[Mapbender-commits] r8639 - trunk/mapbender/core
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jun 3 01:25:08 PDT 2013
Author: verenadiewald
Date: 2013-06-03 01:25:08 -0700 (Mon, 03 Jun 2013)
New Revision: 8639
   trunk/mapbender/core/epsg.php
added an array with all lat-lon srs
Modified: trunk/mapbender/core/epsg.php
--- trunk/mapbender/core/epsg.php	2013-06-03 08:17:48 UTC (rev 8638)
+++ trunk/mapbender/core/epsg.php	2013-06-03 08:25:08 UTC (rev 8639)
@@ -16,7 +16,27 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+//this array should contain all used lat lon axis order srs, should be extended if neccessary
+$latLonSrsArray = array(
+	'urn:x-ogc:def:crs:EPSG:4326',
+	'urn:ogc:def:crs:EPSG::4326',
+	'urn:x-ogc:def:crs:EPSG:4258',
+	'urn:ogc:def:crs:EPSG::4258',
+	'urn:x-ogc:def:crs:EPSG:31466',
+	'urn:ogc:def:crs:EPSG::31466',
+	'urn:x-ogc:def:crs:EPSG:31467',
+	'urn:ogc:def:crs:EPSG::31467',
+	'urn:x-ogc:def:crs:EPSG:31468',
+	'urn:ogc:def:crs:EPSG::31468',
+	'urn:x-ogc:def:crs:EPSG:31469',
+	'urn:ogc:def:crs:EPSG::31469',
+	'urn:ogc:def:crs:EPSG:6.9:31466',
+	'urn:ogc:def:crs:EPSG:6.9:4326'
+$latLonSrsJson = json_encode($latLonSrsArray);
 function check_epsg_wms_13($someEPSG) {
    #define("EPSG_FOR_AXIS_ORDER"
    $epsgArray = array(4326,4258,31466,31467,31468,31469,2166,2167,2168,2036,2044,2045,2065,2081,2082,2083,2085,2086,2091,2092,2093,2096,2097,2098,2105,2106,2107,2108,2109,2110,2111,2112,2113,2114,2115,2116,2117,2118,2119,2120,2121,2122,2123,2124,2125,2126,2127,2128,2129,2130,2131,2132,2169,2170,2171,2172,2173,2174,2175,2176,2177,2178,2179,2180,2193,2199,2200,2206,2207,2208,2209,2210,2211,2212,2319,2320,2321,2322,2323,2324,2325,2326,2327,2328,2329,2330,2331,2332,2333,2334,2335,2336,2337,2338,2339,2340,2341,2342,2343,2344,2345,2346,2347,2348,2349,2350,2351,2352,2353,2354,2355,2356,2357,2358,2359,2360,2361,2362,2363,2364,2365,2366,2367,2368,2369,2370,2371,2372,2373,2374,2375,2376,2377,2378,2379,2380,2381,2382,2383,2384,2385,2386,2387,2388,2389,2390,2391,2392,2393,2394,2395,2396,2397,2398,2399,2400,2401,2402,2403,2404,2405,2406,2407,2408,2409,2410,2411,2412,2413,2414,2415,2416,2417,2418,2419,2420,2421,2422,2423,2424,2425,2426,2427,2428,2429,2430,2431,2432,2433,2434,2435,2436,243
 7,2438,2439,2440,2441,2442,2443,2444,2445,2446,2447,2448,2449,2450,2451,2452,2453,2454,2455,2456,2457,2458,2459,2460,2461,2462,2463,2464,2465,2466,2467,2468,2469,2470,2471,2472,2473,2474,2475,2476,2477,2478,2479,2480,2481,2482,2483,2484,2485,2486,2487,2488,2489,2490,2491,2492,2493,2494,2495,2496,2497,2498,2499,2500,2501,2502,2503,2504,2505,2506,2507,2508,2509,2510,2511,2512,2513,2514,2515,2516,2517,2518,2519,2520,2521,2522,2523,2524,2525,2526,2527,2528,2529,2530,2531,2532,2533,2534,2535,2536,2537,2538,2539,2540,2541,2542,2543,2544,2545,2546,2547,2548,2549,2551,2552,2553,2554,2555,2556,2557,2558,2559,2560,2561,2562,2563,2564,2565,2566,2567,2568,2569,2570,2571,2572,2573,2574,2575,2576,2577,2578,2579,2580,2581,2582,2583,2584,2585,2586,2587,2588,2589,2590,2591,2592,2593,2594,2595,2596,2597,2598,2599,2600,2601,2602,2603,2604,2605,2606,2607,2608,2609,2610,2611,2612,2613,2614,2615,2616,2617,2618,2619,2620,2621,2622,2623,2624,2625,2626,2627,2628,2629,2630,2631,2632,2633,2634,2635,26
 36,2637,2638,2639,2640,2641,2642,2643,2644,2645,2646,2647,2648,2649,2650,2651,2652,2653,2654,2655,2656,2657,2658,2659,2660,2661,2662,2663,2664,2665,2666,2667,2668,2669,2670,2671,2672,2673,2674,2675,2676,2677,2678,2679,2680,2681,2682,2683,2684,2685,2686,2687,2688,2689,2690,2691,2692,2693,2694,2695,2696,2697,2698,2699,2700,2701,2702,2703,2704,2705,2706,2707,2708,2709,2710,2711,2712,2713,2714,2715,2716,2717,2718,2719,2720,2721,2722,2723,2724,2725,2726,2727,2728,2729,2730,2731,2732,2733,2734,2735,2738,2739,2740,2741,2742,2743,2744,2745,2746,2747,2748,2749,2750,2751,2752,2753,2754,2755,2756,2757,2758,2935,2936,2937,2938,2939,2940,2941,2953,2963,3006,3007,3008,3009,3010,3011,3012,3013,3014,3015,3016,3017,3018,3019,3020,3021,3022,3023,3024,3025,3026,3027,3028,3029,3030,3034,3035,3038,3039,3040,3041,3042,3043,3044,3045,3046,3047,3048,3049,3050,3051,3058,3059,3068,3114,3115,3116,3117,3118,3120,3126,3127,3128,3129,3130,3131,3132,3133,3134,3135,3136,3137,3138,3139,3140,3146,3147,3150,3
 151,3152,3300,3301,3328,3329,3330,3331,3332,3333,3334,3335,3346,3350,3351,3352,3366,3386,3387,3388,3389,3390,3396,3397,3398,3399,3407,3414,3416,3764,3788,3789,3790,3791,3793,3795,3796,3819,3821,3823,3824,3833,3834,3835,3836,3837,3838,3839,3840,3841,3842,3843,3844,3845,3846,3847,3848,3849,3850,3851,3852,3854,3873,3874,3875,3876,3877,3878,3879,3880,3881,3882,3883,3884,3885,3888,3889,3906,3907,3908,3909,3910,3911,4001,4002,4003,4004,4005,4006,4007,4008,4009,4010,4011,4012,4013,4014,4015,4016,4017,4018,4019,4020,4021,4022,4023,4024,4025,4026,4027,4028,4029,4030,4031,4032,4033,4034,4035,4036,4037,4038,4040,4041,4042,4043,4044,4045,4046,4047,4052,4053,4054,4055,4074,4075,4080,4081,4120,4121,4122,4123,4124,4125,4126,4127,4128,4129,4130,4131,4132,4133,4134,4135,4136,4137,4138,4139,4140,4141,4142,4143,4144,4145,4146,4147,4148,4149,4150,4151,4152,4153,4154,4155,4156,4157,4158,4159,4160,4161,4162,4163,4164,4165,4166,4167,4168,4169,4170,4171,4172,4173,4174,4175,4176,4178,4179,4180,4181,
 4182,4183,4184,4185,4188,4189,4190,4191,4192,4193,4194,4195,4196,4197,4198,4199,4200,4201,4202,4203,4204,4205,4206,4207,4208,4209,4210,4211,4212,4213,4214,4215,4216,4218,4219,4220,4221,4222,4223,4224,4225,4226,4227,4228,4229,4230,4231,4232,4233,4234,4235,4236,4237,4238,4239,4240,4241,4242,4243,4244,4245,4246,4247,4248,4249,4250,4251,4252,4253,4254,4255,4256,4257,4259,4260,4261,4262,4263,4264,4265,4266,4267,4268,4269,4270,4271,4272,4273,4274,4275,4276,4277,4278,4279,4280,4281,4282,4283,4284,4285,4286,4287,4288,4289,4291,4292,4293,4294,4295,4296,4297,4298,4299,4300,4301,4302,4303,4304,4306,4307,4308,4309,4310,4311,4312,4313,4314,4315,4316,4317,4318,4319,4322,4324,4327,4329,4339,4341,4343,4345,4347,4349,4351,4353,4355,4357,4359,4361,4363,4365,4367,4369,4371,4373,4375,4377,4379,4381,4383,4386,4388,4417,4434,4463,4466,4469,4470,4472,4475,4480,4482,4483,4490,4491,4492,4493,4494,4495,4496,4497,4498,4499,4500,4501,4502,4503,4504,4505,4506,4507,4508,4509,4510,4511,4512,4513,4514,4515
 ,4516,4517,4518,4519,4520,4521,4522,4523,4524,4525,4526,4527,4528,4529,4530,4531,4532,4533,4534,4535,4536,4537,4538,4539,4540,4541,4542,4543,4544,4545,4546,4547,4548,4549,4550,4551,4552,4553,4554,4555,4557,4558,4568,4569,4570,4571,4572,4573,4574,4575,4576,4577,4578,4579,4580,4581,4582,4583,4584,4585,4586,4587,4588,4589,4600,4601,4602,4603,4604,4605,4606,4607,4608,4609,4610,4611,4612,4613,4614,4615,4616,4617,4618,4619,4620,4621,4622,4623,4624,4625,4626,4627,4628,4629,4630,4631,4632,4633,4634,4635,4636,4637,4638,4639,4640,4641,4642,4643,4644,4645,4646,4652,4653,4654,4655,4656,4657,4658,4659,4660,4661,4662,4663,4664,4665,4666,4667,4668,4669,4670,4671,4672,4673,4674,4675,4676,4677,4678,4679,4680,4681,4682,4683,4684,4685,4686,4687,4688,4689,4690,4691,4692,4693,4694,4695,4696,4697,4698,4699,4700,4701,4702,4703,4704,4705,4706,4707,4708,4709,4710,4711,4712,4713,4714,4715,4716,4717,4718,4719,4720,4721,4722,4723,4724,4725,4726,4727,4728,4729,4730,4731,4732,4733,4734,4735,4736,4737,473
 8,4739,4740,4741,4742,4743,4744,4745,4746,4747,4748,4749,4750,4751,4752,4753,4754,4755,4756,4757,4758,4759,4760,4761,4762,4763,4764,4765,4766,4767,4768,4769,4770,4771,4772,4773,4774,4775,4776,4777,4778,4779,4780,4781,4782,4783,4784,4785,4786,4787,4788,4789,4790,4791,4792,4793,4794,4795,4796,4797,4798,4799,4800,4801,4802,4803,4804,4805,4806,4807,4808,4809,4810,4811,4812,4813,4814,4815,4816,4817,4818,4819,4820,4821,4822,4823,4824,4839,4855,4856,4857,4858,4859,4860,4861,4862,4863,4864,4865,4866,4867,4868,4869,4870,4871,4872,4873,4874,4875,4876,4877,4878,4879,4880,4883,4885,4887,4889,4891,4893,4895,4898,4900,4901,4902,4903,4904,4907,4909,4921,4923,4925,4927,4929,4931,4933,4935,4937,4939,4941,4943,4945,4947,4949,4951,4953,4955,4957,4959,4961,4963,4965,4967,4969,4971,4973,4975,4977,4979,4981,4983,4985,4987,4989,4991,4993,4995,4997,4999,5012,5013,5017,5048,5105,5106,5107,5108,5109,5110,5111,5112,5113,5114,5115,5116,5117,5118,5119,5120,5121,5122,5123,5124,5125,5126,5127,5128,5129,51
 30,5132,5167,5168,5169,5170,5171,5172,5173,5174,5175,5176,5177,5178,5179,5180,5181,5182,5183,5184,5185,5186,5187,5188,5224,5228,5229,5233,5245,5246,5251,5252,5253,5254,5255,5256,5257,5258,5259,5263,5264,5269,5270,5271,5272,5273,5274,5275,5801,5802,5803,5804,5808,5809,5810,5811,5812,5813,5814,5815,5816,20004,20005,20006,20007,20008,20009,20010,20011,20012,20013,20014,20015,20016,20017,20018,20019,20020,20021,20022,20023,20024,20025,20026,20027,20028,20029,20030,20031,20032,20064,20065,20066,20067,20068,20069,20070,20071,20072,20073,20074,20075,20076,20077,20078,20079,20080,20081,20082,20083,20084,20085,20086,20087,20088,20089,20090,20091,20092,21413,21414,21415,21416,21417,21418,21419,21420,21421,21422,21423,21453,21454,21455,21456,21457,21458,21459,21460,21461,21462,21463,21473,21474,21475,21476,21477,21478,21479,21480,21481,21482,21483,21896,21897,21898,21899,22171,22172,22173,22174,22175,22176,22177,22181,22182,22183,22184,22185,22186,22187,22191,22192,22193,22194,22195,22
 196,22197,25884,27205,27206,27207,27208,27209,27210,27211,27212,27213,27214,27215,27216,27217,27218,27219,27220,27221,27222,27223,27224,27225,27226,27227,27228,27229,27230,27231,27232,27391,27392,27393,27394,27395,27396,27397,27398,27492,28402,28403,28404,28405,28406,28407,28408,28409,28410,28411,28412,28413,28414,28415,28416,28417,28418,28419,28420,28421,28422,28423,28424,28425,28426,28427,28428,28429,28430,28431,28432,28462,28463,28464,28465,28466,28467,28468,28469,28470,28471,28472,28473,28474,28475,28476,28477,28478,28479,28480,28481,28482,28483,28484,28485,28486,28487,28488,28489,28490,28491,28492,29701,29702,30161,30162,30163,30164,30165,30166,30167,30168,30169,30170,30171,30172,30173,30174,30175,30176,30177,30178,30179,30800,31251,31252,31253,31254,31255,31256,31257,31258,31259,31275,31276,31277,31278,31279,31281,31282,31283,31284,31285,31286,31287,31288,31289,31290,31700);
@@ -27,5 +47,4 @@
    		return false;
More information about the Mapbender_commits mailing list
