[Mapbender-commits] r8671 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org
Tue Jul 16 03:46:36 PDT 2013
Author: armin11
Date: 2013-07-16 03:46:36 -0700 (Tue, 16 Jul 2013)
New Revision: 8671
trunk/mapbender/http/geoportal/mod_readCSWResults.php
trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php
Allow integration of terra catalogue csw - there are other options than in geonetwork for getrecords operation :-(
Modified: trunk/mapbender/http/geoportal/mod_readCSWResults.php
--- trunk/mapbender/http/geoportal/mod_readCSWResults.php 2013-07-15 13:48:40 UTC (rev 8670)
+++ trunk/mapbender/http/geoportal/mod_readCSWResults.php 2013-07-16 10:46:36 UTC (rev 8671)
@@ -135,7 +135,7 @@
$e = new mb_notice("q= : ".$_REQUEST["q"]);
$e = new mb_notice("ranking: ".$ranking);
$e = new mb_notice("coord: ".$coord);
-$e = new mb_exception("geoportal/mod_readCSWResults.php queryText: ".$queryText);
+//$e = new mb_exception("geoportal/mod_readCSWResults.php queryText: ".$queryText);
if (isset($x1) && isset($x2) && isset($y1) && isset($y2) && isset($coord)) {
/* <BBOX>
<PropertyName>ows:BoundingBox</PropertyName>
@@ -215,16 +215,45 @@
//get urls for getrecords and getrecordbyid from table cat
$v = $row_csw["fkey_cat_id"];
$t = 'i';
- $sql_gr = "select param_value from cat_op_conf where fk_cat_id = $1 and param_type = 'getrecords' and param_name='get'";
+ $sql_gr = "select param_value, param_name from cat_op_conf where fk_cat_id = $1 and param_type = 'getrecords'";
$res_gr = db_prep_query($sql_gr, $v, $t);
- $row_gr = db_fetch_array($res_gr);
- $csw_list[$cnt_csw] ['getrecordsurl'] = $row_gr['param_value'];
- echo "<br>getrecordsurl: ".$csw_list[$cnt_csw]['getrecordsurl']."<br>";
+ //look after the values preference get/post/post_xml
+ while ($row_gr = db_fetch_array($res_gr)) {
+ switch ($row_gr['param_name']) {
+ case "get" :
+ $csw_list[$cnt_csw] ['getrecordsurl_param_name'] = "get";
+ if (isset($row_gr['param_value']) || $row_gr['param_value'] != '') {
+ $csw_list[$cnt_csw] ['getrecordsurl'] = $row_gr['param_value'];
+ break 2;
+ break 1;
+ case "post" :
+ $csw_list[$cnt_csw] ['getrecordsurl_param_name'] = "post";
+ break 2;
+ break 1;
+ case "post_xml" :
+ $csw_list[$cnt_csw] ['getrecordsurl_param_name'] = "post_xml";
+ if (isset($row_gr['param_value']) || $row_gr['param_value'] != '' ) {
+ break 2;
+ break 1;
+ $e = new mb_notice("<br>getrecords param type: ".$csw_list[$cnt_csw]['getrecordsurl_param_name']."<br>");
+ $csw_list[$cnt_csw] ['getrecordsurl'] = rtrim($csw_list[$cnt_csw] ['getrecordsurl'], "?");
+ $e = new mb_notice("mod_readCSWResults.php: getrecordsurl: ".$csw_list[$cnt_csw]['getrecordsurl']);
$sql_grbi = "select param_value from cat_op_conf where fk_cat_id = $1 and param_type = 'getrecordbyid' and param_name='get'";
$res_grbi = db_prep_query($sql_grbi, $v, $t);
$row_grbi = db_fetch_array($res_grbi);
$csw_list[$cnt_csw] ['getrecordbyidurl'] = $row_grbi['param_value'];
- echo "<br>getrecordbyidurl: ".$csw_list[$cnt_csw]['getrecordbyidurl']."<br>";
+ //Delete question marks from end of url
+ $csw_list[$cnt_csw] ['getrecordbyidurl'] = rtrim($csw_list[$cnt_csw] ['getrecordbyidurl'], "?");
+ $e = new mb_notice("mod_readCSWResults.php: getrecordbyidurl: ".$csw_list[$cnt_csw]['getrecordbyidurl']);
$csw_list[$cnt_csw] ['h'] = $row_csw["csw_h"];
$csw_list[$cnt_csw] ['p'] = $row_csw["csw_p"];
$cnt_csw++;
@@ -421,10 +450,9 @@
//echo $openSearchUrl[$i_si]."<br>";
$cswInterfaceObject->load($openSearchUrl[$i_si]);
#echo "<br>Results: ".htmlentities($cswInterfaceObject->file)."<br><br>";
$openSearchResult = $cswInterfaceObject->file;
$openSearchUrlDetail[$i_si]=$csw_list[$i_si] ['getrecordbyidurl']."?";
+ $e = new mb_notice("mod_readCSWResults.php: detailurl: ".$openSearchUrlDetail[$i_si]);
//get resultlists
//$url=$openSearchUrlSearch[$i_si]."q=".$queryText.$csw_list[$i_si] ['standardfilter']."&h=".$csw_list[$i_si] ['h']."&p=".$request_p;
$url = $openSearchUrl[$i_si];
@@ -567,7 +595,7 @@
//generate link to original csw
$cswSearchUrlDetail = $openSearchUrlDetail[$i_si];
$cswSearchUrlDetail = $cswSearchUrlDetail."request=GetRecordById&service=CSW&version=2.0.2&Id=".$uuid."&ElementSetName=full&OUTPUTSCHEMA=http://www.isotc211.org/2005/gmd";
- $e = new mb_notice("URL for calling full iso19139 service record over csw api: ".$cswSearchUrlDetail);
+ $e = new mb_notice("mod_readCSWResults.php: URL for calling full iso19139 service record over csw api: ".$cswSearchUrlDetail);
//extract title from iso19139 record
Modified: trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php
--- trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php 2013-07-15 13:48:40 UTC (rev 8670)
+++ trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php 2013-07-16 10:46:36 UTC (rev 8671)
@@ -689,11 +689,37 @@
$v = (integer)$row_csw["fkey_cat_id"];
$t = 'i';
- $sql_gr = "select * from cat_op_conf where fk_cat_id = $1 and param_type = 'getrecords' and param_name='get'";
- #var_dump($row_gr);
+ case "get" :
+ break 2;
+ break 1;
+ case "post" :
+ break 2;
+ break 1;
+ case "post_xml" :
+ break 2;
+ break 1;
#echo "count csw: ".$cnt_csw;
#echo "<br>getrecordsurl: ".$csw_list[$cnt_csw]['getrecordsurl']."<br>";
@@ -701,7 +727,7 @@
#echo "<br>getrecordbyidurl: ".$csw_list[$cnt_csw]['getrecordbyidurl']."<br>";
More information about the Mapbender_commits
