[Mapbender-commits] r7653 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Sat Feb 26 08:54:25 EST 2011
Author: astrid_emde
Date: 2011-02-26 05:54:25 -0800 (Sat, 26 Feb 2011)
New Revision: 7653
Added:
trunk/mapbender/http/php/mod_deleteCategory.php
new module to delete a category. Notice: all categories can be deleted no filter by user is implemented yet
Added: trunk/mapbender/http/php/mod_deleteCategory.php
--- trunk/mapbender/http/php/mod_deleteCategory.php (rev 0)
+++ trunk/mapbender/http/php/mod_deleteCategory.php 2011-02-26 13:54:25 UTC (rev 7653)
@@ -0,0 +1,102 @@
+<?php
+# $Id:
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+$e_id="deleteCategory";
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+ * @security_patch irv done
+//security_patch_log(__FILE__,__LINE__);
+$categoryList=$_POST["categoryList"];
+$del=$_POST["del"];
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Delete Category</title>
+<?php
+include '../include/dyn_css.php';
+<script type="text/javascript">
+function validate(){
+ var ind = document.form1.categoryList.selectedIndex;
+ if(ind > -1){
+ var permission = confirm("delete: " + document.form1.categoryList.options[ind].text + " ?");
+ if(permission == true){
+ document.form1.del.value = 1;
+ document.form1.submit();
+</script>
+</head>
+<body>
+<?php
+###delete
+if($del){
+ $sql = "DELETE FROM gui_category WHERE category_name = $1";
+ $v = array($categoryList);
+ $t = array('s');
+ $res = db_prep_query($sql,$v,$t);
+ $v = array();
+ $t = array();
+ $sql = "SELECT * from gui_category";
+ $sql .= " order by category_name";
+ $cnt = 0;
+ echo "<form name='form1' action='" . $self ."' method='post'>";
+ echo "<select size='20' style='width:400px' name='categoryList' class='categoryList' onchange='document.form1.categoryList.value = this.value;submit()'>";
+ while($row = db_fetch_array($res)){
+ $categoryvalue = $row["category_name"];
+ //mark previously selected GUI <==> text = " selected"
+ if ($categoryvalue == $categoryList) {
+ $text = " selected";
+ else {
+ $text = "";
+ echo "<option value='".$categoryvalue."'" . $text . ">".$row["category_name"]."(".$row["category_description"].")</option>";
+ $cnt++;
+ echo "</select><br>";
+ if($cnt>0){
+ echo "<input class='button_del' type='button' value='delete' onclick='validate()'>";
+ }else{
+ echo "There are no categories available.";
+ echo "<input type='hidden' name='del'>";
+ echo "</form>";
+</body>
+</html>
More information about the Mapbender_commits
