[Mapbender-commits] r7627 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Feb 18 14:59:19 EST 2011
Author: marc
Date: 2011-02-18 11:59:19 -0800 (Fri, 18 Feb 2011)
New Revision: 7627
   trunk/mapbender/http/extensions/jquery.mousewheel.min.js
#781
Modified: trunk/mapbender/http/extensions/jquery.mousewheel.min.js
--- trunk/mapbender/http/extensions/jquery.mousewheel.min.js	2011-02-18 10:46:47 UTC (rev 7626)
+++ trunk/mapbender/http/extensions/jquery.mousewheel.min.js	2011-02-18 19:59:19 UTC (rev 7627)
@@ -1,16 +1,12 @@
-/* Copyright (c) 2006 Brandon Aaron (brandon.aaron at gmail.com || http://brandonaaron.net)
- * Dual licensed under the MIT (http://www.opensource.org/licenses/mit-license.php)
- * and GPL (http://www.opensource.org/licenses/gpl-license.php) licenses.
+/* Copyright (c) 2010 Brandon Aaron (http://brandonaaron.net)
+ * Licensed under the MIT License (LICENSE.txt).
  * Thanks to: http://adomas.org/javascript-mouse-wheel/ for some pointers.
  * Thanks to: Mathias Bank(http://www.mathias-bank.de) for a scope bug fix.
+ * Thanks to: Seamus Leahy for adding deltaX and deltaY
- * $LastChangedDate: 2007-12-14 23:57:10 -0600 (Fri, 14 Dec 2007) $
- * $Rev: 4163 $
+ * Version: 3.0.4
- * Version: 3.0
- * Requires: $ 1.2.2+
+ * Requires: 1.2.2+
-(function($){$.event.special.mousewheel={setup:function(){var handler=$.event.special.mousewheel.handler;if($.browser.mozilla)$(this).bind('mousemove.mousewheel',function(event){$.data(this,'mwcursorposdata',{pageX:event.pageX,pageY:event.pageY,clientX:event.clientX,clientY:event.clientY});});if(this.addEventListener)this.addEventListener(($.browser.mozilla?'DOMMouseScroll':'mousewheel'),handler,false);else
-this.onmousewheel=handler;},teardown:function(){var handler=$.event.special.mousewheel.handler;$(this).unbind('mousemove.mousewheel');if(this.removeEventListener)this.removeEventListener(($.browser.mozilla?'DOMMouseScroll':'mousewheel'),handler,false);else
-this.onmousewheel=function(){};$.removeData(this,'mwcursorposdata');},handler:function(event){var args=Array.prototype.slice.call(arguments,1);event=$.event.fix(event||window.event);$.extend(event,$.data(this,'mwcursorposdata')||{});var delta=0,returnValue=true;if(event.wheelDelta)delta=event.wheelDelta/120;if(event.detail)delta=-event.detail/3;if($.browser.opera)delta=-event.wheelDelta;event.data=event.data||{};event.type="mousewheel";args.unshift(delta);args.unshift(event);return $.event.handle.apply(this,args);}};$.fn.extend({mousewheel:function(fn){return fn?this.bind("mousewheel",fn):this.trigger("mousewheel");},unmousewheel:function(fn){return this.unbind("mousewheel",fn);}});})(jQuery);
\ No newline at end of file
+(function(c){var a=["DOMMouseScroll","mousewheel"];c.event.special.mousewheel={setup:function(){if(this.addEventListener){for(var d=a.length;d;){this.addEventListener(a[--d],b,false)}}else{this.onmousewheel=b}},teardown:function(){if(this.removeEventListener){for(var d=a.length;d;){this.removeEventListener(a[--d],b,false)}}else{this.onmousewheel=null}}};c.fn.extend({mousewheel:function(d){return d?this.bind("mousewheel",d):this.trigger("mousewheel")},unmousewheel:function(d){return this.unbind("mousewheel",d)}});function b(i){var g=i||window.event,f=[].slice.call(arguments,1),j=0,h=true,e=0,d=0;i=c.event.fix(g);i.type="mousewheel";if(i.wheelDelta){j=i.wheelDelta/120}if(i.detail){j=-i.detail/3}d=j;if(g.axis!==undefined&&g.axis===g.HORIZONTAL_AXIS){d=0;e=-1*j}if(g.wheelDeltaY!==undefined){d=g.wheelDeltaY/120}if(g.wheelDeltaX!==undefined){e=-1*g.wheelDeltaX/120}f.unshift(i,j,e,d);return c.event.handle.apply(this,f)}})(jQuery);
More information about the Mapbender_commits mailing list
