[Mapbender-commits] r8537 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Dec 28 05:55:07 PST 2012
Author: armin11
Date: 2012-12-28 05:55:05 -0800 (Fri, 28 Dec 2012)
New Revision: 8537
   trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Bugfixes and owsproxy for INSPIRE Atom feeds
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2012-12-28 11:46:21 UTC (rev 8536)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2012-12-28 13:55:05 UTC (rev 8537)
@@ -66,8 +66,23 @@
 	$testMatch = NULL;
+//check if opensearch should be used
+if (isset($_REQUEST['OPENSEARCH']) & $_REQUEST['OPENSEARCH'] != "") {
+	//validate
+	$testMatch = $_REQUEST["OPENSEARCH"];
+ 	if ($testMatch != "true" && $testMatch != "false"){
+		echo 'OPENSEARCH: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$openSearch = $testMatch;
+	if ($openSearch == 'true') {
+		$openSearch = true;
+	} else {
+		$openSearch = false;
+	$testMatch = NULL;
 //validate request params
 if (isset($_REQUEST['ID']) & $_REQUEST['ID'] != "") {
 	//validate uuid
@@ -171,7 +186,7 @@
 $feedDoc->formatOutput = true;
 function generateOpenSearchDescription($feedDoc, $recordId, $generateFrom) {
-	global $admin, $type, $imageResolution, $maxImageSize, $maxFeatureCount, $mapbenderMetadata, $indexMapbenderMetadata, $layerId, $wfsId, $mapbenderPath;
+	global $admin, $type, $mapbenderMetadata, $indexMapbenderMetadata, $layerId, $wfsId, $mapbenderPath, $epsgId, $alterAxisOrder, $departmentMetadata, $userMetadata, $hasPermission, $m, $crs, $crsUpper, $countRessource;
 	//part which generates the feed
 	$feed =  $feedDoc->createElementNS('http://a9.com/-/spec/opensearch/1.1/', 'OpenSearchDescription');
 	$feed = $feedDoc->appendChild($feed);
@@ -246,12 +261,14 @@
 	$osImage->appendChild($osImageText);
 	$feed->appendChild($osImage);
 	//Query
+	//example
+	//$mapbenderMetadata[$m]->datasetid_codespace."#".$mapbenderMetadata[$m]->datasetid;
 	$osQuery = $feedDoc->createElement("Query");
-	$osQuery->setAttribute("inspire_dls:spatial_dataset_identifier_namespace", "http://www.geoportal.rlp.de");
-	$osQuery->setAttribute("inspire_dls:spatial_dataset_identifier_code", "some uuid");
-	$osQuery->setAttribute("inspire_dls:crs", "EPSG:25832");
+	$osQuery->setAttribute("inspire_dls:spatial_dataset_identifier_namespace", $mapbenderMetadata[$m]->datasetid_codespace);
+	$osQuery->setAttribute("inspire_dls:spatial_dataset_identifier_code", $mapbenderMetadata[$m]->datasetid);
+	$osQuery->setAttribute("inspire_dls:crs", "EPSG:".$epsgId);
 	$osQuery->setAttribute("language", "de");
-	$osQuery->setAttribute("title", "Titel des Datensatzes");
+	$osQuery->setAttribute("title", $mapbenderMetadata[$m]->metadata_title);
 	$osQuery->setAttribute("count", "1");
 	//$osQueryText = $feedDoc->createTextNode("Query");
 	//$osQuery->appendChild($osQueryText);
@@ -270,28 +287,8 @@
-//Some needfull functions to pull metadata out of the database.
-//List of data which is needed to build the feed:
-//header part ******
-// - feed title: Generated from dataset name - either mb_metadata.title or layer.layer_title
-// - feed subtitle: Generated from dataset name - either mb_metadata.title or layer.layer_title, organisation name - mapbender group information (metadata contact) - cause it is generated from data of a registrated wms
-// - link to ISO19139 service metadata - this will be created dynamically by given layer_id as this script itself
-// - link to opensearch description for this download service - as before the layer_id will be used as a parameter
-// - id - link to the script itself
-// - rights - the access constraints of the view service are used - they should also give information about the access constraints for the usage of the data
-// - updated : last date the feed was updated - use current timestamp of the wms as the feed will be generated from dataurl entry of the layer object - wms.wms_timestamp
-//datalink.random_id - this is newly created when layers are updated ! - new
-//author - use information from mapbender group - metadata point of contact - registrating organization
-//entry part ******
-// - entry title: Generated from dataset name - either mb_metadata.title or layer.layer_title - in combination e.g. with "Feed for ..."
-// - link to the dataset feed - invoked by layer id as this is done before
-// - summary -  Generated by some infomation: mb_metadata.format, mb_metadata.ref_sytem, ...., datalink.datalink_format
-// - updated - timestamp of wms as done before
-function generateFeed($feedDoc, $recordId, $generateFrom) {
+function readInfoFromDatabase($recordId, $generateFrom){
 	switch ($generateFrom) {
 		case "dataurl":
@@ -460,6 +457,30 @@
 		$hasPermission = true;
+//Some needfull functions to pull metadata out of the database.
+//List of data which is needed to build the feed:
+//header part ******
+// - feed title: Generated from dataset name - either mb_metadata.title or layer.layer_title
+// - feed subtitle: Generated from dataset name - either mb_metadata.title or layer.layer_title, organisation name - mapbender group information (metadata contact) - cause it is generated from data of a registrated wms
+// - link to ISO19139 service metadata - this will be created dynamically by given layer_id as this script itself
+// - link to opensearch description for this download service - as before the layer_id will be used as a parameter
+// - id - link to the script itself
+// - rights - the access constraints of the view service are used - they should also give information about the access constraints for the usage of the data
+// - updated : last date the feed was updated - use current timestamp of the wms as the feed will be generated from dataurl entry of the layer object - wms.wms_timestamp
+//datalink.random_id - this is newly created when layers are updated ! - new
+//author - use information from mapbender group - metadata point of contact - registrating organization
+//entry part ******
+// - entry title: Generated from dataset name - either mb_metadata.title or layer.layer_title - in combination e.g. with "Feed for ..."
+// - link to the dataset feed - invoked by layer id as this is done before
+// - summary -  Generated by some infomation: mb_metadata.format, mb_metadata.ref_sytem, ...., datalink.datalink_format
+// - updated - timestamp of wms as done before
+function generateFeed($feedDoc, $recordId, $generateFrom) {
+	global $admin, $type, $imageResolution, $maxImageSize, $maxFeatureCount, $mapbenderMetadata, $indexMapbenderMetadata, $layerId, $wfsId, $mapbenderPath, $epsgId, $alterAxisOrder, $departmentMetadata, $userMetadata, $hasPermission, $m, $crs, $crsUpper,$countRessource;
 	$feed =  $feedDoc->createElementNS('http://www.w3.org/2005/Atom', 'feed');
@@ -480,6 +501,8 @@
 	if (isset($mapbenderMetadata[$m]->metadata_title) && $mapbenderMetadata[$m]->metadata_title != '' ) {
 		$ressourceTitle = $mapbenderMetadata[$m]->metadata_title;
 	} else {
+		//TODO check wfs title....
 		if (isset($mapbenderMetadata[$m]->layer_title) && $mapbenderMetadata[$m]->layer_title != '' ) {
 		$ressourceTitle = $mapbenderMetadata[$m]->layer_title;
 		} else {
@@ -550,9 +573,9 @@
 	//self reference - 5.1.4 / 5.2
 	if ($type == 'SERVICE') {
-		$selfReference = $mapbenderPath."php/mod_inspireDownloadFeed.php?ID=".$recordId."&type=SERVICE&generatefrom=".$generateFrom;
+		$selfReference = $mapbenderPath."..".$_SERVER['SCRIPT_NAME']."?ID=".$recordId."&type=SERVICE&generatefrom=".$generateFrom;
 	} else { //DATASET
-		$selfReference = $mapbenderPath."php/mod_inspireDownloadFeed.php?ID=".$recordId."&type=DATASET&generatefrom=".$generateFrom;
+		$selfReference = $mapbenderPath."..".$_SERVER['SCRIPT_NAME']."?ID=".$recordId."&type=DATASET&generatefrom=".$generateFrom;
 		switch($generateFrom) {
 			case "wmslayer":
 				$selfReference .= "&layerid=".$mapbenderMetadata[$m]->layer_id;
@@ -575,7 +598,7 @@
 	//opensearch descriptionlink 5.1.5
 		$feedLink = $feedDoc->createElement("link");
-		$feedLink->setAttribute("href", $mapbenderPath."php/mod_inspireDownloadFeed.php?id=".$recordId."&type=".$type."&generateFrom=".$generateFrom."&wfsid=".$wfsId."&layerid=".$layerId."&getopensearch=true");
+		$feedLink->setAttribute("href", $mapbenderPath."..".$_SERVER['SCRIPT_NAME']."?id=".$recordId."&type=".$type."&generateFrom=".$generateFrom."&wfsid=".$wfsId."&layerid=".$layerId."&getopensearch=true");
 		$feedLink->setAttribute("rel", "search");
 		$feedLink->setAttribute("type", "application/opensearchdescription+xml");
 		//$feedLink->setAttribute("hreflang", "de");
@@ -742,6 +765,7 @@
 			for ($i = 0; $i < $countRessource; $i++) {
 				//overwrite feature count with information from database
 				$maxFeatureCount = (integer)$mapbenderMetadata[$i]->wfs_max_features;
 				$crs = $mapbenderMetadata[$i]->metadata_ref_system;
 				//use featuretype ref system?
 				$crs = $mapbenderMetadata[$i]->featuretype_srs;
@@ -976,7 +1000,7 @@
 		//<link rel="alternate" href="http://xyz.org/data/abc/waternetwork_WGS84.shp" type="application/x-shp" hreflang="en" title="Water Network encoded as a ShapeFile in WGS84geographic coordinates (http://www.opengis.net/def/crs/OGC/1.3/CRS84)"/>
-		$datasetFeedLink = $mapbenderPath."php/mod_inspireDownloadFeed.php?id=".$recordId."&type=DATASET&generatefrom=".$mapbenderMetadata[$i]->origin;
+		$datasetFeedLink = $mapbenderPath."..".$_SERVER['SCRIPT_NAME']."?id=".$recordId."&type=DATASET&generatefrom=".$mapbenderMetadata[$i]->origin;
 		switch($mapbenderMetadata[$i]->origin) {
 			case "wmslayer":
 				$datasetFeedLink .= "&layerid=".$mapbenderMetadata[$i]->layer_id;
@@ -1048,7 +1072,14 @@
 						$feedEntry->appendChild($feedEntryContent);
 					for ($m = 0; $m < $numberOfTiles; $m++ ) {
-						$furtherLink[$m] = $mapbenderMetadata[$i]->wms_getmap."REQUEST=GetMap&VERSION=".$mapbenderMetadata[$i]->wms_version."&SERVICE=WMS&LAYERS=".$mapbenderMetadata[$i]->layer_name;
+						//check if proxy is used, if so exchange urls with proxy urls
+						if ($mapbenderMetadata[$i]->wms_owsproxy <> NULL && $mapbenderMetadata[$i]->wms_getmap != '') {
+							$getMapUrl = str_replace(":80","",HTTP_AUTH_PROXY)."/".$mapbenderMetadata[$i]->layer_id."?";
+							//TODO check why :80 is part of the http_host - maybe apache rewrite
+						} else {
+							$getMapUrl = $mapbenderMetadata[$i]->wms_getmap;
+						$furtherLink[$m] = $getMapUrl."REQUEST=GetMap&VERSION=".$mapbenderMetadata[$i]->wms_version."&SERVICE=WMS&LAYERS=".$mapbenderMetadata[$i]->layer_name;
 						$furtherLink[$m] .= "&STYLES=&SRS=".trim($crs)."&BBOX=".$bboxWms[$m]."&WIDTH=".$maxImageSize."&HEIGHT=".$maxImageSize."&FORMAT=image/tiff&";
 						$furtherLink[$m] .= "BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage";
 						$furtherLinkType[$m] = "image/tiff"; //formats from layer_format - geotiff
@@ -1092,6 +1123,11 @@
 					for ($m = 0; $m < count($getFeatureLink); $m++ ) {
 						$furtherLink[$m] = $getFeatureLink[$m];//was computed before
+						//discard filter if only one request is needed - problem with epsg codes? TODO solve problem
+						if (count($getFeatureLink) == 1) {
+							$splittedLink = explode('&FILTER=',$furtherLink[$m]);
+							$furtherLink[$m] = $splittedLink[0];
 						$furtherLinkType[$m] = "text/xml; subtype=gml/3.1.1";//TODO: set right format for wfs version!
 						$currentIndex = $m+1;
 						$furtherLinkTitle[$m] = $ressourceTitle." im CRS ".$mapbenderMetadata[$i]->metadata_ref_system." - ".$mapbenderMetadata[$i]->format." - Teil ".$currentIndex." von ".count($getFeatureLink)."";//TODO: set right format for wfs version!
@@ -1286,6 +1322,7 @@
 		$mapbenderMetadata[$indexMapbenderMetadata]->format = $row['format'];
 		$mapbenderMetadata[$indexMapbenderMetadata]->datalink_url = $row['datalink_url'];
 		$mapbenderMetadata[$indexMapbenderMetadata]->wms_getmap = $row['wms_getmap'];
+		$mapbenderMetadata[$indexMapbenderMetadata]->wms_owsproxy = $row['wms_owsproxy'];
 		$mapbenderMetadata[$indexMapbenderMetadata]->wms_version = $row['wms_version'];
 		$mapbenderMetadata[$indexMapbenderMetadata]->wms_max_imagesize = $row['wms_max_imagesize'];
 		$mapbenderMetadata[$indexMapbenderMetadata]->layer_name = $row['layer_name'];
@@ -1322,8 +1359,10 @@
 if ($getOpenSearch) {
+	readInfoFromDatabase($recordId, $generateFrom);
 	pushOpenSearch($feedDoc, $recordId, $generateFrom);
 } else {
 	pushFeed($feedDoc, $recordId, $generateFrom); //throw it out to world!
More information about the Mapbender_commits mailing list
