[Mapbender-commits] r8287 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Mar 13 10:37:48 EDT 2012
Author: astrid_emde
Date: 2012-03-13 07:37:48 -0700 (Tue, 13 Mar 2012)
New Revision: 8287
Removed:
   trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php
   trunk/mapbender/http/javascripts/mod_jsonAutocompleteGazetteer.php
moved to plugins-folder
Deleted: trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php
--- trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php	2012-03-13 14:32:32 UTC (rev 8286)
+++ trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php	2012-03-13 14:37:48 UTC (rev 8287)
@@ -1,400 +0,0 @@
-<?php
- * Package: mod_WMSpreferencesDiv
- * Description:
- * This module generates a table with wms of the mapObject. The user
- * can change the mapformat, featureinfoformat and the exceptionformat for each wms.
- * Also the wms priority and the map transparency can be changed interactivly. The module
- * should exchange the old mod_WMSpreferences module which was an iframe before.
- * The module is invoked thru a button click. The button must be a mb_button.js module
- * Files:
- *  - http/javascripts/mod_WMSpreferencesDiv.php
- * SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * >   e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * >  e_height, e_z_index, e_more_styles, e_content, e_closetag,
- * >  e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES(
- * > '<app_id>','WMS_preferencesDiv',12,1,'Configure WMS preferences - div tag','WMS preferences',
- * > 'div','','',870,60,400,500,NULL ,'z-index:9999;','','div','mod_WMSpreferencesDiv.php',
- * > '','mapframe1','jq_ui_dialog','http://www.mapbender.org/index.php/mod_WMSpreferencesDiv.php');
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
- * > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
- * > VALUES('<app_id>','WMS_preferencesButton',2,1,'button for configure the preferences of each loaded wms',
- * > 'Manage WMS preferences','img','../img/button_blink_red/preferences_off.png','',
- * > 670,60,24,24,1,'','','','../plugins/mb_button.js','','WMS_preferencesDiv',
- * > '','http://www.mapbender.org/index.php/mb_button');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
- * > context, var_type) VALUES('gui1', 'WMS_preferencesButton', 'dialogWidth', '400', '' ,'var');
- * Help:
- * http://www.mapbender.org/mod_WMSpreferencesDiv
- * Maintainer:
- * http://www.mapbender.org/User:Armin_Retterath
- * Parameters:
- * none
- * License:
- * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
- * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-$e_id = 'WMS_preferencesDiv';
-$gui_id = array(Mapbender::session()->get("mb_user_gui"));
-//include all element vars from the given element
-include '../include/dyn_js.php';
-include '../include/dyn_php.php';
-$vis = "";
-$wmsid = "";
-$sql_visible = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1";
-$v = array(Mapbender::session()->get("mb_user_gui"));
-$t = array("s");
-$res_visible = db_prep_query($sql_visible, $v, $t);
-$cnt_visible = 0;
-while($row = db_fetch_array($res_visible)){
-	$gui_wms_visible[$cnt_visible] = $row["gui_wms_visible"];
-	$fkey_wms_id_visible[$cnt_visible] = $row["fkey_wms_id"];
-	if($cnt_visible>0){
-		$vis .= ",";
-		$wmsid .= ",";
-	$vis .= $gui_wms_visible[$cnt_visible];
-	$wmsid .= $fkey_wms_id_visible[$cnt_visible];
-	$cnt_visible++;
-echo "var mod_gui_wms_visible = '".$vis."';";
-echo "var mod_fkey_wms_id_visible = '".$wmsid."';";
-//initialize module
-var WMS_preferencesDiv = function() {
-	var that = this;
-	var targetName = options.target;
-	var ind = getMapObjIndexByName(targetName);
-	var my = mb_mapObj[ind];
-	//functions
-	this.mb_swapWmsByIndex = function(mapObj_ind, indexA, indexB) {
- 		var myMapObj = mb_mapObj[mapObj_ind];
-		if (indexA != indexB && indexA >= 0 && indexA < myMapObj.wms.length && indexB >= 0 && indexB < myMapObj.wms.length) {
-			upper = myMapObj.wms[indexA];
-			myMapObj.wms[indexA] = myMapObj.wms[indexB];
-			myMapObj.wms[indexB] = upper;
-			var upperLayers = myMapObj.layers[indexA];
-			var upperStyles = myMapObj.styles[indexA];
-			var upperQuerylayers = myMapObj.querylayers[indexA];
-			myMapObj.layers[indexA] = myMapObj.layers[indexB];
-			myMapObj.styles[indexA] = myMapObj.styles[indexB];
-			myMapObj.querylayers[indexA] = myMapObj.querylayers[indexB];
-			myMapObj.layers[indexB] = upperLayers;
-			myMapObj.styles[indexB] = upperStyles;
-			myMapObj.querylayers[indexB] = upperQuerylayers;
-			return true;
-		else {
-			return false;
-	this.setMapformat = function(val) {
-		var tmp = val.split(",");
-		my.wms[tmp[0]].gui_wms_mapformat = tmp[1];
-		Mapbender.modules[options.target].setMapRequest();
-		this.formContainer.remove();
-		this.initForm();
-	this.setFeatureformat = function(val) {
-		my.wms[tmp[0]].gui_wms_featureinfoformat = tmp[1];
-		this.initForm();
-	this.setExceptionformat = function(val) {
-		my.wms[tmp[0]].gui_wms_exceptionformat = tmp[1];
-		this.initForm();
-	this.swap = function(index1, index2) {
-		if (this.mb_swapWmsByIndex(ind, index1, index2) == true) {
-			this.initForm();
-			zoom(options.target, true, 1.0);
-			mb_execloadWmsSubFunctions();
-	this.remove_wms = function(num) {
-		var cnt_vis=0;
-		var wms_visible_down = mod_gui_wms_visible.split(",");
-		var wms_vis_down = wms_visible_down.length;
-		//check if there are more than two visible wms's
-		for(var i=0; i < wms_visible_down.length; i++){
-			var my_wms_visible = wms_visible_down[i];
-			if(my_wms_visible == 0){
-  				var cnt_vis = cnt_vis+1;
-		if(my.wms.length - cnt_vis>1){
-	  		var ind = getMapObjIndexByName(options.target);
-  			mb_mapObjremoveWMS(ind,num)
-		else{
-			alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
-		this.initForm();
-	this.deleteForm = function() {
-	this.refreshTransparency = function(visibleWmsIndexArray) {
-		for (var i = 0 ; i < visibleWmsIndexArray.length ; i++) {
-			wmsId = my.wms[visibleWmsIndexArray[i]].wms_id;
-			$( "#transparency_"+wmsId ).val( $( "#slider_" + wmsId ).slider( "value" ) );
-			my.wms[visibleWmsIndexArray[i]].setOpacity(100-($( "#slider_" + wmsId ).slider( "value" )));
-	this.initForm = function() {
-		var str = "";
-		var wms_visible = mod_gui_wms_visible.split(",");
-		var wms_id_visible = mod_fkey_wms_id_visible.split(",");
-		var visibleWmsIndexArray = new Array();
-		this.formContainer = $(document.createElement('form')).attr({'id':'wms-preferences-form'}).appendTo('#' + options.id);
-		for(var i=0; i < my.wms.length; i++){
-			var found = false;
-			for(var j=0; j < wms_id_visible.length; j++){
-				if (wms_visible[j] == 1 && wms_id_visible[j] == my.wms[i].wms_id){
-					visibleWmsIndexArray[visibleWmsIndexArray.length] = i;
-					found = true;
-			if (found == false && my.wms[i].gui_wms_visible == 1) {
-		//loop over all visible wms if reversed layer order is wished, reverse visibleWmsIndexArray
-		options.reversePreferences = true;
-		if (options.reversePreferences) {
-			visibleWmsIndexArray.reverse();
-			z = visibleWmsIndexArray[i];
-			var mapString = "";
-			var featureinfoString = "";
-			var exceptionString = "";
-			for(var j=0; j<my.wms[z].data_type.length; j++){
-				if(my.wms[z].data_type[j] == 'map'){
-					mapString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-					if(my.wms[z].data_format[j] == my.wms[z].gui_wms_mapformat){
-						mapString += "selected";
-					mapString += ">"+my.wms[z].data_format[j]+"</option>";
-				else if(my.wms[z].data_type[j] == 'featureinfo'){
-					featureinfoString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-					if(my.wms[z].data_format[j] == my.wms[z].gui_wms_featureinfoformat){
-						featureinfoString += "selected";
-					featureinfoString += ">"+my.wms[z].data_format[j]+"</option>";
-				else if(my.wms[z].data_type[j] == 'exception'){
-					exceptionString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-					if(my.wms[z].data_format[j] == my.wms[z].gui_wms_exceptionformat){
-						exceptionString += "selected";
-					exceptionString += ">"+my.wms[z].data_format[j]+"</option>";
-			//extract wms title, id and abstract
-			var wmsTitle = my.wms[z].wms_title;
-			var wmsAbstract = my.wms[z].wms_abstract;
-			var wmsId = my.wms[z].wms_id;
-			//generate Form
-			this.tableContainer = $(document.createElement('table')).appendTo(this.formContainer);
-			this.tableContainer.attr({'border':'1'});
-			this.tableContainer.attr({'rules':'rows'});
-			this.tableContainer.attr({'width':'300'});
-			this.rowContainer = $(document.createElement('tr')).appendTo(this.tableContainer);
-			this.columnContainer = $(document.createElement('th')).appendTo(this.rowContainer);
-			if (visibleWmsIndexArray.length > 1) {
-				if (i != 0) {
-					//show up arrow only if it is not the first entry and if the count of entries is greater than 1
-					this.wmsUp = $(document.createElement('img')).appendTo(this.columnContainer);
-					this.wmsUp.attr({'src':'../img/button_gray/up.png'});
-					this.wmsUp.attr({'id':'wmsUp_'+i});
-					//this.wmsUp.attr({'style':'filter:Chroma(color=#C2CBCF);'});
-					this.wmsUp.attr({'value':'up'});
-					this.wmsUp.attr({'title':'move WMS up'});
-					$("#" + "wmsUp" + "_" + i).click((function (i,z) {
-						return function(){
-							Mapbender.modules[options.id].swap(visibleWmsIndexArray[i-1],z);
-                        			//alert("move up");
- 		        		})(i,z));
-				//show down arrow only if the entry is not the last one and if the count of entries is greater than 1
-				if (i != visibleWmsIndexArray.length-1) {
-					this.wmsDown = $(document.createElement('img')).appendTo(this.columnContainer);
-					this.wmsDown.attr({'src':'../img/button_gray/down.png'});
-					this.wmsDown.attr({'id':'wmsDown_'+i});
-					//this.wmsDown.attr({'style':'filter:Chroma(color=#C2CBCF);'});
-					//this.wmsDown.attr({'onclick':'alert("move up");'});
-					this.wmsDown.attr({'value':'down'});
-					this.wmsDown.attr({'title':'move WMS down'});
-					$("#" + "wmsDown" + "_" + i).click((function (i,z) {
-							Mapbender.modules[options.id].swap(z,visibleWmsIndexArray[i+1]);
- 		        		})(i,z));
-				this.wmsRemove = $(document.createElement('img')).appendTo(this.columnContainer);
-				this.wmsRemove.attr({'src':'../img/button_gray/del.png'});
-				this.wmsRemove.attr({'id':'wmsRemove_'+i});
-				//this.wmsRemove.attr({'onclick':'alert("remove");'});
-				this.wmsRemove.attr({'value':'remove'});
-				this.wmsRemove.attr({'title':'remove WMS from GUI'});
-				$("#" + "wmsRemove" + "_" + i).click((function (z) {
-						Mapbender.modules[options.id].remove_wms(z);
- 		       		})(z));
-			this.wmsTitleDiv = $(document.createElement('div')).appendTo(this.columnContainer);
-			this.wmsTitleDiv.attr({'id':'id_'+wmsId});
-			this.wmsTitleDiv.attr({'style':'cursor:pointer'});
-			this.wmsTitleDiv.attr({'onmouseover':'title=\"'+'id:'+wmsId+' '+my.wms[z].wms_abstract+'\"'});
-			//this.wmsTitleDiv.attr({'width':'300'});
-			this.wmsTitle = $(document.createElement('b')).appendTo(this.columnContainer);
-			this.wmsTitle.attr({'title':wmsId+':'+wmsAbstract});
-			this.wmsTitle.append(wmsTitle);
-			//new row mapImageFormat
-			this.columnContainer = $(document.createElement('td')).appendTo(this.rowContainer);
-			this.mapInfoTitle = this.columnContainer.append('<?php echo _mb('MapFormat'); ?>: ');
-			this.mapInfoSelect = $(document.createElement('select')).appendTo(this.columnContainer);
-			this.mapInfoSelect.change(function () {
-					Mapbender.modules[options.id].setMapformat(this.value);
-			this.mapInfoSelect.attr({'onchange':'Mapbender.modules[options.id].setMapformat(this.value);'});
-			this.mapInfoSelect.append(mapString);
-			//new row featureInfoFormat
-			this.featureInfoTitle = this.columnContainer.append('<?php echo _mb('FeatureInfoFormat'); ?>: ');
-			this.featureInfoSelect = $(document.createElement('select')).appendTo(this.columnContainer);
-			this.featureInfoSelect.attr({'onchange':'Mapbender.modules[options.id].setFeatureformat(this.value);'});
-			this.featureInfoSelect.append(featureinfoString);
-			//new row exceptionFormat
-			this.exceptionTitle = this.columnContainer.append('<?php echo _mb('ExceptionFormat'); ?>: ');
-			this.exceptionSelect = $(document.createElement('select')).appendTo(this.columnContainer);
-			this.exceptionSelect.attr({'onchange':'Mapbender.modules[options.id].setExceptionformat(this.value);'});
-			this.exceptionSelect.append(exceptionString);
-			this.transparencyTitle = this.columnContainer.append('<?php echo _mb('Transparency'); ?>: ');
-			this.transparencyValue = $(document.createElement('input')).appendTo(this.columnContainer);
-			this.transparencyValue.attr({'type':'text'});
-			this.transparencyValue.attr({'id':'transparency_'+wmsId});
-			if (isNaN(my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity)) {
-				thisWmsOpacity = 0;
-			} else {
-				thisWmsOpacity =  100-(my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity*100);
-			this.transparencyValue.attr({'value':thisWmsOpacity});
-			this.transparencyValue.attr({'style':'border:0; color:#f6931f; font-weight:bold;'});
-			this.wmsTransparencySliderDiv = $(document.createElement('div')).appendTo(this.columnContainer)
-			this.wmsTransparencySliderDiv.attr({'id':'slider_'+wmsId});
-			$("#slider_" + wmsId).slider({
-				min: 0,
-				max: 100,
-				step: 10,
-				value: thisWmsOpacity,
-				change: function( event, ui) {
-						that.refreshTransparency(visibleWmsIndexArray);
-			/*$("#slider_" + wmsId).slider();
-			$("#slider_" + wmsId).slider( "option", "min", 100 );
-			$("#slider_" + wmsId).slider( "option", "max", 0 );
-			$("#slider_" + wmsId).slider( "option", "step", -10 );*/
-			this.formContainer.append('<br>');
-this.initForm();
-Mapbender.events.init.register(function() {
-	Mapbender.modules[options.id] = $.extend(new WMS_preferencesDiv(),Mapbender.modules[options.id]);
Deleted: trunk/mapbender/http/javascripts/mod_jsonAutocompleteGazetteer.php
--- trunk/mapbender/http/javascripts/mod_jsonAutocompleteGazetteer.php	2012-03-13 14:32:32 UTC (rev 8286)
+++ trunk/mapbender/http/javascripts/mod_jsonAutocompleteGazetteer.php	2012-03-13 14:37:48 UTC (rev 8287)
@@ -1,308 +0,0 @@
-<?php
- * Package: mod_jsonAutocompleteGazetteer
- * Description:
- * Files:
- *  - http/javascripts/mod_jsonAutocompleteGazetteer.php
- * SQL:
- * Help:
- * Maintainer:
- * Parameters:
- * none
- * License:
-$e_id = 'jsonAutocompleteGazetteer';
-//include '../include/dyn_php.php';
-var standingHighlight = null;
-Mapbender.events.afterMapRequest.register( function(){
-	if(standingHighlight){
-		standingHighlight.paint();
-alert(options.gazetteerUrl);
-if (options.gazetteerUrl === undefined) {
-	options.gazetteerUrl = 'http://www.geoportal.rlp.de/mapbender/geoportal/gaz_geom_mobile.php';
-	//options.gazetteerUrl = 'http://ws.geonames.org/searchJSON?lang=de&';
-if (options.isGeonames === undefined) {
-	options.isGeonames = false;
-if (options.latLonZoomExtension === undefined) {
-	options.latLonZoomExtension = 0.1;
-if (options.minLength === undefined) {
-	options.minLength = 3;
-if (options.delay === undefined) {
-	options.delay = 400;
-if (options.isDraggable === undefined) {
-	options.isDraggable = true;
-if (options.maxResults === undefined) {
-	options.maxResults = 15;
-if (options.inputWidth === undefined) {
-	options.inputWidth = 250;
-if (options.searchEpsg === undefined) {
-	options.searchEpsg = "4326";
-if (options.drawCentrePoint === undefined) {
-	options.drawCentrePoint = true;
-if (options.gazetteerFrontImageOn === undefined) {
-	options.gazetteerFrontImageOn = "../img/button_blue_red/gazetteer3_on.png";
-if (options.gazetteerFrontImageOff === undefined) {
-	options.gazetteerFrontImageOff = "../img/button_blue_red/gazetteer3_off.png";
-var JsonAutocompleteGazetteer = function() {
-	var that = this;
-	alert(options.gazetteerUrl);
-	/*this.zoomToExtent = function(minx,miny,maxx,maxy) {
-		var newExtent = new Mapbender.Extent(
-                   	 parseFloat(minx),
-                         parseFloat(miny),
-                         parseFloat(maxx),
-                         parseFloat(maxy)
-		my.calculateExtent(newExtent);
-		alert(my.epsg);
-		my.setMapRequest();
-	this.zoomToExtent = function(fromSrs,minx,miny,maxx,maxy) {
-		var parameters = {
-			fromSrs: fromSrs,
-			toSrs: Mapbender.modules[targetName].epsg
-		parameters.bbox = parseFloat(minx)+ "," +parseFloat(miny)+ "," +parseFloat(maxx)+ "," +parseFloat(maxy);
-		//function to transform from one crs to another
-		var req = new Mapbender.Ajax.Request({
-			url: "../php/mod_coordsLookup_server.php",
-			method: "transform",
-			parameters: parameters,
-			callback: function (obj, success, message) {
-				if (!success) {
-					new Mapbender.Exception(message);
-					return;
-				if (options.drawCentrePoint) {
-					//generate layer for visualization of point
-					if(standingHighlight !== null){
-						standingHighlight.clean();
-					}else{
-						standingHighlight = new Highlight(
-							[options.target],
-							"standingHighlight",
-							{"position":"absolute", "top":"0px", "left":"0px", "z-index":10000},
-							2);
-					var point0 = new Point(obj.points[0].x,obj.points[0].y);
-					var point1 = new Point(obj.points[1].x,obj.points[1].y);
-					var x = point0.x + (point1.x - point0.x)/2;
-					var y = point0.y + (point1.y - point0.y)/2;
-					var point = new Point(x,y);
-					var ga = new GeometryArray();
-					ga.importPoint({
-						coordinates:[x,y,null]
-					},Mapbender.modules[targetName].epsg)
-					var m = ga.get(-1,-1);
-					standingHighlight.add(m, "#ff0000");
-					//alert(m);
-				if (obj.points) {
-					if (obj.points.length === 2) {
-						var newExtent = new Extent(
-							obj.points[0].x,
-							obj.points[0].y,
-							obj.points[1].x,
-							obj.points[1].y
-		req.send();
-	this.toggleInput = function(){
-		/*if (this.inputAddress.attr("disabled")) {
-			$("#geographicName").show();
-		} else {
-			$("#geographicName").hide();
-		if ($("#geographicName").css("display") == 'none') {
-			$("#symboldForInputId").attr({'src':options.gazetteerFrontImageOn});
-		} else {
-			$("#symboldForInputId").attr({'src':options.gazetteerFrontImageOff});
-		//$("#geographicName").toggle();
-		epsg = Mapbender.modules[targetName].epsg.replace('EPSG:', '');
-		this.formContainer = $(document.createElement('form')).attr({'id':'json-autocomplete-gazetteer'}).appendTo('#' + options.id);
-		this.formContainer.submit(function() {
-			return false;
-		if (options.isDraggable){
-			this.formContainer.draggable();
-		//this.labelForInput = $(document.createElement('label')).appendTo(this.formContainer);
-		//this.labelForInput.attr({'for':'geographicName'});
-		//this.labelForInputTitle = this.labelForInput.append('<?php echo _mb('Address'); ?>: ');
-		this.symbolForInput = $(document.createElement('img')).appendTo(this.formContainer);
-		this.symbolForInput.attr({'id':'symboldForInputId'});
-		this.symbolForInput.attr({'src':options.gazetteerFrontImageOn});
-		this.symbolForInput.attr({'title':'<?php echo _mb('Address'); ?>'});
-		this.symbolForInput.click(function() {
-			that.toggleInput();
-		//.ui-menu .ui-menu-item {
-		this.inputAddress = $(document.createElement('input')).appendTo(this.formContainer);
-		this.inputAddress.attr({'id':'geographicName'});
-		//default value
-		this.inputAddress.val('<?php echo _mb('Search for addresses'); ?>');
-		this.inputAddress.css('width',options.inputWidth);
-		$('.ui-menu').css('width','100px');
-		$('.ui-menu-item').css('width','100px');
-		//set the loading symbol for autoloader class
-		$('.ui-autocomplete-loading').css('background','white url("../img/indicator_wheel.gif") right center no-repeat');
-		//http://stackoverflow.com/questions/622122/how-can-i-change-the-css-class-rules-using-jquery
-		//$("<style type='text/css'> .ui-autocomplete { position: absolute; cursor: default; background:black; color:white} </style>").appendTo("head");
-		//this.inputAddress.attr({'width':options.inputWidth}); is defind thru css ui-widget-autocomplete
-		$(function() {
-			$( "#geographicName" ).autocomplete({
-				source: function( request, response ) {
-					$.ajax({
-						url: options.gazetteerUrl,
-						dataType: "jsonp",
-						data: {
-							outputFormat: 'json',
-							resultTarget: 'web',
-							searchEPSG: options.searchEpsg,
-							maxResults: options.maxResults,
-							maxRows: options.maxResults,
-							searchText: request.term,
-							featureClass: "P",
-							style: "full",
-							name_startsWith: request.term
-						success: function( data ) {
-							if (options.isGeonames) {
-								response( $.map( data.geonames, function( item ) {
-									return {
-										label: item.name+" - "+item.fclName+" - "+item.countryName,
-										minx: item.lng-options.latLonZoomExtension,
-										miny: item.lat-options.latLonZoomExtension,
-										maxx: item.lng+options.latLonZoomExtension,
-										maxy: item.lat+options.latLonZoomExtension
-							} else {
-									return {
-										label: item.title,
-										minx: item.minx,
-										miny: item.miny,
-										maxx: item.maxx,
-										maxy: item.maxy
-				minLength: options.minLength,
-				delay: options.delay,
-				select: function( event, ui ) {
-					that.zoomToExtent("EPSG:"+options.searchEpsg,ui.item.minx,ui.item.miny,ui.item.maxx,ui.item.maxy);
-				open: function() {
-					$( this ).removeClass( "ui-corner-all" ).addClass( "ui-corner-top" );
-				close: function() {
-					$( this ).removeClass( "ui-corner-top" ).addClass( "ui-corner-all" );
-	this.initForm();
-	Mapbender.modules[options.id] = $.extend(new JsonAutocompleteGazetteer(),Mapbender.modules[options.id]);
More information about the Mapbender_commits mailing list
