[Mapbender-commits] r8276 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Mar 6 02:04:18 EST 2012
Author: armin11
Date: 2012-03-05 23:04:17 -0800 (Mon, 05 Mar 2012)
New Revision: 8276
Added:
   trunk/mapbender/http/plugins/mod_jsonAutocompleteGazetteer.php
Push module to folder plugins
Added: trunk/mapbender/http/plugins/mod_jsonAutocompleteGazetteer.php
--- trunk/mapbender/http/plugins/mod_jsonAutocompleteGazetteer.php	                        (rev 0)
+++ trunk/mapbender/http/plugins/mod_jsonAutocompleteGazetteer.php	2012-03-06 07:04:17 UTC (rev 8276)
@@ -0,0 +1,269 @@
+<?php
+ * Package: mod_jsonAutocompleteGazetteer
+ * Description:
+ * This module is a client for a json gazetteer webservice as used by http://www.geonames.org. The default
+ * service is the service from geonames.org which allows searching for
+ * Files:
+ *  - http/plugins/mod_jsonAutocompleteGazetteer.php
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src,
+ * > e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag,
+ * > e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>','jq_ui_autocomplete',5,1,
+ * > 'Module to manage jQuery UI autocomplete module','','div','','',-1,-1,15,15,NULL ,'','','div',
+ * > '','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.autocomplete.js',
+ * > '','jq_ui,jq_ui_widget,jq_ui_position','');
+ * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+ * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>',
+ * > 'jsonAutocompleteGazetteer',12,1,'Client for json webservices like geonames.org','Gazetteer',
+ * > 'div','','',230,30,NULL ,NULL ,999,'','','div','../plugins/mod_jsonAutocompleteGazetteer.php',
+ * > '','mapframe1','','http://www.mapbender.org/index.php/mod_jsonAutocompleteGazetteer');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+ * > VALUES('<app_id>', 'jsonAutocompleteGazetteer', 'gazetteerUrl', 'http://ws.geonames.org/searchJSON?lang=de&',
+ * >  '' ,'var');
+ * >  VALUES('<app_id>', 'jsonAutocompleteGazetteer', 'isGeonames', 'true', '' ,'var');
+ * Help:
+ * http://www.mapbender.org/mod_jsonAutocompleteGazetteer
+ * Maintainer:
+ * http://www.mapbender.org/User:Armin_Retterath
+ * Parameters:
+ * none
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+var standingHighlight = null;
+Mapbender.events.afterMapRequest.register( function(){
+	if(standingHighlight){
+		standingHighlight.paint();
+//initialize modul
+if (options.gazetteerUrl === undefined) {
+	options.gazetteerUrl = 'http://ws.geonames.org/searchJSON?lang=de&';
+if (options.isGeonames === undefined) {
+	options.isGeonames = true;
+if (options.latLonZoomExtension === undefined) {
+	options.latLonZoomExtension = 0.1;
+if (options.minLength === undefined) {
+	options.minLength = 3;
+if (options.delay === undefined) {
+	options.delay = 400;
+if (options.isDraggable === undefined) {
+	options.isDraggable = true;
+if (options.maxResults === undefined) {
+	options.maxResults = 15;
+if (options.inputWidth === undefined) {
+	options.inputWidth = 250;
+if (options.searchEpsg === undefined) {
+	options.searchEpsg = "4326";
+if (options.drawCentrePoint === undefined) {
+	options.drawCentrePoint = true;
+if (options.gazetteerFrontImageOn === undefined) {
+	options.gazetteerFrontImageOn = "../img/button_blue_red/gazetteer3_on.png";
+if (options.gazetteerFrontImageOff === undefined) {
+	options.gazetteerFrontImageOff = "../img/button_blue_red/gazetteer3_off.png";
+var JsonAutocompleteGazetteer = function() {
+	var that = this;
+	var targetName = options.target;
+	var ind = getMapObjIndexByName(targetName);
+	var my = mb_mapObj[ind];
+	this.zoomToExtent = function(fromSrs,minx,miny,maxx,maxy) {
+		var parameters = {
+			fromSrs: fromSrs,
+			toSrs: Mapbender.modules[targetName].epsg
+		parameters.bbox = parseFloat(minx)+ "," +parseFloat(miny)+ "," +parseFloat(maxx)+ "," +parseFloat(maxy);
+		//function to transform from one crs to another
+		var req = new Mapbender.Ajax.Request({
+			url: "../php/mod_coordsLookup_server.php",
+			method: "transform",
+			parameters: parameters,
+			callback: function (obj, success, message) {
+				if (!success) {
+					new Mapbender.Exception(message);
+					return;
+				if (options.drawCentrePoint) {
+					//generate layer for visualization of point
+					if(standingHighlight !== null){
+						standingHighlight.clean();
+					}else{
+						standingHighlight = new Highlight(
+							[options.target],
+							"standingHighlight",
+							{"position":"absolute", "top":"0px", "left":"0px", "z-index":10000},
+							2);
+					var point0 = new Point(obj.points[0].x,obj.points[0].y);
+					var point1 = new Point(obj.points[1].x,obj.points[1].y);
+					var x = point0.x + (point1.x - point0.x)/2;
+					var y = point0.y + (point1.y - point0.y)/2;
+					var point = new Point(x,y);
+					var ga = new GeometryArray();
+					ga.importPoint({
+						coordinates:[x,y,null]
+					},Mapbender.modules[targetName].epsg)
+					var m = ga.get(-1,-1);
+					standingHighlight.add(m, "#ff0000");
+					//alert(m);
+				if (obj.points) {
+					if (obj.points.length === 2) {
+						var newExtent = new Extent(
+							obj.points[0].x,
+							obj.points[0].y,
+							obj.points[1].x,
+							obj.points[1].y
+						my.calculateExtent(newExtent);
+					my.setMapRequest();
+		req.send();
+	this.toggleInput = function(){
+		if ($("#geographicName").css("display") == 'none') {
+			$("#geographicName").show();
+			$("#symboldForInputId").attr({'src':options.gazetteerFrontImageOn});
+		} else {
+			$("#geographicName").hide();
+			$("#symboldForInputId").attr({'src':options.gazetteerFrontImageOff});
+	this.initForm = function() {
+		epsg = Mapbender.modules[targetName].epsg.replace('EPSG:', '');
+		this.formContainer = $(document.createElement('form')).attr({'id':'json-autocomplete-gazetteer'}).appendTo('#' + options.id);
+		this.formContainer.submit(function() {
+			return false;
+		if (options.isDraggable){
+			this.formContainer.draggable();
+		this.symbolForInput = $(document.createElement('img')).appendTo(this.formContainer);
+		this.symbolForInput.attr({'id':'symboldForInputId'});
+		this.symbolForInput.attr({'src':options.gazetteerFrontImageOn});
+		this.symbolForInput.attr({'title':'<?php echo _mb('Address'); ?>'});
+		this.symbolForInput.click(function() {
+			that.toggleInput();
+		this.inputAddress = $(document.createElement('input')).appendTo(this.formContainer);
+		this.inputAddress.attr({'id':'geographicName'});
+		//default value
+		this.inputAddress.val('<?php echo _mb('Search for addresses'); ?>');
+		this.inputAddress.css('width',options.inputWidth);
+		$('.ui-menu').css('width','100px');
+		$('.ui-menu-item').css('width','100px');
+		//set the loading symbol for autoloader class
+		//$('.ui-autocomplete-loading').css('background','white url("../img/indicator_wheel.gif") right center no-repeat');
+		//http://stackoverflow.com/questions/622122/how-can-i-change-the-css-class-rules-using-jquery
+		//$("<style type='text/css'> .ui-autocomplete { position: absolute; cursor: default; background:black; color:white} </style>").appendTo("head");
+		$(function() {
+			$( "#geographicName" ).autocomplete({
+				source: function( request, response ) {
+					$.ajax({
+						url: options.gazetteerUrl,
+						dataType: "jsonp",
+						data: {
+							outputFormat: 'json',
+							resultTarget: 'web',
+							searchEPSG: options.searchEpsg,
+							maxResults: options.maxResults,
+							maxRows: options.maxResults,
+							searchText: request.term,
+							featureClass: "P",
+							style: "full",
+							name_startsWith: request.term
+						success: function( data ) {
+							if (options.isGeonames) {
+								response( $.map( data.geonames, function( item ) {
+									return {
+										label: item.name+" - "+item.fclName+" - "+item.countryName,
+										minx: item.lng-options.latLonZoomExtension,
+										miny: item.lat-options.latLonZoomExtension,
+										maxx: item.lng+options.latLonZoomExtension,
+										maxy: item.lat+options.latLonZoomExtension
+							} else {
+									return {
+										label: item.title,
+										minx: item.minx,
+										miny: item.miny,
+										maxx: item.maxx,
+										maxy: item.maxy
+				minLength: options.minLength,
+				delay: options.delay,
+				select: function( event, ui ) {
+					that.zoomToExtent("EPSG:"+options.searchEpsg,ui.item.minx,ui.item.miny,ui.item.maxx,ui.item.maxy);
+				open: function() {
+					$( this ).removeClass( "ui-corner-all" ).addClass( "ui-corner-top" );
+				close: function() {
+					$( this ).removeClass( "ui-corner-top" ).addClass( "ui-corner-all" );
+	this.initForm();
+Mapbender.events.init.register(function() {
+	Mapbender.modules[options.id] = $.extend(new JsonAutocompleteGazetteer(),Mapbender.modules[options.id]);
More information about the Mapbender_commits mailing list
