[Mapbender-commits] r7657 - in trunk/mapbender: http/classes http/php http_auth/http
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun Feb 27 11:20:53 EST 2011
Author: armin11
Date: 2011-02-27 08:20:53 -0800 (Sun, 27 Feb 2011)
New Revision: 7657
   trunk/mapbender/http/classes/class_administration.php
   trunk/mapbender/http/php/wms.php
   trunk/mapbender/http_auth/http/index.php
Bugfix
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php	2011-02-27 12:32:08 UTC (rev 7656)
+++ trunk/mapbender/http/classes/class_administration.php	2011-02-27 16:20:53 UTC (rev 7657)
@@ -1218,12 +1218,11 @@
 	function getLayerPermission($wms_id, $layer_name, $user_id){
 		//prohibit problems with layer names
 		$layer_name = urldecode($layer_name);
+		$layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
 		if (!is_int($layer_id)) {//TODO: do this also in User->isLayerAccessible
-			$e = new mb_exception("No id for the requested layer with name '".$layer_name."' found in database!");
+			$e = new mb_exception("No id for the requested layer with name ".$layer_name." found in database!");
 			return false;
-		$layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
 		$array_guis = $this->getGuisByPermission($user_id,true);
 		$v = array();
 		$t = array();
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php	2011-02-27 12:32:08 UTC (rev 7656)
+++ trunk/mapbender/http/php/wms.php	2011-02-27 16:20:53 UTC (rev 7657)
@@ -1,1040 +1,1104 @@
-<?php
-# $Id: mb_listGUIs.php 11 2006-07-31 16:22:36Z rothstein $
-# http://www.mapbender.org/index.php/mb_listGUIs.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__)."/../classes/class_layer_monitor.php");
-//ob_start(); //TODO why?
-// make all parameters available as upper case
-foreach($_GET as $key => $val) {
-	$_GET[strtoupper($key)] = $val;
-$requestType = $_GET["REQUEST"];
-$version = $_GET["VERSION"];
-$service = strtoupper($_GET["SERVICE"]);
-$layerId = $_GET["LAYER_ID"];
-$updateSequence = intval($_GET["UPDATESEQUENCE"]);
-//$mapbenderMetadataUrl = preg_replace("/(.*)frames\/login.php/", "$1php/mod_showMetadata.php?resource=layer&id=", LOGIN);
-$mapbenderMetadaUrl = $_SERVER['HTTP_HOST']."/mapbender/php/mod_showMetadata.php?resource=layer&id=";
-if (isset($_SERVER["HTTPS"])){
-	$urlPrefix = "https://";
-} else {
-	$urlPrefix = "http://";
-$mapbenderMetadataUrl = $urlPrefix.$mapbenderMetadataUrl;
- * Creates an XML Exception according to WMS 1.1.1
- * @return an XML String
- * @param $errorCode String
- * @param $errorMessage String
-function createExceptionXml ($errorCode, $errorMessage) {
-	// see http://de2.php.net/manual/de/domimplementation.createdocumenttype.php
-	$imp = new DOMImplementation;
-	$dtd = $imp->createDocumentType("ServiceExceptionReport", "", "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd");
-	$doc = $imp->createDocument("", "", $dtd);
-	$doc->encoding = 'UTF-8';
-	$doc->standalone = false;
-	$el = $doc->createElement("ServiceExceptionReport");
-	$exc = $doc->createElement("ServiceException", $errorMessage);
-	if ($errorCode) {
-		$exc->setAttribute("code", $errorCode);
-	$el->appendChild($exc);
-	$doc->appendChild($el);
-	return $doc->saveXML();
-// check if service param is set
-if (!isset($service) || $service === "" || $service != "WMS") {
-	header("Content-type: application/xhtml+xml; charset=UTF-8");
-	echo createExceptionXml("", "Parameter SERVICE invalid");
-	die;
-// check if request param is set
-if (!isset($requestType) || $requestType === "" ||
-	($service == "WMS" && $requestType != "GetCapabilities")) {
-	echo createExceptionXml("", "Parameter REQUEST invalid");
-	die;
-// check if version param is set
-if (!isset($version) || $version === "" ||
-	($service == "WMS" && $version != "1.1.1")) {
-	// optional parameter, set to 1.1.1 if not set
-	$version = "1.1.1";
-// check if layer id is set
-if (!isset($layerId) || !is_numeric($layerId)) {
-	// TO DO: create exception XML
-		"Layer not defined",
-		"Unknown layer id " . $layerId
-	die;
-// check if layer is stored in database
-$wms_sql = "SELECT * FROM wms AS w, layer AS l " .
-	"where l.layer_id = $1 AND l.fkey_wms_id = w.wms_id LIMIT 1";
-$v = array($layerId);
-$t = array("i");
-$res_wms_sql = db_prep_query($wms_sql, $v, $t);
-$wms_row = db_fetch_array($res_wms_sql);
-if (!$wms_row["wms_id"]) {
-	die;
-// check if update sequence is valid
-$updateSequenceDb = intval($wms_row["wms_timestamp"]);
-if ($updateSequence) {
-	if ($updateSequence > $updateSequenceDb) {
-		// Exception: code=InvalidUpdateSequence
-		echo createExceptionXml("InvalidUpdateSequence", "Invalid update sequence");
-		die;
-	else if ($updateSequence == $updateSequenceDb) {
-		// Exception: code=CurrentUpdateSequence
-		echo createExceptionXml("CurrentUpdateSequence", "Current update sequence");
-		die;
-// increment layer count
-$monitor = new Layer_load_count();
-$monitor->increment($layerId);
-// START TO CREATE CAPABILITIES DOC
-// (return most recent Capabilities XML)
-$doc = new DOMDocument('1.0');
-$doc->encoding = 'UTF-8';
-$doc->standalone = false;
-#Check for existing content in database
-#to be adopted TODO armin
-function validate ($contactInformation_column) {
-    if ($contactInformation_column <> "" AND $contactInformation_column <> NULL) {
-             $contactinformationcheck = true;
-    else {
-		$contactinformationcheck = false;
-	return $contactinformationcheck;
-#Creating the "WMT_MS_Capabilities" node
-$wmt_ms_capabilities = $doc->createElement("WMT_MS_Capabilities");
-$wmt_ms_capabilities->setAttribute("updateSequence", $wms_row["wms_timestamp"]);
-$wmt_ms_capabilities = $doc->appendChild($wmt_ms_capabilities);
-$wmt_ms_capabilities->setAttribute('version', '1.1.1');
-#Creatig the "Service" node
-$service = $doc->createElement("Service");
-$service = $wmt_ms_capabilities->appendChild($service);
-#Creating the "Name" Node
-$name = $doc->createElement("Name");
-$name = $service->appendChild($name);
-$nameText = $doc->createTextNode("OGC:WMS");
-$nameText = $name->appendChild($nameText);
-#Creating the "Title" node
-if($wms_row['wms_title'] <> "" AND $wms_row['wms_title'] <> NULL) {
-    $title = $doc->createElement("Title");
-	$title = $service->appendChild($title);
-	$titleText = $doc->createTextNode($wms_row['wms_title']);
-	$titleText = $title->appendChild($titleText);
-#Creating the "Abstract" node
-if($wms_row['wms_abstract'] <> "" AND $wms_row['wms_abstract'] <> NULL) {
-	$abstract = $doc->createElement("Abstract");
-	$abstract = $service->appendChild($abstract);
-	$abstractText = $doc->createTextNode($wms_row['wms_abstract']);
-	$abstractText = $abstract->appendChild($abstractText);
-# switch URLs for OWSPROXY
-if($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL) {
-	$tmpOR = $urlPrefix.$_SERVER["HTTP_HOST"]."/owsproxy/".session_id()."/".$wms_row["wms_owsproxy"]."?";
-	$tmpOR = str_replace(SERVERIP, SERVERNAME, $tmpOR);
-	$wms_row['wms_getcapabilities'] = $tmpOR;
-	$wms_row['wms_getmap'] = $tmpOR;
-	$wms_row['wms_getfeatureinfo'] = $tmpOR;
-#Creating the "OnlineResource" node
-//if($wms_row['wms_getcapabilities'] <> "" AND $wms_row['wms_getcapabilities'] <> NULL) {
-    $onlineResource = $doc->createElement("OnlineResource");
-	$onlineResource = $service->appendChild($onlineResource);
-	$onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink" );
-//	$onlineResource->setAttribute("xlink:href", $wms_row['wms_getcapabilities']);
-	$onlRes = $_SERVER["HTTP_HOST"] . $_SERVER["SCRIPT_NAME"] . "?layer_id=" . $layerId."&".session_name()."=".session_id();
-	if (isset($_SERVER["HTTPS"])) {
-		$onlRes = "https://" . $onlRes;
-	else {
-		$onlRes = "http://" . $onlRes;
-	$onlineResource->setAttribute("xlink:href", $onlRes);
-	$onlineResource->setAttribute("xlink:type", "simple");
-#Insert contact information
-#Creating "Contact Information" node
-if (validate($wms_row['contactperson']) &&
-	validate($wms_row['contactorganization']) &&
-	validate($wms_row['contactposition']) &&
-	validate($wms_row['address']) &&
-	validate($wms_row['city']) &&
-	validate($wms_row['stateorprovince']) &&
-	validate($wms_row['postcode']) /*AND validate($wms_row['country'])*/ &&
-	validate($wms_row['contactvoicetelephone']) &&
-	validate($wms_row['contactfacsimiletelephone']) &&
-	validate($wms_row['contactelectronicmailaddress']))
-$contactInformation = $doc->createElement("ContactInformation");
-$contactInformation = $service->appendChild($contactInformation);
-#Creating "Contact Person Primary" node
-if(validate($wms_row['contactperson']) AND validate($wms_row['contactorganization']))
-$contactPersonPrimary = $doc->createElement("ContactPersonPrimary");
-$contactPersonPrimary = $contactInformation->appendChild($contactPersonPrimary);
-#Creating the "ContactPerson" node
-if(validate($wms_row['contactperson']))
-    $contactPerson = $doc->createElement("ContactPerson");
-    $contactPerson = $contactPersonPrimary->appendChild($contactPerson);
-    $contactPersonText = $doc->createTextNode($wms_row['contactperson']);
-    $contactPersonText = $contactPerson->appendChild($contactPersonText);
-#Creating the "ContactOrganization" node
-if(validate($wms_row['contactorganization']))
-    $contactOrganization = $doc->createElement("ContactOrganization");
-    $contactOrganization = $contactPersonPrimary->appendChild($contactOrganization);
-    $contactOrganizationText = $doc->createTextNode($wms_row['contactorganization']);
-    $contactOrganizationText = $contactOrganization->appendChild($contactOrganizationText);
-#Creating the "ContactPosition" node
-if(validate($wms_row['contactposition']))
-    $contactPosition = $doc->createElement("ContactPosition");
-    $contactPosition = $contactInformation->appendChild($contactPosition);
-    $contactPositionText = $doc->createTextNode($wms_row['contactposition']);
-    $contactPositionText = $contactPosition->appendChild($contactPositionText);
-#Creating "ContactAddress" node
-if(validate($wms_row['address']) AND validate($wms_row['city']) AND validate($wms_row['stateorprovince']) AND               validate($wms_row['postcode']) /*AND validate($wms_row['country'])*/)
-$contactAddress = $doc->createElement("ContactAddress");
-$contactAddress = $contactInformation->appendChild($contactAddress);
-#Creating the "AddressType" and "Address" textnode
-if(validate($wms_row['address']))
-    $addressType = $doc->createElement("AddressType");
-    $addressType = $contactAddress->appendChild($addressType);
-    $addresstypeText = $doc->createTextNode("postal");
-    $addresstypeText = $addressType->appendChild($addresstypeText);
-    $address = $doc->createElement("Address");
-    $address = $contactAddress->appendChild($address);
-    $addressText = $doc->createTextNode($wms_row['address']);
-    $addressText = $address->appendChild($addressText);
-#Creatig the "City" node
-if(validate($wms_row['city']))
-    $city = $doc->createElement("City");
-    $city = $contactAddress->appendChild($city);
-    $cityText = $doc->createTextNode($wms_row['city']);
-    $cityText = $city->appendChild($cityText);
-#Creatig the "StateOrProvince" node
-if(validate($wms_row['stateorprovince']))
-    $stateOrProvince = $doc->createElement("StateOrProvince");
-    $stateOrProvince = $contactAddress->appendChild($stateOrProvince);
-    $stateOrProvinceText = $doc->createTextNode($wms_row['stateorprovince']);
-    $stateOrProvinceText = $stateOrProvince->appendChild($stateOrProvinceText);
-#Creatig the "PostCode" node
-if(validate($wms_row['postcode']))
-    $postCode = $doc->createElement("PostCode");
-    $postCode = $contactAddress->appendChild($postCode);
-    $postCodeText = $doc->createTextNode($wms_row['postcode']);
-    $postCodeText = $postCode->appendChild($postCodeText);
-#Creatig the "Country" node
-if(isset($wms_row['country']) AND validate($wms_row['country']))
-    $country = $doc->createElement("Country");
-    $country = $contactAddress->appendChild($country);
-    $countryText = $doc->createTextNode($wms_row['country']);
-    $countryText = $country->appendChild($countryText);
-#Creatig the "ContactVoiceTelephone" node
-if(validate($wms_row['contactvoicetelephone']))
-    $contactVoiceTelephone = $doc->createElement("ContactVoiceTelephone");
-    $contactVoiceTelephone = $contactInformation->appendChild($contactVoiceTelephone);
-    $contactVoiceTelephoneText = $doc->createTextNode($wms_row['contactvoicetelephone']);
-    $contactVoiceTelephoneText = $contactVoiceTelephone->appendChild($contactVoiceTelephoneText);
-#Creatig the "ContactFacsimileTelephone" node
-if(validate($wms_row['contactfacsimiletelephone']))
-    $contactFacsimileTelephone = $doc->createElement("ContactFacsimileTelephone");
-    $contactFacsimileTelephone = $contactInformation->appendChild($contactFacsimileTelephone);
-    $contactFacsimileTelephoneText = $doc->createTextNode($wms_row['contactfacsimiletelephone']);
-    $contactFacsimileTelephoneText = $contactFacsimileTelephone->appendChild($contactFacsimileTelephoneText);
-#Creatig the "ContactElectronicMailAddress" node
-if(validate($wms_row['contactelectronicmailaddress']))
-    $contactElectronicMailAddress = $doc->createElement("ContactElectronicMailAddress");
-    $contactElectronicMailAddress = $contactInformation->appendChild($contactElectronicMailAddress);
-    $contactElectronicMailAddressText = $doc->createTextNode($wms_row['contactelectronicmailaddress']);
-    $contactElectronicMailAddressText = $contactElectronicMailAddress->appendChild($contactElectronicMailAddressText);
-#Creatig the "Fees" node
-if(validate($wms_row['fees']))
-    $fees = $doc->createElement("Fees");
-    $fees = $service->appendChild($fees);
-    $feesText = $doc->createTextNode($wms_row['fees']);
-    $feesText = $fees->appendChild($feesText);
-#Creating the "AccessConstraints" node
-if(validate($wms_row['accessconstraints']))
-	$accessConstraints = $doc->createElement("AccessConstraints");
-    $accessConstraints = $service->appendChild($accessConstraints);
-    $accessConstraintsText = $doc->createTextNode($wms_row['accessconstraints']);
-    $accessConstraintsText = $accessConstraints->appendChild($accessConstraintsText);
-#Creatig the "Capability" node
-$capability = $doc->createElement("Capability");
-$capability = $wmt_ms_capabilities->appendChild($capability);
-#Creatig the "Request" node
-$request = $doc->createElement("Request");
-$request = $capability->appendChild($request);
-#GetCapabilities
-#Creatig the "GetCapabilities" node
-$getCapabilities = $doc->createElement("GetCapabilities");
-$getCapabilities = $request->appendChild($getCapabilities);
-#Creatig the "Format" node
-$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'capability'";
-$v = array($wms_row['wms_id']);
-$t = array("i");
-$res_wms_format_sql = db_prep_query($wms_format_sql, $v, $t);
-while ($wms_format_row = db_fetch_array($res_wms_format_sql)) {
-    $format = $doc->createElement("Format");
-    $format = $getCapabilities->appendChild($format);
-    $formatText = $doc->createTextNode($wms_format_row['data_format']);
-    $formatText = $format->appendChild($formatText);
-#cause the format for capabilities is not read :
-    $formatText = $doc->createTextNode('application/vnd.ogc.wms_xml');
-#Creating the "DCPType" node
-$DCPType = $doc->createElement("DCPType");
-$DCPType = $getCapabilities->appendChild($DCPType);
-#Creating the "HTTP" node
-$HTTP = $doc->createElement("HTTP");
-$HTTP = $DCPType->appendChild($HTTP);
-#Creating the "Get" node
-$get = $doc->createElement("Get");
-$get = $HTTP->appendChild($get);
-//if ($wms_row['wms_getcapabilities'] <> "" AND $wms_row['wms_getcapabilities'] <> NULL) {
-	$onlineResource = $get->appendChild($onlineResource);
-	$onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
-	$onlRes = $_SERVER["HTTP_HOST"] . $_SERVER["SCRIPT_NAME"] . "?layer_id=" . $layerId;
-	else {
-#Creating the "Post" node
-$post = $doc->createElement("Post");
-$post = $HTTP->appendChild($post);
-	$onlineResource = $post->appendChild($onlineResource);
-	else {
-#GetMap
-#Creatig the "GetMap" node
-$getMap = $doc->createElement("GetMap");
-$getMap = $request->appendChild($getMap);
-$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'map'";
-$t = array("i");
-    $format = $getMap->appendChild($format);
-$DCPType = $getMap->appendChild($DCPType);
-if ($wms_row['wms_getmap'] <> "" AND $wms_row['wms_getmap'] <> NULL) {
-	$onlineResource->setAttribute("xlink:href", $wms_row['wms_getmap']);
-if($wms_row['wms_getmap'] <> "" AND $wms_row['wms_getmap'] <> NULL) {
-#GetFeatureInfo
-#Creatig the "GetFeatureInfo" node
-$getFeatureInfo = $doc->createElement("GetFeatureInfo");
-$getFeatureInfo = $request->appendChild($getFeatureInfo);
-$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'featureinfo'";
-$t = array("i");
-    $format = $getFeatureInfo->appendChild($format);
-$DCPType = $getFeatureInfo->appendChild($DCPType);
-if($wms_row['wms_getfeatureinfo'] <> "" AND $wms_row['wms_getfeatureinfo'] <> NULL)
-	$onlineResource->setAttribute("xlink:href", $wms_row['wms_getfeatureinfo']);
-if($wms_row['wms_getfeatureinfo'] <> "" AND $wms_row['wms_getfeatureinfo'] <> NULL) {
-#Creating the "Exeption" node
-$exception = $doc->createElement("Exception");
-$exception = $capability->appendChild($exception);
-$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'exception'";
-$t = array("i");
-    $format = $exception->appendChild($format);
-#Querying layer table
-$layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = $1 AND layer.layer_parent = ''";
-$t = array("i");
-$res_layer_sql = db_prep_query($layer_sql, $v, $t);
-$layer_row = db_fetch_array($res_layer_sql);
-#Creating layer node
-$layer = $doc->createElement("Layer");
-$layer = $capability->appendChild($layer);
-#Write layer to parent layer array
-$parentLayerArray[$layer_row['layer_pos']] = $layer;
-#Creating Name node
-if ($layer_row['layer_name'] <> "" AND $layer_row['layer_name'] <> NULL) {
-	$name = $doc->createElement("Name");
-	$name = $layer->appendChild($name);
-	$nameText = $doc->createTextNode($layer_row['layer_name']);
-	$nameText = $name->appendChild($nameText);
-#Creating Title node
-if ($layer_row['layer_title'] <> "" AND $layer_row['layer_title'] <> NULL) {
-	$title = $layer->appendChild($title);
-	$titleText = $doc->createTextNode($layer_row['layer_title']);
-if($layer_row['layer_abstract'] <> "" AND $layer_row['layer_abstract'] <> NULL) {
-    $abstract = $layer->appendChild($abstract);
-    $abstractText = $doc->createTextNode($layer_row['layer_abstract']);
-#Request the specific wms- and layerkeywords
-$keyword_sql = "SELECT DISTINCT keyword FROM keyword, layer_keyword, layer " .
-	"WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
-	"AND layer_keyword.fkey_layer_id = layer.layer_id " .
-	"AND layer.fkey_wms_id = $1";
-$t = array("i");
-$res_keyword_sql = db_prep_query($keyword_sql, $v, $t);
-#Creating list of keyword nodes
-#Iterating over a List of Keywords
-$keywordlistExist = 0;
-while ($keyword_sql = db_fetch_array($res_keyword_sql))
-    #Creating the "KeywordList" node
-    if ($keywordlistExist == 0) {
-        $keywordList = $doc->createElement("KeywordList");
-        $keywordList = $layer->appendChild($keywordList);
-		$keywordlistExist = 1;
-    #Creating the "Keyword" node
-    $keyword_dom = $doc->createElement("Keyword");
-    $keyword_dom = $keywordList->appendChild($keyword_dom);
-    $keyword_domText = $doc->createTextNode($keyword_sql['keyword']);
-    $keyword_domText = $keyword_dom->appendChild($keyword_domText);
-#SQL statement to get additional layer information from layer epsg
-$epsg_sql = "SELECT layer_epsg.epsg, layer_epsg.minx, layer_epsg.miny, " .
-	"layer_epsg.maxy, layer_epsg.maxx " .
-	"FROM layer_epsg WHERE layer_epsg.fkey_layer_id = $1";
-$v = array($layer_row['layer_id']);
-$t = array("i");
-$res_espg_sql = db_prep_query($epsg_sql, $v, $t);
-$latLonBoundingBoxCreated = false;
-$BoundingBoxCreated = false;
-while ($epsg_row = db_fetch_array($res_espg_sql)) {
-	#Creating SRS node
-	$srs = $doc->createElement("SRS");
-	$srs = $layer->appendChild($srs);
-	$srsText = $doc->createTextNode($epsg_row['epsg']);
-	$srsText = $srs->appendChild($srsText);
-$t = array("i");
-	#set only epsg 4326 for latlonbbox
-	if ($epsg_row['epsg'] == "EPSG:4326") {
-		$latlon['minx'] = $epsg_row['minx'];
-		$latlon['miny'] = $epsg_row['miny'];
-		$latlon['maxx'] = $epsg_row['maxx'];
-		$latlon['maxy'] = $epsg_row['maxy'];
-		#Creating LatLongBoundingBox node
-		$latLonBoundingBox = $doc->createElement("LatLonBoundingBox");
-		$latLonBoundingBox = $layer->appendChild($latLonBoundingBox);
-		$latLonBoundingBox->setAttribute('minx', $latlon['minx']);
-		$latLonBoundingBox->setAttribute('miny', $latlon['miny']);
-		$latLonBoundingBox->setAttribute('maxx', $latlon['maxx']);
-		$latLonBoundingBox->setAttribute('maxy', $latlon['maxy']);
-	    break;
-$t = array("i");
-	#set only first epsg for bbox
-	$bbox['epsg'] = $epsg_row['epsg'];
-	$bbox['minx'] = $epsg_row['minx'];
-	$bbox['miny'] = $epsg_row['miny'];
-	$bbox['maxx'] = $epsg_row['maxx'];
-	$bbox['maxy'] = $epsg_row['maxy'];
-	#Creating BoundingBox node
-	$boundingBox = $doc->createElement("BoundingBox");
-	$boundingBox = $layer->appendChild($boundingBox);
-	$boundingBox->setAttribute('SRS', $bbox['epsg']);
-	$boundingBox->setAttribute('minx', $bbox['minx']);
-	$boundingBox->setAttribute('miny', $bbox['miny']);
-	$boundingBox->setAttribute('maxx', $bbox['maxx']);
-	$boundingBox->setAttribute('maxy', $bbox['maxy']);
-#Append epsg string to srs node
-$srsText = $doc->createTextNode($epsgText);
-$srsText = $srs->appendChild($srsText);
-####### duplicate root layer
-#if layer is root layer itself!
-#<armin>
-##if ($layer_row['layer_pos']=='0'){
-#</armin>
-##$clonedLayer = $layer->cloneNode(true);
-##$clonedLayer->setAttribute("queryable", "0");
-##$clonedLayer->setAttribute("cascaded", "0");
-##$layer->appendChild($clonedLayer);
-#<armin>
-#</armin>
-############## sublayer
-#SQL statement to get all layers
-$sub_layer_sql = "SELECT * FROM layer WHERE fkey_wms_id = $1 AND layer_parent <> ''";
-$t = array("i");
-if (isset($layerId) && $layerId > 0) {
-	$sub_layer_sql .= " AND layer_id = $2";
-	array_push($v, $layerId);
-	array_push($t, "i");
-$sub_layer_sql .= " ORDER BY layer_pos";
-$res_sub_layer_sql = db_prep_query($sub_layer_sql, $v, $t);
-#<armin>
-$res_sub_layer_sql_2 = db_prep_query($sub_layer_sql, $v, $t);
-$sub_layer_row_2 = db_fetch_array($res_sub_layer_sql_2);
-if (!isset($sub_layer_row_2['layer_pos'])) {
-	$clonedLayer = $layer->cloneNode(true);
-	$clonedLayer->setAttribute("queryable", "0");
-	$clonedLayer->setAttribute("cascaded", "0");
-	$layer->appendChild($clonedLayer);
-#</armin>
-while ($sub_layer_row = db_fetch_array($res_sub_layer_sql)) {
-	#Creating layer node
-	$sub_layer = $doc->createElement("Layer");
-	$parent = $parentLayerArray[$sub_layer_row['layer_parent']];
-	$sub_layer = $parent->appendChild($sub_layer);
-    if($sub_layer_row['layer_queryable'] <> "" AND $sub_layer_row['layer_queryable'] <> NULL) {
-		$sub_layer->setAttribute('queryable', $sub_layer_row['layer_queryable']);
-	#Getting information about the hierarchie of layers
-	$cascadeSQL = "SELECT COUNT(*) FROM layer WHERE fkey_wms_id = $1 AND layer_parent = $2";
-	$v = array($wms_row[0], $sub_layer_row['layer_pos']);
-	$t = array("i", "i");
-	$res_cascadeSQL = db_prep_query($cascadeSQL, $v, $t);
-	$cascade = 0;
-	$cascade_row = db_fetch_row($res_cascadeSQL);
-	if($cascade_row[0] > 0)	{
-		$cascade = 1;
-	$sub_layer->setAttribute('cascaded', $cascade);
-	#Write layer to parent layer array
-	$parentLayerArray[$sub_layer_row['layer_pos']] = $sub_layer;
-	#Creating name node
-    if($sub_layer_row['layer_name'] <> "" AND $sub_layer_row['layer_name'] <> NULL)
-		$name = $sub_layer->appendChild($name);
-		$nameText = $doc->createTextNode($sub_layer_row['layer_name']);
-	#Creating Title node
-    if($sub_layer_row['layer_title'] <> "" AND $sub_layer_row['layer_title'] <> NULL)
-		$title = $sub_layer->appendChild($title);
-		$titleText = $doc->createTextNode($sub_layer_row['layer_title']);
-		#Creating the "Abstract" node
-    if($sub_layer_row['layer_abstract'] <> "" AND $sub_layer_row['layer_abstract'] <> NULL)
-    	$abstract = $sub_layer->appendChild($abstract);
-    	$abstractText = $doc->createTextNode($sub_layer_row['layer_abstract']);
-    #Request the specific wms- and layerkeywords
-    $keyword_sql = "SELECT DISTINCT keyword FROM layer LEFT JOIN layer_keyword ON layer_keyword.fkey_layer_id = layer.layer_id LEFT JOIN keyword ON  keyword.keyword_id = layer_keyword.fkey_keyword_id WHERE layer.fkey_wms_id = ".$wms_row['wms_id']." AND layer.layer_id = ".$sub_layer_row['layer_id']."";
-    $res_keyword_sql = db_query($keyword_sql);
-    #Creating list of keyword nodes
-    #Iterating over a List of Keywords
-    $keywordlistExist = 0;
-    while ($keyword_sql = db_fetch_array($res_keyword_sql))
-            $keywordList = $sub_layer->appendChild($keywordList);
-	// inherit srs from parent layer
-	$layer_srs_sql = "SELECT DISTINCT epsg FROM layer_epsg " .
-			"WHERE fkey_layer_id = ".$sub_layer_row['layer_id'] .
-			" OR fkey_layer_id = " . $layer_row['layer_id'];
-	$res_layer_srs_sql = db_query($layer_srs_sql);
-	while ($layer_srs_row = db_fetch_array($res_layer_srs_sql)) {
-		$srs = $sub_layer->appendChild($srs);
-		$srsText = $doc->createTextNode($layer_srs_row['epsg']);
-	#SQL statement to get additional layer information from layer epsg
-	$epsg_sql = "SELECT layer_epsg.epsg, layer_epsg.minx, layer_epsg.miny, " .
-			"layer_epsg.maxy, layer_epsg.maxx FROM layer_epsg " .
-			"WHERE layer_epsg.fkey_layer_id = ".$sub_layer_row['layer_id'];
-	$res_espg_sql = db_query($epsg_sql);
-	while ($epsg_row = db_fetch_array($res_espg_sql)) {
-		#set epsg 4326 for latlonbbox
-		if ($epsg_row['epsg'] == "EPSG:4326" AND $latLonBoundingBoxCreated == false) {
-		    $latLonBoundingBox = $sub_layer->appendChild($latLonBoundingBox);
-		$boundingBox = $sub_layer->appendChild($boundingBox);
-	# Creating Metadata Node
-	$metadataUrl = $doc->createElement("MetadataURL");
-	$metadataUrl = $sub_layer->appendChild($metadataUrl);
-	$metadataUrl->setAttribute('type', "TC211");
-    $format = $metadataUrl->appendChild($format);
-    $formatText = $doc->createTextNode('text/html');
-	if ($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL) {
-	   	$onlineResource = $metadataUrl->appendChild($onlineResource);
-		$onlineResource->setAttribute("xlink:href", OWSPROXY."/".session_id()."/".$wms_row["wms_owsproxy"]."?");
-	else {
-		if ($sub_layer_row['layer_metadataurl'] <> "" AND $sub_layer_row['layer_metadataurl'] <> NULL) {
-			$onlineResource->setAttribute("xlink:href", $sub_layer_row['layer_metadataurl']);
-else
-	# Creating DataURL Node
-	$dataUrl = $doc->createElement("DataURL");
-	$dataUrl = $sub_layer->appendChild($dataUrl);
-    $format = $dataUrl->appendChild($format);
-	if($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL)
-	   	$onlineResource = $dataUrl->appendChild($onlineResource);
-	else
-		if($sub_layer_row['layer_dataurl'] <> "" AND $sub_layer_row['layer_dataurl'] <> NULL)
-			$onlineResource->setAttribute("xlink:href", $sub_layer_row['layer_dataurl']);
-else
-                        $onlineResource->setAttribute("xlink:href", $mapbenderMetadataUrl.$sub_layer_row['layer_id']);
-	#Creating Style Node
-	$style = $doc->createElement("Style");
-	$style = $sub_layer->appendChild($style);
-    $name = $style->appendChild($name);
-    $nameText = $doc->createTextNode('default');
-    $title = $style->appendChild($title);
-    $titleText = $doc->createTextNode('default');
-    if($wms_row['wms_getlegendurl'] <> "" AND $wms_row['wms_getlegendurl'] <> NULL){
-	$legendUrl = $doc->createElement("LegendURL");
-	$legendUrl = $style->appendChild($legendUrl);
-	$legendUrl->setAttribute("width", "10" );
-	$legendUrl->setAttribute("height", "8" );
-    $format = $legendUrl->appendChild($format);
-    $formatText = $doc->createTextNode('image/png');
-	   	$onlineResource = $legendUrl->appendChild($onlineResource);
-		$onlineResource->setAttribute("xlink:href", OWSPROXY."/".session_id()."/".$wms_row["wms_owsproxy"]."?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=".$sub_layer_row['layer_name']."&format=image/png");
-	else
-			$onlineResource->setAttribute("xlink:href", $wms_row['wms_getlegendurl']."version=1.1.1&service=WMS&request=GetLegendGraphic&layer=".$sub_layer_row['layer_name']."&format=image/png");
-	#Creating "ScaleHint" node
-    if ($sub_layer_row['layer_minscale'] <> "" AND $sub_layer_row['layer_minscale'] <> NULL) {
-		$scaleHint = $doc->createElement("ScaleHint");
-		$scaleHint = $sub_layer->appendChild($scaleHint);
-		$scaleHint->setAttribute('min', (floatval($sub_layer_row['layer_minscale'])/2004.3976484406788493955738891127));
-		$scaleHint->setAttribute('max', (floatval($sub_layer_row['layer_maxscale'])/2004.3976484406788493955738891127));
-header("Content-type: application/xml; charset=UTF-8");
-echo ltrim(" ",$doc->saveXml());
+<?php
+# $Id: mb_listGUIs.php 11 2006-07-31 16:22:36Z rothstein $
+# http://www.mapbender.org/index.php/mb_listGUIs.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_layer_monitor.php");
+// make all parameters available as upper case
+foreach($_GET as $key => $val) {
+	$_GET[strtoupper($key)] = $val;
+$requestType = $_GET["REQUEST"];
+$version = $_GET["VERSION"];
+$service = strtoupper($_GET["SERVICE"]);
+$layerId = $_GET["LAYER_ID"];
+$updateSequence = intval($_GET["UPDATESEQUENCE"]);
+$mapbenderMetadaUrl = $_SERVER['HTTP_HOST']."/mapbender/php/mod_showMetadata.php?resource=layer&id=";
+if (isset($_SERVER["HTTPS"])){
+	$urlPrefix = "https://";
+} else {
+	$urlPrefix = "http://";
+$mapbenderMetadataUrl = $urlPrefix.$mapbenderMetadataUrl;
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+ * Creates an XML Exception according to WMS 1.1.1
+ * @return an XML String
+ * @param $errorCode String
+ * @param $errorMessage String
+function createExceptionXml ($errorCode, $errorMessage) {
+	// see http://de2.php.net/manual/de/domimplementation.createdocumenttype.php
+	$imp = new DOMImplementation;
+	$dtd = $imp->createDocumentType("ServiceExceptionReport", "", "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd");
+	$doc = $imp->createDocument("", "", $dtd);
+	$doc->encoding = 'UTF-8';
+	$doc->standalone = false;
+	$el = $doc->createElement("ServiceExceptionReport");
+	$exc = $doc->createElement("ServiceException", $errorMessage);
+	if ($errorCode) {
+		$exc->setAttribute("code", $errorCode);
+	$el->appendChild($exc);
+	$doc->appendChild($el);
+	return $doc->saveXML();
+// check if service param is set
+if (!isset($service) || $service === "" || $service != "WMS") {
+	header("Content-type: application/xhtml+xml; charset=UTF-8");
+	echo createExceptionXml("", "Parameter SERVICE invalid");
+	die;
+// check if request param is set
+if (!isset($requestType) || $requestType === "" || ($service == "WMS" && $requestType != "GetCapabilities")) {
+	echo createExceptionXml("", "Parameter REQUEST invalid");
+	die;
+// check if version param is set
+if (!isset($version) || $version === "" || ($service == "WMS" && $version != "1.1.1")) {
+	// optional parameter, set to 1.1.1 if not set
+	$version = "1.1.1";
+// check if layer id is set
+if (!isset($layerId) || !is_numeric($layerId)) {
+	// TO DO: create exception XML
+	echo createExceptionXml("Layer not defined", "Unknown layer id " . $layerId);
+	die;
+// check if layer is stored in database
+$wms_sql = "SELECT * FROM wms AS w, layer AS l " .
+	"where l.layer_id = $1 AND l.fkey_wms_id = w.wms_id LIMIT 1";
+$v = array($layerId);
+$t = array("i");
+$res_wms_sql = db_prep_query($wms_sql, $v, $t);
+$wms_row = db_fetch_array($res_wms_sql);
+if (!$wms_row["wms_id"]) {
+	die;
+// check if update sequence is valid
+$updateSequenceDb = intval($wms_row["wms_timestamp"]);
+if ($updateSequence) {
+	if ($updateSequence > $updateSequenceDb) {
+		// Exception: code=InvalidUpdateSequence
+		echo createExceptionXml("InvalidUpdateSequence", "Invalid update sequence");
+		die;
+	else if ($updateSequence == $updateSequenceDb) {
+		// Exception: code=CurrentUpdateSequence
+		echo createExceptionXml("CurrentUpdateSequence", "Current update sequence");
+		die;
+// increment layer count
+$monitor = new Layer_load_count();
+$monitor->increment($layerId);
+// START TO CREATE CAPABILITIES DOC
+// (return most recent Capabilities XML)
+$doc = new DOMDocument('1.0');
+$doc->encoding = 'UTF-8';
+$doc->standalone = false;
+#Check for existing content in database
+#to be adopted TODO armin
+function validate ($contactInformation_column) {
+    if ($contactInformation_column <> "" AND $contactInformation_column <> NULL) {
+             $contactinformationcheck = true;
+    else {
+		$contactinformationcheck = false;
+	return $contactinformationcheck;
+#Creating the "WMT_MS_Capabilities" node
+$wmt_ms_capabilities = $doc->createElement("WMT_MS_Capabilities");
+$wmt_ms_capabilities->setAttribute("updateSequence", $wms_row["wms_timestamp"]);
+$wmt_ms_capabilities = $doc->appendChild($wmt_ms_capabilities);
+$wmt_ms_capabilities->setAttribute('version', '1.1.1');
+#Creatig the "Service" node
+$service = $doc->createElement("Service");
+$service = $wmt_ms_capabilities->appendChild($service);
+#Creating the "Name" Node
+$name = $doc->createElement("Name");
+$name = $service->appendChild($name);
+$nameText = $doc->createTextNode("OGC:WMS");
+$nameText = $name->appendChild($nameText);
+#Creating the "Title" node
+if($wms_row['wms_title'] <> "" AND $wms_row['wms_title'] <> NULL) {
+    $title = $doc->createElement("Title");
+	$title = $service->appendChild($title);
+	$titleText = $doc->createTextNode($wms_row['wms_title']);
+	$titleText = $title->appendChild($titleText);
+#Creating the "Abstract" node
+if($wms_row['wms_abstract'] <> "" AND $wms_row['wms_abstract'] <> NULL) {
+	$abstract = $doc->createElement("Abstract");
+	$abstract = $service->appendChild($abstract);
+	$abstractText = $doc->createTextNode($wms_row['wms_abstract']);
+	$abstractText = $abstract->appendChild($abstractText);
+# switch URLs for OWSPROXY
+if($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL) {
+	$tmpOR = $urlPrefix.$_SERVER["HTTP_HOST"]."/owsproxy/".session_id()."/".$wms_row["wms_owsproxy"]."?";
+	$tmpOR = str_replace(SERVERIP, SERVERNAME, $tmpOR);
+	$wms_row['wms_getcapabilities'] = $tmpOR;
+	$wms_row['wms_getmap'] = $tmpOR;
+	$wms_row['wms_getfeatureinfo'] = $tmpOR;
+#Creating the "OnlineResource" node
+//if($wms_row['wms_getcapabilities'] <> "" AND $wms_row['wms_getcapabilities'] <> NULL) {
+    $onlineResource = $doc->createElement("OnlineResource");
+	$onlineResource = $service->appendChild($onlineResource);
+	$onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink" );
+//	$onlineResource->setAttribute("xlink:href", $wms_row['wms_getcapabilities']);
+	$onlRes = $_SERVER["HTTP_HOST"] . $_SERVER["SCRIPT_NAME"] . "?layer_id=" . $layerId."&".session_name()."=".session_id();
+	if (isset($_SERVER["HTTPS"])) {
+		$onlRes = "https://" . $onlRes;
+	else {
+		$onlRes = "http://" . $onlRes;
+	$onlineResource->setAttribute("xlink:href", $onlRes);
+	$onlineResource->setAttribute("xlink:type", "simple");
+#Insert contact information
+#Creating "Contact Information" node
+if (validate($wms_row['contactperson']) &&
+	validate($wms_row['contactorganization']) &&
+	validate($wms_row['contactposition']) &&
+	validate($wms_row['address']) &&
+	validate($wms_row['city']) &&
+	validate($wms_row['stateorprovince']) &&
+	validate($wms_row['postcode']) /*AND validate($wms_row['country'])*/ &&
+	validate($wms_row['contactvoicetelephone']) &&
+	validate($wms_row['contactfacsimiletelephone']) &&
+	validate($wms_row['contactelectronicmailaddress']))
+$contactInformation = $doc->createElement("ContactInformation");
+$contactInformation = $service->appendChild($contactInformation);
+#Creating "Contact Person Primary" node
+if(validate($wms_row['contactperson']) AND validate($wms_row['contactorganization']))
+$contactPersonPrimary = $doc->createElement("ContactPersonPrimary");
+$contactPersonPrimary = $contactInformation->appendChild($contactPersonPrimary);
+#Creating the "ContactPerson" node
+if(validate($wms_row['contactperson']))
+    $contactPerson = $doc->createElement("ContactPerson");
+    $contactPerson = $contactPersonPrimary->appendChild($contactPerson);
+    $contactPersonText = $doc->createTextNode($wms_row['contactperson']);
+    $contactPersonText = $contactPerson->appendChild($contactPersonText);
+#Creating the "ContactOrganization" node
+if(validate($wms_row['contactorganization']))
+    $contactOrganization = $doc->createElement("ContactOrganization");
+    $contactOrganization = $contactPersonPrimary->appendChild($contactOrganization);
+    $contactOrganizationText = $doc->createTextNode($wms_row['contactorganization']);
+    $contactOrganizationText = $contactOrganization->appendChild($contactOrganizationText);
+#Creating the "ContactPosition" node
+if(validate($wms_row['contactposition']))
+    $contactPosition = $doc->createElement("ContactPosition");
+    $contactPosition = $contactInformation->appendChild($contactPosition);
+    $contactPositionText = $doc->createTextNode($wms_row['contactposition']);
+    $contactPositionText = $contactPosition->appendChild($contactPositionText);
+#Creating "ContactAddress" node
+if(validate($wms_row['address']) AND validate($wms_row['city']) AND validate($wms_row['stateorprovince']) AND               validate($wms_row['postcode']) /*AND validate($wms_row['country'])*/)
+$contactAddress = $doc->createElement("ContactAddress");
+$contactAddress = $contactInformation->appendChild($contactAddress);
+#Creating the "AddressType" and "Address" textnode
+if(validate($wms_row['address']))
+    $addressType = $doc->createElement("AddressType");
+    $addressType = $contactAddress->appendChild($addressType);
+    $addresstypeText = $doc->createTextNode("postal");
+    $addresstypeText = $addressType->appendChild($addresstypeText);
+    $address = $doc->createElement("Address");
+    $address = $contactAddress->appendChild($address);
+    $addressText = $doc->createTextNode($wms_row['address']);
+    $addressText = $address->appendChild($addressText);
+#Creatig the "City" node
+if(validate($wms_row['city']))
+    $city = $doc->createElement("City");
+    $city = $contactAddress->appendChild($city);
+    $cityText = $doc->createTextNode($wms_row['city']);
+    $cityText = $city->appendChild($cityText);
+#Creatig the "StateOrProvince" node
+if(validate($wms_row['stateorprovince']))
+    $stateOrProvince = $doc->createElement("StateOrProvince");
+    $stateOrProvince = $contactAddress->appendChild($stateOrProvince);
+    $stateOrProvinceText = $doc->createTextNode($wms_row['stateorprovince']);
+    $stateOrProvinceText = $stateOrProvince->appendChild($stateOrProvinceText);
+#Creatig the "PostCode" node
+if(validate($wms_row['postcode']))
+    $postCode = $doc->createElement("PostCode");
+    $postCode = $contactAddress->appendChild($postCode);
+    $postCodeText = $doc->createTextNode($wms_row['postcode']);
+    $postCodeText = $postCode->appendChild($postCodeText);
+#Creatig the "Country" node
+if(isset($wms_row['country']) AND validate($wms_row['country']))
+    $country = $doc->createElement("Country");
+    $country = $contactAddress->appendChild($country);
+    $countryText = $doc->createTextNode($wms_row['country']);
+    $countryText = $country->appendChild($countryText);
+#Creatig the "ContactVoiceTelephone" node
+if(validate($wms_row['contactvoicetelephone']))
+    $contactVoiceTelephone = $doc->createElement("ContactVoiceTelephone");
+    $contactVoiceTelephone = $contactInformation->appendChild($contactVoiceTelephone);
+    $contactVoiceTelephoneText = $doc->createTextNode($wms_row['contactvoicetelephone']);
+    $contactVoiceTelephoneText = $contactVoiceTelephone->appendChild($contactVoiceTelephoneText);
+#Creatig the "ContactFacsimileTelephone" node
+if(validate($wms_row['contactfacsimiletelephone']))
+    $contactFacsimileTelephone = $doc->createElement("ContactFacsimileTelephone");
+    $contactFacsimileTelephone = $contactInformation->appendChild($contactFacsimileTelephone);
+    $contactFacsimileTelephoneText = $doc->createTextNode($wms_row['contactfacsimiletelephone']);
+    $contactFacsimileTelephoneText = $contactFacsimileTelephone->appendChild($contactFacsimileTelephoneText);
+#Creatig the "ContactElectronicMailAddress" node
+if(validate($wms_row['contactelectronicmailaddress']))
+    $contactElectronicMailAddress = $doc->createElement("ContactElectronicMailAddress");
+    $contactElectronicMailAddress = $contactInformation->appendChild($contactElectronicMailAddress);
+    $contactElectronicMailAddressText = $doc->createTextNode($wms_row['contactelectronicmailaddress']);
+    $contactElectronicMailAddressText = $contactElectronicMailAddress->appendChild($contactElectronicMailAddressText);
+#Creatig the "Fees" node
+if(validate($wms_row['fees']))
+    $fees = $doc->createElement("Fees");
+    $fees = $service->appendChild($fees);
+    $feesText = $doc->createTextNode($wms_row['fees']);
+    $feesText = $fees->appendChild($feesText);
+#Creating the "AccessConstraints" node
+if(validate($wms_row['accessconstraints']))
+	$accessConstraints = $doc->createElement("AccessConstraints");
+    $accessConstraints = $service->appendChild($accessConstraints);
+    $accessConstraintsText = $doc->createTextNode($wms_row['accessconstraints']);
+    $accessConstraintsText = $accessConstraints->appendChild($accessConstraintsText);
+#Creatig the "Capability" node
+$capability = $doc->createElement("Capability");
+$capability = $wmt_ms_capabilities->appendChild($capability);
+#Creatig the "Request" node
+$request = $doc->createElement("Request");
+$request = $capability->appendChild($request);
+#GetCapabilities
+#Creatig the "GetCapabilities" node
+$getCapabilities = $doc->createElement("GetCapabilities");
+$getCapabilities = $request->appendChild($getCapabilities);
+#Creatig the "Format" node
+$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'capability'";
+$v = array($wms_row['wms_id']);
+$t = array("i");
+$res_wms_format_sql = db_prep_query($wms_format_sql, $v, $t);
+while ($wms_format_row = db_fetch_array($res_wms_format_sql)) {
+    $format = $doc->createElement("Format");
+    $format = $getCapabilities->appendChild($format);
+    $formatText = $doc->createTextNode($wms_format_row['data_format']);
+    $formatText = $format->appendChild($formatText);
+#cause the format for capabilities is not read :
+    $formatText = $doc->createTextNode('application/vnd.ogc.wms_xml');
+#Creating the "DCPType" node
+$DCPType = $doc->createElement("DCPType");
+$DCPType = $getCapabilities->appendChild($DCPType);
+#Creating the "HTTP" node
+$HTTP = $doc->createElement("HTTP");
+$HTTP = $DCPType->appendChild($HTTP);
+#Creating the "Get" node
+$get = $doc->createElement("Get");
+$get = $HTTP->appendChild($get);
+//if ($wms_row['wms_getcapabilities'] <> "" AND $wms_row['wms_getcapabilities'] <> NULL) {
+	$onlineResource = $get->appendChild($onlineResource);
+	$onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+	$onlRes = $_SERVER["HTTP_HOST"] . $_SERVER["SCRIPT_NAME"] . "?layer_id=" . $layerId;
+	else {
+#Creating the "Post" node
+$post = $doc->createElement("Post");
+$post = $HTTP->appendChild($post);
+	$onlineResource = $post->appendChild($onlineResource);
+	else {
+#GetMap
+#Creatig the "GetMap" node
+$getMap = $doc->createElement("GetMap");
+$getMap = $request->appendChild($getMap);
+$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'map'";
+$t = array("i");
+    $format = $getMap->appendChild($format);
+$DCPType = $getMap->appendChild($DCPType);
+if ($wms_row['wms_getmap'] <> "" AND $wms_row['wms_getmap'] <> NULL) {
+	$onlineResource->setAttribute("xlink:href", $wms_row['wms_getmap']);
+if($wms_row['wms_getmap'] <> "" AND $wms_row['wms_getmap'] <> NULL) {
+#GetFeatureInfo
+#Creatig the "GetFeatureInfo" node
+$getFeatureInfo = $doc->createElement("GetFeatureInfo");
+$getFeatureInfo = $request->appendChild($getFeatureInfo);
+$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'featureinfo'";
+$t = array("i");
+    $format = $getFeatureInfo->appendChild($format);
+$DCPType = $getFeatureInfo->appendChild($DCPType);
+if($wms_row['wms_getfeatureinfo'] <> "" AND $wms_row['wms_getfeatureinfo'] <> NULL)
+	$onlineResource->setAttribute("xlink:href", $wms_row['wms_getfeatureinfo']);
+if($wms_row['wms_getfeatureinfo'] <> "" AND $wms_row['wms_getfeatureinfo'] <> NULL) {
+#Creating the "Exeption" node
+$exception = $doc->createElement("Exception");
+$exception = $capability->appendChild($exception);
+$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'exception'";
+$t = array("i");
+    $format = $exception->appendChild($format);
+#Querying layer table
+$layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = $1 AND layer.layer_parent = ''";
+$t = array("i");
+$res_layer_sql = db_prep_query($layer_sql, $v, $t);
+$layer_row = db_fetch_array($res_layer_sql);
+#Creating layer node
+$layer = $doc->createElement("Layer");
+$layer = $capability->appendChild($layer);
+#Write layer to parent layer array
+$parentLayerArray[$layer_row['layer_pos']] = $layer;
+#Creating Name node
+if ($layer_row['layer_name'] <> "" AND $layer_row['layer_name'] <> NULL) {
+	$name = $doc->createElement("Name");
+	$name = $layer->appendChild($name);
+	$nameText = $doc->createTextNode($layer_row['layer_name']);
+	$nameText = $name->appendChild($nameText);
+#Creating Title node
+if ($layer_row['layer_title'] <> "" AND $layer_row['layer_title'] <> NULL) {
+	$title = $layer->appendChild($title);
+	$titleText = $doc->createTextNode($layer_row['layer_title']);
+if($layer_row['layer_abstract'] <> "" AND $layer_row['layer_abstract'] <> NULL) {
+    $abstract = $layer->appendChild($abstract);
+    $abstractText = $doc->createTextNode($layer_row['layer_abstract']);
+#Request the specific wms- and layerkeywords
+$keyword_sql = "SELECT DISTINCT keyword FROM keyword, layer_keyword, layer " .
+	"WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
+	"AND layer_keyword.fkey_layer_id = layer.layer_id " .
+	"AND layer.fkey_wms_id = $1";
+$t = array("i");
+$res_keyword_sql = db_prep_query($keyword_sql, $v, $t);
+#Creating list of keyword nodes
+#Iterating over a List of Keywords
+$keywordlistExist = 0;
+while ($keyword_sql = db_fetch_array($res_keyword_sql))
+    #Creating the "KeywordList" node
+    if ($keywordlistExist == 0) {
+        $keywordList = $doc->createElement("KeywordList");
+        $keywordList = $layer->appendChild($keywordList);
+		$keywordlistExist = 1;
+    #Creating the "Keyword" node
+    $keyword_dom = $doc->createElement("Keyword");
+    $keyword_dom = $keywordList->appendChild($keyword_dom);
+    $keyword_domText = $doc->createTextNode($keyword_sql['keyword']);
+    $keyword_domText = $keyword_dom->appendChild($keyword_domText);
+#SQL statement to get additional layer information from layer epsg
+$epsg_sql = "SELECT layer_epsg.epsg, layer_epsg.minx, layer_epsg.miny, " .
+	"layer_epsg.maxy, layer_epsg.maxx " .
+	"FROM layer_epsg WHERE layer_epsg.fkey_layer_id = $1";
+$v = array($layer_row['layer_id']);
+$t = array("i");
+$res_espg_sql = db_prep_query($epsg_sql, $v, $t);
+$latLonBoundingBoxCreated = false;
+$BoundingBoxCreated = false;
+while ($epsg_row = db_fetch_array($res_espg_sql)) {
+	#Creating SRS node
+	$srs = $doc->createElement("SRS");
+	$srs = $layer->appendChild($srs);
+	$srsText = $doc->createTextNode($epsg_row['epsg']);
+	$srsText = $srs->appendChild($srsText);
+$t = array("i");
+	#set only epsg 4326 for latlonbbox
+	if ($epsg_row['epsg'] == "EPSG:4326") {
+		$latlon['minx'] = $epsg_row['minx'];
+		$latlon['miny'] = $epsg_row['miny'];
+		$latlon['maxx'] = $epsg_row['maxx'];
+		$latlon['maxy'] = $epsg_row['maxy'];
+		#Creating LatLongBoundingBox node
+		$latLonBoundingBox = $doc->createElement("LatLonBoundingBox");
+		$latLonBoundingBox = $layer->appendChild($latLonBoundingBox);
+		$latLonBoundingBox->setAttribute('minx', $latlon['minx']);
+		$latLonBoundingBox->setAttribute('miny', $latlon['miny']);
+		$latLonBoundingBox->setAttribute('maxx', $latlon['maxx']);
+		$latLonBoundingBox->setAttribute('maxy', $latlon['maxy']);
+	    break;
+$t = array("i");
+	#set only first epsg for bbox
+	$bbox['epsg'] = $epsg_row['epsg'];
+	$bbox['minx'] = $epsg_row['minx'];
+	$bbox['miny'] = $epsg_row['miny'];
+	$bbox['maxx'] = $epsg_row['maxx'];
+	$bbox['maxy'] = $epsg_row['maxy'];
+	#Creating BoundingBox node
+	$boundingBox = $doc->createElement("BoundingBox");
+	$boundingBox = $layer->appendChild($boundingBox);
+	$boundingBox->setAttribute('SRS', $bbox['epsg']);
+	$boundingBox->setAttribute('minx', $bbox['minx']);
+	$boundingBox->setAttribute('miny', $bbox['miny']);
+	$boundingBox->setAttribute('maxx', $bbox['maxx']);
+	$boundingBox->setAttribute('maxy', $bbox['maxy']);
+#Append epsg string to srs node
+$srsText = $doc->createTextNode($epsgText);
+$srsText = $srs->appendChild($srsText);
+####### duplicate root layer
+#if layer is root layer itself!
+#<armin>
+##if ($layer_row['layer_pos']=='0'){
+#</armin>
+##$clonedLayer = $layer->cloneNode(true);
+##$clonedLayer->setAttribute("queryable", "0");
+##$clonedLayer->setAttribute("cascaded", "0");
+##$layer->appendChild($clonedLayer);
+#<armin>
+#</armin>
+############## sublayer
+#SQL statement to get all layers
+$sub_layer_sql = "SELECT * FROM layer WHERE fkey_wms_id = $1 AND layer_parent <> ''";
+$t = array("i");
+if (isset($layerId) && $layerId > 0) {
+	$sub_layer_sql .= " AND layer_id = $2";
+	array_push($v, $layerId);
+	array_push($t, "i");
+$sub_layer_sql .= " ORDER BY layer_pos";
+$res_sub_layer_sql = db_prep_query($sub_layer_sql, $v, $t);
+#<armin>
+$res_sub_layer_sql_2 = db_prep_query($sub_layer_sql, $v, $t);
+$sub_layer_row_2 = db_fetch_array($res_sub_layer_sql_2);
+if (!isset($sub_layer_row_2['layer_pos'])) {
+	$clonedLayer = $layer->cloneNode(true);
+	$clonedLayer->setAttribute("queryable", "0");
+	$clonedLayer->setAttribute("cascaded", "0");
+	$layer->appendChild($clonedLayer);
+#</armin>
+while ($sub_layer_row = db_fetch_array($res_sub_layer_sql)) {
+	#Creating layer node
+	$sub_layer = $doc->createElement("Layer");
+	$e = new mb_exception("wms.php: layer_parent:".$sub_layer_row['layer_parent']);
+	$parent = $parentLayerArray[$sub_layer_row['layer_parent']];
+	$sub_layer = $parent->appendChild($sub_layer);
+    if($sub_layer_row['layer_queryable'] <> "" AND $sub_layer_row['layer_queryable'] <> NULL) {
+		$sub_layer->setAttribute('queryable', $sub_layer_row['layer_queryable']);
+	#Getting information about the hierarchie of layers
+	$cascadeSQL = "SELECT COUNT(*) FROM layer WHERE fkey_wms_id = $1 AND layer_parent = $2";
+	$v = array($wms_row[0], $sub_layer_row['layer_pos']);
+	$t = array("i", "i");
+	$res_cascadeSQL = db_prep_query($cascadeSQL, $v, $t);
+	$cascade = 0;
+	$cascade_row = db_fetch_row($res_cascadeSQL);
+	if($cascade_row[0] > 0)
+		$cascade = 1;
+	$sub_layer->setAttribute('cascaded', $cascade);
+	#Write layer to parent layer array
+	$parentLayerArray[$sub_layer_row['layer_pos']] = $sub_layer;
+	#Creating name node
+    if($sub_layer_row['layer_name'] <> "" AND $sub_layer_row['layer_name'] <> NULL)
+		$name = $sub_layer->appendChild($name);
+		$nameText = $doc->createTextNode($sub_layer_row['layer_name']);
+	#Creating Title node
+    if($sub_layer_row['layer_title'] <> "" AND $sub_layer_row['layer_title'] <> NULL)
+		$title = $sub_layer->appendChild($title);
+		$titleText = $doc->createTextNode($sub_layer_row['layer_title']);
+		#Creating the "Abstract" node
+    if($sub_layer_row['layer_abstract'] <> "" AND $sub_layer_row['layer_abstract'] <> NULL)
+    	$abstract = $sub_layer->appendChild($abstract);
+    	$abstractText = $doc->createTextNode($sub_layer_row['layer_abstract']);
+    #Request the specific wms- and layerkeywords
+    $keyword_sql = "SELECT DISTINCT keyword FROM layer LEFT JOIN layer_keyword ON layer_keyword.fkey_layer_id = layer.layer_id LEFT JOIN keyword ON  keyword.keyword_id = layer_keyword.fkey_keyword_id WHERE layer.fkey_wms_id = ".$wms_row['wms_id']." AND layer.layer_id = ".$sub_layer_row['layer_id']."";
+    $res_keyword_sql = db_query($keyword_sql);
+    #Creating list of keyword nodes
+    #Iterating over a List of Keywords
+    $keywordlistExist = 0;
+    while ($keyword_sql = db_fetch_array($res_keyword_sql))
+            $keywordList = $sub_layer->appendChild($keywordList);
+	// inherit srs from parent layer
+	$layer_srs_sql = "SELECT DISTINCT epsg FROM layer_epsg " .
+			"WHERE fkey_layer_id = ".$sub_layer_row['layer_id'] .
+			" OR fkey_layer_id = " . $layer_row['layer_id'];
+	$res_layer_srs_sql = db_query($layer_srs_sql);
+	while ($layer_srs_row = db_fetch_array($res_layer_srs_sql)) {
+		$srs = $sub_layer->appendChild($srs);
+		$srsText = $doc->createTextNode($layer_srs_row['epsg']);
+	#SQL statement to get additional layer information from layer epsg
+	$epsg_sql = "SELECT layer_epsg.epsg, layer_epsg.minx, layer_epsg.miny, " .
+			"layer_epsg.maxy, layer_epsg.maxx FROM layer_epsg " .
+			"WHERE layer_epsg.fkey_layer_id = ".$sub_layer_row['layer_id'];
+	$res_espg_sql = db_query($epsg_sql);
+	while ($epsg_row = db_fetch_array($res_espg_sql)) {
+		#set epsg 4326 for latlonbbox
+		if ($epsg_row['epsg'] == "EPSG:4326" AND $latLonBoundingBoxCreated == false) {
+		    $latLonBoundingBox = $sub_layer->appendChild($latLonBoundingBox);
+		$boundingBox = $sub_layer->appendChild($boundingBox);
+	# Creating Metadata Node
+	$metadataUrl = $doc->createElement("MetadataURL");
+	$metadataUrl = $sub_layer->appendChild($metadataUrl);
+	$metadataUrl->setAttribute('type', "TC211");
+    $format = $metadataUrl->appendChild($format);
+    $formatText = $doc->createTextNode('text/html');
+	if ($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL) {
+	   	$onlineResource = $metadataUrl->appendChild($onlineResource);
+		$onlineResource->setAttribute("xlink:href", OWSPROXY."/".session_id()."/".$wms_row["wms_owsproxy"]."?");
+	else {
+		if ($sub_layer_row['layer_metadataurl'] <> "" AND $sub_layer_row['layer_metadataurl'] <> NULL) {
+			$onlineResource->setAttribute("xlink:href", $sub_layer_row['layer_metadataurl']);
+			//TODO set metadataUrl from mb_database
+else
+                        //$onlineResource->setAttribute("xlink:href", "http://www.geoportal.rlp.de/mapbender/x_geoportal/mod_layerMetadata.php?id=".$sub_layer_row['layer_id']);
+                        $onlineResource->setAttribute("xlink:href", $mapbenderMetadaUrl.$sub_layer_row['layer_id']);
+	# Creating DataURL Node
+	$dataUrl = $doc->createElement("DataURL");
+	$dataUrl = $sub_layer->appendChild($dataUrl);
+    $format = $dataUrl->appendChild($format);
+	if($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL)
+	   	$onlineResource = $dataUrl->appendChild($onlineResource);
+	else
+		if($sub_layer_row['layer_dataurl'] <> "" AND $sub_layer_row['layer_dataurl'] <> NULL)
+			$onlineResource->setAttribute("xlink:href", $sub_layer_row['layer_dataurl']);
+else
+                        $onlineResource->setAttribute("xlink:href", "http://www.geoportal.rlp.de/mapbender/x_geoportal/mod_layerMetadata.php?id=".$sub_layer_row['layer_id']);
+	#Creating Style Node
+	$style = $doc->createElement("Style");
+	$style = $sub_layer->appendChild($style);
+    $name = $style->appendChild($name);
+    $nameText = $doc->createTextNode('default');
+    $title = $style->appendChild($title);
+    $titleText = $doc->createTextNode('default');
+    if($wms_row['wms_getlegendurl'] <> "" AND $wms_row['wms_getlegendurl'] <> NULL){
+	$legendUrl = $doc->createElement("LegendURL");
+	$legendUrl = $style->appendChild($legendUrl);
+	$legendUrl->setAttribute("width", "10" );
+	$legendUrl->setAttribute("height", "8" );
+    $format = $legendUrl->appendChild($format);
+    $formatText = $doc->createTextNode('image/png');
+	   	$onlineResource = $legendUrl->appendChild($onlineResource);
+		$onlineResource->setAttribute("xlink:href", OWSPROXY."/".session_id()."/".$wms_row["wms_owsproxy"]."?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=".$sub_layer_row['layer_name']."&format=image/png");
+	else
+			$onlineResource->setAttribute("xlink:href", $wms_row['wms_getlegendurl']."version=1.1.1&service=WMS&request=GetLegendGraphic&layer=".$sub_layer_row['layer_name']."&format=image/png");
+	#Creating "ScaleHint" node
+    if ($sub_layer_row['layer_minscale'] <> "" AND $sub_layer_row['layer_minscale'] <> NULL) {
+		$scaleHint = $doc->createElement("ScaleHint");
+		$scaleHint = $sub_layer->appendChild($scaleHint);
+		$scaleHint->setAttribute('min', (floatval($sub_layer_row['layer_minscale'])/2004.3976484406788493955738891127));
+		$scaleHint->setAttribute('max', (floatval($sub_layer_row['layer_maxscale'])/2004.3976484406788493955738891127));
+header("Content-type: application/xhtml+xml; charset=UTF-8");
+echo $doc->saveXml();
Modified: trunk/mapbender/http_auth/http/index.php
--- trunk/mapbender/http_auth/http/index.php	2011-02-27 12:32:08 UTC (rev 7656)
+++ trunk/mapbender/http_auth/http/index.php	2011-02-27 16:20:53 UTC (rev 7657)
@@ -104,7 +104,7 @@
 		} else {
-		$request = $urlPrefix.$_SERVER['HTTP_HOST']."/mapbender/php/wms.php?layer_id=".$layer_id;
+		$request = $urlPrefix.$_SERVER['HTTP_HOST']."/mapbender/php/wms.php?layer_id=".$layerId;
 		$requestFull .= $request.'&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS';
 		if(isset($auth)){
 			getCapabilities($request,$requestFull,$auth);
More information about the Mapbender_commits mailing list
