[Mapbender-commits] r8373 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Jun 7 02:03:25 PDT 2012
Author: armin11
Date: 2012-06-07 02:03:25 -0700 (Thu, 07 Jun 2012)
New Revision: 8373
trunk/mapbender/http/classes/class_iso19139.php
Add simple initial iso19139 object to class - further work have to be done.
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2012-06-06 18:54:10 UTC (rev 8372)
+++ trunk/mapbender/http/classes/class_iso19139.php 2012-06-07 09:03:25 UTC (rev 8373)
@@ -40,7 +40,27 @@
var $type;
var $origin;
+ function __construct() {
+ //initialize empty iso19139 object
+ $this->fileIdentifier = "";
+ $title->title = "empty iso19139 object title";
+ $title->abstract = "empty iso19139 object abstract";
+ $this->createDate = "1900-01-01";
+ $this->changeDate = "1900-01-01";
+ $this->metadata = "";
+ $this->datasetId = "";
+ $this->datasetIdCodeSpace = "";
+ $this->keywords[0] = "";
+ $this->hierachyLevel = "dataset";
+ $this->tmpExtentBegin = "1900-01-01";
+ $this->tmpExtentEnd = "1900-01-01";
+ $this->randomId = "";
+ $this->href = "";
+ $this->format = "";
+ $this->type = "";
+ $this->origin = "";
+ $this->refSystem = "";
public function removeGetRecordTag ($xml) {
$regex = "#<csw:GetRecordByIdResponse .*?>#";
$xml = preg_replace($regex,"",$xml);
@@ -70,10 +90,14 @@
//if parsing was successful
if ($iso19139Xml != false) {
$this->fileIdentifier = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString');
+ $this->fileIdentifier = $this->fileIdentifier[0];
$this->createDate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
+ $this->createDate = $this->createDate[0];
$this->changeDate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
+ $this->changeDate = $this->changeDate[0];
//TODO: check if this is set, maybe DateTime must be searched instead?
$this->title = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:title/gco:CharacterString');
+ $this->title = $this->title[0];
//dataset identifier - howto model into md_metadata?
//check where datasetid is defined - maybe as RS_Identifier or as MD_Identifier see http://inspire.jrc.ec.europa.eu/documents/Metadata/INSPIRE_MD_IR_and_ISO_v1_2_20100616.pdf page 18
//First check if MD_Identifier is set, then check if RS_Identifier is used!
@@ -96,10 +120,14 @@
//abstract
$this->abstract = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:abstract/gco:CharacterString');
+ $this->abstract = $this->abstract[0];
$this->keywords = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:descriptiveKeywords/gmd:MD_Keywords/gmd:keyword/gco:CharacterString');
$this->hierachyLevel = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:hierarchyLevel/gmd:MD_ScopeCode');
+ $this->hierachyLevel = $this->hierachyLevel[0];
$this->tmpExtentBegin = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:beginPosition');
- $this->tmpExtentEnd = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:endPosition');
+ $this->tmpExtentBegin = $this->tmpExtentBegin[0];
+ $this->tmpExtentEnd = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:endPosition');
+ $this->tmpExtentEnd = $this->tmpExtentEnd[0];
//spatial_res_type
//spatial_res_value
//ref_system
@@ -183,7 +211,7 @@
$e = new mb_exception(_mb("Cannot insert metadata relation!"));
return false;
} else {
- $sql = "UPDATE mb_metadata SET harvestresult = 0 where metadata_id = $1";
+ $sql = "UPDATE mb_metadata SET harvestresult = 0, harvestexception = 'Linked metadata could not be interpreted, only linkage is stored to mb_metadata!' where metadata_id = $1";
$v = array($metadataId);
$t = array('i');
$res = db_prep_query($sql,$v,$t);
@@ -208,13 +236,13 @@
$this->type,
$this->fileIdentifier[0],
$this->title[0],
- $this->createDate[0],
- $this->changeDate[0],
+ $this->createDate,
+ $this->changeDate,
$this->abstract[0],
$this->keywords[0],
- $this->hierachyLevel[0],
- $this->tmpExtentBegin[0],
- $this->tmpExtentEnd[0],
+ $this->hierachyLevel,
+ $this->tmpExtentBegin,
+ $this->tmpExtentEnd,
't',
$this->datasetId,
$this->datasetIdCodeSpace,
More information about the Mapbender_commits
