[Mapbender-commits] r8192 - in trunk/mapbender/http: classes php plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Oct 27 05:30:19 EDT 2011
Author: armin11
Date: 2011-10-27 02:30:19 -0700 (Thu, 27 Oct 2011)
New Revision: 8192
   trunk/mapbender/http/classes/class_wms.php
   trunk/mapbender/http/php/mod_layerISOMetadata.php
   trunk/mapbender/http/php/wms.php
   trunk/mapbender/http/plugins/mb_metadata_server.php
Bugfix for Metadataeditor
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2011-10-25 13:57:33 UTC (rev 8191)
+++ trunk/mapbender/http/classes/class_wms.php	2011-10-27 09:30:19 UTC (rev 8192)
@@ -101,7 +101,7 @@
 		#	"$1php/mod_layerMetadata.php?id=",
 		#	LOGIN
 		#) . $wmsId;
-		return LOGIN."/../php/mod_showMetadata.php?resource=wms&id=".$wmsId;
+		return LOGIN."/../../mapbender/php/mod_showMetadata.php?resource=wms&id=".$wmsId;
 	public static function getLayerMetadataUrl ($layerId) {
 		#return preg_replace(
@@ -109,7 +109,7 @@
 		#	LOGIN
 		#) . $wmsId;
-		return LOGIN."/../php/mod_showMetadata.php?resource=layer&id=".$layerId;
+		return LOGIN."/../../mapbender/php/mod_showMetadata.php?resource=layer&id=".$layerId;
 	public static function isOwsProxyUrl ($getmap) {
 //		$e = new mb_notice("isOwsProxyUrl? " . $getmap);
@@ -2188,6 +2188,13 @@
 				//load metadata from link
 				$metadataConnector = new connector($this->objLayer[$i]->layer_metadataurl[$j]->href);
 				$metaData = $metadataConnector->file;
+				//delete getRecordByIdResponse from xml if there cause we handle only iso19139 files !
+				$regex = "#<csw:GetRecordByIdResponse .*?>#";
+				$output = preg_replace($regex,"",$metaData);
+				$regex = "#</csw:GetRecordByIdResponse>#";
+				$output = preg_replace($regex,"",$output);
+				//$e = new mb_exception($output);
+				$metaData = $output;
 				//parse metadata
 				try {
 					//$iso19139Xml = simplexml_load_string($metaData);
Modified: trunk/mapbender/http/php/mod_layerISOMetadata.php
--- trunk/mapbender/http/php/mod_layerISOMetadata.php	2011-10-25 13:57:33 UTC (rev 8191)
+++ trunk/mapbender/http/php/mod_layerISOMetadata.php	2011-10-27 09:30:19 UTC (rev 8192)
@@ -508,7 +508,7 @@
 	//a special keyword for service type wms as INSPIRE likes it ;-)
 	$keyword=$iso19139->createElement("gmd:keyword");
 	$keyword_cs=$iso19139->createElement("gco:CharacterString");
-	$keywordText = $iso19139->createTextNode("humanGeographicViewer");
+	$keywordText = $iso19139->createTextNode("infoMapAccessService");
 	$keyword_cs->appendChild($keywordText);
 	$keyword->appendChild($keyword_cs);
 	$MD_Keywords->appendChild($keyword);
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php	2011-10-25 13:57:33 UTC (rev 8191)
+++ trunk/mapbender/http/php/wms.php	2011-10-27 09:30:19 UTC (rev 8192)
@@ -503,6 +503,11 @@
 	$onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
 //	$onlineResource->setAttribute("xlink:href", $wms_row['wms_getcapabilities']);
 	$onlRes = $_SERVER["HTTP_HOST"] . $_SERVER["SCRIPT_NAME"] . "?layer_id=" . $layerId;
+	if ($inspire) {
+	$onlRes = $onlRes."&INSPIRE=1";
 	if (isset($_SERVER["HTTPS"])) {
 		$onlRes = "https://" . $onlRes;
@@ -524,6 +529,11 @@
+	if ($inspire) {
+	$onlRes = $onlRes."&INSPIRE=1&";
@@ -664,21 +674,28 @@
 	$vendorSpecificCapabilities = $capability->appendChild($vendorSpecificCapabilities);
 	#generate inspire_vs:ExtendedCapabilities node
 	$inspire_vs_ExtendedCapabilities = $doc->createElement("inspire_vs:ExtendedCapabilities");
-	$inspire_vs_ExtendedCapabilities->setAttribute("xmlns:inspire_common", "http://inspire.ec.europa.eu/schemas/common/1.0");
+	$inspire_vs_ExtendedCapabilities->setAttribute("xmlns:inspire_vs", "http://inspire.ec.europa.eu/schemas/inspire_vs/1.0");
 	$inspire_vs_ExtendedCapabilities = $vendorSpecificCapabilities->appendChild($inspire_vs_ExtendedCapabilities);
 	#generate inspire_vs: node
 	#$inspire_vs_ExtendedCapabilities = $doc->createElement("inspire_vs:ExtendedCapabilities");
 	#$inspire_vs_ExtendedCapabilities = $vendorSpecificCapabilities->appendChild($inspire_vs_ExtendedCapabilities);
 	#MetadataUrl to inspire service metadata
 	$inspire_common_MetadataUrl = $doc->createElement("inspire_common:MetadataUrl");
+	/*<inspire_common:MetadataUrl xmlns:inspire_common="http://inspire.ec.europa.eu/schemas/common/1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="inspire_common:resourceLocatorType">*/
+	$inspire_common_MetadataUrl->setAttribute("xmlns:inspire_common", "http://inspire.ec.europa.eu/schemas/common/1.0");
+	$inspire_common_MetadataUrl->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
+	$inspire_common_MetadataUrl->setAttribute("xsi:type", "inspire_common:resourceLocatorType");
 	$inspire_common_MetadataUrl = $inspire_vs_ExtendedCapabilities->appendChild($inspire_common_MetadataUrl);
 	#URL
 	$inspire_common_URL = $doc->createElement("inspire_common:URL");
+	$inspire_common_URL->setAttribute("xmlns:inspire_common", "http://inspire.ec.europa.eu/schemas/common/1.0");
 	$inspire_common_URLText = $doc->createTextNode($inspireServiceMetadataUrl.$layerId);
 	$inspire_common_URL->appendChild($inspire_common_URLText);
 	$inspire_common_URL = $inspire_common_MetadataUrl->appendChild($inspire_common_URL);
 	#MediaType
 	$inspire_common_MediaType = $doc->createElement("inspire_common:MediaType");
+	$inspire_common_MediaType->setAttribute("xmlns:inspire_common", "http://inspire.ec.europa.eu/schemas/common/1.0");
 	$inspire_common_MediaTypeText = $doc->createTextNode('application/vnd.iso.19139+xml');#from http://inspire.ec.europa.eu/schemas/inspire_vs/1.0/examples/WMS_Image2000GetCapabilities_InspireSchema.xml
 	$inspire_common_MediaType->appendChild($inspire_common_MediaTypeText);
 	$inspire_common_MediaType = $inspire_common_MetadataUrl->appendChild($inspire_common_MediaType);
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2011-10-25 13:57:33 UTC (rev 8191)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2011-10-27 09:30:19 UTC (rev 8192)
@@ -788,7 +788,7 @@
 		$randomid = new Uuid();
 		//Check if origin is external and export2csw is activated!
-		if ($origin == 'external' && $export2csw == 't' ) {
+		if ($origin == 'external' ) {
 			//harvest link from location, parse the content for datasetid and push xml into data column
 			//load metadata from link TODO: function from class_wms - generate a class for metadata management and include it here and in class_wms
 			$metadataConnector = new connector();
@@ -798,7 +798,13 @@
 			if (!$metaData) {
     				abort(_mb("Could not load metadata from source url!"));
 			//write metadata to temporary file:
 			$randomFileId = new Uuid();
@@ -814,7 +820,6 @@
 			} else {
 				abort(_mb("Temporary file could not be parsed!"));
 			//$metaData = $metadataConnector->file;
 			//parse metadata
 			/*try {
@@ -827,6 +832,7 @@
 				//get elements for database from xml by using xpath
 				//uuid
 				$uuid = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString');
+				$e = new mb_exception("plugins/mb_metadata_server.php: File Identifier found: ".$uuid);
 				//createdate
 				$createdate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
 				//changedate
@@ -843,27 +849,27 @@
 				$datasetid = 'undefined';
 				$code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:MD_Identifier/gmd:code/gco:CharacterString');
 				if (isset($code[0]) && $code[0] != '') {
-					$e = new mb_exception("class_wms.php: code given thru MD_Identifier: ".$code[0]);
+					$e = new mb_exception("plugins/mb_metadata_server.php: code given thru MD_Identifier: ".$code[0]);
 					//check if code is defined by codespace and code
 					$codeSplit = explode("#",$code);
 					if (isset($codeSplit[0]) && $codeSplit[0] != '' && isset($codeSplit[1]) && $codeSplit[1] != '') {
-						$e = new mb_exception("class_wms.php: code was constructed via codespace#code !");
+						$e = new mb_exception("plugins/mb_metadata_server.php: code was constructed via codespace#code !");
 						$datasetid = $codeSplit[0]."#".$codeSplit[1];
 					} else {
-						$e = new mb_exception("class_wms.php: code was not constructed via codespace#code !");
-						$datasetid = $code;
+						$e = new mb_exception("plugins/mb_metadata_server.php: code was not constructed via codespace#code !");
+						$datasetid = $code[0];
 				} else { //try to read code from RS_Identifier
 					$code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString');
 					$codeSpace = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString');
-				#$e = new mb_exception("class_wms.php: code: ".$code[0]);
-				#$e = new mb_exception("class_wms.php: codeSpace: ".$codeSpace[0]);
+				#$e = new mb_exception("plugins/mb_metadata_server.php: code: ".$code[0]);
+				#$e = new mb_exception("plugins/mb_metadata_server.php: codeSpace: ".$codeSpace[0]);
 					if (isset($codeSpace[0]) && isset($code[0]) && $codeSpace[0] != '' && $code[0] != '') {
 						$datasetid = $codeSpace[0]."#".$code[0];
-						$e = new mb_exception("class_wms.php: datasetid: ".$datasetid);
+						$e = new mb_exception("plugins/mb_metadata_server.php: datasetid: ".$datasetid);
 					} else {
 						//neither MD_Identifier nor RS_Identifier are defined in a right way
-						$e = new mb_exception("class_wms.php: the service data coupling has problems, cause the metadata doesnt have defined a datasetid");
+						$e = new mb_exception("plugins/mb_metadata_server.php: the service data coupling has problems, cause the metadata doesnt have defined a datasetid");
 				//abstract
@@ -905,7 +911,7 @@
 				abort(_mb("Problem with parsing the XML structure with SimpleXML! Record was not inserted into database! Ask your administrator."));
 				//give back error message - cause parsing has problems
-		} else { //fill only links into db - do not try to load data
+		}/* else { //fill only links into db - do not try to load data
 			//TODO: Extract the information from the link - this should include datasetid!
 			$sql = <<<SQL
@@ -921,7 +927,7 @@
 			catch (Exception $e){
 				abort(_mb("Insert of link into database failed!"));
 		//set relation into relation table
 		//get metadata_id of record which have been inserted before
 		$sql = <<<SQL
@@ -1027,16 +1033,20 @@
 		if (!$metaData){
 			abort(_mb("Reading file ".$filename." failed!"));
-		try {
-			$iso19139Xml =  new SimpleXMLElement($metaData);
-		catch (Exception $e) {
-			abort(_mb("Parsing ISO19139 XML failed!"));
 		//uuid
+		if (!isset($uuid) || $uuid == "") {
+			abort(_mb(" No fileIdentifier found, parsing ISO19139 XML maybe failed. Check if element /gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString is given and not empty!"));
+		//$e = new mb_exception("plugins/mb_metadata_server.php: File Identifier found: ".$uuid);
 		//createdate
 		//changedate
@@ -1052,27 +1062,27 @@
 			} else {
 				$datasetid = $code;
 			} else {
More information about the Mapbender_commits mailing list
