ($map_height / $real_shown_height);
 			$target_height     = $theRealCoord - $coord[1];
 			$thePDFvalue       = $mapOffset_bottom + ($target_height * $ratio_to_display);
 		  break;
@@ -87,16 +105,57 @@
 	return $thePDFvalue;
 } // end of function transformForPDF
+ * Use for new template print with lib fpdi:
+ * into a pdf-coordinate. Needs the variables $mapOffset_left, $mapOffset_bottom,
+ * $map_height, $map_width, $coord to be defined in a global scope.
+ * @param float the realworld coordinate
+ * @param string type of coordinate either 'X' or 'Y'
+ * @see makeCoordPairsForFpdi [needs this function]
+ * @return float the pdf-coordinate
+ * @author V. Diewald
+function transformForPDFFpdi ($theRealCoord, $theType) {
+  global $mapOffset_left, $mapOffset_bottom, $map_height, $map_width, $coord;
+	$thePDFvalue = "";
+	switch (mb_strtolower($theType)) {
+	  case 'x':
+		  // calculate pdf x-pos:
+			$real_shown_width = $coord[2] - $coord[0];
+			$ratio_to_display = $map_width / $real_shown_width;
+			$target_width     = $theRealCoord - $coord[0];
+			$thePDFvalue      = $mapOffset_left + ($target_width * $ratio_to_display);
+			break;
+		case 'y':
+		  // calculate pdf y-pos:
+			$real_shown_height = $coord[3] - $coord[1];
+			$target_height     = $theRealCoord - $coord[1];
+			$thePDFvalue       = $mapOffset_bottom +($map_height- ($target_height * $ratio_to_display));
+		  break;
+		default:
+		  // a non valid parameter was given
+		  $thePDFvalue = $theRealCoord;
+      break;
+	return $thePDFvalue;
+} // end of function transformForPDFFpdi
- * extracts PDF-relevant information from a full coordinates array
+ * extracts PDF-relevant information from a full coordinates array
  * and returns a transformed array
  * @param array the Array containing all infos about single coordinates
  *              created via makeCoordPairs()
  * @return array the array containing PDF-Values for a polygon
@@ -121,7 +180,7 @@
  * @return array the array containing PDF-Values for single lines
@@ -160,7 +219,7 @@
  * @return bool is it closed (TRUE || FALSE)
@@ -172,7 +231,7 @@
 	if ($coord_arr[0]['pdf_x'] == $coord_arr[$nr_of-1]['pdf_x']
 	    && $coord_arr[0]['pdf_y'] == $coord_arr[$nr_of-1]['pdf_y']
 			&& $nr_of != 1) {
-	  return TRUE;
+	  return TRUE;
 	} else {
 	  return FALSE;
@@ -183,7 +242,7 @@
  * Adds the measured item to the PDF output.
  * @param object reference (!) to the current ezPDF-Object
  * @param string commaseperated X-Values of polygon / line
  * @param string commaseperated Y-Values of polygon / line
@@ -208,7 +267,7 @@
 	$leg_img = imagecreate($legend_width, $legend_width);
 	// save previous state:
 	$thePDF->saveState();
 	// save colors for legend:
 	if(!defined("MAP_HAS_USER_POLYGON")) {
 	  define("MAP_HAS_USER_POLYGON", "test");
@@ -217,22 +276,22 @@
 	// get the arrays
 		$isClosed = TRUE;
 	else {
 		$isClosed = FALSE;
 	$nr_of_points = count($theFullArr);
 	// is fill option set?
 	// wenn der erste und letzte punkt nicht �bereinstimmen,
 	// so muss in jedem Falle dofill auf 0 gesetzt werden
 	if($theConfArray['do_fill'] != '' && $isClosed) {
 	  $doFill = 1;
 	  // which color to use for filling?
-	  if (is_array($theConfArray['fill_color'])
+	  if (is_array($theConfArray['fill_color'])
 	      && $theConfArray['fill_color']['r'] != ''
 			  && $theConfArray['fill_color']['g'] != ''
 			  && $theConfArray['fill_color']['b'] != '') {
@@ -250,11 +309,11 @@
 		// color to legend file
 	  $bg_color = imagecolorallocate($leg_img, -1, -1, -1);
 	// Do we need to stroke (outline)?
 	if($theConfArray['do_stroke'] != '') {
-	  if (is_array($theConfArray['stroke_color'])
+	  if (is_array($theConfArray['stroke_color'])
 	      && $theConfArray['stroke_color']['r'] != ''
 			  && $theConfArray['stroke_color']['g'] != ''
 			  && $theConfArray['stroke_color']['b'] != '') {
@@ -266,7 +325,7 @@
 				if ($i != count($theStrokePointPairs) - 1
 				    || $isClosed) {
 			    $thePDF->line($line[0], $line[1], $line[2], $line[3]);
 					$stroke_color_legend_image = imagecolorallocate($leg_img, round($theConfArray['stroke_color']['r'] * 255), round($theConfArray['stroke_color']['g'] * 255), round($theConfArray['stroke_color']['b'] * 255));
 					if (is_array($theConfArray['line_style']['dash'])
 					    && $theConfArray['line_style']['dash'][1] != ""
@@ -280,16 +339,16 @@
 						imageline($leg_img, $legend_width-1, 0, $legend_width-1, $legend_width-1, $stroke_color_legend_image);
 						imageline($leg_img, $legend_width-1, $legend_width-1, 0, $legend_width-1, $stroke_color_legend_image);
 						imageline($leg_img, 0, $legend_width-1, 0, 0, $stroke_color_legend_image);
   $thePDF->polygon($thePolyArr, $nr_of_points, $doFill);
   // eventually create the file:
 	imagepng($leg_img, $legendFilenameUserPolygon);
 	$thePDF->restoreState();
 } // end of function addMeasuredItem
@@ -309,7 +368,7 @@
     	// trimme wort auf maximal erlaubte zeichenzahl
         $word_fit = mb_substr($word, 0, $available_chars_per_line);
 	    $chars = preg_split('//', $word_fit, -1, PREG_SPLIT_NO_EMPTY);
 	    if(count($chars) + $chars_current_line + 1 < $available_chars_per_line && $total_number_of_lines < $maxlines) {
 		    $chars_current_line += count($chars) + 1;
 			$the_return_array[$total_number_of_lines]  .= " " . $word_fit;
@@ -326,7 +385,7 @@
  * Adds two white polygons to hide any user elements outside the mapframe:
  * First all A-Areas are filled, then all B-Areas. This is a rather grumpy
  * way out of having user edited stuff flying outside the mapframe.
  * @example <pre>
  * BBBBBBBBBBBBBBBBBBBBBBBBBBBBAAA
@@ -339,7 +398,7 @@
  * AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
  * </pre>
  * @param reference (!, pass over with '&') to the pdf-file
@@ -359,7 +418,7 @@
     0                              , 0
 	// draw polygon
-  $pdf->polygon($allOutside, 7, 1);
+  $pdf->polygon($allOutside, 7, 1);
   // The BBB-part
   $allOutside = array(
     0                              , $mapOffset_bottom,       // 1st coord-pair
@@ -368,7 +427,7 @@
     $mapOffset_left + $map_width   , $mapOffset_bottom + $map_height,
     $mapOffset_left + $map_width   , $pdf->ez['pageHeight'],
     0                              , $pdf->ez['pageHeight'],
-    0                              , $mapOffset_bottom,
+    0                              , $mapOffset_bottom,
 	// draw polygon
More information about the Mapbender_commits mailing list
