[Mapbender-commits] r7892 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org
Wed Jun 29 10:04:21 EDT 2011
Author: armin11
Date: 2011-06-29 07:04:21 -0700 (Wed, 29 Jun 2011)
New Revision: 7892
trunk/mapbender/http/geoportal/mod_readOpenSearchResults.php
trunk/mapbender/http/geoportal/mod_readOpenSearchResultsDetail.php
Bugfix. First version which uses the portalu csw getrecordbyid request. Not yet ready!
Modified: trunk/mapbender/http/geoportal/mod_readOpenSearchResults.php
--- trunk/mapbender/http/geoportal/mod_readOpenSearchResults.php 2011-06-29 08:42:16 UTC (rev 7891)
+++ trunk/mapbender/http/geoportal/mod_readOpenSearchResults.php 2011-06-29 14:04:21 UTC (rev 7892)
@@ -342,7 +342,7 @@
- fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&mdtype=html"));
+ fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&docuuid=".$docuuid."&mdtype=html"));
fwrite($os_catalogs_file_handle,"</catalogtitlelink>\n");
#Tags for objecttitle and abstract
@@ -396,10 +396,10 @@
#fwrite($os_catalogs_file_handle,"");
fwrite($os_catalogs_file_handle,"<iso19139url>");
- fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&mdtype=iso19139"));
+ fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&docuuid=".$docuuid."&mdtype=iso19139"));
fwrite($os_catalogs_file_handle,"</iso19139url>\n");
fwrite($os_catalogs_file_handle,"<inspireurl>");
- fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&mdtype=inspire"));
+ fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&docuuid=".$docuuid."&mdtype=inspire"));
fwrite($os_catalogs_file_handle,"</inspireurl>\n");
#end of resultlist
fwrite($os_catalogs_file_handle,"</result>\n");
Modified: trunk/mapbender/http/geoportal/mod_readOpenSearchResultsDetail.php
--- trunk/mapbender/http/geoportal/mod_readOpenSearchResultsDetail.php 2011-06-29 08:42:16 UTC (rev 7891)
+++ trunk/mapbender/http/geoportal/mod_readOpenSearchResultsDetail.php 2011-06-29 14:04:21 UTC (rev 7892)
@@ -3,18 +3,8 @@
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
-#function logit($text){
- #if($h = fopen("/home/armin/Desktop/opensearch_log.txt","a")){
- # $content = $text .chr(13).chr(10);
- # if(!fwrite($h,$content)){
- # #exit;
- # fclose($h);
-#require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
require_once(dirname(__FILE__)."/../classes/class_connector.php");
function display_text($string) {
$string = eregi_replace("[[:alpha:]]+://[^<>[:space:]]+[[:alnum:]/]", "<a href=\"\\0\" target=_blank>\\0</a>", $string);
$string = eregi_replace("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@([0-9a-z](-?[0-9a-z])*\.)+[a-z]{2}([zmuvtg]|fo|me)?$", "<a href=\"mailto:\\0\" target=_blank>\\0</a>", $string);
@@ -22,493 +12,45 @@
return $string;
+$md_ident = array(
+ array( ibus => "t01_object.obj_id",
+ iso19139 => "/gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString",
+ iso19139explode => "false" ,
+ inspire => "unique resource identifier",
+ inspiremandatory => "true",
+ iso_name => "fileIdentifier",
+ html => _mb("Metadata file identifier"),
+ value => "",
+ gdescription => "Ein Wert, durch den die Ressource eindeutig gekennzeichnet wird. Der Wertebereich dieses Metadatenelements ist ein obligatorischer Zeichenkettencode, der in der Regel vom Eigentümer der Daten zugeordnet wird, und ein Zeichenketten-Namensraum, der das Umfeld des Bezeichnercodes eindeutig bestimmt (z. B. den Eigentümer der Daten). "
+ array( ibus => "abstract",
+ iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:abstract/gco:CharacterString",
+ inspire => "resource abstract",
+ iso_name => "description",
+ html => _mb("Metadata description"),
+ value => "",
+ gdescription => "Description"
- $md_ident=array(
- array( ibus => "object_node.fk_obj_uuid",
- iso19139 => "MD_Metadata.parentIdentifier",
- iso19139explode => "false" ,
- inspire => "",
- inspiremandatory => "false",
- iso_name => "",
- html => "Identifikator des übergeordneten Objektes",
- gdescription => ""),
- array( ibus => "t01_object",
- iso19139 => "MD_Metadata.fileIdentifier",
- inspire => "",
- iso_name => "",
- html => "Objectidentifikator",
- array( ibus => "t01_object.obj_name",
- iso19139 => "MD_Metadata.identificationInfo?",
- inspire => "",
- iso_name => "",
- html => "Objektname",
- array( ibus => "t01_object.obj_class",
- iso19139 => "",
- inspire => "",
- iso_name => "",
- html => "ID der Objektklasse",
- gdescription => "Relevant sind 1 und 3"),
- array( ibus => "t01_object.info_note",
- iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.purpose",
- inspire => "",
- iso_name => "",
- html => "Herstellungszweck",
- gdescription => "Zusatzinformation"),
- array( ibus => "t01_object.loc_descr",
- iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.description",
- inspire => "",
- iso_name => "",
- html => "Raumbezug:Erläuterung",
- gdescription => "Raumbezug"),
- array( ibus => "t01_object.time_from",
- iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.EX_Extent.temporalElement.EX_TemporalExtent.....",
- inspire => "",
- iso_name => "",
- html => "Zeitbezug des Dateninhalts von:",
- gdescription => "Zeitbezug"),
- array( ibus => "t01_object.time_to",
- inspire => "",
- iso_name => "",
- html => "Zeitbezug des Dateninhalts bis:",
- array( ibus => "t011_obj_literatur.base",
- iso19139 => "MD_Metadata.identificationInfo.MD_Identification.descriptiveKeywords.MD_Keywords.keyword",
- iso19139explode => "true" ,
- inspire => "B 3.1 Keyword value",
- inspiremandatory => "true",
- iso_name => "descriptive Keywords",
- html => "INSPIRE Thema",
- array( ibus => "t04_search.searchterm",
- html => "Suchbegriffe",
- array( ibus => "title",
- iso19139 => "identificationInfo[1]/*/citation/*/title",
- inspire => "B 1.1 Resource title",
- iso_name => "Title",
- html => "Titel",
- array( ibus => "t0113_dataset_reference.reference_date",
- iso19139 => "",
- inspire => "B 5.2 Date of publication",
- iso_name => "Date of publication",
- html => "Veröffentlichungsdatum",
- array( ibus => "t01_object.time_status",
- iso19139 => "",
- inspire => "B 5.3 Date of revision",
- iso_name => "Date of revision",
- html => "Datum der letzten Überarbeitung",
- array( ibus => "txx", #to find
- iso19139 => "",
- inspire => "B 5.4 Date of creation",
- iso_name => "Date of creation",
- html => "Erzeugungsdatum",
- array( ibus => "summary",
- iso19139 => "identificationInfo[1]/*/abstract",
- inspire => "B 1.2 Resource abstract",
- iso_name => "abstract",
- html => "Zusammenfassung",
- array( ibus => "t011_obj_serv.type",
- iso19139 => "MD_Metadata.identificationInfo.SV_ServiceIdentification.serviceType",
- inspire => "B 2.2 Spatial data service type",
- iso_name => "ServiceType",
- html => "Typ des Dienstes",
- array( ibus => "t011_obj_serv_version.version",
- iso19139 => "MD_Metadata.identificationInfo.SV_ServiceIdentification.serviceTypeVersion",
- inspire => "",
- iso_name => "Service Type Version",
- html => "Version des Dienstes",
- array( ibus => "x1",
- //array( ibus => "spatial_ref_value.x1",
- iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.EX_GeographicBoundingBox.WestBoundLongitude",
- inspire => "B 4.1 Geographic bounding box - western longitude",
- iso_name => "WestBoundLongitude",
- html => "Westliche Begrenzung (geographische Länge)",
- array( ibus => "y1",
- iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.EX_GeographicBoundingBox.SouthBoundLatitude",
- inspire => "B 4.1 Geographic bounding box - southern latitude",
- iso_name => "SouthBoundLatitude",
- html => "Südliche Begrenzung (geographische Breite)",
- array( ibus => "x2",
- iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.EX_GeographicBoundingBox.EastBoundLongitude",
- inspire => "B 4.1 Geographic bounding box - eastern longitude",
- iso_name => "EastBoundLongitude",
- html => "Östliche Begrenzung (geographische Länge)",
- array( ibus => "y2",
- iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.EX_GeographicBoundingBox.NorthBoundLatitude",
- inspire => "B 4.1 Geographic bounding box - northern latitude",
- iso_name => "NorthBoundLatitude",
- html => "Nördliche Begrenzung (geographische Breite)",
- array( ibus => "t01_object.metadata_language",
- iso19139 => "MD_Metadata.language",
- inspire => "B 10.3 Metadata language",
- iso_name => "Metadata language",
- html => "Sprache des Metadatensatzes",
- iso19139 => "MD_Metadata.identificationInfo.MD_Identification.citation.CI_Citation.alternateTitle",
- inspire => "",
- iso_name => "Dataset alternate title",
- html => "Kurzbezeichnung",
- array( ibus => "t011_object_geo.special_base",
- iso19139 => "MD_Metadata.dataQualityInfo.lineage.LI_Lineage.statement",
- inspire => "B 6.1 Lineage",
- iso_name => "B 1.6 Lineage",
- html => "Informationen zum Herstellungsprozess",
- array( ibus => "t011_object_geo.rec_exact",
- iso19139 => "MD_Metadata.dataQualityInfo.lineage.DQ_DataQuality.report.DQ_RelativeInternalPositionAccuracy.value",
- inspire => "",
- iso_name => "",
- html => "Fachliche Grundlage",
- array( ibus => "t011_object_geo_scale.scale",
- iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.spatialResolution.MD_Resolution.equivalentScale.MD_RepresentativeFraction.denominator",
- inspire => "B 6.2 Spatial Resolution",
- iso_name => "",
- html => "Erstellungsmaßstab->Maßstab",
- array( ibus => "t011_object_geo_scale.resolution_ground",
- iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.spatialResolution.MD_Resolution.distance",
- iso_name => "",
- html => "Erstellungsmaßstab->Bodenauflösung",
-#The resolutions for services will be hold in different objects!
- array( ibus => "t011_object_serv_scale.scale",
- iso_name => "",
- gdescription => "Auflösung bei Diensten"),
- array( ibus => "t011_object_serv_scale.resolution_ground",
- iso_name => "",
- array( ibus => "t011_obj_geo_spatial_rep",
- iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.spatialRepresentationType.MD_SpatialRepresentationTypeCode",
- inspire => "",
- iso_name => "",
- html => "Digitale Repräsentation",
- array( ibus => "t011_obj_geo.hierarchy_level",
- iso19139 => "MD_Metadata.hierachyLevelName",
- inspire => "B 1.3 Resource Type",
- iso_name => "hierachyLevelName",
- html => "Datensatz/Datenserie",
- array( ibus => "t012_obj_obj.object_from_id",
- inspire => "",
- iso_name => "Parent Identifier",
- html => "Identifikator des übergeordneten Datensatzes",
- array( ibus => "t02_address.city",
- iso19139 => "",
- iso19139explode => "" ,
- inspire => "",
- iso_name => "",
- html => "Stadt",
- array( ibus => "t02_address.institution",
- iso19139 => "",
- inspire => "",
- iso_name => "",
- html => "Organisation",
- array( ibus => "t02_address.firstname",
- iso19139 => "",
- inspire => "",
- iso_name => "",
- html => "Vorname",
- array( ibus => "t02_address.lastname",
- iso19139 => "",
- inspire => "",
- iso_name => "",
- html => "Nachname",
- array( ibus => "t02_address.postcode",
- iso19139 => "",
- inspire => "",
- iso_name => "",
- html => "Postleitzahl",
- array( ibus => "t02_address.street",
- iso19139 => "",
- inspire => "",
- iso_name => "",
- html => "Straße",
- array( ibus => "t021_communication.comm_value",
- iso19139 => "",
- inspire => "B 10.1 Metadata point of contact email",
- iso_name => "",
- html => "Email - Verantwortlicher für Metadaten",
-array( ibus => "t011_obj_literature.publisher",
- iso19139 => "",
- inspire => "B 10.1 Metadata Contact Organisation",
- iso_name => "",
- html => "Verantwortliche Organisation für Metadaten",
- array( ibus => "t011_obj_literature_publishing",
- iso19139 => "",
- inspire => "B 9.1 Responsible party organisation",
- iso_name => "",
- html => "Verantwortliche Organisation",
- array( ibus => "t012_obj_adr.special_name",
- iso19139 => "",
- inspire => "B 9.2 Responsible party role",
- iso_name => "",
- html => "Rolle der verantwortlichen Organisation",
- array( ibus => "t017_url_ref.content",
- iso19139 => "",
- inspire => "",
- iso_name => "",
- html => "Art des Links",
- array( ibus => "t017_url_ref.url_link",
- iso19139 => "",
- inspire => "",
- iso_name => "",
- html => "Link",
- array( ibus => "t01_object.obj_id",
- iso19139 => "",
- inspire => "",
- iso_name => "",
- html => "Objektidentifikator",
- array( ibus => "t01_object.obj_uuid",
- iso19139 => "?",
- inspire => "",
- iso_name => "",
- html => "Eindeutiger Objektidentifikator",
- iso19139 => "",
- inspire => "B 1.5 Unique resource identifier",
- iso_name => "",
- html => "Name des Objektes",
- array( ibus => "t01_object.mod_time",
- iso19139 => "",
- inspire => "B 10.2 Metadata date",
- iso_name => "",
- html => "Datum des Metadatensatzes",
- array( ibus => "t011_obj_serv_type.serv_type_key",
- inspire => "B 2.2 Spatial Data Service Type",
- iso_name => "",
- html => "Version des Services",
- array( ibus => "t011_obj_serv_op_connpoint.connect_point",
- iso19139 => "",
- inspire => "",
- iso_name => "",
- html => "URL zum Online Aufruf",
- array( ibus => "t01_object.avail_access_note",
- iso19139 => "identificationInfo[1]/*/resourceConstraints/*/accessConstraints",
- inspire => "B 8.1 Condition applying to access and use",
- iso_name => "",
- html => "Zugriffsbeschränkungen",
- array( ibus => "t01_object.fees",
- iso19139 => "identificationInfo[1]/*/resourceConstraints/*/useLimitation",
- inspire => "B 8.2 Limitations on public access",
- iso_name => "",
- html => "Kosten/Gebühren",
- array( ibus => "t01_object.data_language",
- iso19139 => "",
- inspire => "B 1.7 Resource Language",
- iso_name => "",
- html => "Sprache des Datensatzes",
- array( ibus => "t011_obj_geo_topic_cat.topic_category",
- iso19139 => "identificationInfo[1]/*/topicCategory",
- inspire => "B 2.1 Topic Category",
- iso_name => "Topic Category",
- html => "Kategorie",
- gdescription => "ISO Kategorie")
- #array( ibus => "t011_obj_geo_topic_cat.topic.topic_category",
- #iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.topicCategory",
- #iso19139explode => "true" ,
- #inspire => "",
- #inspiremandatory => "false",
- #iso_name => "Dataset topic category",
- #html => "Kategorisierung",
- #gdescription => "")
-if(!isset($_REQUEST["osid"]) )
+if(!isset($_REQUEST["osid"]) ) {
echo "no opensearch id set";
die();
-else
- if(isset($_REQUEST["mdtype"])&($_REQUEST["mdtype"]=='debug') )
+} else {
+ if(isset($_REQUEST["mdtype"])&($_REQUEST["mdtype"]=='debug') ) {
echo "opensearch interface no.: ".$_REQUEST["osid"]." will be requested<br>";
+if(!isset($_REQUEST["docuuid"]) ) {
+ echo "No uuid of dataset given!";
+ die();
+} else {
+ $docuuid = $_REQUEST["docuuid"];
#***get the information out of the mapbender-db
#get url to search interface (opensearch):
@@ -528,120 +70,120 @@
$os_list[$cnt_os] ['url']= $row_os["os_url"];
$os_list[$cnt_os] ['h']= $row_os["os_h"];
$os_list[$cnt_os] ['standardfilter']= $row_os["os_standard_filter"];
-#os_standard_filter
+ $os_list[$cnt_os] ['version']= $row_os["os_version"];
$cnt_os++;
#give out count of interfaces to use
#echo "\nCount of registrated OpenSearch Interfaces: ".count($os_list)."\n";
+switch ($os_list[0] ['version']) {
+ case 2:
+ #define new csw get record by id search like:
+ #http://www.portalu.de/csw202?request=GetRecordById&service=CSW&version=2.0.2&Id=81FF8BB2-2753-4A95-8C1E-F78C19035780&ElementSetName=full
+ $openSearchUrlDetail = $os_list[0] ['url'];
+ //exchange opensearch with csw202?
+ $openSearchUrlDetail = str_replace('opensearch/', 'csw202?', $openSearchUrlDetail);
+ $url = $openSearchUrlDetail."request=GetRecordById&service=CSW&version=2.0.2&Id=".$docuuid."&ElementSetName=full";
+ break;
+ default:
+ #define opensearch detail url
+ $openSearchUrlDetail=$os_list[0] ['url']."detail?";
+ #get resultlists
+ $url=$openSearchUrlDetail."plugid=".$_REQUEST['plugid']."&docid=".$_REQUEST['docid'];
+ break;
- #define opensearch detail url
- $openSearchUrlDetail=$os_list[0] ['url']."detail?";
- #get resultlists
- $url=$openSearchUrlDetail."plugid=".$_REQUEST['plugid']."&docid=".$_REQUEST['docid'];
-if(isset($_REQUEST["mdtype"])&($_REQUEST["mdtype"]=='debug') )
+if(isset($_REQUEST["mdtype"])&($_REQUEST["mdtype"]=='debug') ) {
echo "<br> REQUEST: ".$url."<br>";
- #create connector object
- $openSearchObject = new connector($url);
- #get results
- $openSearchDetail = $openSearchObject->file;
- #save resultset in temporary folder identified by sessionid, katalog_id and page_id! Now there would be more tmp files than before!
- #this has to be done in order to give the information to typo3
- #**************to be done!************************************
- #parse result to simplexml
- #$openSearchXml=simplexml_load_string($openSearchDetail);
+#create connector object
+$openSearchObject = new connector($url);
+#get results
+$openSearchDetail = $openSearchObject->file;
- $openSearchDetailXML=simplexml_load_string($openSearchDetail);
- #*****************************bbox********************************************
- #do things for getting the bbox of the object in crs of last defined mapbender
- #read out the epsg from session
- #read out the bbox if exists
- #transform bbox from wgs84 to last epsg of mapbender
+#$openSearchDetail = str_replace('xmlns=', 'ns=', $openSearchDetail);
+$openSearchDetailXML=simplexml_load_string($openSearchDetail);
+#extract objects to iso19139 elements
+$openSearchDetailXML->registerXPathNamespace("csw", "http://www.opengis.net/cat/csw/2.0.2");
+$openSearchDetailXML->registerXPathNamespace("gml", "http://www.opengis.net/gml");
+$openSearchDetailXML->registerXPathNamespace("gco", "http://www.isotc211.org/2005/gco");
+$openSearchDetailXML->registerXPathNamespace("gmd", "http://www.isotc211.org/2005/gmd");
+$openSearchDetailXML->registerXPathNamespace("gts", "http://www.isotc211.org/2005/gts");
+$openSearchDetailXML->registerXPathNamespace("srv", "http://www.isotc211.org/2005/srv");
- #extract objects to iso19139 elements
- #count unidentified elements
- $i=0;
+if ($_REQUEST['mdtype']=='iso19139') {
+ header("Content-type: application/xhtml+xml; charset=UTF-8");
+ //delete scw entries from response file
+ $MD_Metadata = str_replace('<csw:GetRecordByIdResponse xmlns:csw="http://www.opengis.net/cat/csw/2.0.2">', '', $openSearchDetail);
+ $MD_Metadata = str_replace('</csw:GetRecordByIdResponse>', '', $MD_Metadata);
+ echo $MD_Metadata;
+ die();
- #get list for ibus variables - cause php is row major
- $ibus_names = array();
- for($a = 0; $a < count($md_ident); $a++) {
- $ibus_names[$a] = $md_ident[$a]["ibus"];
- echo "ibus_names[".$a."]=".$md_ident[$a]["ibus"]."<br>";
+ #count unidentified elements
+ $i=0;
+ #get list for ibus variables - cause php is row major
+ $ibus_names = array();
+ for($a = 0; $a < count($md_ident); $a++) {
+ $ibus_names[$a] = $md_ident[$a]["ibus"];
+ echo "ibus_names[".$a."]=".$md_ident[$a]["ibus"]."<br>";
- #define array of key-value pairs
- $detail_array=array();
- #read key-value pairs
- $j=0;
+ $detail_array=array();
+ #read key-value pairs
+ $j=0;
+ switch ($os_list[0] ['version']) {
+ case 2:
+ #echo $url."<br><br>";
+ //register namespaces:
+/* <gmd:MD_Metadata xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gml="http://www.opengis.net/gml" xmlns:gts="http://www.isotc211.org/2005/gts" xmlns:srv="http://www.isotc211.org/2005/srv" id="_ingrid-group_iplug-rp-udk-db_263">*/
+ $resultOfXpath = $openSearchDetailXML->xpath('/csw:GetRecordByIdResponse'.$md_ident[$a]['iso19139']);
+ $md_ident[$a]['value'] = $resultOfXpath[0];
+ echo "<b>".$md_ident[$a]['html']."</b>: ".$md_ident[$a]['value']."<br><br>";
+ echo "Version of PortalU CSW interface is currently not yet full supported! We work on the new Interface.<br> Please use the link <b>Originäre Metadaten</b> instead.";
+ die();
+ break;
+ default:
foreach ( $openSearchDetailXML->channel->item->details->detail as $detail) {
$detail_key=(string)$detail->{'detail-key'}; #cast explicitly to string
$detail_value=(string)$detail->{'detail-value'};
$detail_array[$detail_key] = $detail_value;
$detail_keys[$j]=$detail_key;
- # echo "Key: ".$detail->{'detail-key'}."<br>";
- # echo "array: ".$detail_array[$detail_key]."<br>"; #gives values
- #check if key is in array else count failures
if (in_array($detail_key, $ibus_names)) {
echo "Key <b>".$detail_key."</b> exists in lookup table!<br>";
$i++;
- $j++;
+ $j++;
- echo "<br>".$i." elements have been identified!<br>";
+ break;
+ echo "<br>".$i." elements have been identified!<br>";
-#$test1=in_array('t04_search.searchterm', $ibus_names);
-#$test2=array_search('t04_search.searchterm', $ibus_names);
-#if ($test1){echo "found at position: ".$test2."<br>";}
-#else
-#{echo "not found<br>";}
- var_dump($detail_keys);
+ var_dump($detail_keys);
if ($_REQUEST['mdtype']=='debug'){
echo "DEBUG Metadatenanzeige<br>";
#define table
@@ -723,479 +265,6 @@
-if ($_REQUEST['mdtype']=='iso19139') {
-//echo '<br><b>ISO19139 output comming soon!</b><br>';
-$iso19139 = new DOMDocument('1.0');
-$iso19139->encoding = 'UTF-8';
-#$iso19139->standalone = false;
-#Creating the "MD_Metadata" node
-$MD_Metadata = $iso19139->createElementNS('http://www.isotc211.org/2005/gmd', 'gmd:MD_Metadata');
-#$MD_Metadata=$iso19139->registerNamespace('srv','http://www.iso211.org/2005/srv');
-#$wmt_ms_capabilities->setAttribute("updateSequence", $wms_row["wms_timestamp"]);
-$MD_Metadata = $iso19139->appendChild($MD_Metadata);
-$MD_Metadata->setAttribute("xmlns:srv", "http://www.isotc211.org/2005/srv");
-$MD_Metadata->setAttribute("xmlns:gml", "http://www.opengis.net/gml");
-$MD_Metadata->setAttribute("xmlns:gco", "http://www.isotc211.org/2005/gco");
-$MD_Metadata->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
-$MD_Metadata->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
-$MD_Metadata->setAttribute("xsi:schemaLocation", "http://www.isotc211.org/2005/gmd ./xsd/gmd/gmd.xsd://www.isotc211.org/2005/srv ./xsd/srv/srv.xsd");
-#generate language part B 10.3 (if available)
-$language = $iso19139->createElement("gmd:language");
-$languagecode = $iso19139->createElement("gmd:LanguageCode");
-if (isset($detail_array['t01_object.metadata_language'])) {
-$languageText = $iso19139->createTextNode($detail_array['t01_object.metadata_language']);
-else {
-$languageText = $iso19139->createTextNode("not yet defined");
-$languagecode->appendChild($languageText);
-$language ->appendChild($languagecode);
-$language=$MD_Metadata->appendChild($language);
-#generate MD_Scope part B 1.3 (if available)
-$hierarchyLevel = $iso19139->createElement("gmd:hierarchyLevel");
-$scopecode = $iso19139->createElement("gmd:MD_ScopeCode");
-if (isset($detail_array['t011_obj_geo.hierarchy_level'])) {
-$scopeText = $iso19139->createTextNode($detail_array['t011_obj_geo.hierarchy_level']);
-else {
-$scopeText = $iso19139->createTextNode("not yet defined");
-$scopecode->appendChild($scopeText);
-$hierarchyLevel->appendChild($scopecode);
-$hierarchyLevel=$MD_Metadata->appendChild($hierarchyLevel);
-#Part B 10.1
-$contact=$iso19139->createElement("gmd:contact");
-$CI_ResponsibleParty=$iso19139->createElement("gmd:CI_ResponsibleParty");
-$organisationName=$iso19139->createElement("gmd:organisationName");
-$organisationName_cs=$iso19139->createElement("gco:CharacterString");
-if (isset($detail_array['t011_obj_literatur.publisher'])) {
-$organisationNameText=$iso19139->createTextNode($detail_array['t011_obj_literatur.publisher']);
-else
-$organisationNameText=$iso19139->createTextNode('not given');
-$contactInfo=$iso19139->createElement("gmd:contactInfo");
-$CI_Contact=$iso19139->createElement("gmd:CI_Contact");
-$address=$iso19139->createElement("gmd:address");
-$CI_Address=$iso19139->createElement("gmd:CI_Address");
-$electronicMailAddress=$iso19139->createElement("gmd:electronicMailAddress");
-$electronicMailAddress_cs=$iso19139->createElement("gco:CharacterString");
-if (isset($detail_array['t021_communication.comm_value'])) {
-$electronicMailAddressText=$iso19139->createTextNode($detail_array['t021_communication.comm_value']);
-else
-$electronicMailAddressText=$iso19139->createTextNode('not given');
-#create xml tree
-$organisationName_cs->appendChild($organisationNameText);
-$organisationName->appendChild($organisationName_cs);
-$CI_ResponsibleParty->appendChild($organisationName);
-$electronicMailAddress_cs->appendChild($electronicMailAddressText);
-$electronicMailAddress->appendChild($electronicMailAddress_cs);
-$CI_Address->appendChild($electronicMailAddress);
-$address->appendChild($CI_Address);
-$CI_Contact->appendChild($address);
-$contactInfo->appendChild($CI_Contact);
-$CI_ResponsibleParty->appendChild($contactInfo);
-$contact->appendChild($CI_ResponsibleParty);
-$MD_Metadata->appendChild($contact);
-#generate dateStamp part B 10.2 (if available)
-$dateStamp = $iso19139->createElement("gmd:dateStamp");
-$mddate = $iso19139->createElement("gco:Date");
-if (isset($detail_array['t01_object.mod_time'])) {
-$mddateText = $iso19139->createTextNode($detail_array['t01_object.mod_time']);
-else {
-$mddateText = $iso19139->createTextNode("not yet defined");
-$mddate->appendChild($mddateText);
-$dateStamp->appendChild($mddate);
-$dateStamp=$MD_Metadata->appendChild($dateStamp);
-#do the things for identification
-#create nodes
-$identificationInfo=$iso19139->createElement("gmd:identificationInfo");
-$MD_DataIdentification=$iso19139->createElement("gmd:MD_DataIdentification");
-#add attribut
-$MD_DataIdentification->setAttribute("id", "dataId");
-$citation=$iso19139->createElement("gmd:citation");
-$CI_Citation=$iso19139->createElement("gmd:CI_Citation");
-#create nodes for things which are defined - howto do the multiplicities? Ask Martin!
-#Create Resource title element B 1.1
-$title=$iso19139->createElement("gmd:title");
-$title_cs=$iso19139->createElement("gco:CharacterString");
-if (isset($detail_array['title'])) {
-$titleText = $iso19139->createTextNode($detail_array['title']);
-else {
-$titleText = $iso19139->createTextNode("not yet defined");
-$title_cs->appendChild($titleText);
-$title->appendChild($title_cs);
-$CI_Citation->appendChild($title);
-#Create date elements B5.2-5.4
-#Do things for B 5.2 date of publication
-if (isset($detail_array['t0113_dataset_reference.reference_date'])) {
-$date1=$iso19139->createElement("gmd:date");
-$CI_Date=$iso19139->createElement("gmd:CI_Date");
-$date2=$iso19139->createElement("gmd:date");
-$gcoDate=$iso19139->createElement("gco:Date");
-$dateType=$iso19139->createElement("gmd:dateType");
-$dateTypeCode=$iso19139->createElement("gmd:CI_DateTypeCode");
-$dateTypeCodeText=$iso19139->createTextNode('publication');
-$dateText= $iso19139->createTextNode($detail_array['t0113_dataset_reference.reference_date']);
-$dateTypeCode->appendChild($dateTypeCodeText);
-$dateType->appendChild($dateTypeCode);
-$gcoDate->appendChild($dateText);
-$date2->appendChild($gcoDate);
-$CI_Date->appendChild($date2);
-$CI_Date->appendChild($dateType);
-$date1->appendChild($CI_Date);
-$CI_Citation->appendChild($date1);
-#Do things for B 5.3 date of revision
-if (isset($detail_array['t01_object.time_status'])) {
-$dateTypeCodeText=$iso19139->createTextNode('revision');
-#Do things for B 5.4 date of creation
-if (isset($detail_array['txx'])) {
-$dateTypeCodeText=$iso19139->createTextNode('creation');
-#Do things for B 1.5 Resource unique identifier
-$identifier=$iso19139->createElement("gmd:identifier");
-$rs_identifier=$iso19139->createElement("gmd:RS_Identifier");
-$code=$iso19139->createElement("gmd:code");
-$code_cs=$iso19139->createElement("gco:CharacterString");
-$codeText=$iso19139->createTextNode($detail_array['t01_object.obj_id']);
-$code_cs->appendChild($codeText);
-$code->appendChild($code_cs);
-$rs_identifier->appendChild($code);
-$identifier->appendChild($rs_identifier);
-$CI_Citation->appendChild($identifier);
-#create tree
-$citation->appendChild($CI_Citation);
-$MD_DataIdentification->appendChild($citation);
-#Create part for abstract B 1.2
-$abstract=$iso19139->createElement("gmd:abstract");
-$abstract_cs=$iso19139->createElement("gco:CharacterString");
-if (isset($detail_array['summary'])) {
-$abstractText = $iso19139->createTextNode($detail_array['summary']);
-else {
-$abstractText = $iso19139->createTextNode("not yet defined");
-$abstract_cs->appendChild($abstractText);
-$abstract->appendChild($abstract_cs);
-$MD_DataIdentification->appendChild($abstract);
-#End for abstract
-#Create part for point of contact
-#Define relevant objects
-$pointOfContact=$iso19139->createElement("gmd:pointOfContact");
-$orgaName_cs=$iso19139->createElement("gco:CharacterString");
-$address_1=$iso19139->createElement("gmd:adress");
-$email_cs=$iso19139->createElement("gco:CharacterString");
-$role=$iso19139->createElement("gmd:role");
-$CI_RoleCode=$iso19139->createElement("gmd:CI_RoleCode");
-if (isset($detail_array['t011_obj_literature_publishing'])) {
-$resOrgaText = $iso19139->createTextNode($detail_array['t011_obj_literature_publishing']);
-else {
-$resOrgaText= $iso19139->createTextNode("not yet defined");
-if (isset($detail_array['tmail'])) {
-$resMailText = $iso19139->createTextNode($detail_array['tmail']);
-else {
-$resMailText = $iso19139->createTextNode("really wanted by INSPIRE?");
-if (isset($detail_array['t012_obj_adr.special_name'])) {
-$resRoleText = $iso19139->createTextNode($detail_array['t012_obj_adr.special_name']);
-else {
-$resRoleText = $iso19139->createTextNode("not yet defined");
-#put them in xml
-$orgaName_cs->appendChild($resOrgaText);
-$CI_ResponsibleParty->appendChild($orgaName_cs);
-$email_cs->appendChild($resMailText);
-$electronicMailAddress->appendChild($email_cs);
-$address_1->appendChild($CI_Address);
-$CI_Contact->appendChild($address_1);
-$CI_RoleCode->appendChild($resRoleText);
-$role->appendChild($CI_RoleCode);
-$CI_ResponsibleParty->appendChild($role);
-$pointOfContact->appendChild($CI_ResponsibleParty);
-$MD_DataIdentification->appendChild($pointOfContact);
-#Part B 3 INSPIRE Category
-#do only if INSPIRE keyword (Annex I-III) is set
-if (isset($detail_array['t011_obj_literatur.base'])) {
-$descriptiveKeywords=$iso19139->createElement("gmd:descriptiveKeywords");
-$MD_Keywords=$iso19139->createElement("gmd:MD_Keywords");
-$keyword=$iso19139->createElement("gmd:keyword");
-$keyword_cs=$iso19139->createElement("gco:CharacterString");
-$keywordText = $iso19139->createTextNode($detail_array['t011_obj_literatur.base']);
-$thesaurusName=$iso19139->createElement("gmd:thesaurusName");
-$titleText=$iso19139->createTextNode('GEMET Thesaurus version 1.0.0'); # to be adopted to get dynamically
-$date_1=$iso19139->createElement("gmd:date");
-$date_2=$iso19139->createElement("gmd:date");
-$date_date=$iso19139->createElement("gco:Date");
-$dateText=$iso19139->createTextNode('2008-12-08');
-$CI_DateTypeCode=$iso19139->createElement("gmd:CI_DateTypeCode");
-$CI_DateTypeCodeText=$iso19139->createTextNode('publication'); #to be adopted to get dynamically
-#write to xml tree
-$keyword_cs->appendChild($keywordText);
-$keyword->appendChild($keyword_cs);
-$MD_Keywords->appendChild($keyword);
-$CI_DateTypeCode->appendChild($CI_DateTypeCodeText);
-$dateType->appendChild($CI_DateTypeCode);
-$date_date->appendChild($dateText);
-$date_2->appendChild($date_date);
-$CI_Date->appendChild($date_2);
-$date_1->appendChild($CI_Date);
-$CI_Citation->appendChild($date_1);
-$thesaurusName->appendChild($CI_Citation);
-$MD_Keywords->appendChild($thesaurusName);
-$descriptiveKeywords->appendChild($MD_Keywords);
-$MD_DataIdentification->appendChild($descriptiveKeywords);
-#Resource Constraints B 8
-if (isset($detail_array['t01_object.avail_access_note'])){
-$resourceConstraints1=$iso19139->createElement("gmd:resourceConstraints");
-$MD_LegalConstraints1=$iso19139->createElement("gmd:MD_LegalConstraints");
-$accessConstraints=$iso19139->createElement("gmd:accessConstraints");
-$MD_RestrictionCode=$iso19139->createElement("gmd:MD_RestrictionCode");
-$MD_RestrictionCodeText=$iso19139->createTextNode($detail_array['t01_object.avail_access_note']);
-$MD_RestrictionCode->appendChild($MD_RestrictionCodeText);
-$accessConstraints->appendChild($MD_RestrictionCode);
-$MD_LegalConstraints1->appendChild($accessConstraints);
-$resourceConstraints1->appendChild($MD_LegalConstraints1);
-$MD_DataIdentification->appendChild($resourceConstraints1);
-if(isset($detail_array['t01_object.fees'])){
-$resourceConstraints2=$iso19139->createElement("gmd:resourceConstraints");
-$MD_LegalConstraints2=$iso19139->createElement("gmd:MD_LegalConstraints");
-$useLimitation=$iso19139->createElement("gmd:useLimitation");
-$useLimitation_cs=$iso19139->createElement("gco:CharacterString");
-$useLimitationText=$iso19139->createTextNode($detail_array['t01_object.fees']);
-$useLimitation_cs->appendChild($useLimitationText);
-$useLimitation->appendChild($useLimitation_cs);
-$MD_LegalConstraints2->appendChild($useLimitation);
-$resourceConstraints2->appendChild($MD_LegalConstraints2);
-$MD_DataIdentification->appendChild($resourceConstraints2);
-# Part B 1.7 Dataset Language
-if(isset($detail_array['t01_object.data_language'])){
-$language=$iso19139->createElement("gmd:language");
-$LanguageCode=$iso19139->createElement("gmd:LanguageCode");
-$LanguageCodeText=$iso19139->createTextNode($detail_array['t01_object.data_language']);
-$LanguageCode->appendChild($LanguageCodeText);
-$language->appendChild($LanguageCode);
-$MD_DataIdentification->appendChild($language);
-#Topic Category B 2.1
-if(isset($detail_array['t011_obj_geo_topic_cat.topic_category'])){
-$topicCategory=$iso19139->createElement("gmd:topicCategory");
-$MD_TopicCategoryCode=$iso19139->createElement("gmd:MD_TopicCategoryCode");
-$MD_TopicCategoryText=$iso19139->createTextNode($detail_array['t011_obj_geo_topic_cat.topic_category']);
-$MD_TopicCategoryCode->appendChild($MD_TopicCategoryText);
-$topicCategory->appendChild($MD_TopicCategoryCode);
-$MD_DataIdentification->appendChild($topicCategory);
-if(isset($detail_array['x1']) and isset($detail_array['x2']) and isset($detail_array['y1']) and isset($detail_array['y2'])){
-$extent=$iso19139->createElement("gmd:extent");
-$EX_Extent=$iso19139->createElement("gmd:EX_Extent");
-$geographicElement=$iso19139->createElement("gmd:geographicElement");
-$EX_GeographicBoundingBox=$iso19139->createElement("gmd:EX_GeographicBoundingBox");
-$westBoundLongitude=$iso19139->createElement("gmd:westBoundLongitude");
-$wb_dec=$iso19139->createElement("gco:Decimal");
-$wb_text=$iso19139->createTextNode($detail_array['x1']);
-$eastBoundLongitude=$iso19139->createElement("gmd:eastBoundLongitude");
-$eb_dec=$iso19139->createElement("gco:Decimal");
-$eb_text=$iso19139->createTextNode($detail_array['x2']);
-$southBoundLatitude=$iso19139->createElement("gmd:southBoundLatitude");
-$sb_dec=$iso19139->createElement("gco:Decimal");
-$sb_text=$iso19139->createTextNode($detail_array['y1']);
-$northBoundLatitude=$iso19139->createElement("gmd:northBoundLatitude");
-$nb_dec=$iso19139->createElement("gco:Decimal");
-$nb_text=$iso19139->createTextNode($detail_array['y2']);
-$wb_dec->appendChild($wb_text);
-$westBoundLongitude->appendChild($wb_dec);
-$EX_GeographicBoundingBox->appendChild($westBoundLongitude);
-$eb_dec->appendChild($eb_text);
-$eastBoundLongitude->appendChild($eb_dec);
-$EX_GeographicBoundingBox->appendChild($eastBoundLongitude);
-$sb_dec->appendChild($sb_text);
-$southBoundLatitude->appendChild($sb_dec);
-$EX_GeographicBoundingBox->appendChild($southBoundLatitude);
-$nb_dec->appendChild($nb_text);
-$northBoundLatitude->appendChild($nb_dec);
-$EX_GeographicBoundingBox->appendChild($northBoundLatitude);
-$geographicElement->appendChild($EX_GeographicBoundingBox);
-$EX_Extent->appendChild($geographicElement);
-$extent->appendChild($EX_Extent);
-$MD_DataIdentification->appendChild($extent);
-$identificationInfo->appendChild($MD_DataIdentification);
-$MD_Metadata->appendChild($identificationInfo);
-header("Content-type: application/xhtml+xml; charset=UTF-8");
-echo $iso19139->saveXml();
if ($_REQUEST['mdtype']=='inspire') {
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="de">
@@ -1258,21 +327,4 @@
echo '<br><b>INSPIRE output not completly implemented!<b><br>';
-#phpinfo();
-#$xmltest = new DOMDocument;
-#$xmltest=simplexml_load_file('/home/armin/Desktop/GDI-RP/metadaten/detail_portalu.xml');
-#$xsl = new DOMDocument;
-#var_dump($xmltest);
-//$xsl->load('simplesearch_overview.xsl');
-#$xsl=simplexml_load_file('/home/workspace/mapbender_rp/http/geoportal/opensearch2html.xsl');
-// Configure the transformer
-#var_dump($xsl);
-#$proc = new XSLTProcessor;
-#$proc->importStyleSheet($xsl); // attach the xsl rules
-#var_dump($proc);
-#$trans = $proc->transformToXML($xmltest);
-#var_dump($trans);
More information about the Mapbender_commits
