[Mapbender-commits] r8446 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jul 10 07:07:51 PDT 2012
Author: armin11
Date: 2012-07-10 07:07:51 -0700 (Tue, 10 Jul 2012)
New Revision: 8446
   trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Bugfix for INSPIRE predefined dataset: Don't use WFS 1.0.0 to generate feed, cause reslutType=hits is not supported.
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2012-07-09 15:31:31 UTC (rev 8445)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2012-07-10 14:07:51 UTC (rev 8446)
@@ -269,6 +269,9 @@
 		return "<error>The metadataset with id ".$mapbenderMetadata[$m]->metadata_id." has no coupled ".$generateFrom." ressource ".$m."</error>";
 	$crs = $mapbenderMetadata[$m]->metadata_ref_system;
+	if (!isset($mapbenderMetadata[$m]->metadata_ref_system) || $mapbenderMetadata[$m]->metadata_ref_system == '') {
+		return "<error>For the metadataset with id ".$mapbenderMetadata[$m]->metadata_id." is no reference system defined!</error>";
 	$epsgId = explode(':',$crs);
 	//infos about the registrating department, check first if a special metadata point of contact is defined in the service table - function from mod_showMetadata - TODO: should be defined in admin class
@@ -586,7 +589,12 @@
 			//For each featuretype which was found! Maybe more than one!
 			for ($i = 0; $i < $countRessource; $i++) {
 				$crs = $mapbenderMetadata[$i]->metadata_ref_system;
+				$e = new mb_notice("Ref system of featuretype ".$mapbenderMetadata[$i]->featuretype_name." : ".$crs);
+				$e = new mb_notice("Epsg id of featuretype ".$mapbenderMetadata[$i]->featuretype_name." : ".$epsgId[1]);
+				if (!($mapbenderMetadata[$i]->wfs_version) || $mapbenderMetadata[$i]->wfs_version == '' || $mapbenderMetadata[$i]->wfs_version == '1.0.0') {
+				return "<error>Version of WFS : ".$mapbenderMetadata[$i]->wfs_version." is not supported to generate inspire download services for predefined datasets!</error>";
 				//define request to get number of hits per featuretype
 				$gHLink = $mapbenderMetadata[$i]->wfs_getfeature."SERVICE=WFS&REQUEST=GetFeature&VERSION=";
 				$gHLink .= $mapbenderMetadata[$i]->wfs_version."&typeName=";
@@ -595,6 +603,7 @@
 				$startRequestTime = time();
 				$hitConnector = new connector($gHLink);
 				$hitXml = $hitConnector->file;
+				$e = new mb_exception($gHLink);
 				$endRequestTime = time();
 				$diffTime = $endRequestTime-$startRequestTime;
 				$e = new mb_exception("Time for counting objects of featuretype ".$mapbenderMetadata[$i]->featuretype_name." : ".$diffTime." seconds!");
@@ -642,8 +651,8 @@
 				$diffX = $maxx - $minx; //in m - depends on given epsg code
 				$diffY = $maxy - $miny;	//in m
-				$e = new mb_exception($diffX);
-				$e = new mb_exception($diffY);
+				$e = new mb_notice($diffX);
+				$e = new mb_notice($diffY);
 				$width = ceil(sqrt(($diffX * $diffY) / $countTiles));
 $e = new mb_exception($width);
@@ -720,7 +729,7 @@
 			$numberOfEntries = count($mapbenderMetadata);
+	$e = new mb_exception("Count of bboxes: ".$numberOfEntries);
 	for ($i = 0; $i < $numberOfEntries; $i++) {
 		//<entry> 5.1.12 / 5.2.3
 		$feedEntry = $feedDoc->createElement("entry");
More information about the Mapbender_commits mailing list
