[Mapbender-commits] r8601 - branches/2.7/http/javascripts trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Apr 15 02:24:18 PDT 2013
Author: verenadiewald
Date: 2013-04-15 02:24:18 -0700 (Mon, 15 Apr 2013)
New Revision: 8601
   branches/2.7/http/javascripts/mod_key.php
   trunk/mapbender/http/javascripts/mod_key.php
exclude html tags like input and textarea from event binding "keydown"
Modified: branches/2.7/http/javascripts/mod_key.php
--- branches/2.7/http/javascripts/mod_key.php	2013-04-10 19:06:14 UTC (rev 8600)
+++ branches/2.7/http/javascripts/mod_key.php	2013-04-15 09:24:18 UTC (rev 8601)
@@ -52,10 +52,21 @@
 function mod_key_init(){
 	for(var i=0; i<mb_key_elements.length; i++){
 		if(mb_key_elements[i] == "body"){
-			document.getElementById(mb_key_ids[i]).onkeydown = mod_key_Keyhandler;
-		else{
-			window.frames[mb_key_ids[i]].document.getElementsByTagName("body")[0].onkeydown = new Function("mod_key_Keyhandler('" +mb_key_ids[i] + "');");
+			$('body').live('keydown', function(e) {
+      			var tag = e.target.tagName.toLowerCase();
+    			if (tag != 'input' && tag != 'textarea') {
+        			mod_key_Keyhandler();
+		else {
+			$(document.getElementById(mb_key_ids[i]).contentWindow.document).keydown(function(e) {
+				var currentKeyId = mb_key_ids[i];
+					mod_key_Keyhandler(currentKeyId);
Modified: trunk/mapbender/http/javascripts/mod_key.php
--- trunk/mapbender/http/javascripts/mod_key.php	2013-04-10 19:06:14 UTC (rev 8600)
+++ trunk/mapbender/http/javascripts/mod_key.php	2013-04-15 09:24:18 UTC (rev 8601)
@@ -52,6 +52,108 @@
+		else {
+function mod_key_Keyhandler(frameName){
+	if(frameName){
+		var code = eval("window.frames['"+frameName+"'].event.keyCode");
+		focus();
+	else{
+		var code = event.keyCode;
+	if(code == 187 || code == 107){
+		zoom(mod_key_map,true, '2.0');
+	if(code == 189 || code == 109){
+		zoom(mod_key_map,false, '2.0');
+	if(code == 32 || code == 13){
+		setMapRequest(mod_key_map);
+	if(code == 37){
+		mb_panMap(mod_key_map,"W");
+	if(code == 38){
+		mb_panMap(mod_key_map,"N");
+	if(code == 39){
+		mb_panMap(mod_key_map,"E");
+	if(code == 40){
+		mb_panMap(mod_key_map,"S");
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_key.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+echo "var mod_key_map = '".$e_target[0]."';";
+$sql = "SELECT e_id,e_element FROM gui_element WHERE (e_element = 'body' or e_element = 'iframe') AND fkey_gui_id = $1 AND e_public = 1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
+$cnt = 0;
+while($row = db_fetch_array($res)){
+	$ids[$cnt] = $row["e_id"];
+	$elements[$cnt] = $row["e_element"];
+	$cnt++;
+echo "var mb_key_elements = new Array(";
+for($i=0; $i < count($elements); $i++){
+	if($i > 0){
+		echo ",";
+	echo "'".$elements[$i]."'";
+echo ");";
+echo "var mb_key_ids = new Array(";
+for($i=0; $i < count($ids); $i++){
+	if($i > 0){ echo ",";}
+	echo "'".$ids[$i]."'";
+echo ");";
+if(ie){
+   mb_registerInitFunctions('mod_key_init()');
+function mod_key_init(){
+	for(var i=0; i<mb_key_elements.length; i++){
+		if(mb_key_elements[i] == "body"){
 		else{
More information about the Mapbender_commits mailing list
