[Mapbender-commits] r7819 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 17 06:04:08 EDT 2011
Author: armin11
Date: 2011-05-17 03:04:08 -0700 (Tue, 17 May 2011)
New Revision: 7819
   trunk/mapbender/http/php/mod_dataISOMetadata.php
Extension to show uploaded metadata
Modified: trunk/mapbender/http/php/mod_dataISOMetadata.php
--- trunk/mapbender/http/php/mod_dataISOMetadata.php	2011-05-17 10:03:36 UTC (rev 7818)
+++ trunk/mapbender/http/php/mod_dataISOMetadata.php	2011-05-17 10:04:08 UTC (rev 7819)
@@ -134,6 +134,23 @@
 		//if xml has been harvested - push this xml from database, if not just harvest it and push the result
 		break;
+		case 'upload':
+			if ($mb_metadata['harvestresult'] == 1) {
+				if ($_REQUEST['VALIDATE'] != "true") {
+					header("Content-type: text/xml");
+					echo $mb_metadata['data'];
+					die();
+				} else {
+					validateInspireMetadataFromData($row['data']);
+					die();
+			} else {
+				//send error report - metadata has not been harvested - maybe
+				$errMsg = "Metadata should have been harvested, but some unkown error occured";
+				echo $errMsg;
+				die();
+		break;
 		case 'capabilities':
 			//do the same as for the external case but all from caps should be harvested
More information about the Mapbender_commits mailing list
