[Mapbender-commits] r7879 - in trunk/mapbender: http/extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe http/plugins resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 21 09:54:51 EDT 2011
Author: armin11
Date: 2011-06-21 06:54:51 -0700 (Tue, 21 Jun 2011)
New Revision: 7879
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.js
   trunk/mapbender/http/plugins/mb_print.php
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.1_to_2.7.2_pgsql_UTF-8.sql
Bugfixe for ie9 and printPDF module. The bgiframe js had problems and was replaced by the newer 2.1.2 version. The minified script should not be used any more. One problem remains: The jquery ui dialogs are not draggable with ie9?
Modified: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.js	2011-06-19 15:52:39 UTC (rev 7878)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.js	2011-06-21 13:54:51 UTC (rev 7879)
@@ -1,100 +1,40 @@
-/* Copyright (c) 2006 Brandon Aaron (http://brandonaaron.net)
- * Dual licensed under the MIT (http://www.opensource.org/licenses/mit-license.php)
- * and GPL (http://www.opensource.org/licenses/gpl-license.php) licenses.
- * $LastChangedDate: 2007-07-21 18:44:59 -0500 (Sat, 21 Jul 2007) $
- * $Rev: 2446 $
- * Version 2.1.1
+/*! Copyright (c) 2010 Brandon Aaron (http://brandonaaron.net)
+* Licensed under the MIT License (LICENSE.txt).
+* Version 2.1.2
 (function($){
- * The bgiframe is chainable and applies the iframe hack to get
- * around zIndex issues in IE6. It will only apply itself in IE6
- * and adds a class to the iframe called 'bgiframe'. The iframe
- * is appeneded as the first child of the matched element(s)
- * with a tabIndex and zIndex of -1.
- * By default the plugin will take borders, sized with pixel units,
- * into account. If a different unit is used for the border's width,
- * then you will need to use the top and left settings as explained below.
- * NOTICE: This plugin has been reported to cause perfromance problems
- * when used on elements that change properties (like width, height and
- * opacity) a lot in IE6. Most of these problems have been caused by
- * the expressions used to calculate the elements width, height and
- * borders. Some have reported it is due to the opacity filter. All
- * these settings can be changed if needed as explained below.
- * @example $('div').bgiframe();
- * @before <div><p>Paragraph</p></div>
- * @result <div><iframe class="bgiframe".../><p>Paragraph</p></div>
- * @param Map settings Optional settings to configure the iframe.
- * @option String|Number top The iframe must be offset to the top
- * 		by the width of the top border. This should be a negative
- *      number representing the border-top-width. If a number is
- * 		is used here, pixels will be assumed. Otherwise, be sure
- *		to specify a unit. An expression could also be used.
- * 		By default the value is "auto" which will use an expression
- * 		to get the border-top-width if it is in pixels.
- * @option String|Number left The iframe must be offset to the left
- * 		by the width of the left border. This should be a negative
- *      number representing the border-left-width. If a number is
- * 		to get the border-left-width if it is in pixels.
- * @option String|Number width This is the width of the iframe. If
- *		a number is used here, pixels will be assume. Otherwise, be sure
- * 		to specify a unit. An experssion could also be used.
- *		By default the value is "auto" which will use an experssion
- * 		to get the offsetWidth.
- * @option String|Number height This is the height of the iframe. If
- * 		to get the offsetHeight.
- * @option Boolean opacity This is a boolean representing whether or not
- * 		to use opacity. If set to true, the opacity of 0 is applied. If
- *		set to false, the opacity filter is not applied. Default: true.
- * @option String src This setting is provided so that one could change
- *		the src of the iframe to whatever they need.
- *		Default: "javascript:false;"
- * @name bgiframe
- * @type jQuery
- * @cat Plugins/bgiframe
- * @author Brandon Aaron (brandon.aaron at gmail.com || http://brandonaaron.net)
-$.fn.bgIframe = $.fn.bgiframe = function(s) {
-	// This is only for IE6
-	if ( $.browser.msie && /6.0/.test(navigator.userAgent) ) {
-		s = $.extend({
-			top     : 'auto', // auto == .currentStyle.borderTopWidth
-			left    : 'auto', // auto == .currentStyle.borderLeftWidth
-			width   : 'auto', // auto == offsetWidth
-			height  : 'auto', // auto == offsetHeight
-			opacity : true,
-			src     : 'javascript:false;'
-		}, s || {});
-		var prop = function(n){return n&&n.constructor==Number?n+'px':n;},
-		    html = '<iframe class="bgiframe"frameborder="0"tabindex="-1"src="'+s.src+'"'+
-		               'style="display:block;position:absolute;z-index:-1;'+
-			               (s.opacity !== false?'filter:Alpha(Opacity=\'0\');':'')+
-					       'top:'+(s.top=='auto'?'expression(((parseInt(this.parentNode.currentStyle.borderTopWidth)||0)*-1)+\'px\')':prop(s.top))+';'+
-					       'left:'+(s.left=='auto'?'expression(((parseInt(this.parentNode.currentStyle.borderLeftWidth)||0)*-1)+\'px\')':prop(s.left))+';'+
-					       'width:'+(s.width=='auto'?'expression(this.parentNode.offsetWidth+\'px\')':prop(s.width))+';'+
-					       'height:'+(s.height=='auto'?'expression(this.parentNode.offsetHeight+\'px\')':prop(s.height))+';'+
-		return this.each(function() {
-			if ( $('> iframe.bgiframe', this).length == 0 )
-				this.insertBefore( document.createElement(html), this.firstChild );
-	return this;
+$.fn.bgiframe = ($.browser.msie && /msie 6\.0/i.test(navigator.userAgent) ? function(s) {
+    s = $.extend({
+        top : 'auto', // auto == .currentStyle.borderTopWidth
+        left : 'auto', // auto == .currentStyle.borderLeftWidth
+        width : 'auto', // auto == offsetWidth
+        height : 'auto', // auto == offsetHeight
+        opacity : true,
+        src : 'javascript:false;'
+    }, s);
+    var html = '<iframe class="bgiframe"frameborder="0"tabindex="-1"src="'+s.src+'"'+
+                   'style="display:block;position:absolute;z-index:-1;'+
+                       (s.opacity !== false?'filter:Alpha(Opacity=\'0\');':'')+
+                       'top:'+(s.top=='auto'?'expression(((parseInt(this.parentNode.currentStyle.borderTopWidth)||0)*-1)+\'px\')':prop(s.top))+';'+
+                       'left:'+(s.left=='auto'?'expression(((parseInt(this.parentNode.currentStyle.borderLeftWidth)||0)*-1)+\'px\')':prop(s.left))+';'+
+                       'width:'+(s.width=='auto'?'expression(this.parentNode.offsetWidth+\'px\')':prop(s.width))+';'+
+                       'height:'+(s.height=='auto'?'expression(this.parentNode.offsetHeight+\'px\')':prop(s.height))+';'+
+    return this.each(function() {
+        if ( $(this).children('iframe.bgiframe').length === 0 )
+            this.insertBefore( document.createElement(html), this.firstChild );
+} : function() { return this; });
-})(jQuery);
\ No newline at end of file
+// old alias
+$.fn.bgIframe = $.fn.bgiframe;
+function prop(n) {
+    return n && n.constructor === Number ? n + 'px' : n;
+})(jQuery);
Modified: trunk/mapbender/http/plugins/mb_print.php
--- trunk/mapbender/http/plugins/mb_print.php	2011-06-19 15:52:39 UTC (rev 7878)
+++ trunk/mapbender/http/plugins/mb_print.php	2011-06-21 13:54:51 UTC (rev 7879)
@@ -19,7 +19,7 @@
  * > 2,1,'pdf print','Print','div','','',1,1,2,2,5,'',
  * > '<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>',
  * > 'div','../plugins/mb_print.php',
- * > '../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../extensions/jquery.form.min.js',
+ * > '../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.js,../extensions/jquery.form.min.js',
  * > 'mapframe1','','http://www.mapbender.org/index.php/Print');
  * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.1_to_2.7.2_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.1_to_2.7.2_pgsql_UTF-8.sql	2011-06-19 15:52:39 UTC (rev 7878)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.1_to_2.7.2_pgsql_UTF-8.sql	2011-06-21 13:54:51 UTC (rev 7879)
@@ -83,3 +83,7 @@
  (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'loadwmc' AND fkey_gui_id NOT IN (
 	SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_dialog'
+-- Bugfix for ie9 startup problem. problem with dialogs remain - they cannot be dragged
+UPDATE gui_element SET e_mb_mod = '../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.js,../extensions/jquery.form.min.js,../extensions/wz_jsgraphics.js' WHERE e_id = 'printPDF';
More information about the Mapbender_commits mailing list
