[Mapbender-commits] r7924 - branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 8 03:59:35 EDT 2011
Author: verenadiewald
Date: 2011-07-08 00:59:35 -0700 (Fri, 08 Jul 2011)
New Revision: 7924
Added:
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_diagonals-thick_18_b81900_40x40.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_diagonals-thick_20_666666_40x40.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_flat_10_000000_40x100.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_glass_100_f6f6f6_1x400.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_glass_65_ffffff_1x400.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_gloss-wave_35_f6a828_500x100.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_highlight-soft_75_ffe45c_1x100.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_222222_256x240.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_228ef1_256x240.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_ef8c08_256x240.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_ffd27a_256x240.png
   branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_ffffff_256x240.png
current jquery ui version from http://jqueryui.com/download
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_diagonals-thick_18_b81900_40x40.png
(Binary files differ)
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_diagonals-thick_18_b81900_40x40.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_diagonals-thick_20_666666_40x40.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_diagonals-thick_20_666666_40x40.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_flat_10_000000_40x100.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_flat_10_000000_40x100.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_glass_100_f6f6f6_1x400.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_glass_100_f6f6f6_1x400.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_glass_65_ffffff_1x400.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_glass_65_ffffff_1x400.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_gloss-wave_35_f6a828_500x100.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_gloss-wave_35_f6a828_500x100.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_highlight-soft_75_ffe45c_1x100.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-bg_highlight-soft_75_ffe45c_1x100.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_222222_256x240.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_222222_256x240.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_228ef1_256x240.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_228ef1_256x240.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_ef8c08_256x240.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_ef8c08_256x240.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_ffd27a_256x240.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_ffd27a_256x240.png
Added: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_ffffff_256x240.png
Property changes on: branches/2.7/http/extensions/jquery-ui-1.8.14.custom/css/ui-lightness/images/ui-icons_ffffff_256x240.png
More information about the Mapbender_commits mailing list
