[Mapbender-commits] r7693 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 10 15:11:11 EST 2011
Author: armin11
Date: 2011-03-10 12:11:11 -0800 (Thu, 10 Mar 2011)
New Revision: 7693
   trunk/mapbender/http/php/mod_layerISOMetadata.php
   trunk/mapbender/http/php/mod_wmc2ol.php
Remove redundant getGuisByPermission functions from source. They should all be removed and exchanged with admin->getGuisByPermission which controls the user/group access for the mapbender authorization component.
Modified: trunk/mapbender/http/php/mod_layerISOMetadata.php
--- trunk/mapbender/http/php/mod_layerISOMetadata.php	2011-03-10 17:08:43 UTC (rev 7692)
+++ trunk/mapbender/http/php/mod_layerISOMetadata.php	2011-03-10 20:11:11 UTC (rev 7693)
@@ -21,10 +21,13 @@
 require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
 require_once(dirname(__FILE__) . "/../classes/class_connector.php");
+require_once(dirname(__FILE__) . "/../classes/class_administration.php");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
+$admin = new administration();
 //define the view or table to use as input for metadata generation
 $wmsView = "wms_search_table";
 $wmsView = '';
@@ -66,6 +69,7 @@
 function fillISO19139($iso19139, $recordId) {
         global $wmsView;
+	global $admin;
 	//read out relevant information from mapbender database:
 	if ($wmsView != '') {
 		$sql = "SELECT * ";
@@ -110,7 +114,7 @@
 	$res = db_prep_query($sql,$v,$t);
 	$userMetadata = db_fetch_array($res);
 	//check if resource is freely available to anonymous user - which are all users who search thru metadata catalogues:
-	$hasPermission=getLayerPermission($mapbenderMetadata['wms_id'],$mapbenderMetadata['layer_id'],ANONYMOUS_USER);
+	$hasPermission=$admin->getLayerPermission($mapbenderMetadata['wms_id'],$mapbenderMetadata['layer_name'],ANONYMOUS_USER);
 	//Creating the "MD_Metadata" node
 	$MD_Metadata = $iso19139->createElementNS('http://www.isotc211.org/2005/gmd', 'gmd:MD_Metadata');
 	//$MD_Metadata=$iso19139->registerNamespace('srv','http://www.iso211.org/2005/srv');
@@ -896,88 +900,6 @@
 		die();
-	function user_authorization($wms_id,$layer_name,$user_id){
-		$n = new administration();
-		$this->n = $n;
-		$permission=$this->n->getLayerPermission($wms_id, $layer_name, $user_id);
-		return $permission;
-//functions necessary to decide if service url should be displayed
-	function getLayerPermission($wms_id, $layer_id, $user_id){
-		//$layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
-		$array_guis = getGuisByPermission($user_id,true);
-		$v = array();
-		$t = array();
-		$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id IN (";
-		$c = 1;
-		//generate guilist assigned to specific user
-		for($i=0; $i<count($array_guis); $i++){
-			if($i>0){ $sql .= ",";}
-			$sql .= "$".$c;
-			$c++;
-			array_push($v, $array_guis[$i]);
-			array_push($t, 's');
-		$sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1"; //Status must be 1
-		array_push($v,$layer_id);
-		array_push($t,'i');
-		$res = db_prep_query($sql,$v,$t);
-		if($row = db_fetch_array($res)){
-			return true;
-		else{
-			return false;
-	function getGuisByPermission($mb_user_id,$ignoreublic){
-		$arrayGuis = array();
-		$mb_user_groups = array();
-		$sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
-		$v = array($mb_user_id);
-		$t = array("i");
-		$res_groups = db_prep_query($sql_groups,$v,$t);
-		$cnt_groups = 0;
-		while($row = db_fetch_array($res_groups)){
-			$mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
-			$cnt_groups++;
-		if($cnt_groups > 0){
-			$v = array();
-			$t = array();
-			$sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
-			$sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
-			for($i=0; $i<count($mb_user_groups);$i++){
-				if($i > 0){$sql_g .= ",";}
-				$sql_g .= "$".strval($i+1);
-				array_push($v,$mb_user_groups[$i]);
-				array_push($t,"i");
-			$sql_g .= ") GROUP BY gui.gui_id";
-			$res_g = db_prep_query($sql_g,$v,$t);
-			while($row = db_fetch_array($res_g)){
-				array_push($arrayGuis,$row["gui_id"]);
-		$sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
-		$sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
-		if (!isset($ignore_public) OR $ignore_public== false){
-			$sql_guis .= " AND gui.gui_public = 1 ";
-		$sql_guis .= " GROUP BY gui.gui_id";
-		$t = array("i");
-		$res_guis = db_prep_query($sql_guis,$v,$t);
-		$guis = array();
-		while($row = db_fetch_array($res_guis)){
-			if(!in_array($row['gui_id'],$arrayGuis)){
-		return $arrayGuis;
 function getEpsgByLayerId ($layer_id) { // from merge_layer.php
 	$epsg_list = "";
 	$sql = "SELECT DISTINCT epsg FROM layer_epsg WHERE fkey_layer_id = $1";
Modified: trunk/mapbender/http/php/mod_wmc2ol.php
--- trunk/mapbender/http/php/mod_wmc2ol.php	2011-03-10 17:08:43 UTC (rev 7692)
+++ trunk/mapbender/http/php/mod_wmc2ol.php	2011-03-10 20:11:11 UTC (rev 7693)
@@ -16,13 +16,11 @@
 #http://www.geoportal.rlp.de/mapbender/php/mod_wmc2ol.php?wmc_id=45_1291218568&GEORSS=1&LayerSwitcher=1
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-//require_once(dirname(__FILE__)."/../classes/class_wmc.php");
 require_once(dirname(__FILE__)."/../classes/class_user.php");
-//require_once(dirname(__FILE__)."/../classes/class_json.php");
-//require_once(dirname(__FILE__)."/../classes/class_administration.php");
-//require_once(dirname(__FILE__)."/../classes/class_wmcToXml.php");
-//$userId = Mapbender::session()->get("mb_user_id");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
 $user = new User();
 $userId = $user->id;
 //check for parameter wmc_id
 if(!isset($_GET["wmc_id"])){
@@ -98,39 +96,8 @@
 	$testMatch = NULL;
-//the next functions should come from class administration, but they are not included as they are needed
-//TODO
-function getLayerPermission($wms_id, $layer_id, $user_id){
-		$v = array();
-		$t = array();
-		$c = 1;
-			$sql .= "$".$c;
-			$c++;
-		$sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1"; //status 1 must be
-			return true;
-		else{
-			return false;
+//functions which may be integrated from class_administration
 function getWmsGetMapUrl($wmsId){
 	$sql = "SELECT wms_getmap FROM wms WHERE wms_id =$1";
 	$v = array($wmsId);
@@ -142,58 +109,14 @@
 		return false;
-function getGuisByPermission($mb_user_id,$ignoreublic){
-	$t = array("i");
-	$cnt_groups = 0;
-		$cnt_groups++;
-		$v = array();
-		$t = array();
-	$t = array("i");
-	$guis = array();
-//end of functions which m,ay be included from class_administration in next versions
+//end of functions which may be included from class_administration in next versions
 //Function to create an OpenLayers Javascript from a mapbender wmc document
 function createOlFromWMC_id($wmc_id, $pointRadius, $fillColor){
 	//$myWmc = new wmc();
+	global $user;
 	global $userId;
+	global $admin;
 	//Get WMC out of mb Database
 	$sql = "SELECT wmc, wmc_serial_id FROM mb_user_wmc WHERE wmc_serial_id = $1";
 	$res = db_prep_query($sql, array($wmc_id), array("s"));
@@ -406,9 +329,9 @@
 		$html.="	layer0 = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
 		$extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org/context');
 		$layer_id=dom_import_simplexml($extensions->layer_id)->nodeValue;
+		$layer_name=$xml->LayerList->Layer[$i]->Name;
 		$wms_id=dom_import_simplexml($extensions->wms_id)->nodeValue;
-		$has_permission=getLayerPermission($wms_id,$layer_id,$userId);//problem: guest user must have fix id
-		//echo $layer_id."<br>";
+		$has_permission=$admin->getLayerPermission($wms_id, $layer_name, $userId);
 		if ($has_permission || $layer_id==''){
 			$getMapUrl = $xml->LayerList->Layer[$i]->Server->OnlineResource->attributes('http://www.w3.org/1999/xlink')->href;
 			if (getWmsGetMapUrl($wms_id) != false) {
@@ -462,8 +385,9 @@
 		#$layer_id=$extensions->layer_id;
 		$wms_id=$extensions->wms_id;
-		$has_permission=getLayerPermission($wms_id,$layer_id,$userId);//problem: guest user must have fix id TODO
 		if (($xml->LayerList->Layer[$i]->attributes()->hidden=='0' && $has_permission) ||
 			($layer_id=='' && $xml->LayerList->Layer[$i]->attributes()->hidden=='0')){
 			$html.="	layer".$i." = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
More information about the Mapbender_commits mailing list
