[Mapbender-commits] r7550 - in branches/2.7/resources/db: .
pgsql/UTF-8/update
svn_mapbender at osgeo.org
Thu Feb 10 06:08:15 EST 2011
Author: kmq
Date: 2011-02-10 03:08:15 -0800 (Thu, 10 Feb 2011)
New Revision: 7550
branches/2.7/resources/db/install.sh
branches/2.7/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
branches/2.7/resources/db/update.bat
branches/2.7/resources/db/update.sh
update to install/update scripts merged from trunk
Modified: branches/2.7/resources/db/install.sh
--- branches/2.7/resources/db/install.sh 2011-02-10 11:03:54 UTC (rev 7549)
+++ branches/2.7/resources/db/install.sh 2011-02-10 11:08:15 UTC (rev 7550)
@@ -137,7 +137,7 @@
pgsql/$DBENCODING/update/update_2.6_to_2.6.1_pgsql_$DBENCODING.sql \
pgsql/$DBENCODING/update/update_2.6.1_to_2.6.2_pgsql_$DBENCODING.sql \
pgsql/$DBENCODING/update/update_2.6.2_to_2.7rc1_pgsql_$DBENCODING.sql \
- pgsql/$DBENCODING/update/update_2.7rc1_to_2.7rc2_pgsql_$DBENCODING.sql \
+ pgsql/$DBENCODING/update/update_2.7rc_to_2.7rc2_pgsql_$DBENCODING.sql \
pgsql/pgsql_serial_set_sequences_2.7.sql \
> _install.sql
echo "inserting data (this might take a while longer)"
Property changes on: branches/2.7/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/kmq_dev/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql:4021-4487
+ /branches/kmq_dev/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql:4021-4487
/trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql:7549
Modified: branches/2.7/resources/db/update.bat
--- branches/2.7/resources/db/update.bat 2011-02-10 11:03:54 UTC (rev 7549)
+++ branches/2.7/resources/db/update.bat 2011-02-10 11:08:15 UTC (rev 7550)
@@ -110,8 +110,10 @@
psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.2_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
echo update to 2.7rc2
psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.7rc1_to_2.7rc2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
-echo update sequences
+echo update to 2.7
psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
goto END:
:PGNOTFOUND
Modified: branches/2.7/resources/db/update.sh
--- branches/2.7/resources/db/update.sh 2011-02-10 11:03:54 UTC (rev 7549)
+++ branches/2.7/resources/db/update.sh 2011-02-10 11:08:15 UTC (rev 7550)
@@ -99,11 +99,11 @@
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.1_to_2.6.2_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
echo "update to 2.7rc1"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.2_to_2.7rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
- echo "update to 2.7rc2"
+ echo "update to 2.7rc2"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.7rc1_to_2.7rc2_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
echo "update sequences"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.7.sql $DBNAME >> log_update.txt 2>> err_update.txt
#magic starts here
More information about the Mapbender_commits
