[Mapbender-commits] r7566 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Fri Feb 11 10:40:08 EST 2011
Author: astrid_emde
Date: 2011-02-11 07:40:08 -0800 (Fri, 11 Feb 2011)
New Revision: 7566
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
new element feedTree in gui
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql 2011-02-11 13:26:20 UTC (rev 7565)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql 2011-02-11 15:40:08 UTC (rev 7566)
@@ -141,3 +141,15 @@
--deactivate OnEarth Web Map Server in gui_digitize
UPDATE gui_layer SET gui_layer_visible='0' where fkey_gui_id='gui_digitize' AND gui_layer_wms_id='640';
+-- feedTree to load GeoRSS or KML
+-- create a new tab in application gui to load georss
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'tabs', 'tab_frameHeight[8]', '240', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'tabs', 'tab_ids[8]', 'feedTree', '' ,'php_var');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','feedTree',2,1,'Displays a GeoRSS feed on the map','GeoRss','ul','','',1,1,1,1,NULL ,'visibility:hidden','','ul','../plugins/feedTree.js','../../lib/mb.ui.displayFeatures.js','mapframe1','jq_ui_widget','http://www.mapbender.org/Loadkmlgeorss');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'feedTree', 'styles', '../css/feedtree.css', '' ,'file/css');
More information about the Mapbender_commits
