[Mapbender-commits] r7666 - in trunk/mapbender/http: classes javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Mar 2 08:14:13 EST 2011
Author: armin11
Date: 2011-03-02 05:14:13 -0800 (Wed, 02 Mar 2011)
New Revision: 7666
   trunk/mapbender/http/classes/class_wmc.php
   trunk/mapbender/http/javascripts/initWmcObj.php
Fix problem with exchanging urls of wmc documents with urls from database and owsproxy while loading them.
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2011-03-02 11:40:20 UTC (rev 7665)
+++ trunk/mapbender/http/classes/class_wmc.php	2011-03-02 13:14:13 UTC (rev 7666)
@@ -521,9 +521,9 @@
 		$WMSIdList = $xpath->query($query_mbWMSId);
 		foreach($WMSIdList as $WMSId) {
 			$id =  $WMSId->nodeValue;
-			$sql = "SELECT wms_timestamp,wms_getmap,wms_getlegendurl " .
-				"FROM wms WHERE wms_id = $1 AND " .
-				"wms_owsproxy <> NULL AND wms_owsproxy <> ''";
+			$sql = "SELECT wms_timestamp,wms_getmap,wms_getlegendurl, wms_owsproxy " .
+				"FROM wms WHERE wms_id = $1";// AND " .
+				//"wms_owsproxy <> NULL AND wms_owsproxy <> ''";
 			$v = array($id);
 			$t = array("t");
@@ -533,24 +533,59 @@
 			} //FIMXE: PROPER ERROR MESSAGE
 			if($row = db_fetch_array($res)) {
-				$wms_timestamp = $row["wms_timestamp"];
-				if ($this->timestamp < $wms_timestamp) {
-				// wmc is fresh, life is good
-				else {
+				//check if ows_proxy is set
+				if (isset($row["wms_owsproxy"]) && $row["wms_owsproxy"] != '') {
+					//set relevant wms urls to owsproxy urls
+					$wmsowsproxy = $row["wms_owsproxy"];
+					$owsproxyurl = OWSPROXY."/".session_id()."/".$wmsowsproxy."?";
+					$wmsGetMapUrl = $owsproxyurl;
+					$wmsGetLegendUrl = $owsproxyurl;
+					//in the case of owsproxy the urls should be exchanged every time!
 					$MapResources = $xpath->query("../../wmc:Server/wmc:OnlineResource",$WMSId);
 					foreach($MapResources as $MapResource) {
-						$MapResource->setAttribute("xlink:href",$row["wms_getmap"]);
+						$MapResource->setAttribute("xlink:href",$wmsGetMapUrl);
 					$LegendResources = $xpath->query("../../wmc:StyleList/wmc:Style/wmc:LegendURL/wmc:OnlineResource",$WMSId);
 					foreach ($LegendResources as $LegendResource) {
-						$base = $row["wms_getlegendurl"];
-						$origurl = explode('&', $LegendResource->getAttribute("xlink:href"),2);
-						$url = $base . $origurl[1];
-						$LegendResource->setAttribute("xlink:href",$url);
+							$e = new mb_notice("class_wmc.php: old getlegendurl (WMC): ".$LegendResource->getAttribute("xlink:href"));
+							$e = new mb_notice("class_wmc.php: new getlegendurl (OWSPROXY): ".$wmsGetLegendUrl);
+							//get param part of getlegend url from xml
+							$arURL = parse_url($LegendResource->getAttribute("xlink:href"));
+							$query = $arURL["query"];
+							$url = $wmsGetLegendUrl . $query;
+							$LegendResource->setAttribute("xlink:href",$url);
+				} else { //service is not secured - exchange urls only when they may have changed
+					$wmsGetMapUrl = $row["wms_getmap"];
+					$wmsGetLegendUrl = $row["wms_getlegendurl"];
+					//in cases when no owsproxy is defined exchange only if timestamp are not in sync
+					$wms_timestamp = $row["wms_timestamp"];
+					//if ($this->timestamp < $wms_timestamp) {//TODO: check if such a distiction is really needful - the timestamp of a wmc changes if some metadata changes - therefor it is needed - exchange all urls by default!
+					if (false) {
+						// wmc is fresh, life is good
+						$e = new mb_notice("class_wmc.php: the wms metadata has not been changed - no url will be exchanged!");
+					else {
+						$MapResources = $xpath->query("../../wmc:Server/wmc:OnlineResource",$WMSId);
+						$e = new mb_notice("class_wmc.php: the wms is newer than the wmc -urls will be exchanged!");
+						foreach($MapResources as $MapResource) {
+						$LegendResources = $xpath->query("../../wmc:StyleList/wmc:Style/wmc:LegendURL/wmc:OnlineResource",$WMSId);
+						foreach ($LegendResources as $LegendResource) {
+							$e = new mb_notice("class_wmc.php: new getlegendurl (DB): ".$wmsGetLegendUrl);
 		$updatedWMC = $WMCDoc->saveXML();
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php	2011-03-02 11:40:20 UTC (rev 7665)
+++ trunk/mapbender/http/javascripts/initWmcObj.php	2011-03-02 13:14:13 UTC (rev 7666)
@@ -120,6 +120,9 @@
 	// just make it work for a single Wmc
 		try {
 			$wmcGetApi = WmcFactory::createFromDb($input["id"]);
+			//update urls from wmc with urls from database if id is given
+			$updatedWMC = $wmcGetApi->updateUrlsFromDb();
+	        	$wmcGetApi->createFromXml($updatedWMC);
 			//increment load count
 			$wmcGetApi->incrementWmcLoadCount();
@@ -327,6 +330,7 @@
 $xml = $wmcGetApi->toXml();
 $wmcGetApi = new wmc();
+//new Object with merged layers and other features
 $wmcGetApi->createFromXml($xml);
More information about the Mapbender_commits mailing list
