[Mapbender-commits] r8173 - in trunk/mapbender/http: classes php plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Oct 3 05:45:51 EDT 2011
Author: armin11
Date: 2011-10-03 02:45:50 -0700 (Mon, 03 Oct 2011)
New Revision: 8173
   trunk/mapbender/http/classes/class_wms.php
   trunk/mapbender/http/php/mod_dataISOMetadata.php
   trunk/mapbender/http/php/mod_layerISOMetadata.php
   trunk/mapbender/http/php/wms.php
   trunk/mapbender/http/plugins/mb_metadata_server.php
Extension for INSPIRE conformant layer metadata editor. It now parses either MD_Identifier or RS_Identifier if coupled datasets are given. The simple editor now gets a new constant METADATA_DEFAULT_CODESPACE which is defined in the mapbender.conf.  Some further things have to be done, but this is conformant with the way the GDI-DE will handle the service-dataset metadata coupling.
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2011-09-28 13:47:25 UTC (rev 8172)
+++ trunk/mapbender/http/classes/class_wms.php	2011-10-03 09:45:50 UTC (rev 8173)
@@ -2010,7 +2010,7 @@
 //		GET SRS_ARRAY of mapbender.conf
 		if(SRS_ARRAY != "") {
-			$confSrsArray = split(",",SRS_ARRAY);
+			$confSrsArray = explode(",",SRS_ARRAY);
 			foreach($confSrsArray as &$srs) {
 				$srs = trim($srs);
@@ -2212,18 +2212,35 @@
 					$title = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:title/gco:CharacterString');
 					//dataset identifier - howto model into md_metadata?
 					//check where datasetid is defined - maybe as RS_Identifier or as MD_Identifier see http://inspire.jrc.ec.europa.eu/documents/Metadata/INSPIRE_MD_IR_and_ISO_v1_2_20100616.pdf page 18
-					$code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString');
-					$codeSpace = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString');
-					$e = new mb_exception("class_wms.php: code: ".$code[0]);
-					$e = new mb_exception("class_wms.php: codeSpace: ".$codeSpace[0]);
-					if (isset($codeSpace[0]) && isset($code[0]) && $codeSpace[0] != '' && $code[0] != '') {
+					//First check if MD_Identifier is set, then check if RS_Identifier is used!
+					//Initialize datasetid
+					$datasetid = 'undefined';
+					$code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:MD_Identifier/gmd:code/gco:CharacterString');
+					if (isset($code[0]) && $code[0] != '') {
+						$e = new mb_exception("class_wms.php: code given thru MD_Identifier: ".$code[0]);
+						//check if code is defined by codespace and code
+						$codeSplit = explode("#",$code);
+						if (isset($codeSplit[0]) && $codeSplit[0] != '' && isset($codeSplit[1]) && $codeSplit[1] != '') {
+							$e = new mb_exception("class_wms.php: code was constructed via codespace#code !");
+							$datasetid = $codeSplit[0]."#".$codeSplit[1];
-						$datasetid = $codeSpace[0]."#".$code[0];
-						$e = new mb_exception("class_wms.php: datasetid: ".$datasetid);
-					} else {
-						$datasetid = 'undefined';# in sense of INSPIRE TODO control MD_Identifier too!
+						} else {
+							$e = new mb_exception("class_wms.php: code was not constructed via codespace#code !");
+							$datasetid = $code;
+					} else { //try to read code from RS_Identifier
+						$code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString');
+						$codeSpace = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString');
+					#$e = new mb_exception("class_wms.php: code: ".$code[0]);
+					#$e = new mb_exception("class_wms.php: codeSpace: ".$codeSpace[0]);
+						if (isset($codeSpace[0]) && isset($code[0]) && $codeSpace[0] != '' && $code[0] != '') {
+							$datasetid = $codeSpace[0]."#".$code[0];
+							$e = new mb_exception("class_wms.php: datasetid: ".$datasetid);
+						} else {
+							//neither MD_Identifier nor RS_Identifier are defined in a right way
+							$e = new mb_exception("class_wms.php: the service data coupling has problems, cause the metadata doesnt have defined a datasetid");
 					//abstract
 					$abstract = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:abstract/gco:CharacterString');
Modified: trunk/mapbender/http/php/mod_dataISOMetadata.php
--- trunk/mapbender/http/php/mod_dataISOMetadata.php	2011-09-28 13:47:25 UTC (rev 8172)
+++ trunk/mapbender/http/php/mod_dataISOMetadata.php	2011-10-03 09:45:50 UTC (rev 8173)
@@ -532,12 +532,17 @@
 		$CI_Citation->appendChild($date1);
-	#Do things for B 1.5 Resource unique identifier NOTE: not applicable for services
+#Do things for B 1.5 Resource unique identifier NOTE: not applicable for services
 //example from INSPIRE Guidance Metadata
 //The main problem will be, that this entry is the identifier for the service data coupling
 //to make it easy, we will use the same identifier as for fileidentifier! In case of external datasets, the right data identifier must be harvested!
+//*******exchanged with some new german specific way - use MD_Identifier
 /*<gmd:identifier><gmd:RS_Identifier><gmd:code><gco:CharacterString>gdi-rp</gco:CharacterString></gmd:code><gmd:codeSpace><gco:CharacterString>gdi-rp</gco:CharacterString></gmd:codeSpace></gmd:RS_Identifier></gmd:identifier>*/
 	$identifier=$iso19139->createElement("gmd:identifier");
 	$rs_identifier=$iso19139->createElement("gmd:RS_Identifier");
@@ -556,12 +561,32 @@
 	$codeSpace_cs->appendChild($codeSpaceText);
 	$codeSpace->appendChild($codeSpace_cs);
 	$rs_identifier->appendChild($codeSpace);
+//****** exchanged with some kind of MD_Identifier - cause this has to bee defined for german datasets
+/*<gmd:identifier><gmd:MD_Identifier><gmd:code><gco:CharacterString>gdi-rp</gco:CharacterString></gmd:code></gmd:MD_Identifier></gmd:identifier>*/
+	$identifier=$iso19139->createElement("gmd:identifier");
+	$md_identifier=$iso19139->createElement("gmd:MD_Identifier");
+	$code=$iso19139->createElement("gmd:code");
+	$code_cs=$iso19139->createElement("gco:CharacterString");
+	if (defined('METADATA_DEFAULT_CODESPACE')) {
+		$codeText=$iso19139->createTextNode(METADATA_DEFAULT_CODESPACE."#".$mb_metadata['uuid']); //in case of the mapbender addon!
+	} else {
+		$codeText=$iso19139->createTextNode("http://www.mapender.org"."#".$mb_metadata['uuid']); //in case of the mapbender addon!
-	$identifier->appendChild($rs_identifier);
+	$code_cs->appendChild($codeText);
+	$code->appendChild($code_cs);
+	$md_identifier->appendChild($code);
+	$identifier->appendChild($md_identifier);
 	$CI_Citation->appendChild($identifier);
 	$citation->appendChild($CI_Citation);
 	$MD_DataIdentification->appendChild($citation);
Modified: trunk/mapbender/http/php/mod_layerISOMetadata.php
--- trunk/mapbender/http/php/mod_layerISOMetadata.php	2011-09-28 13:47:25 UTC (rev 8172)
+++ trunk/mapbender/http/php/mod_layerISOMetadata.php	2011-10-03 09:45:50 UTC (rev 8173)
@@ -734,7 +734,12 @@
 				break;
 				case 'metador':
 					$operatesOn=$iso19139->createElement("srv:operatesOn");
-					$operatesOn->setAttribute("xlink:href", "http://www.geoportal.rlp.de#".$row_metadata['uuid']);
+						$operatesOn->setAttribute("xlink:href", METADATA_DEFAULT_CODESPACE."#".$row_metadata['uuid']);
+					} else {
+						$operatesOn->setAttribute("xlink:href", "http://www.mapbender.org#".$row_metadata['uuid']);
 					$SV_ServiceIdentification->appendChild($operatesOn);
 				break;
 				case 'external':
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php	2011-09-28 13:47:25 UTC (rev 8172)
+++ trunk/mapbender/http/php/wms.php	2011-10-03 09:45:50 UTC (rev 8173)
@@ -1096,7 +1096,8 @@
 	while ($row_metadata = db_fetch_array($res_metadata)) {
 		//check id datasetid is set, if not use metadataid
 		if ($row_metadata["datasetid"] == '' || !isset($row_metadata["datasetid"])) {
-			$datasetId = $row_metadata["uuid"];
+			//this column is empty, if metador was used and the identifier for dataset id is equal to the identifier of the metadata fileidentifier. In this case we expand a standard codespace http://www.geoportal.rlp.de TODO: use a define in mapbender.conf to pull the standard codespace from!
+			$datasetId = "http://www.geoportal.rlp.de"."#".$row_metadata["uuid"];
 		} else {
 			$datasetId = $row_metadata["datasetid"]; //really datasetid or only second part?
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2011-09-28 13:47:25 UTC (rev 8172)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2011-10-03 09:45:50 UTC (rev 8173)
@@ -786,20 +786,37 @@
 				//TODO: check if this is set, maybe DateTime must be searched instead?
 				//title
+				//datasetid
+				//next came from class_wms - TODO maybe put it into a special function
-				$e = new mb_notice("class_wms.php: code: ".$code[0]);
-				$e = new mb_notice("class_wms.php: codeSpace: ".$codeSpace[0]);
-				} else {
+					} else {
+					} else {
 				//abstract
@@ -841,6 +858,7 @@
 				//give back error message - cause parsing has problems
 		} else { //fill only links into db - do not try to load data
+			//TODO: Extract the information from the link - this should include datasetid!
 			$sql = <<<SQL
 INSERT INTO mb_metadata (link, uuid, origin, title, abstract, format, ref_system, export2csw, inspire_top_consistence, tmp_reference_1, tmp_reference_2, lineage, spatial_res_type, spatial_res_value, inspire_charset, createdate, randomid, update_frequency) VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, now(), $16, $17)
@@ -978,19 +996,39 @@
 		//title
-		$e = new mb_notice("plugins/mb_metadata_server.php: code: ".$code[0]);
-		$e = new mb_notice("plugins/mb_metadata_server.php: codeSpace: ".$codeSpace[0]);
-			$e = new mb_notice("class_wms.php: datasetid: ".$datasetid);
-		} else {
+			} else {
+			} else {
 		//abstract
 		//searchtext -- use keywords!
More information about the Mapbender_commits mailing list
