[Mapbender-commits] r8175 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Oct 3 09:01:04 EDT 2011
Author: armin11
Date: 2011-10-03 06:01:03 -0700 (Mon, 03 Oct 2011)
New Revision: 8175
   trunk/mapbender/http/plugins/mb_metadata_layerTree.js
   trunk/mapbender/http/plugins/mb_metadata_server.php
   trunk/mapbender/http/plugins/mb_metadata_showMetadataAddon.js
Extent layer tree for howing coupling information
Modified: trunk/mapbender/http/plugins/mb_metadata_layerTree.js
--- trunk/mapbender/http/plugins/mb_metadata_layerTree.js	2011-10-03 09:55:57 UTC (rev 8174)
+++ trunk/mapbender/http/plugins/mb_metadata_layerTree.js	2011-10-03 13:01:03 UTC (rev 8175)
@@ -38,12 +38,19 @@
 	var createLeaf = function (set) {
+		if (set.attr.layer_coupling != 0) {
+			//create html annex to title element
+			//annex = set.attr.layer_title+" - "+set.attr.layer_coupling+" x coupled";
+			annex = set.attr.layer_title;
+		} else {
 		return {
 			attr: {
 				data: $.toJSON(set.attr)
 			data: {
-				title: set.attr.layer_title
+				title: annex
@@ -114,6 +121,8 @@
             "checkbox" :{
                 "check_recursively": false
+ 	    "core" : {"html_titles" : true},
 			"plugins" : [ "themes", "json_data", "ui", "checkbox" ]
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2011-10-03 09:55:57 UTC (rev 8174)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2011-10-03 13:01:03 UTC (rev 8175)
@@ -308,10 +308,13 @@
 		$sql = <<<SQL
-SELECT layer_id, layer_pos, layer_parent, layer_name, layer_title, layer_abstract, layer_searchable
+SELECT layer_id, f_count_layer_couplings(layer_id) as count_coupling, layer_pos, layer_parent, layer_name, layer_title, layer_abstract, layer_searchable
 FROM layer WHERE fkey_wms_id = $wmsId ORDER BY layer_pos;
 SQL;
 		$res = db_query($sql);
 		$rows = array();
@@ -331,7 +334,8 @@
 					"layer_name" => $row["layer_name"],
 					"layer_title" => $row["layer_title"],
 					"layer_abstract" => $row["layer_abstract"],
-					"layer_searchable" => intval($row["layer_searchable"])
+					"layer_searchable" => intval($row["layer_searchable"]),
+					"layer_coupling" => intval($row["count_coupling"])
@@ -611,6 +615,26 @@
 		$ajaxResponse->setResult($resultObj);
 		$ajaxResponse->setSuccess(true);
 		break;
+case "getInitialLayerMetadata" :
+		$layerId = $ajaxResponse->getParameter("layerId");
+		$metadataId = $ajaxResponse->getParameter("metadataId");
+		$sql = <<<SQL
+SELECT layer_title, layer_abstract from layer where layer_id = $1
+SQL;
+		$v = array($layerId);
+		$t = array('i');
+		$res = db_prep_query($sql,$v,$t);
+		$row = array();
+		if ($res) {
+			$row = db_fetch_assoc($res);
+			$resultObj["title"]= $row['layer_title']; //serial
+			$resultObj["abstract"] = $row["layer_abstract"]; //char
+		$ajaxResponse->setResult($resultObj);
+		$ajaxResponse->setSuccess(true);
+		break;
 	case "updateLayerMetadataAddon" :
Modified: trunk/mapbender/http/plugins/mb_metadata_showMetadataAddon.js
--- trunk/mapbender/http/plugins/mb_metadata_showMetadataAddon.js	2011-10-03 09:55:57 UTC (rev 8174)
+++ trunk/mapbender/http/plugins/mb_metadata_showMetadataAddon.js	2011-10-03 13:01:03 UTC (rev 8175)
@@ -17,7 +17,47 @@
 		return true;
+	this.getInitialLayerMetadata = function(metadataId, layerId){
+		// get metadata from server
+		var req = new Mapbender.Ajax.Request({
+			url: "../plugins/mb_metadata_server.php",
+			method: "getInitialLayerMetadata",
+			parameters: {
+				"layerId": layerId,
+				"metadataId": metadataId
+			callback: function (obj, result, message) {
+				if (!result) {
+					return;
+				$metadataAddonForm.easyform("reset");
+				$metadataAddonForm.easyform("fill", obj);
+				//that.showForm(metadataId, layerId);
+				//enable link element to edit link!
+				$("#link").removeAttr("disabled");
+				switch (obj.origin) {
+					case "external":
+						$("#metadataUrlEditor").css("display","block");
+						$("#link_editor").css("display","block");
+    						break;
+  					case "metador":
+						$("#simple_metadata_editor").css("display","block");
+    						break;
+  					case "capabilities":
+    						break;
+					default:
+    						break;
+		req.send();
 	this.getAddedMetadata = function(metadataId, layerId){
@@ -250,8 +290,12 @@
 				$("#addonChooser").css("display","block");
 				$("#uploadImage").attr('onclick', 'initUploadForm('+layerId+')');
+				//get initial values (title/abstract)
+				that.getInitialLayerMetadata(metadataId, layerId);
 			that.showForm(metadataId, layerId, isNew);
+			//TODO: make the fields resizable
+			//$( "#abstract" ).resizable({ minWidth: 75 });
 		//upload form
More information about the Mapbender_commits mailing list
