[Mapbender-commits] r7576 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Feb 12 08:27:09 EST 2011
Author: astrid_emde
Date: 2011-02-12 05:27:09 -0800 (Sat, 12 Feb 2011)
New Revision: 7576
   trunk/mapbender/http/plugins/feedTree.js
added Natdocs docu
Modified: trunk/mapbender/http/plugins/feedTree.js
--- trunk/mapbender/http/plugins/feedTree.js	2011-02-12 13:10:29 UTC (rev 7575)
+++ trunk/mapbender/http/plugins/feedTree.js	2011-02-12 13:27:09 UTC (rev 7576)
@@ -1,3 +1,39 @@
+  * Package: feedTree
+  * Description:
+  * Module to load GeoRSS or KML temporary in a tree
+  * Files:
+  *  - mapbender/http/plugins/feedTree.js
+  *  - mapebnder/lib/mb.ui.displayFeatures.js
+  *  - mapbender/http/css/feedtree.css
+  * SQL:
+  * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,
+  * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+  * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>',
+  * > 'feedTree',2,1,'Displays a GeoRSS feed on the map','GeoRss','ul','','',1,1,200,200,NULL ,
+  * > 'visibility:visible','','ul','../plugins/feedTree.js','../../lib/mb.ui.displayFeatures.js',
+  * > 'mapframe1','jq_ui_widget','http://www.mapbender.org/Loadkmlgeorss');
+  * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+  * > VALUES('gui', 'feedTree', 'styles', '../css/feedtree.css', '' ,'file/css');
+  * Help:
+  * http://www.mapbender.org/Loadkmlgeorss
+  * Maintainer:
+  * http://www.mapbender.org/User:Karim_Malhas
+  * License:
+  * Copyright (c) 2009, Open Source Geospatial Foundation
+  * This program is dual licensed under the GNU General Public License
+  * and Simplified BSD license.
+  * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
 var $feedTree = $(this);
 var FeedTree = function(o){
 	$feedTree.children().remove();
More information about the Mapbender_commits mailing list
