[Mapbender-commits] r7544 - in trunk/mapbender/http: classes
javascripts php
svn_mapbender at osgeo.org
Wed Feb 9 10:38:06 EST 2011
Author: armin11
Date: 2011-02-09 07:38:06 -0800 (Wed, 09 Feb 2011)
New Revision: 7544
Added:
trunk/mapbender/http/classes/class_lzw_decompress.php
trunk/mapbender/http/javascripts/lzw.js
trunk/mapbender/http/javascripts/mod_savewmc.js
trunk/mapbender/http/php/mod_savewmc_server.php
New function to compress the mapObject when storing it to session by lzw compression. on small mapObjects ths will reduce the amount of traffic to the server for 20% on bigger docs this will become better. The little problem will be, that the server needs some more cpu to decompress the data.
The handlihg is managed thru an element_var lzwCompressed in the module savewmc.
Added: trunk/mapbender/http/classes/class_lzw_decompress.php
--- trunk/mapbender/http/classes/class_lzw_decompress.php (rev 0)
+++ trunk/mapbender/http/classes/class_lzw_decompress.php 2011-02-09 15:38:06 UTC (rev 7544)
@@ -0,0 +1,127 @@
+<?php
+//class_lzw_decompress.php
+/*function uniord($ch) {
+ $n = ord($ch{0});
+ if ($n < 128) {
+ return $n; // no conversion required
+ if ($n < 192 || $n > 253) {
+ return false; // bad first byte || out of range
+ $arr = array(1 => 192, // byte position => range from
+ 2 => 224,
+ 3 => 240,
+ 4 => 248,
+ 5 => 252,
+ foreach ($arr as $key => $val) {
+ if ($n >= $val) { // add byte to the 'char' array
+ $char[] = ord($ch{$key}) - 128;
+ $range = $val;
+ } else {
+ break; // save some e-trees
+ $retval = ($n - $range) * pow(64, sizeof($char));
+ foreach ($char as $key => $val) {
+ $pow = sizeof($char) - ($key + 1); // invert key
+ $retval += $val * pow(64, $pow); // dark magic
+ return $retval;
+/*function unichr($dec) {
+ if ($dec < 128) {
+ $utf = chr($dec);
+ } else if ($dec < 2048) {
+ $utf = chr(192 + (($dec - ($dec % 64)) / 64));
+ $utf .= chr(128 + ($dec % 64));
+ } else {
+ $utf = chr(224 + (($dec - ($dec % 4096)) / 4096));
+ $utf .= chr(128 + ((($dec % 4096) - ($dec % 64)) / 64));
+ return $utf;
+/*function uniord($c) {
+ $h = ord($c{0});
+ if ($h <= 0x7F) {
+ return $h;
+ } else if ($h < 0xC2) {
+ return false;
+ } else if ($h <= 0xDF) {
+ return ($h & 0x1F) << 6 | (ord($c{1}) & 0x3F);
+ } else if ($h <= 0xEF) {
+ return ($h & 0x0F) << 12 | (ord($c{1}) & 0x3F) << 6
+ | (ord($c{2}) & 0x3F);
+ } else if ($h <= 0xF4) {
+ return ($h & 0x0F) << 18 | (ord($c{1}) & 0x3F) << 12
+ | (ord($c{2}) & 0x3F) << 6
+ | (ord($c{3}) & 0x3F);
+ } else {
+ return false;
+ * Return unicode char by its code
+ * @param int $u
+ * @return char
+/*function unichr($u) {
+ return mb_convert_encoding('&#' . intval($u) . ';', 'UTF-8', 'HTML-ENTITIES');
+ function unichr($u) {
+ return mb_convert_encoding(pack("N",$u), mb_internal_encoding(), 'UCS-4BE');
+function lzw_decompress($compressed) {
+ // Build the dictionary.
+ $dictSize = 256;
+ $dictionary = array();
+ for ($i=0; $i < $dictSize; $i++)
+ $dictionary[$i] = unichr($i);
+ //$e = new mb_exception('dictionary['.$i.']:'.$dictionary[$i]);
+ $w = (string)unichr($compressed[0]);
+ $result = $w;
+ for ($i=1; $i < count($compressed); $i++) {
+ $entry = "";
+ $k = $compressed[$i];
+ if (isset($dictionary[$k])) { //whats with null?
+ $entry = $dictionary[$k];
+ else if ($k == $dictSize) {
+ $entry = $w.$w[0];
+ else {
+ $result = $result.$entry;
+ $dictionary[$dictSize++] = $w.$entry[0]; //for the first time 256 after that it will be increased
+ $w = $entry;
+ return $result;
Added: trunk/mapbender/http/javascripts/lzw.js
--- trunk/mapbender/http/javascripts/lzw.js (rev 0)
+++ trunk/mapbender/http/javascripts/lzw.js 2011-02-09 15:38:06 UTC (rev 7544)
@@ -0,0 +1,65 @@
+//LZW Compression/Decompression for Strings
+//http://rosettacode.org/wiki/LZW_compression#JavaScript
+function LZWCompress(uncompressed)
+ var dictSize = 256;
+ var dictionary = {};
+ for (var i = 0; i < 256; i++)
+ dictionary[String.fromCharCode(i)] = i;
+ var w = "";
+ var result = [];
+ for (var i = 0; i < uncompressed.length; i++)
+ var c = uncompressed.charAt(i);
+ var wc = w + c;
+ if (dictionary[wc])
+ w = wc;
+ else {
+ result.push(dictionary[w]);
+ // Add wc to the dictionary.
+ dictionary[wc] = dictSize++;
+ w = "" + c;
+ // Output the code for w.
+ if (w != "")
+ return result;
+function LZWDecompress(compressed) {
+ var dictionary = [];
+ dictionary[i] = String.fromCharCode(i);
+ var w = String.fromCharCode(compressed[0]);
+ var result = w;
+ for (var i = 1; i < compressed.length; i++) {
+ var entry = "";
+ var k = compressed[i];
+ if (dictionary[k]) {
+ entry = dictionary[k];}
+ else if (k == dictSize)
+ entry = w + w.charAt(0);
+ else
+ return null;
+ result += entry;
+ dictionary[dictSize++] = w + entry.charAt(0);
+ w = entry;
+ return result;
Modified: trunk/mapbender/http/javascripts/mod_savewmc.js
--- trunk/mapbender/http/javascripts/mod_savewmc.js 2011-02-08 09:36:24 UTC (rev 7543)
+++ trunk/mapbender/http/javascripts/mod_savewmc.js 2011-02-09 15:38:06 UTC (rev 7544)
@@ -16,9 +16,15 @@
* > e_mb_mod, e_target, e_requires, e_url) VALUES('<gui_id>','savewmc',2,1,
* > 'save workspace as WMC','Save workspace as web map context document',
* > 'img','../img/button_blink_red/wmc_save_off.png','',870,60,24,24,1,'',
- * > '','','mod_savewmc.php','','mapframe1','mapframe1',
+ * > '','','mod_savewmc.php','','mapframe1','jq_ui_dialog,lzw_compression',
* > 'http://www.mapbender.org/index.php/SaveWMC');
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title,
+ * > e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index,
+ * > e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,
+ * > e_url) VALUES('gui1','lzw_compression',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,
+ * > NULL ,'','','','','lzw.js','','','');
* > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
* > context, var_type) VALUES('<gui_id>', 'savewmc', 'overwrite', '1', '',
* > 'var');
@@ -26,6 +32,9 @@
* > context, var_type) VALUES('<gui_id>', 'savewmc', 'saveInSession', '1',
* > '' ,'var');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+ * > context, var_type) VALUES('<gui_id>', 'savewmc', 'lzwCompressed', 'false',
+ * > '' ,'var');
* Help:
* http://www.mapbender.org/index.php/SaveWMC
@@ -55,9 +64,13 @@
// init element_vars
var overwrite = options.overwrite || false;
var saveInSession = typeof options.saveInSession === "undefined" ?
0 : options.saveInSession;
+var lzwCompressed = typeof options.lzwCompressed === "undefined" ?
+ false : options.lzwCompressed;
var browserCompatibilityMode = typeof options.browserCompatibilityMode === "undefined" ?
0 : options.browserCompatibilityMode;
@@ -99,6 +112,7 @@
this.overwrite = overwrite;
this.saveInSession = saveInSession;
+ this.lzwCompressed = lzwCompressed;
this.events = {
saved: new Mapbender.Event()
@@ -116,16 +130,16 @@
return this;
if (obj.session === true) {
- sendMapDataToServer("session", 1, function(result, status) {});
+ sendMapDataToServer("session", 1, function(result, status) {}, lzwCompressed);
return this;
if (typeof obj.attributes === "object" && typeof obj.callback === "function") {
- sendMapDataToServer(obj.attributes, 0, obj.callback);
+ sendMapDataToServer(obj.attributes, 0, obj.callback, lzwCompressed);
return this;
- var sendMapDataToServer = function (attributes, storeInSession, callbackFunction) {
+ var sendMapDataToServer = function (attributes, storeInSession, callbackFunction, beLzwCompressed) {
var extensionDataString = "";
if (that.extensionData !== null) {
extensionDataString = $.toJSON(that.extensionData);
@@ -135,7 +149,7 @@
//alert('AJAX will be set to asyncron!');
$.ajaxSetup({async:false});
// WORKAROUND....cannot serialize map object,
// as it contains a jQuery collection, which is
@@ -148,7 +162,12 @@
$target.push(mb_mapObj[i].$target);
delete mb_mapObj[i].$target;
+ var mapObjectToSend = $.toJSON(mb_mapObj);
+ //if compression is demanded see http://rosettacode.org/wiki/LZW_compression#JavaScript
+ if (beLzwCompressed == 'true') { //
+ mapObjectToSend=LZWCompress(mapObjectToSend);
+ //alert(LZWDecompress(mapObjectToSend));
// actual save request
var req = new Mapbender.Ajax.Request({
url: "../php/mod_savewmc_server.php",
@@ -156,9 +175,10 @@
parameters : {
saveInSession:storeInSession,
attributes:attributes,
- overwrite: overwrite,
+ overwrite:overwrite,
extensionData:extensionDataString,
- mapObject:$.toJSON(mb_mapObj)
+ lzwCompressed:beLzwCompressed,
+ mapObject:mapObjectToSend
callback: function(result, status, message) {
callbackFunction(result, status, message);
@@ -392,7 +412,7 @@
that.save({
session : true
- //alert('afterMapRequest Saving!');
+ alert('afterMapRequest Saving!');
Modified: trunk/mapbender/http/php/mod_savewmc_server.php
--- trunk/mapbender/http/php/mod_savewmc_server.php 2011-02-08 09:36:24 UTC (rev 7543)
+++ trunk/mapbender/http/php/mod_savewmc_server.php 2011-02-09 15:38:06 UTC (rev 7544)
@@ -11,6 +11,7 @@
require_once(dirname(__FILE__)."/../classes/class_administration.php");
require_once(dirname(__FILE__)."/../classes/class_wmc.php");
require_once(dirname(__FILE__)."/../classes/class_json.php");
+require_once(dirname(__FILE__)."/../classes/class_lzw_decompress.php");
$ajaxResponse = new AjaxResponse($_POST);
if($ajaxResponse->getMethod() != "saveWMC") {
@@ -25,14 +26,31 @@
// get data from POST and SESSION
$userId = Mapbender::session()->get("mb_user_id");
$mapObject = $ajaxResponse->getParameter('mapObject');
+$lzwCompressed = $ajaxResponse->getParameter('lzwCompressed');
$saveInSession = $ajaxResponse->getParameter('saveInSession');
$extensionData = $json->decode($ajaxResponse->getParameter('extensionData'));
$attributes = $ajaxResponse->getParameter('attributes');
$overwrite = $ajaxResponse->getParameter('overwrite');
$overwrite = $overwrite == "1" ? true : false;
+//for debugging, write mapObject to file
+if ($lzwCompressed == 'true') {
+ //$e = new mb_exception('mod_savewmc_server.php: mapObject: '.implode(',',$mapObject));
+ $mapObject = lzw_decompress($mapObject);
+ //$e = new mb_exception('mod_savewmc_server.php: mapObject uncompressed: '.$mapObject);
+ //$filename = TMPDIR."/formerly_compressed_json.txt";//will be set to new one cause ?
+} else {
+ //$filename = TMPDIR."/formerly_uncompressed_json.txt";//will be set to new one cause ?
+//file_put_contents($filename, $mapObject);
+//$e = new mb_exception('mod_savewmc_server.php: mapObject is here ;-)');
$mapObject = $json->decode($mapObject);
+$e = new mb_exception('mod_savewmc_server.php: mapObject has been decoded from json');
// create WMC object
$wmc = new wmc();
if($overwrite) {
@@ -60,7 +78,7 @@
if(Mapbender::session()->get("mb_wmc")) {
$filename = Mapbender::session()->get("mb_wmc");
} else {
- $filename = TMPDIR."/".time()."_".uniqid();
+ $filename = TMPDIR."/".time()."_".uniqid();//will be set to new one cause ?
file_put_contents($filename, $wmc->xml);
Mapbender::session()->set("mb_wmc",$filename);
More information about the Mapbender_commits
