[Mapbender-commits] r7553 - in trunk/mapbender: http/javascripts http/php http/plugins resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Feb 10 07:58:30 EST 2011
Author: armin11
Date: 2011-02-10 04:58:30 -0800 (Thu, 10 Feb 2011)
New Revision: 7553
   trunk/mapbender/http/javascripts/initWmcObj.php
   trunk/mapbender/http/php/mod_getServiceDisclaimer.php
   trunk/mapbender/http/php/mod_getWmcDisclaimer.php
   trunk/mapbender/http/php/mod_showMetadata.php
   trunk/mapbender/http/plugins/wfsConfTree.js
   trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
More german translation and i18 , bufixes
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php	2011-02-10 11:19:50 UTC (rev 7552)
+++ trunk/mapbender/http/javascripts/initWmcObj.php	2011-02-10 12:58:30 UTC (rev 7553)
@@ -24,30 +24,21 @@
 $resultObj = array(
 	"noPermission" => array(
-		"message" => "Sie als Nutzer '" .
+		"message" => _mb("You as User")." '" .
 			Mapbender::session()->get("mb_user_name") . "' " .
-			"haben keine Berechtigung auf folgende Layer zuzugreifen.",
+			_mb("have no authorization to access following layers."),
 		"wms" => array()
 	"withoutId" => array(
-		"message" => "Folgende Layer stammen aus einer dem " .
-			"Geoportal.rlp unbekannten Quelle. Es kann daher nicht " .
-			"überprüft werden, ob die Links verwaist sind oder ob " .
-			"die Dienste überhaupt Daten liefern.",
+		"message" => _mb("Following layers come from an unkown origin. There is no information about the links. They may be broken and the underlaying services may not exist anymore!"),
 		"wms" => array(),
 	"unavailable" => array(
-		"message" => "Bei folgenden Diensten kam es während " .
-			"des letzten Monitorings zu Problemen. Es ist möglich, dass " .
-			"diese Dienste derzeit keine Informationen zur Verfügung stellen " .
-			"können.",
+		"message" => _mb("The last monitoring had problems with the following layers. Maybe the underlying services will not be able to answer the requests for sometime."),
 		"wms" => array()
 	"invalidId" => array(
-		"message" => "Folgende Dienste/Layer sind aus der " .
-			"Registrierungsstelle gelöscht worden. Es kann daher nicht " .
+		"message" => _mb("Following layers have been removed from the registry. They may be broken and the underlaying services may not exist anymore!"),
 		"wms" => array()
 	"wmcTou" => array(
@@ -409,7 +400,7 @@
 //get terms of use from wms objects which are in the remaining wmc and are not already accepted for this session
 $validWMS = $wmcGetApi->getValidWms();
-$translation['wms'] = "Kartendienst";
+$translation['wms'] = _mb("MapService");
 $resourceSymbol = "<img src='../img/osgeo_graphics/geosilk/server_map.png' alt='".$translation['wms']." - picture' title='".$translation['wms']."'>";
 $languageCode = 'de';
 $hostName = $_SERVER['HTTP_HOST'];
@@ -429,22 +420,20 @@
 			$mapbenderProtocol = "http://";
 			$mapbenderBaseUrl = "http://".$hostName;
 		$touServiceConnector = new connector($mapbenderProtocol."localhost".$_SERVER['SCRIPT_NAME']."/../../php/mod_getServiceDisclaimer.php?resource=wms&id=".$WMS['id']."&languageCode=".$languageCode."&asTable=true");
-		$tou .= $touServiceConnector->file;
+		$touForWMS = $touServiceConnector->file;
+		//add only those who have no special tou defined -
+		if ($touForWMS != ''){
+			$tou .= $touForWMS;
 		//set the tou to be accepted - TODO maybe do this after the button which deletes the message window - from a ajax request.
 		$classTou->set('wms',$WMS['id']);
 if ($tou != "") {
-	$tou = "Die zu ladende Konfiguration enthält verschiedene Dienste " .
-			"mit folgenden Nutzungsbedigungen:<br>".$tou;
+	$tou = _mb("The configuration, which should be loaded, consists of different services which have the following terms of use:")."<br>".$tou;
 $resultObj["wmcTou"]["message"] = $tou;
Modified: trunk/mapbender/http/php/mod_getServiceDisclaimer.php
--- trunk/mapbender/http/php/mod_getServiceDisclaimer.php	2011-02-10 11:19:50 UTC (rev 7552)
+++ trunk/mapbender/http/php/mod_getServiceDisclaimer.php	2011-02-10 12:58:30 UTC (rev 7553)
@@ -308,14 +308,15 @@
 } else {
-	//if nothing about restrictions is defined
+	/*//if nothing about restrictions is defined
 	if ($asTable){
 		echo $tableBegin;
 		echo $t_a.$htmlHeader['noInformation'].$t_b.$t_c."<br>";
 		echo $tableEnd;
 	} else {
 		echo $htmlHeader['noInformation']."<br>" ;
+	echo "";//since it is not neccessary to give information about nothing ;-)
Modified: trunk/mapbender/http/php/mod_getWmcDisclaimer.php
--- trunk/mapbender/http/php/mod_getWmcDisclaimer.php	2011-02-10 11:19:50 UTC (rev 7552)
+++ trunk/mapbender/http/php/mod_getWmcDisclaimer.php	2011-02-10 12:58:30 UTC (rev 7553)
@@ -62,16 +62,19 @@
 		$translation['wmcDisclaimerHeader'] = 'Das vorliegende Dokument enthält Datenquellen von unterschiedlichen Stellen. Diese unterliegen den im folgenden aufgeführten Nutzungsbedingungen:';
 		$translation['wfs'] = "Datendienst";
+		$translation['noTouInformation'] = 'Es sind keine Informationen über Nutzungsbedingungen verfügbar!';
 		break;
 	case "en":
 		$translation['wmcDisclaimerHeader'] = 'The document includes data resources from different organizations. The following parapgraph shows the different terms of use for the includes resources:';
 		$translation['wms'] = "Web Map Service";
 		$translation['wfs'] = "Web Feature Service";
+		$translation['noTouInformation'] = 'No informations about terms of use are available!';
 		break;
 	default: #to english
@@ -106,8 +109,16 @@
 foreach($validWMS as $WMS) {
 	echo $resourceSymbol." <a href='".$mapbenderBaseUrl.$_SERVER['SCRIPT_NAME']."/../mod_showMetadata.php?resource=wms&layout=tabs&id=".$WMS['id']."&languageCode=".$languageCode."'>".$WMS['title']."</a><br>";
 	$touServiceConnector = new connector($mapbenderProtocol."localhost".$_SERVER['SCRIPT_NAME']."/../mod_getServiceDisclaimer.php?type=wms&id=".$WMS['id']."&languageCode=".$languageCode."&asTable=true");
-	$wmstou = $touServiceConnector->file;
+	if ($touForWMS == ''){
+		$wmstou = $translation['noTouInformation'];
+	} else {
+		$wmstou = $touForWMS;
+	//$wmstou = $touServiceConnector->file;
 	#$wmstou = file_get_contents("http://localhost/mapbender/php/mod_getServiceDisclaimer.php?resource=wms&id=".$WMS['id']."&languageCode=".$languageCode."&asTable=true");
 	echo $wmstou."<br>";
Modified: trunk/mapbender/http/php/mod_showMetadata.php
--- trunk/mapbender/http/php/mod_showMetadata.php	2011-02-10 11:19:50 UTC (rev 7552)
+++ trunk/mapbender/http/php/mod_showMetadata.php	2011-02-10 12:58:30 UTC (rev 7553)
@@ -169,6 +169,7 @@
 		$translation['graphicUnavailable'] = 'Grahische Übersicht nicht aktiviert';
 		$translation['notMonitored'] = 'Informationen über die Qualität sind nur verfügbar, wenn das Service Monitoring aktiv ist!';
 		$translation['wmcQualityText'] = 'Für Web Map Context Dokumente entfällt die Angabe zur Qualität!';
 		break;
 	case "en":
 		$translation['overview'] = 'Overview';
@@ -232,6 +233,7 @@
 		$translation['graphicUnavailable'] = 'Graphical Overview not active';
 		$translation['notMonitored'] = 'Information about Quality is only available if the service monitoring is activated!';
 		$translation['wmcQualityText'] = 'In case of Web Map Context Documents the Quality part is not applicable!';
 		break;
@@ -295,6 +297,7 @@
 //Array with infos about the different elements which are shown in the tabs
@@ -899,8 +902,11 @@
 	$touWmcConnector = new connector($mapbenderProtocol."localhost".$_SERVER['SCRIPT_NAME']."/../mod_getWmcDisclaimer.php?&id=".$resourceMetadata['contentid']."&languageCode=".$languageCode."&hostName=".$hostName);
 	$tou = $touWmcConnector->file;
-$html .= $tou;
+if ($tou == ''){
+	$html .= $translation['noTouInformation'];
+} else {
+	$html .= $tou;
 $html .= '</p>';
 $html .= '</div>';
 //**************************termsOfUse part end******************************
Modified: trunk/mapbender/http/plugins/wfsConfTree.js
--- trunk/mapbender/http/plugins/wfsConfTree.js	2011-02-10 11:19:50 UTC (rev 7552)
+++ trunk/mapbender/http/plugins/wfsConfTree.js	2011-02-10 12:58:30 UTC (rev 7553)
@@ -60,7 +60,7 @@
 		height: 600,
 		autoOpen: false,
 		buttons:{
-			translatedI18nObject.labelClose : function(){
+			"schliessen" : function(){
 					$(this).dialog("close");
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po	2011-02-10 11:19:50 UTC (rev 7552)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po	2011-02-10 12:58:30 UTC (rev 7553)
@@ -2224,4 +2224,25 @@
 msgid "Examples (first 20 entries):"
 msgstr "Beispielinhalte (erste 20 Datensätze):"
+#: ../http/javascripts/initWmcObj.php
+msgid "You as User"
+msgstr "Sie als Nutzer"
+msgid "have no authorization to access following layers."
+msgstr "haben keine Berechtigung auf folgende Layer zuzugreifen."
+msgid "Following layers come from an unkown origin. There is no information about the links. They may be broken and the underlaying services may not exist anymore!"
+msgstr "Folgende Layer stammen aus einer der Registry unbekannten Quelle. Es kann daher nicht überprüft werden, ob die Links verwaist sind oder ob die Dienste überhaupt Daten liefern."
+msgid "The last monitoring had problems with the following layers. Maybe the underlying services will not be able to answer the requests for sometime."
+msgstr "Bei folgenden Diensten kam es während des letzten Monitorings zu Problemen. Es ist möglich, dass diese Dienste derzeit keine Informationen zur Verfügung stellen können."
+msgid "Following layers have been removed from the registry. They may be broken and the underlaying services may not exist anymore!"
+msgstr "Folgende Dienste/Layer sind aus der Registrierungsstelle gelöscht worden. Es kann daher nicht überprüft werden, ob die Links verwaist sind oder ob die Dienste überhaupt Daten liefern."
+msgid "MapService"
+msgstr "Kartendienst"
+msgid "The configuration, which should be loaded, consists of different services which have the following terms of use:"
+msgstr "Die zu ladende Konfiguration enthält verschiedene Dienste mit folgenden Nutzungsbedigungen:"
More information about the Mapbender_commits mailing list
