[Mapbender-commits] r8533 - in trunk/mapbender: conf http/javascripts http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Dec 18 06:34:20 PST 2012
Author: verenadiewald
Date: 2012-12-18 06:34:20 -0800 (Tue, 18 Dec 2012)
New Revision: 8533
   trunk/mapbender/conf/mapbender.conf-dist
   trunk/mapbender/http/javascripts/user.js
   trunk/mapbender/http/php/user.php
number of hits, mouseover info and second search field for user selectbox
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist	2012-12-18 10:46:33 UTC (rev 8532)
+++ trunk/mapbender/conf/mapbender.conf-dist	2012-12-18 14:34:20 UTC (rev 8533)
@@ -250,7 +250,8 @@
 # user autocomplete
 define('SEARCH_LIMIT', 50);
-define('SEARCH_COLUMN', 'mb_user_name');
+define('SEARCH_COLUMN1', 'mb_user_name');
+define('SEARCH_COLUMN2', 'mb_user_email');
 ###HACK for GLOBALS
 $DBSERVER=DBSERVER;
Modified: trunk/mapbender/http/javascripts/user.js
--- trunk/mapbender/http/javascripts/user.js	2012-12-18 10:46:33 UTC (rev 8532)
+++ trunk/mapbender/http/javascripts/user.js	2012-12-18 14:34:20 UTC (rev 8533)
@@ -37,15 +37,17 @@
                                     .text('NEW...')
-                        for(var i=0; i<data.length; i++) {
+                        for(var i=0; i<data.users.length; i++) {
                             target.append(
                                 $('<option>')
-                                    .attr('value', data[i].id)
-                                    .attr('title', data[i].firstname + ' ' + data.lastname)
-                                    .text(data[i].login)
+                                    .attr('value', data.users[i].id)
+                                    .attr('title', data.users[i].id + ": " + data.users[i].name + ' (' + data.users[i].email + ")")
+                                    .text(data.users[i].login)
+                        target.prev().text("USER (" + data.limit + " von "  + data.hits + "):");
Modified: trunk/mapbender/http/php/user.php
--- trunk/mapbender/http/php/user.php	2012-12-18 10:46:33 UTC (rev 8532)
+++ trunk/mapbender/http/php/user.php	2012-12-18 14:34:20 UTC (rev 8533)
@@ -16,35 +16,49 @@
     die('Error: Searchterm not found.');
-if(!defined('SEARCH_COLUMN') || !defined('SEARCH_LIMIT')) {
-    die('SEARCH_COLUMN or SEARCH_LIMIT not found in mapbender.conf');
+if(!defined('SEARCH_COLUMN1') || !defined('SEARCH_COLUMN2') || !defined('SEARCH_LIMIT')) {
+    die('SEARCH_COLUMN1, SEARCH_COLUMN2 or SEARCH_LIMIT not found in mapbender.conf');
 $conn = pg_connect('host='.DBSERVER.' port='.PORT.' dbname='.DB.' user='.OWNER.' password='.PW);
 if($conn) {
-    $result = pg_query($conn,
-        "SELECT * FROM mb_user WHERE "
-        . SEARCH_COLUMN . " LIKE '%"
-        . pg_escape_string($_POST['searchterm'])
-        . "%' AND mb_user_owner = '" . pg_escape_string($user) . "' ORDER BY ". SEARCH_COLUMN ." LIMIT " . SEARCH_LIMIT
+    $whereCondition = SEARCH_COLUMN1 . " LIKE '%" . pg_escape_string($_POST['searchterm']). "%'";
+    $orderBy = "ORDER BY ". SEARCH_COLUMN1;
+    if(SEARCH_COLUMN2 != "") {
+        $whereCondition .= " OR ". SEARCH_COLUMN2 . " LIKE '%" . pg_escape_string($_POST['searchterm']). "%'";
+        $orderBy .= ", ". SEARCH_COLUMN2;
+    $sql = "SELECT * FROM mb_user WHERE ("
+        . $whereCondition .
+        ") AND mb_user_owner = '" . pg_escape_string($user) . "' ". $orderBy ." LIMIT " . SEARCH_LIMIT;
+    $result = pg_query($conn, $sql);
     if($result) {
         $userArray = array();
-        while($user = pg_fetch_assoc($result)) {
+        while($users = pg_fetch_assoc($result)) {
             $userArray[] = array(
-                'id' => $user['mb_user_id'],
-                'login' => $user['mb_user_name'],
-                'firstname' => $user['mb_user_firstname'],
-                'lastname' => $user['mb_user_lastname']
+                'id' => $users['mb_user_id'],
+                'login' => $users['mb_user_name'],
+                'firstname' => $users['mb_user_firstname'],
+                'lastname' => $users['mb_user_lastname'],
+            	'name' => $users['mb_user_name'],
+                'email' => $users['mb_user_email']
-        die(json_encode($userArray));
+        $sqlCnt = "SELECT count(*) as cnt FROM mb_user WHERE ("
+        ") AND mb_user_owner = '" . pg_escape_string($user) . "'";
+        $resultCnt = pg_query($conn, $sqlCnt);
+        $userCnt = pg_fetch_assoc($resultCnt);
+        $resultArray = array("hits" => $userCnt['cnt'], "limit" => SEARCH_LIMIT, "users" => $userArray);
+        #$resultArray = array($userArray, $userInfoArray);
+        die(json_encode($resultArray));
     } else die('Error: Searchresult.');
 } else die('Error: DB-Connection.');
\ No newline at end of file
More information about the Mapbender_commits mailing list
