[Mapbender-commits] r8001 - branches/2.7
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jul 26 05:26:16 EDT 2011
Author: astrid_emde
Date: 2011-07-26 02:26:16 -0700 (Tue, 26 Jul 2011)
New Revision: 8001
   branches/2.7/Install.txt
comment concerning cURL
Modified: branches/2.7/Install.txt
--- branches/2.7/Install.txt	2011-07-26 09:22:03 UTC (rev 8000)
+++ branches/2.7/Install.txt	2011-07-26 09:26:16 UTC (rev 8001)
@@ -20,6 +20,7 @@
 ** php-gd2
 ** php5-imagick
 ** php-gettext
+** php5-curl (if you want to use cURL - have a look in mapbender.conf)
 The following instructions only describe the configuration process for these packages, please follow the installation instructions for your operating system individually as the paths to files will vary on your systems.
More information about the Mapbender_commits mailing list
