[Mapbender-commits] r7681 - in branches/2.7: . conf http/extensions http/extensions/FirePHP-0.3 http/javascripts http/print resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 3 05:59:21 EST 2011
Author: kmq
Date: 2011-03-03 02:59:21 -0800 (Thu, 03 Mar 2011)
New Revision: 7681
   branches/2.7/
   branches/2.7/conf/digitize_default.conf
   branches/2.7/conf/wfs_default.conf
   branches/2.7/http/extensions/FirePHP-0.3/FirePHP.class.php
   branches/2.7/http/extensions/FirePHP-0.3/fb.php
   branches/2.7/http/extensions/jqjson.min.js
   branches/2.7/http/javascripts/mod_sandclock.js
   branches/2.7/http/javascripts/mod_wfs_gazetteer_client.php
   branches/2.7/http/print/mapbender_template.json
   branches/2.7/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
merged -c7677 from kmq_dev, fix for #793
Property changes on: branches/2.7
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/kmq_dev:4021-4487
/trunk/mapbender:7363-7600
   + /branches/kmq_dev:4021-4487,7677
Modified: branches/2.7/conf/digitize_default.conf
--- branches/2.7/conf/digitize_default.conf	2011-03-03 10:58:25 UTC (rev 7680)
+++ branches/2.7/conf/digitize_default.conf	2011-03-03 10:59:21 UTC (rev 7681)
@@ -33,7 +33,7 @@
 var geomHighlightColour = "#ff0000";
-var snappingHighlightZIndex = 85;
+var snappingHighlightZIndex = 75;
 var digitizeTransactionalZIndex = 80;
 var digitizeNonTransactionalZIndex = 20;
 // see also "generalHighlightZIndex" in wfs_default.conf
Modified: branches/2.7/conf/wfs_default.conf
--- branches/2.7/conf/wfs_default.conf	2011-03-03 10:58:25 UTC (rev 7680)
+++ branches/2.7/conf/wfs_default.conf	2011-03-03 10:59:21 UTC (rev 7681)
@@ -69,7 +69,7 @@
  * z-Index of the highlighted geometries
-var generalHighlightZIndex = 80;
+var generalHighlightZIndex = 70;
  * Line width of the highlighted geometries in pixel
Property changes on: branches/2.7/http/extensions/FirePHP-0.3/FirePHP.class.php
   - /branches/kmq_dev/http/extensions/FirePHP.class.php:4021-4487
/trunk/mapbender/http/extensions/FirePHP-0.3/FirePHP.class.php:7363-7600
   + /branches/kmq_dev/http/extensions/FirePHP-0.3/FirePHP.class.php:7677
Property changes on: branches/2.7/http/extensions/FirePHP-0.3/fb.php
   - /branches/kmq_dev/http/extensions/fb.php:4021-4487
/trunk/mapbender/http/extensions/FirePHP-0.3/fb.php:7363-7600
   + /branches/kmq_dev/http/extensions/FirePHP-0.3/fb.php:7677
Property changes on: branches/2.7/http/extensions/jqjson.min.js
   - /trunk/mapbender/http/extensions/jqjson.min.js:7363-7600
   + /branches/kmq_dev/http/extensions/jqjson.min.js:7677
Property changes on: branches/2.7/http/javascripts/mod_sandclock.js
   - /trunk/mapbender/http/javascripts/mod_sandclock.js:7363-7600
   + /branches/kmq_dev/http/javascripts/mod_sandclock.js:7677
Modified: branches/2.7/http/javascripts/mod_wfs_gazetteer_client.php
--- branches/2.7/http/javascripts/mod_wfs_gazetteer_client.php	2011-03-03 10:58:25 UTC (rev 7680)
+++ branches/2.7/http/javascripts/mod_wfs_gazetteer_client.php	2011-03-03 10:59:21 UTC (rev 7681)
@@ -292,7 +292,7 @@
 		// creates a Highlight object for the request geometry
-		var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":80};
+		var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":70};
 		requestGeometryHighlight = new parent.Highlight(targetArray, "requestGeometryHighlight", styleProperties, 2);
 		parent.mb_registerSubFunctions("window.frames['" + frameName +"'].requestGeometryHighlight.paint()");
@@ -1387,4 +1387,4 @@
 <div id="uploader"></div>
 <div class='resultDiv' name='res' id='res'></div>
 </body>
-</html>
\ No newline at end of file
+</html>
Property changes on: branches/2.7/http/print/mapbender_template.json
   - /trunk/mapbender/http/print/mapbender_template.json:7363-7600
   + /branches/kmq_dev/http/print/mapbender_template.json:7677
Property changes on: branches/2.7/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
   - /branches/kmq_dev/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql:4021-4487
/trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql:7363-7600
   + /branches/kmq_dev/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql:7677
More information about the Mapbender_commits mailing list
