[Mapbender-commits] r8181 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Oct 11 17:45:23 EDT 2011
Author: armin11
Date: 2011-10-11 14:45:23 -0700 (Tue, 11 Oct 2011)
New Revision: 8181
   trunk/mapbender/http/plugins/mb_metadata_layer.js
   trunk/mapbender/http/plugins/mb_metadata_layerTree.js
   trunk/mapbender/http/plugins/mb_metadata_server.php
   trunk/mapbender/http/plugins/mb_metadata_showMetadataAddon.js
some enhancement to show symbols at the layertree elements
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.js
--- trunk/mapbender/http/plugins/mb_metadata_layer.js	2011-10-10 09:53:41 UTC (rev 8180)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.js	2011-10-11 21:45:23 UTC (rev 8181)
@@ -142,7 +142,9 @@
+	this.getWmsId = function() {
+		return wmsId;
 	this.init = function (obj) {
 		delete layerId;
Modified: trunk/mapbender/http/plugins/mb_metadata_layerTree.js
--- trunk/mapbender/http/plugins/mb_metadata_layerTree.js	2011-10-10 09:53:41 UTC (rev 8180)
+++ trunk/mapbender/http/plugins/mb_metadata_layerTree.js	2011-10-11 21:45:23 UTC (rev 8181)
@@ -45,12 +45,23 @@
 		} else {
 			annex = set.attr.layer_title;
+		//following things can be done to show icons in the title element - problem: if the span is clicked, the checkbox is set an no layer is selected - TODO should be fixed
+		/*leafTitle = "<span>";
+		if (set.attr.layer_coupling != 0) {
+			//create html annex to title element
+			leafTitle = leafTitle+"<img src=\"../img/osgeo_graphics/geosilk/link.png\" title=\"coupled\">";
+			//annex = set.attr.layer_title;
+		if (set.attr.inspire_cats != 0) {
+			leafTitle = leafTitle+"<img width=\"15\" height=\"15\" src=\"../img/inspire_tr_36.png\" title=\"INSPIRE classified\">";
+		leafTitle = leafTitle+set.attr.layer_title+"</span>";*/
 		return {
 			attr: {
 				data: $.toJSON(set.attr)
 			data: {
-				title: annex
+				title: leafTitle
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2011-10-10 09:53:41 UTC (rev 8180)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2011-10-11 21:45:23 UTC (rev 8181)
@@ -223,7 +223,7 @@
 		$sql = <<<SQL
-SELECT layer_id, layer_name, layer_title, layer_abstract, layer_searchable
+SELECT layer_id, layer_name, layer_title, layer_abstract, layer_searchable, fkey_wms_id as wms_id
 FROM layer WHERE layer_id = $layerId;
 SQL;
@@ -308,7 +308,7 @@
 		$sql = <<<SQL
-SELECT layer_id, f_count_layer_couplings(layer_id) as count_coupling, layer_pos, layer_parent, layer_name, layer_title, layer_abstract, layer_searchable
+SELECT layer_id, f_count_layer_couplings(layer_id) as count_coupling, f_collect_inspire_cat_layer(layer_id) AS inspire_cats, layer_pos, layer_parent, layer_name, layer_title, layer_abstract, layer_searchable
 FROM layer WHERE fkey_wms_id = $wmsId ORDER BY layer_pos;
 SQL;
@@ -324,6 +324,12 @@
 		$left = 1;
 		function createNode ($left, $right, $row) {
+			$inspireCatsArray = explode(",",str_replace("}","",str_replace("{","",$row["inspire_cats"])));
+			if (count($inspireCatsArray) >= 0) {
+				$inspireCats = 1;
+			} else {
+				$inspireCats = 0;
 			return array(
 				"left" => $left,
 				"right" => $right,
@@ -335,7 +341,8 @@
 					"layer_title" => $row["layer_title"],
 					"layer_abstract" => $row["layer_abstract"],
 					"layer_searchable" => intval($row["layer_searchable"]),
-					"layer_coupling" => intval($row["count_coupling"])
+					"layer_coupling" => intval($row["count_coupling"]),
+					"inspire_cats" => intval($inspireCats)
Modified: trunk/mapbender/http/plugins/mb_metadata_showMetadataAddon.js
--- trunk/mapbender/http/plugins/mb_metadata_showMetadataAddon.js	2011-10-10 09:53:41 UTC (rev 8180)
+++ trunk/mapbender/http/plugins/mb_metadata_showMetadataAddon.js	2011-10-11 21:45:23 UTC (rev 8181)
@@ -9,6 +9,7 @@
 	var that = this;
 	var layerId;
 	var metadataId;
+        //var wmsId;
 	//Function, which pulls the metadata out off the mapbender registry and give a possibility to edit the record or link
 	this.valid = function () {
 		if (validator && validator.numberOfInvalids() > 0) {
@@ -32,6 +33,7 @@
 				$metadataAddonForm.easyform("reset");
 				$metadataAddonForm.easyform("fill", obj);
 				//that.showForm(metadataId, layerId);
 				//enable link element to edit link!
@@ -161,55 +163,18 @@
 				if (!result) {
 					return;
+				//this.wmsId = obj.wms_id;
 				//delete metadataURL entries
 				$('.metadataEntry').remove();
-				//fill MetadataURLs into metadata_selectbox_id
-				that.fillMetadataURLs(obj);
+				//fill MetadataURLs into metadata_selectbox_id - notice: the name of the module is fix!
+				Mapbender.modules.mb_md_layer.fillMetadataURLs(obj);
+				//reload layer tree for showing symbols
+				Mapbender.modules.mb_md_layer_tree.init(Mapbender.modules.mb_md_layer.getWmsId());
 		req.send();
-	//function generate updated metadataUrl entries TODO: this function is defined in mb_metadata_layer.js before but it cannot be called - maybe s.th. have to be changed
-	this.fillMetadataURLs = function (obj) {
-		layerId = obj.layer_id;
-		//for size of md_metadata records:
-		for (i=0;i<obj.md_metadata.metadata_id.length;i++) {
-			if (obj.md_metadata.origin[i] == "capabilities") {
-				$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/osgeo_graphics/geosilk/server_map.png' title='capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td></td></tr>").appendTo($("#metadataTable"));
-			if (obj.md_metadata.origin[i] == "external") {
-				$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/osgeo_graphics/geosilk/link.png' title='linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+layerId+",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+layerId+");return false;'/></td></tr>").appendTo($("#metadataTable"));
-			if (obj.md_metadata.origin[i] == "upload") {
-				$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/button_blue_red/up.png' title='uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+layerId+");return false;'/></td></tr>").appendTo($("#metadataTable"));
-			if (obj.md_metadata.origin[i] == "metador") {
-				$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/gnome/edit-select-all.png' title='metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+layerId+",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+layerId+");return false;'/></td></tr>").appendTo($("#metadataTable"));
-		$("<img class='metadataEntry' title='new' src='../img/add.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+layerId+",true);return false;'/>").appendTo($("#metadataTable"));
-	getWmsId = function(layerId){
-		var req = new Mapbender.Ajax.Request({
-			url: "../plugins/mb_metadata_server.php",
-			method: "getWmsIdByLayerId",
-			parameters: {
-				"layerId": layerId
-			callback: function (obj, result, message) {
-				if (!result) {
-					return;
-				return obj;
-		req.send();
 	deleteAddedMetadata = function(metadataId, layerId){
 		// push metadata from server
@@ -221,23 +186,23 @@
 				if (!result) {
 					return;
 				//update layer form to show edited data
 				that.fillLayerForm(layerId);
-				//alert(getWmsId(layerId));
+				//alert(wmsId);
 				$("<div></div>").text(message).dialog({
 					modal: true
 		req.send();
-		//Mapbender.modules.mb_md_layer_tree.init(950); klappt ganz gut aber wo steht die wms_id
 	this.showForm = function (metadataId, layerId, isNew) {
 		$metadataAddonPopup.append($metadataAddonForm);
 		$metadataAddonPopup.dialog({
More information about the Mapbender_commits mailing list
