[Mapbender-commits] r7849 - in trunk/mapbender: http/php http/plugins resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 9 07:09:56 EDT 2011
Author: armin11
Date: 2011-06-09 04:09:55 -0700 (Thu, 09 Jun 2011)
New Revision: 7849
   trunk/mapbender/http/php/mod_dataISOMetadata.php
   trunk/mapbender/http/plugins/mb_metadata_addon.php
   trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
Some bugfixing
Modified: trunk/mapbender/http/php/mod_dataISOMetadata.php
--- trunk/mapbender/http/php/mod_dataISOMetadata.php	2011-06-09 10:47:08 UTC (rev 7848)
+++ trunk/mapbender/http/php/mod_dataISOMetadata.php	2011-06-09 11:09:55 UTC (rev 7849)
@@ -433,18 +433,18 @@
 	//some initialization for the temporal extent:
 	$beginPositionValue = $mb_metadata['tmp_reference_1'];
 	$endPositionValue = $mb_metadata['tmp_reference_2'];
-	$dateOfLastRevision = date('c');
+	$dateOfLastRevision = date('Y-m-d h:i:s');
 	if (isset($mb_metadata['update_frequency']) && $mb_metadata['update_frequency'] != "") {
 		switch ($mb_metadata['update_frequency']) {
 			case ('continual'):
 				//set value to now
-				$endPositionValue = $letztermonat  = date('c',time());
+				$endPositionValue = date('Y-m-d h:i:s');
 				$dateOfLastRevision = $endPositionValue;
 			break;
 			case ('daily'):
 				//set value to now - one day
-				$endPositionValue = date('c', mktime(0, 0, 0, date("m"), date("d")-1,   date("Y")));
+				$endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m"), date("d")-1,   date("Y")));
 			break;
 			case ('weekly'):
@@ -454,27 +454,27 @@
 			break;
 			case ('fortnightly'):
 				//set value to now - two weeks
-				$endPositionValue = date('c', mktime(0, 0, 0, date("m"), date("d")-14,   date("Y")));
+				$endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m"), date("d")-14,   date("Y")));
 			break;
 			case ('monthly'):
 				//set value to now - one month
-				$endPositionValue =  date('c', mktime(0, 0, 0, date("m")-1, date("d"),   date("Y")));
+				$endPositionValue =  date('Y-m-d h:i:s', mktime(0, 0, 0, date("m")-1, date("d"),   date("Y")));
 			break;
 			case ('quarterly'):
 				//set value to now - 3 months
-				$endPositionValue = date('c', mktime(0, 0, 0, date("m")-3, date("d"),   date("Y")));
+				$endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m")-3, date("d"),   date("Y")));
 			break;
 			case ('biannually'):
 				//set value to now - half a year
-				$endPositionValue = date('c', mktime(0, 0, 0, date("m")-6, date("d"),   date("Y")));
+				$endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m")-6, date("d"),   date("Y")));
 			break;
 			case ('annually'):
 				//set value to now - one year
-				$endPositionValue = date('c', mktime(0, 0, 0, date("m"), date("d"),   date("Y")-1));
+				$endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m"), date("d"),   date("Y")-1));
 			break;
 			default:
Modified: trunk/mapbender/http/plugins/mb_metadata_addon.php
--- trunk/mapbender/http/plugins/mb_metadata_addon.php	2011-06-09 10:47:08 UTC (rev 7848)
+++ trunk/mapbender/http/plugins/mb_metadata_addon.php	2011-06-09 11:09:55 UTC (rev 7849)
@@ -53,7 +53,7 @@
 		</fieldset>
 		<fieldset id="cyclicupdate" name="cyclicupdate">
 			<legend><?php echo _mb("Maintenance and update frequency");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Frequency with which changes and additions are made to the resource after the initial resource is completed. Notice: This value may change the value of the end date of temporal extent. The end date will be computed automatically from the current timestamp if a cyclic update is defined!");?>'}" src="../img/questionmark.png" alt="" /></legend>
-				<select class="cyclic_selectbox" id='update_frequency' name='update_frequency' size="2">
+				<select class="required cyclic_selectbox" id='update_frequency' name='update_frequency'>
 <!-- B.5.18 MD_MaintenanceFrequencyCode <<CodeList>> of ISO19115 -->					<option value="continual"><?php echo _mb("continual");?></option>
 					<option value="daily"><?php echo _mb("daily");?></option>
 					<option value="weekly"><?php echo _mb("weekly");?></option>
@@ -105,7 +105,7 @@
 	</fieldset>
 	<fieldset id="data_format">
 		<legend><?php echo _mb("Encoding");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Description of the computer language construct(s) specifying the representation of data objects in a record, file, message, storage device or transmission channel.");?>'}" src="../img/questionmark.png" alt="" /></legend>
-		<select class="required format_selectbox" id='format' name='format' size="2">
+		<select class="required format_selectbox" id='format' name='format'>
 			<option value="database"><?php echo _mb("Database");?></option>
 			<option value="shapefile"><?php echo _mb("Esri Shape");?></option>
 			<option value="tab"><?php echo _mb("MapInfo Tab file");?></option>
@@ -115,7 +115,7 @@
 	</fieldset>
 	<fieldset id="charset">
 		<legend><?php echo _mb("Character Encoding");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("The character encoding used in the data set. This element is mandatory only if an encoding is used that is not based on UTF-8.");?>'}" src="../img/questionmark.png" alt="" /></legend>
-		<select class="required charset_selectbox" id='inspire_charset' name='inspire_charset' size="2">
+		<select class="required charset_selectbox" id='inspire_charset' name='inspire_charset'>
 			<option value="utf8"><?php echo _mb("utf8");?></option>
 			<option value="latin1"><?php echo _mb("latin1");?></option>
 		</select>
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po	2011-06-09 10:47:08 UTC (rev 7848)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po	2011-06-09 11:09:55 UTC (rev 7849)
@@ -2440,7 +2440,7 @@
 msgstr "bis"
 msgid "Maintenance and update frequency"
-msgstr ""
+msgstr "Pflege-/ Aktualisierungszyklus"
 msgid "Frequency with which changes and additions are made to the resource after the initial resource is completed. Notice: This value may change the value of the end date of temporal extent. The end date will be computed automatically from the current timestamp if a cyclic update is defined!"
 msgstr "Intervall in dem Änderungen und Anpassungen an der Ressource erfolgen nach dem diese erstmalig erstellt wurde. Hinweis: Eine Auswahl eines regelmäßigen Aktualisierungsintervalls ändert den Endzeitpunkt der zeitlichen Ausdehnung. Der Endzeitpunkt wird dann immer anhand des aktuellen Datums berechnet. Da die Metadaten dynamisch erzeugt werden, muss man sie nicht mehr händisch anpassen."
More information about the Mapbender_commits mailing list
