[Mapbender-commits] r8585 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Mar 12 08:29:35 PDT 2013
Author: astrid_emde
Date: 2013-03-12 08:29:35 -0700 (Tue, 12 Mar 2013)
New Revision: 8585
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
new element vars: max_height and max_width - set size in pixel or false
http://trac.osgeo.org/mapbender/ticket/892
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql	2013-03-12 15:21:21 UTC (rev 8584)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql	2013-03-12 15:29:35 UTC (rev 8585)
@@ -72,3 +72,12 @@
 -- legend_url in e_content for printPDF template print
 UPDATE gui_element SET e_content = '<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="opacity" name="opacity" value=""/><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>' WHERE e_id = 'printPDF' and fkey_gui_id = 'template_print';
+-- add new element vars for resizemapSize to gui2
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'resizeMapsize', 'max_height', '700', 'define a max mapframe width (units pixel) f.e. 700 or false' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'resizeMapsize', 'max_width', '700', 'define a max mapframe width (units pixel) f.e. 700 or false' ,'var');
More information about the Mapbender_commits mailing list
