[Mapbender-commits] r8535 - in trunk/mapbender: http/javascripts http/php lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Dec 19 03:31:13 PST 2012
Author: verenadiewald
Date: 2012-12-19 03:31:12 -0800 (Wed, 19 Dec 2012)
New Revision: 8535
   trunk/mapbender/http/javascripts/user.js
   trunk/mapbender/http/php/mod_filteredGroup_User.php
   trunk/mapbender/http/php/mod_filteredGroup_filteredUser.php
   trunk/mapbender/http/php/mod_filteredGui_User.php
   trunk/mapbender/http/php/mod_filteredGui_filteredUser.php
   trunk/mapbender/http/php/mod_filteredUser_Group.php
   trunk/mapbender/http/php/mod_filteredUser_Gui.php
   trunk/mapbender/http/php/mod_filteredUser_filteredGroup.php
   trunk/mapbender/http/php/mod_filteredUser_filteredGui.php
   trunk/mapbender/http/php/mod_group_filteredUser.php
   trunk/mapbender/http/php/mod_group_user.php
   trunk/mapbender/http/php/mod_group_user_role.php
   trunk/mapbender/http/php/mod_gui_filteredUser.php
   trunk/mapbender/http/php/mod_gui_owner.php
   trunk/mapbender/http/php/mod_gui_user.php
   trunk/mapbender/http/php/mod_user_filteredGroup.php
   trunk/mapbender/http/php/mod_user_filteredGui.php
   trunk/mapbender/http/php/mod_user_group.php
   trunk/mapbender/http/php/mod_user_gui.php
   trunk/mapbender/http/php/user.php
   trunk/mapbender/lib/editUser.php
prepared statements for user.php, new param owner-check on/off
Modified: trunk/mapbender/http/javascripts/user.js
--- trunk/mapbender/http/javascripts/user.js	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/javascripts/user.js	2012-12-19 11:31:12 UTC (rev 8535)
@@ -5,6 +5,7 @@
         var input = $(this);
         var target = $('#' + input.attr('data-target'));
         var targetType = input.attr('data-target-type');
+        var ownerCheck = input.attr('owner-check');
         if(typeof timeoutId !== 'undefined') {
             window.clearTimeout(timeoutId);
@@ -20,7 +21,8 @@
             $.ajax({
                 url: "../php/user.php",
                 data: {
-                    "searchterm" : input.val()
+                    "searchterm" : input.val(),
+                    "userCheck" : ownerCheck
                 type: "post",
                 dataType: "json",
Modified: trunk/mapbender/http/php/mod_filteredGroup_User.php
--- trunk/mapbender/http/php/mod_filteredGroup_User.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_filteredGroup_User.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -224,7 +224,7 @@
 echo "</select>";
 /*filterbox****************************************************************************************/
-echo "<input type='text' value='' class='filter2' name='filter2' id='find_user' data-target='selecteduser' data-target-type='select' autocomplete='off'/>";
+echo "<input type='text' value='' class='filter2' name='filter2' id='find_user' data-target='selecteduser' owner-check='off' data-target-type='select' autocomplete='off'/>";
 //echo "<input type='text' value='' class='filter2' id='filter2' name='filter2' onkeyup='filterUser(document.getElementById(\"selecteduser\"),user,this.value);'/>";
 /*insert all profiles in selectbox*****************************************************************/
 echo "<div class='text2'>USER:</div>";
Modified: trunk/mapbender/http/php/mod_filteredGroup_filteredUser.php
--- trunk/mapbender/http/php/mod_filteredGroup_filteredUser.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_filteredGroup_filteredUser.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -234,7 +234,7 @@
 	echo "</select>";
-	echo "<input type='text' value='' class='filter2' name='filter2' id='find_user' data-target='selecteduser' data-target-type='select' autocomplete='off'/>";
+	echo "<input type='text' value='' class='filter2' name='filter2' id='find_user' data-target='selecteduser' owner-check='on' data-target-type='select' autocomplete='off'/>";
Modified: trunk/mapbender/http/php/mod_filteredGui_User.php
--- trunk/mapbender/http/php/mod_filteredGui_User.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_filteredGui_User.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -234,7 +234,7 @@
 echo "</select>";
Modified: trunk/mapbender/http/php/mod_filteredGui_filteredUser.php
--- trunk/mapbender/http/php/mod_filteredGui_filteredUser.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_filteredGui_filteredUser.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -244,7 +244,7 @@
 echo "</select>";
+echo "<input type='text' value='' class='filter2' name='filter2' id='find_user' data-target='selecteduser' owner-check='on' data-target-type='select' autocomplete='off'/>";
Modified: trunk/mapbender/http/php/mod_filteredUser_Group.php
--- trunk/mapbender/http/php/mod_filteredUser_Group.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_filteredUser_Group.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -210,7 +210,7 @@
 echo "<form name='form1' action='" . $self ."' method='post'>";
-echo "<input type='text' value='' class='filter1' name='filter1' id='find_user' data-target='selecteduser' data-target-type='select' autocomplete='off'/>";
+echo "<input type='text' value='' class='filter1' name='filter1' id='find_user' data-target='selecteduser' owner-check='on' data-target-type='select' autocomplete='off'/>";
 //echo "<input type='text' value='' class='filter1' id='filter1' name='filter1' onkeyup='filterUser(document.getElementById(\"selecteduser\"),user,this.value);'/>";
 /*insert all user in selectbox*************************************************************************************/
 echo "<div class='text1'>USER: </div>";
Modified: trunk/mapbender/http/php/mod_filteredUser_Gui.php
--- trunk/mapbender/http/php/mod_filteredUser_Gui.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_filteredUser_Gui.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -219,7 +219,7 @@
Modified: trunk/mapbender/http/php/mod_filteredUser_filteredGroup.php
--- trunk/mapbender/http/php/mod_filteredUser_filteredGroup.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_filteredUser_filteredGroup.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -217,7 +217,7 @@
Modified: trunk/mapbender/http/php/mod_filteredUser_filteredGui.php
--- trunk/mapbender/http/php/mod_filteredUser_filteredGui.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_filteredUser_filteredGui.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -258,7 +258,7 @@
Modified: trunk/mapbender/http/php/mod_group_filteredUser.php
--- trunk/mapbender/http/php/mod_group_filteredUser.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_group_filteredUser.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -220,7 +220,7 @@
 echo "</select>";
Modified: trunk/mapbender/http/php/mod_group_user.php
--- trunk/mapbender/http/php/mod_group_user.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_group_user.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -218,7 +218,7 @@
 echo "</select>";
Modified: trunk/mapbender/http/php/mod_group_user_role.php
--- trunk/mapbender/http/php/mod_group_user_role.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_group_user_role.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -295,7 +295,7 @@
 echo "</select>";
Modified: trunk/mapbender/http/php/mod_gui_filteredUser.php
--- trunk/mapbender/http/php/mod_gui_filteredUser.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_gui_filteredUser.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -225,7 +225,7 @@
 echo "</select>";
Modified: trunk/mapbender/http/php/mod_gui_owner.php
--- trunk/mapbender/http/php/mod_gui_owner.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_gui_owner.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -237,7 +237,7 @@
 echo "</select>";
Modified: trunk/mapbender/http/php/mod_gui_user.php
--- trunk/mapbender/http/php/mod_gui_user.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_gui_user.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -215,7 +215,7 @@
 echo "</select>";
Modified: trunk/mapbender/http/php/mod_user_filteredGroup.php
--- trunk/mapbender/http/php/mod_user_filteredGroup.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_user_filteredGroup.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -209,7 +209,7 @@
+echo "<input type='text' value='' class='filter1' name='filter1' id='find_user' data-target='selecteduser' owner-check='off' data-target-type='select' autocomplete='off'/>";
Modified: trunk/mapbender/http/php/mod_user_filteredGui.php
--- trunk/mapbender/http/php/mod_user_filteredGui.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_user_filteredGui.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -254,7 +254,7 @@
Modified: trunk/mapbender/http/php/mod_user_group.php
--- trunk/mapbender/http/php/mod_user_group.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_user_group.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -201,7 +201,7 @@
Modified: trunk/mapbender/http/php/mod_user_gui.php
--- trunk/mapbender/http/php/mod_user_gui.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/mod_user_gui.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -205,7 +205,7 @@
 echo "<form name='form1' action='" . $self ."&e_id_css=".$_REQUEST["e_id_css"]."' method='post'>";
Modified: trunk/mapbender/http/php/user.php
--- trunk/mapbender/http/php/user.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/http/php/user.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -3,8 +3,7 @@
 //$e_id="user";
-require_once(dirname(__FILE__) . "/../classes/class_administration.php");
-require_once dirname(__FILE__) . '/../../conf/mapbender.conf';
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
 $user = (int)Mapbender::session()->get("mb_user_id");
@@ -20,45 +19,75 @@
     die('SEARCH_COLUMN1, SEARCH_COLUMN2 or SEARCH_LIMIT not found in mapbender.conf');
-$conn = pg_connect('host='.DBSERVER.' port='.PORT.' dbname='.DB.' user='.OWNER.' password='.PW);
+if($_POST['userCheck'] == "on") {
+    if(SEARCH_COLUMN2 != "") {
+        $sql = "SELECT * FROM mb_user WHERE mb_user_owner = $1 AND (" . SEARCH_COLUMN1 . " LIKE '%' || $2 || '%' OR " . SEARCH_COLUMN2 . " LIKE '%' || $3 || '%') " .
+        	"ORDER BY " . SEARCH_COLUMN1 ."," . SEARCH_COLUMN2 . " LIMIT " . SEARCH_LIMIT;
+        $sqlCnt = "SELECT count(*) as cnt FROM mb_user WHERE mb_user_owner = $1 AND (" . SEARCH_COLUMN1 . " LIKE '%' || $2 || '%' OR " . SEARCH_COLUMN2 . " LIKE '%' || $3 || '%')";
-if($conn) {
-    $whereCondition = SEARCH_COLUMN1 . " LIKE '%" . pg_escape_string($_POST['searchterm']). "%'";
-    $orderBy = "ORDER BY ". SEARCH_COLUMN1;
-    if(SEARCH_COLUMN2 != "") {
-        $whereCondition .= " OR ". SEARCH_COLUMN2 . " LIKE '%" . pg_escape_string($_POST['searchterm']). "%'";
-        $orderBy .= ", ". SEARCH_COLUMN2;
+        $v = array($user, $_POST['searchterm'], $_POST['searchterm']);
+        $t = array("i", "s", "s");
-    $sql = "SELECT * FROM mb_user WHERE ("
-        . $whereCondition .
-        ") AND mb_user_owner = '" . pg_escape_string($user) . "' ". $orderBy ." LIMIT " . SEARCH_LIMIT;
-    $result = pg_query($conn, $sql);
+    else {
+        $sql = "SELECT * FROM mb_user WHERE mb_user_owner = $1 AND " . SEARCH_COLUMN1 . " LIKE '%' || $2 || '%' " .
+        	"ORDER BY " . SEARCH_COLUMN1 ." LIMIT " . SEARCH_LIMIT;
-    if($result) {
-        $userArray = array();
+        $sqlCnt = "SELECT count(*) as cnt FROM mb_user WHERE mb_user_owner = $1 AND " . SEARCH_COLUMN1 . " LIKE '%' || $2 || '%' ";
-        while($users = pg_fetch_assoc($result)) {
-            $userArray[] = array(
-                'id' => $users['mb_user_id'],
-                'login' => $users['mb_user_name'],
-                'firstname' => $users['mb_user_firstname'],
-                'lastname' => $users['mb_user_lastname'],
-            	'name' => $users['mb_user_name'],
-                'email' => $users['mb_user_email']
+        $v = array($user, $_POST['searchterm']);
+        $t = array("i", "s");
+else {
+        $sql = "SELECT * FROM mb_user WHERE " . SEARCH_COLUMN1 . " LIKE '%' || $1 || '%' OR " . SEARCH_COLUMN2 . " LIKE '%' || $2 || '%' " .
-        $sqlCnt = "SELECT count(*) as cnt FROM mb_user WHERE ("
-        ") AND mb_user_owner = '" . pg_escape_string($user) . "'";
-        $resultCnt = pg_query($conn, $sqlCnt);
-        $userCnt = pg_fetch_assoc($resultCnt);
-        $resultArray = array("hits" => $userCnt['cnt'], "limit" => SEARCH_LIMIT, "users" => $userArray);
+        $sqlCnt = "SELECT count(*) as cnt FROM mb_user WHERE " . SEARCH_COLUMN1 . " LIKE '%' || $1 || '%' OR " . SEARCH_COLUMN2 . " LIKE '%' || $2 || '%' ";
-        #$resultArray = array($userArray, $userInfoArray);
+        $v = array($_POST['searchterm'], $_POST['searchterm']);
+        $t = array("s", "s");
+    else {
+        $sql = "SELECT * FROM mb_user WHERE " . SEARCH_COLUMN1 . " LIKE '%' || $1 || '%' " .
-        die(json_encode($resultArray));
+        $sqlCnt = "SELECT count(*) as cnt FROM mb_user WHERE " . SEARCH_COLUMN1 . " LIKE '%' || $1 || '%' ";
-    } else die('Error: Searchresult.');
+        $v = array($_POST['searchterm']);
+        $t = array("s");
+$result = db_prep_query($sql,$v,$t);
+$resultCnt = db_prep_query($sqlCnt,$v,$t);
+if($result) {
+    $userArray = array();
-} else die('Error: DB-Connection.');
\ No newline at end of file
+    while($users = db_fetch_assoc($result)) {
+        $userArray[] = array(
+            'id' => $users['mb_user_id'],
+            'login' => $users['mb_user_name'],
+            'firstname' => $users['mb_user_firstname'],
+            'lastname' => $users['mb_user_lastname'],
+        	'name' => $users['mb_user_name'],
+            'email' => $users['mb_user_email']
+    $userCnt = db_fetch_assoc($resultCnt);
+    if($userCnt['cnt'] < SEARCH_LIMIT) {
+        $limit = $userCnt['cnt'];
+    else {
+        $limit = SEARCH_LIMIT;
+    $resultArray = array("hits" => $userCnt['cnt'], "limit" => $limit, "users" => $userArray);
+    #$resultArray = array($userArray, $userInfoArray);
+    die(json_encode($resultArray));
+} else die('Error: Searchresult.');
Modified: trunk/mapbender/lib/editUser.php
--- trunk/mapbender/lib/editUser.php	2012-12-18 15:12:37 UTC (rev 8534)
+++ trunk/mapbender/lib/editUser.php	2012-12-19 11:31:12 UTC (rev 8535)
@@ -274,7 +274,7 @@
 	      echo _mb("User").": ";
 	   echo "</td>";
 	echo "<td>";
-	   echo "<input type='text' value='' id='find_user' data-target='selecteduser' data-target-type='select' data-target-new='true' />";
+	   echo "<input type='text' value='' id='find_user' data-target='selecteduser' owner-check='off' data-target-type='select' data-target-new='true' />";
 //	   echo "<input type='text' value='' onkeyup='filterUser(document.getElementById(\"selecteduser\"),user,this.value);'/>";
 	   echo "<br /><select id='selecteduser' name='selected_user' onchange='submit()'>";
 	   echo "<option value='new'>"._mb("NEW")."...</option>";
More information about the Mapbender_commits mailing list
