[Mapbender-commits] r8262 - in branches/2.7: http/javascripts resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Feb 23 02:40:50 EST 2012
Author: verenadiewald
Date: 2012-02-22 23:40:50 -0800 (Wed, 22 Feb 2012)
New Revision: 8262
   branches/2.7/http/javascripts/mod_legend.php
   branches/2.7/http/javascripts/mod_legendDiv.php
   branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
rename element var reverse to reverseLegend
Modified: branches/2.7/http/javascripts/mod_legend.php
--- branches/2.7/http/javascripts/mod_legend.php	2012-02-22 14:54:33 UTC (rev 8261)
+++ branches/2.7/http/javascripts/mod_legend.php	2012-02-23 07:40:50 UTC (rev 8262)
@@ -68,7 +68,7 @@
 var checkbox_on_off = typeof checkbox_on_off === "undefined" ? 'false' : checkbox_on_off;
 var stickylegend = typeof stickylegend === "undefined" ? "false" : stickylegend;
-var reverse = typeof reverse === "undefined" ? "false" : reverse;
+var reverseLegend = typeof reverseLegend === "undefined" ? "false" : reverseLegend;
 function mod_legend_pos(frameName){
 	if(frameName == mod_legend_target){
@@ -87,7 +87,7 @@
 		var str = "";
 		var str_tmp = "";
-		if(reverse == 'true') {
+		if(reverseLegend == 'true') {
 			for(var i=parent.mb_mapObj[ind].wms.length-1; i>=0; i--){
 			 	var layerNames = parent.mb_mapObj[ind].wms[i].getLayers(parent.mb_mapObj[ind]);
 				for(var j=0; j<layerNames.length; j++){
Modified: branches/2.7/http/javascripts/mod_legendDiv.php
--- branches/2.7/http/javascripts/mod_legendDiv.php	2012-02-22 14:54:33 UTC (rev 8261)
+++ branches/2.7/http/javascripts/mod_legendDiv.php	2012-02-23 07:40:50 UTC (rev 8262)
@@ -43,7 +43,7 @@
 var showwmstitle = typeof showwmstitle === "undefined" ? "false" : showwmstitle;
 var showlayertitle = typeof showlayertitle === "undefined" ? "false" : showlayertitle;
 var showgroupedlayertitle = typeof showgroupedlayertitle === "undefined" ? "false" : showgroupedlayertitle;
@@ -53,7 +53,7 @@
 		var str = "";
 		var str_tmp = "";
 			for(var i=mb_mapObj[ind].wms.length-1; i>=0; i--){
 				 	var layerNames = mb_mapObj[ind].wms[i].getLayers(mb_mapObj[ind]);
Modified: branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql	2012-02-22 14:54:33 UTC (rev 8261)
+++ branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql	2012-02-23 07:40:50 UTC (rev 8262)
@@ -184,15 +184,15 @@
 -- Fix: wrong tooltip for Legend-button
 UPDATE gui_element SET e_title = 'Legend' WHERE e_id = 'legendButton' AND fkey_gui_id = 'template_print';
--- new element_var reverse for element legend
+-- new element_var reverseLegend for element legend
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
 SELECT gui_element.fkey_gui_id,
-'legend', 'reverse', 'false', 'parameter to decide wether the legend should be in the reverse direction' ,'var'
+'legend', 'reverseLegend', 'false', 'parameter to decide wether the legend should be in the reverse direction' ,'var'
 from gui_element
 WHERE
 gui_element.e_id = 'legend' AND
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'legend' AND var_name = 'reverse');
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'legend' AND var_name = 'reverseLegend');
 -- change datatype from 50 to 256 to handle longer style names
More information about the Mapbender_commits mailing list
