[Mapbender-commits] r8623 - in trunk/mapbender/http/extensions/mobilemap: . _build js mod_mapbender query
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 21 08:08:21 PDT 2013
Author: armin11
Date: 2013-05-21 08:08:21 -0700 (Tue, 21 May 2013)
New Revision: 8623
Removed:
   trunk/mapbender/http/extensions/mobilemap/_build/_merge_compress_js.sh~
   trunk/mapbender/http/extensions/mobilemap/js/backgroundlayer.js~
   trunk/mapbender/http/extensions/mobilemap/js/backgroundlayer.php~
   trunk/mapbender/http/extensions/mobilemap/map.php~
   trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js~
   trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search_proxy.php~
   trunk/mapbender/http/extensions/mobilemap/mod_mapbender/wmc_proxy.php~
   trunk/mapbender/http/extensions/mobilemap/query/proxy.php~
   trunk/mapbender/http/extensions/mobilemap/query/rasterquery.php~
   trunk/mapbender/http/extensions/mobilemap/query/searchproxy.php~
Delete files which are not needed
Deleted: trunk/mapbender/http/extensions/mobilemap/_build/_merge_compress_js.sh~
--- trunk/mapbender/http/extensions/mobilemap/_build/_merge_compress_js.sh~	2013-05-21 15:06:10 UTC (rev 8622)
+++ trunk/mapbender/http/extensions/mobilemap/_build/_merge_compress_js.sh~	2013-05-21 15:08:21 UTC (rev 8623)
@@ -1,16 +0,0 @@
-#!/bin/sh
-outputfile="ngms_eventtest.js"
-outputfilemin="ngms_eventtest.min.js"
-dirjs="../js/dev/"
-dirmb="../mod_mapbender/"
-dirtarget="../js/"
-echo "//concatenated js files" > $outputfile
-cat $dirjs"1_ngms_olextent.js" >> $outputfile
-cat $dirjs"2_ngms_global.js" >> $outputfile
-cat $dirmb"searchobjects.js" >> $outputfile
-cat $dirmb"search.js" >> $outputfile
-cat $dirjs"4_ngms_base.js" >> $outputfile
-cat $dirjs"5_ngms_jq.js" >> $outputfile
-java -jar compress/compiler.jar --js=$outputfile --js_output_file=$outputfilemin
Deleted: trunk/mapbender/http/extensions/mobilemap/js/backgroundlayer.js~
--- trunk/mapbender/http/extensions/mobilemap/js/backgroundlayer.js~	2013-05-21 15:06:10 UTC (rev 8622)
+++ trunk/mapbender/http/extensions/mobilemap/js/backgroundlayer.js~	2013-05-21 15:08:21 UTC (rev 8623)
@@ -1,9 +0,0 @@
-<?php
-//Basic configuration of mapserver client
-require_once(dirname(__FILE__)."/../../../conf/mobilemap.conf");
-$js = "";
-for ($i==0; count($layer);$i++) {
-	$js .= layer[$i];
-echo $js;
Deleted: trunk/mapbender/http/extensions/mobilemap/js/backgroundlayer.php~
--- trunk/mapbender/http/extensions/mobilemap/js/backgroundlayer.php~	2013-05-21 15:06:10 UTC (rev 8622)
+++ trunk/mapbender/http/extensions/mobilemap/js/backgroundlayer.php~	2013-05-21 15:08:21 UTC (rev 8623)
@@ -1,12 +0,0 @@
-<?php
-//require_once(dirname(__FILE__)."/../../../conf/mobilemap.conf");
-echo "test";
-$js = "";
-/*for ($i = 0; $i < count($layer); $i++) {
-	$js .= $layer[$i];
-//header - javascript
-echo $js;
Deleted: trunk/mapbender/http/extensions/mobilemap/map.php~
--- trunk/mapbender/http/extensions/mobilemap/map.php~	2013-05-21 15:06:10 UTC (rev 8622)
+++ trunk/mapbender/http/extensions/mobilemap/map.php~	2013-05-21 15:08:21 UTC (rev 8623)
@@ -1,353 +0,0 @@
-<?php
-//Fixes IPhone, Android 2.x
-if(strstr($_SERVER['HTTP_USER_AGENT'], 'iPhone') || strstr($_SERVER['HTTP_USER_AGENT'], 'iPod') || strstr($_SERVER['HTTP_USER_AGENT'], 'Android 2.')) {
- $scaleselect = "false";
-else {
- $scaleselect = "true";
-//WMC Anfrage Mapbendermodul
-if (isset($_GET['wmcid'])) {
-	$wmcid = htmlspecialchars($_GET["wmcid"]);
-//Validate parameters for zooming to special extent for WMC
-if(isset($_REQUEST["mb_myBBOX"]) && $_REQUEST["mb_myBBOX"] != ""){
-	//Check for numerical values for BBOX
-	$array_bbox = explode(',',$_REQUEST["mb_myBBOX"]);
-	if ((is_numeric($array_bbox[0])) and (is_numeric($array_bbox[1])) and (is_numeric($array_bbox[2])) and (is_numeric($array_bbox[3])) ) {
-		$mb_myBBOX = $_REQUEST["mb_myBBOX"];
-		if(isset($_REQUEST["mb_myBBOXEpsg"])){
-			//Check epsg
-			$targetEpsg=intval($_REQUEST["mb_myBBOXEpsg"]);
-			if (($targetEpsg >= 1) and ($targetEpsg <= 50001)) {
-				#echo "is in the codespace of the epsg registry\n";
-				$mb_myBBOXEpsg = $targetEpsg;
-			} else {
-				#echo "is outside\n";
-				echo 'The REQUEST parameter mb_myBBOXEpsg is not in the epsg realm - please define another EPSG Code.';
-				die();
-	} else {
-		echo "The REQUEST parameters for mb_myBBOX are not numeric - please give numeric values!";
-		die();
-<!DOCTYPE html>
-<html>
-<head>
-<meta charset="UTF-8">
-<title><?php echo $apptitle; ?></title>
-<meta name="viewport" content="width=device-width, user-scalable=no, initial-scale=1.0, maximum-scale=1.0;">
-<meta name="apple-mobile-web-app-capable" content="yes">
-<link rel="apple-touch-icon" href="<?php echo $iPhoneIcon; ?>"/>
-<link rel="shortcut icon" href="<?php echo $favIcon; ?>"/>
-<link rel="stylesheet" href="http://code.jquery.com/mobile/1.2.0/jquery.mobile-1.2.0.min.css" />
-<link href="<?php echo $style_1; ?>" rel="stylesheet" >
-<link href="<?php echo $style_2; ?>" rel="stylesheet" >
-<?php if($googleapi){ ?>
-<script src="http://maps.google.com/maps/api/js?sensor=false&region=DE"></script>
-<?php } ?>
-<script src="../mobilemap/js/proj4js.min.js" ></script>
-<script src="../mobilemap/js/OpenLayers.mobile.min.js"></script>
-<script src="http://code.jquery.com/jquery-1.8.2.min.js"></script>
-<script src="http://code.jquery.com/mobile/1.2.0/jquery.mobile-1.2.0.min.js"></script>
-<script src="../mobilemap/js/jquery-lang.js"></script>
-<script src="../mobilemap/js/langpack/en.js" charset="utf-8" type="text/javascript"></script>
-<script src="../mobilemap/backgroundlayer.php" charset="utf-8" type="text/javascript"></script>
-<?php if($mapbendermod){ ?>
-<!-- Mod Mapbender -->
-<link href="../mobilemap/mod_mapbender/search.css" rel="stylesheet" >
-<!-- /Mod Mapbedner -->
-<?php } ?>
-<?php if($devmode){ ?>
-<script src="../mobilemap/js/dev/1_ngms_olextent.js" ></script>
-<script src="../mobilemap/js/dev/2_ngms_global.js" ></script>
-<script src="../mobilemap/mod_mapbender/searchobjects.js"></script>
-<script src="../mobilemap/mod_mapbender/search.js"></script>
-<?php } else { ?>
-<script src="../mobilemap/js/dev/3_ngms_layer.js" ></script>
-<?php } ?>
-<script src="../mobilemap/js/dev/4_ngms_base.js" ></script>
-<script src="../mobilemap/js/dev/5_ngms_jq.js" ></script>
-<?php } else{ ?>
-<script src="../mobilemap/js/ngms_event.min.js" ></script>
-<?php } ?>
-<script type="text/javascript">
-	window.lang = new jquery_lang_js();
-	$().ready(function () {
-		window.lang.run();
-		changeLanguage('<?php echo $mylang; ?>',false);
-		<?php if($wmcid != ''){ ?>
-		var wmcurl = '<?php echo $mapbender_wmcurl.$wmcid; ?>';
-		//add user defined bbox values if given
-		<?php if(isset($mb_myBBOX) && isset($mb_myBBOXEpsg)){ ?>
-			var wmcurl = wmcurl+"&mb_myBBOX="+<?php echo "'".$mb_myBBOX."'"; ?>+"&mb_myBBOXEpsg="+<?php echo "'".$mb_myBBOXEpsg."'"; ?>;
-		<?php } ?>
-		searchWmc(wmcurl);
-		<?php } ?>
-</script>
-</head>
-<body>
-<!-- Map Seite Start-->
-<div data-role="page" id="mappage">
-  <div data-role="content">
-    <div id="logo"><a href="map.php?lang=<?php echo $mylang; ?>" target="_self"><img src="img/logo.png" ></a></div>
-    <div id="map"></div>
-    <div id="navbutgroup">
-      <div id="ovbut" class="navbuttons" style="margin-top:2px"></div>
-      <div id="zoominbut" class="navbuttons" style="margin-top:2px"></div>
-      <div id="zoomoutbut" class="navbuttons" style="margin-top:2px"></div>
-    </div>
-	<div id="navbutgrouptop">
-	<?php if($mapbendermod){ ?>
-	  <!-- Mapbender -->
-	  <div id="mapbenderbut" class="navbuttons" style="float:left; margin-left:2px;"  ></div>
-	  <?php } else { ?>
-      <div id="layerbut" class="navbuttons" style="float:left; margin-left:2px;"  ></div>
-	  <?php } ?>
-      <div id="searchbut" class="navbuttons" style="float:left; margin-left:2px;"  ></div>
-      <div id="locatebut" class="navbuttons" style="float:left; margin-left:2px;"  ></div>
-      <div id="menubut" class="navbuttons" style="float:left; margin-left:2px;"  ></div>
-    </div>
-    <div id="markerhint">
-      <div id="xheader"></div>
-      <div id="xcontent"></div>
-    </div>
-   <div id="measurehint" >
-      <div id="mheader"><span lang="de">Messen</span></div>
-      <div id="measureoutput"></div>
-    </div>
-    <div id="scaleline"></div>
-    <div id="copyright"><span lang="de"><?php echo $copyright;  ?></span></div>
-    <div id="LoadingPanel"></div>
-    <div id="zoomscale">
-      <select name="selectzoom" id="selectzoom" onChange="changeScale(this.value);" data-inline="true" data-mini="true" data-native-menu="<?php echo $scaleselect;  ?>" >
-      </select>
-      <label for="test"></label>
-    </div>
-		<div data-role="popup" id="popupMenu" data-overlay-theme="a" data-theme="a" style="max-width:2280px;" class="ui-corner-all">
-		<a href="#" data-rel="back" data-role="button" data-theme="a" data-icon="delete" data-iconpos="notext" class="ui-btn-right">Close</a>
-			<div data-role="header" data-theme="a" class="ui-corner-top">
-				<h1>Tools</h1>
-			</div>
-			<div data-role="content" data-theme="d" class="ui-corner-bottom ui-content"><br>
-<table border="0" cellspacing="0" cellpadding="14">
-  <tr>
-    <td><div id="helpbut" class="navbuttons" ></div></td>
-    <td><div id="gearbut" class="navbuttons" ></div></td>
-  </tr>
-  <tr>
-    <td><div id="measurelinebut" class="navbuttons" ></div></td>
-    <td><div id="measurepolybut" class="navbuttons" ></div></td>
-  </tr>
-</table>
-	</div>
-	</div>
-  </div>
-  <!-- /content -->
-</div>
-<!-- /Map Seite Ende-->
-<!-- Mapbender Seite Start-->
-<div data-role="page" id="mod_mapbender" >
-  <div data-role="header" data-position="fixed" data-theme="d"> <a href="#" class="addToMapBut" data-icon="arrow-l"><span lang="de">Karte</span></a>
-    <h1><span lang="de">Katalogsuche</span></h1>
-  </div>
-  <!-- /header -->
-  <div data-role="content" style="padding: 10px; overflow:hidden;" >
-    <div data-role="collapsible" >
-      <h3><span lang="de">Hintergrundkarte</span></h3>
-      <div id="baselayers"></div>
-    </div>
-    <label for="mapbendersearchfield"><span lang="de">Layer suchen:</span> </label>
-    <input type="search" name="mapbendersearchfield" id="mapbendersearchfield" value="" />
-    <input type="submit" value="Suchen" lang="de"  id="mapbendersearchformbut" data-icon="arrow-r" data-iconpos="right" />
-	<ul data-role="listview" data-inset="true">
-		<li data-theme="b">Ihre Auswahl</li>
-		<li id="ownlist"></li>
-	</ul>
-	<div data-role="popup" id="preview" data-overlay-theme="a" data-theme="a" style="max-width:2280px;" class="ui-corner-all">
-			<a href="#" id="preview_zoom" data-icon="search"><span lang="de">Karte</span></a>
-			<h3> </h3>
-		</div>
-		<div data-role="content" data-theme="d" class="ui-corner-bottom ui-content"></div>
-	</div>
-	<div data-role="popup" id="info" data-overlay-theme="a" data-theme="a" style="max-width:2280px;" class="ui-corner-all">
-		<div data-role="header" data-theme="a" class="ui-corner-top"><h3><span lang="de">Meldung</span></h3></div>
-			<table border="0" cellspacing="0" cellpadding="14">
- 			 	<tr><td id="info_content"></td></tr>
-			</table>
-		</div>
-	</div>
-	<ul data-role="listview" data-inset="true" id="resultlist"></ul>
-  </div>
-</div>
-<!-- /Mapbender Seite Ende-->
-<?php } else { ?>
-<!-- Layer Seite nicht dynamisch (Beispieleinträge vgl. 3_ngms_layer.js) Start-->
-<div data-role="page" id="layerpage" >
-  <div data-role="header" data-position="fixed" > <a href="#" class="mapbackbut" data-icon="arrow-l"><span lang="de">Karte</span></a>
-    <h1><span lang="de">Ebenen</span></h1>
-  </div>
-  <!-- /header -->
-  <div data-role="content" style="padding: 10px" >
-	 <div class="checkrow" >
-        <div class="baselayer_check" id="atkis_praes_tms" ><span lang="de">Rlp Zusammenstellung</span></div>
-      </div>
-      <div class="clearfix"></div>
-        <div class="baselayer_check" id="luftbilder" ><span lang="de">Luftbilder</span></div>
-      </div>
-        <div class="baselayer_check" id="grenze_leer" ><span lang="de">keine Hintergrundkarte</span></div>
-      </div>
-    </div>
-      <h3><span lang="de">Overlays</span></h3>
-        <div class="layer_check" id="likar" ><span lang="de">Liegenschaftskarte</span></div>
-      </div>
-        <div class="query_check" id="naturschutzgebiet_query" > </div>
-        <div class="layer_check" id="naturschutzgebiet" ><span lang="de">Naturschutzgebiete</span></div>
-      </div>
-    </div>
-    <div class="infobox" ><span lang="de">Hinweis: Um eine Ebene abzufragen aktivieren Sie die Info-Option und tapen danach in der Karte auf das Objekt der Ebene.</span> </div>
-    <div class="query_check" id="dhm_query" > </div>
-    <div class="layer_nocheck" ><span lang="de">Abfrage Höhe + GPS</span></div>
-    <input name="queryselect" id="queryselect" type="hidden" value="dhm">
-    <br>
-    <div class="infobox" ><span lang="de">Änderung der Ebenen wechselt direkt zur Kartenansicht</span></div>
-    <div data-role="fieldcontain" style="margin:1px; padding:1px;">
-      <select name="slider" id="autolayerchange" data-role="slider">
-        <option value="off" selected >off</option>
-        <option value="on">on</option>
-      </select>
-    </div>
-  </div>
-</div>
-<!-- /Layer Seite Ende-->
-<?php } ?>
-<!-- Search Seite Start-->
-<div data-role="page" id="searchpage" >
-    <h1><span lang="de">Suche</span></h1>
-  </div>
-  <!-- /header -->
-    <div>
-      <label for="searchfield"><span lang="de">Ort suchen:</span> </label>
-      <input type="search" name="searchfield" id="searchfield" value="" />
-      <input type="submit" lang="de" value="Suchen" id="searchformbut" data-icon="arrow-r" data-iconpos="right" />
-    </div>
-    <div id="mygooglelink" > </div>
-    <div id="searchdbresult" style="margin-top:20px;" >
-      <ul data-role="listview" id= "search_results" data-theme="a" data-divider-theme="a" >
-      </ul>
-    </div>
-    <div id="mygooglemap" > </div>
-  </div>
-</div>
-<!-- /Search Seite Ende-->
-<!-- FeatureInfo Seite Start-->
-<div data-role="page" id="featureinforesult" style="height: 100%">
-  <div data-role="header" data-position="fixed" > <a href="#" class="mapbackbut" data-icon="arrow-l" onclick='$("#ficontentdiv").empty();'><span lang="de">Karte</span></a>
-    <h1><span lang="de">Sachdatenanzeige</span></h1>
-  </div>
-  <!-- /header -->
- <!-- <div data-role="content" style="padding: 10px" >-->
-	<div id="ficontentdiv" style="height: 100%"> </div>
- <!-- </div>-->
-</div>
-<!-- /FeatureInfo Seite Ende-->
-<!-- Hilfe Seite Start-->
-<div data-role="page" id="helppage">
-  <div data-role="header" data-position="fixed" > <a href="#" class="mapbackbut" data-icon="arrow-l" ><span lang="de">Karte</span></a>
-    <h1><span lang="de">Hilfe / Info</span></h1>
-  </div>
-  <div data-role="content" style="padding: 10px">
-    <div id="helpdiv"> </div>
-    </div>
-  <!-- /content -->
-</div>
-<!-- /Hilfe Seite Ende-->
-<!-- Einstellungen Start-->
-<div data-role="page" id="gearpage">
-    <h1><span lang="de">Einstellungen</span></h1>
-  </div>
-        <strong><span lang="de">App Einstellungen</span></strong>
-      <br>
-      <label for="select-lang" class="select"><span lang="de">Sprache:</span></label>
-      <select name="select-lang" id="select-lang" onChange="changeLanguage(this.value,true);" data-icon="gear" data-inline="true" data-native-menu="false">
-        <option value="de" lang="de">Deutsch</option>
-        <option value="en" lang="de">English</option>
-      </select>
-      <br>
-      <label for="select-hand" class="select"><span lang="de">Händigkeit:</span></label>
-      <select name="select-hand" id="select-hand" onChange="changeHand(this.value);" data-icon="gear" data-inline="true" data-native-menu="false">
-        <option value="r" lang="de">Rechtshänder</option>
-        <option value="l" lang="de">Linkshänder</option>
-      </select>
-      <br>
-      <label for="select-feature-info" class="select"><span lang="de">Sachdatenanzeige:</span></label>
-      <select name="select-feature-info" id="select-feature-info" onChange="changeFeatureInfo(this.value);" data-icon="gear" data-inline="true" data-native-menu="false">
-        <option value="n" lang="de">Neues Fenster</option>
-        <option value="p" lang="de">Popup</option>
-      </select>
-      <br>
-      <div class="apptools">
-      Browserinfo:<br>
-    <?php echo $_SERVER['HTTP_USER_AGENT']; ?> <br>
-		<a href="#" onClick="checkZindex();">Testfunktion</a><br>
-    </div>
-    </div>
-  </div>
-  <!-- /content -->
-</div>
-<!-- /Loading Seite Ende-->
-</body>
-</html>
Deleted: trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js~
--- trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js~	2013-05-21 15:06:10 UTC (rev 8622)
+++ trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search.js~	2013-05-21 15:08:21 UTC (rev 8623)
@@ -1,727 +0,0 @@
-Anmerkungen:
-Die Suche gibt Dienste (data.wms.srv zurück), die Dienstinformationen (id, title, abstract ect. enthalten).
-Hier werden auch die Zusatzinformationen zur verfügbarkeit ect. abgelegt.
-Diese beinhalten auch das Objekt data.wms.srv.layer, welches über (id, title, abstract, getMapUrl) verfügt.
-Es scheint jedoch immer nur einer dieser Gruppenlayer vorzuliegen.
-Es handelt sich bei data.wms.srv.layer wiederum um eine Zusammenfassung von Layern mit dem unterobjekt Objekt data.wms.srv.layer.layer.
-Dort finden sich Informationen zum Layer selber (id, title, abstract) und Informationen zur Abfragbarbeit.
-Beim Testen fiel auf, dass Services (mit eindeutiger id) auch doppelt mit unterschiedlichen Layern vorkommen können.
-Implementierung:
-Hier werden diese einzelen Objekte als js-Objekte neu definiert um gegen änderungen in der Mapbender-Schnittstelle unabhängig zu sein.
-Hier wurde folgende Objekthierarchie festgelegt
-"ServiceList" ist eine Zusammenstellung (Array) von Services und trägt die Informationn ob es sich um das Suchergebnis oder die Auswahlliste handelt
-diese Information wird beim Einfügen eines "Service" weitegegeben.
-Ein "Service" ist ein Array von Gruppenlayern
-Ein "Gruppenlayer" ist ein Array von Layern
-"Layer" enthält die Layerinformation
-var maxlayers = 5;
-var maxresults = 40;
-// Hintergrundkarten (Urls werden erst beim laden in die Karte besorgt)
-var baseinfo = [];
-// Angabe Bezeichnung, kommaseperierte Id's
-//baseinfo.push(["Hintergrund1","27694","4.8,49,9.9,50"]);
-//baseinfo.push(["Hintergrund2","25420","4.8,49,9.9,50"]);
-//baseinfo.push(["Hintergrund3","25351,100110","4.8,49,9.9,50"]);
-searchUrl = 'mod_mapbender/search_proxy.php?languageCode=de&resultTarget=web&maxResults='+maxresults;
-// Initialisierung
-function addmyLayer(){
-	//Erweiterung OpenLayers - angepasster Click Event
-	OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control, {
-		defaultHandlerOptions: {
-			'single': true,
-			'pixelTolerance': 0,
-			'stopSingle': false
-		initialize: function(options) {
-			var opts = options || {};
-			this.handlerOptions = OpenLayers.Util.applyDefaults(opts.handlerOptions || {},this.defaultHandlerOptions);
-			OpenLayers.Control.prototype.initialize.apply(this,arguments);
-			this.handler = new OpenLayers.Handler.Click(this,{'click': this.onClick},this.handlerOptions);
-		onClick: function( evt ) {
-		// click funktion
-			var lonlat = map.getLonLatFromViewPortPx(evt.xy);
-			var querylayer = $('#ownlist').find('.query_checked').parent();
-			var actuallang = $('#select-lang').val();
-			//Punkt erzeugen
-			var geompoint = new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat);
-			var geompoint1 = new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat);
-			vector_marker.removeAllFeatures();
-			vector_marker.addFeatures([
-				new OpenLayers.Feature.Vector(geompoint,{},olSearchSymbol),
-				new OpenLayers.Feature.Vector(geompoint1,{},olFeaturequerySymbol)
-			if ($("#select-feature-info").val() === 'p') {
-				var fiPopUp = true;
-			} else {
-				var fiPopUp = false;
-			if (fiPopUp) {
-				setMarkerhint(window.lang.convert('Meldung:'),window.lang.convert('bitte warten...'));
-			} else {
-				$.mobile.changePage($("#featureinforesult"),pageTransition);
-				$("#ficontentdiv").text(window.lang.convert("Bitte warten..."));
-	 		if(querylayer.length>0){
-				// Abfrage des ausgewählten Layers
-				var featureurl = querylayer.attr('getmapurl')
-						+ '&wms=SERVICE=WMS&REQUEST=getFeatureInfo&VERSION=1.1.1'
-						+ '&mapfile='+ querylayer.attr('name')
-						+ '&layers=' + querylayer.attr('name') + '&QUERY_LAYERS=' + querylayer.attr('name')
-						+ '&SRS=' + featurequerySrc
-						+ '&BBOX=' + map.getExtent().toBBOX()
-						+ '&WIDTH=' + map.size.w + '&HEIGHT=' + map.size.h
-						+ '&X=' + evt.xy.x + '&Y=' + evt.xy.y
-						+ '&INFO_FORMAT=text/html'
-						+ '&FORMAT=image/png' //only for some wms that have problems if this parameter is not given
-						+ '&STYLES='; //only for some wms that have problems if this parameter is not given
-				if (fiPopUp) {
-					var iframe=$('<iframe src="'+featureurl+'" class="query_iframe">'
-						+'<p>Die Abfrage kann leider nicht angezeigt werden.</p></img>'
-					setMarkerhint('Abfrageergebnis:',iframe);
-				} else {
-					var iframe=$('<iframe src="'+featureurl+'" class="query_iframe_full">'
-					//alert(featureurl);
-					//$.mobile.changePage($("#featureinforesult"),pageTransition);
-					$("#ficontentdiv").append(iframe);
-					//add onclick delete iframe from page
-			} else {
-				// Standardabfrage, falls keiner ausgewählt ist
-				var featureurl = 'query/rasterquery.php?coord='+lonlat.lon+ ', '+lonlat.lat+'&lang='+actuallang;
-				loadFeature(featureurl);
-    		CLASS_NAME: "OpenLayers.Control.Click"
-	$("#mapbenderbut").click(function(){
-        	$.mobile.changePage($("#mod_mapbender"),pageTransition);
-		refresh();
-	//Suchbutton
-	$('#mapbendersearchformbut').click(function() {
-		searchMaps(searchUrl+'&searchText='+$('#mapbendersearchfield').val());
-	//Suchfeld
-	$('#mapbendersearchfield').live('keypress', function(e) {
-		if(e.keyCode === 13){
-	// Alle anderen Layer einklappen
-	$('div[data-role=collapsible]').live('expand', function(){
-		$("div[data-role=collapsible]").not($(this)).trigger("collapse");
-	//zurück zur Karte-Button
-	$(".addToMapBut").click(function(){
-		$("div[data-role=collapsible]").not('.ui-collapsible-collapsed').trigger("collapse");
-		$.mobile.changePage($("#mappage"),pageTransition);
-	addBaselayers();
-// Popupfenster:
-// Popupfenster für Vorschau mit Ajax (deaktiviert)
-function preview(url,layerid,bbox){
-	$.ajax({
-		previewurl: url,
-		layerid: layerid,
-		bbox: bbox,
-		success: function() {
-			$("#preview").find('div[data-role=content]').empty();
-			$("#preview").find('div[data-role=content]').append('<img src="' + $(this).attr("previewurl") + '" alt="image" style="width:200px;">');
-			var bbox=$(this).attr("bbox");
-			var layerid=$(this).attr("layerid");
-			$("#preview_zoom").click(function(){
-				var index=getOpenlayersIndex(layerid);
-				/*if(index>=0){
-					map.zoomToExtent(map.layers[index].getExtent());
-				zoomToBbox(bbox);
-			$('#preview').popup('open');
-// Anzeigen eines Popups, bei einer zu großen Auswahl
-getInfo = function(content){
-	$("#info_content").empty();
-	$("#info_content").append(content);
-	$('#info').popup('open');
-// Funktionen für Openlayers:
-// Index des Openlayer Eintrages zurückgeben
-function getOpenlayersIndex(layerid){
-	for (var i=0; i<map.layers.length; i++){
-		if(map.layers[i].name==layerid){
-			return i;
-	return -1;
-// Layer in die Karte einfügen
-function addOpenlayer(layerid,layername,getMapUrl){
-	var openLayer = new OpenLayers.Layer.WMS(layerid,getMapUrl,
-			{ layers: layername, format: "image/png", transparent: "TRUE", transitionEffect: 'resize'},
-			{ projection: mapProj, units: projUnits, opacity: 0.8, singleTile: true, 'isBaseLayer': false, visibility: true, alwaysInRange: true
-	map.addLayer(openLayer);
-	map.setLayerIndex(openLayer, 0);
-// Bestimmter Layer aus Karte entfernen
-function removeOpenlayer(layerid){
-	if(index>=0){
-		map.removeLayer(map.layers[index]);
-// Baselayer auswählen
-function setOpenBaselayer(baseid){
-	var index=getOpenlayersIndex(baseid);
-	if(index>=0){
-		map.setBaseLayer(map.layers[index]);
-// Overlay sichtbar schalten
-function selectOpenlayer(layerid,visibility){
-	if(index>=0){
-		map.layers[index].setVisibility(visibility);
-// Dynamische Hintergrundkarte in die Karte einfügen
-function addOpenBaselayer(baselayername,baselayerids){
-	// Layerdaten dynamisch laden
-	var searchUrl = 'mod_mapbender/search_proxy.php?languageCode=de&resultTarget=web&resourceIds='+baselayerids;
-	$.getJSON(
-		searchUrl,
-		function(data){
-		// Hintergrundkarten
-		var services=data.wms.srv;
-		$.each(services, function(index,srv){
-			$.each(srv.layer, function(index, layer){
-				if(layer.layer){
-					layer=layer.layer[0];
-				var layername=layer.name;
-				var getMapUrl=srv.getMapUrl;
-				var openLayer = new OpenLayers.Layer.WMS(baselayername,getMapUrl,
-					{ layers:layername, format:"image/png", transparent:"false", transitionEffect:'resize'},
-					{ projection:mapProj, units:projUnits, singleTile:true, 'isBaseLayer':true,  alwaysInRange:true}
-				map.addLayers([openLayer]);
-// Zoomen auf bestimmte Boundingbox (in WGS84 gegeben!)
-function zoomToBbox(bbox){
-	var extend=bbox.split(',');
-	var p1 = new OpenLayers.LonLat(extend[0],extend[1]).transform(wgs84Proj,mapProj);
-	var p2 = new OpenLayers.LonLat(extend[2],extend[3]).transform(wgs84Proj,mapProj);
-	map.zoomToExtent(new OpenLayers.Bounds(p1.lon, p1.lat, p2.lon, p2.lat));
-// Listenfunktionen:
-// Anzahl der Dienste zurückgeben
-function numServices(){
-	return $('#resultlist').find('.service').length;
-// Anzahl der Layer in einem bestimmten Element zurückgeben
-function numResultLayers(element){
-	return element.find('.layer').length;
-// Prüfen ob und wo ein Layer in einer Liste ist
-function layerInList(list,id){
-	var layers=list.find('.layer');
-	for(var i=0; i<layers.length; i++){
-		if($(layers[i]).attr('layerid')==id) { return i }
-	return -1;
-// Layer in Auswahl rauf
-function up(layerid){
-	var position = layerInList($('#ownlist'),layerid);
-	if(position>0){
-		$($('#ownlist').find('.layer')[position]).after($($('#ownlist').find('.layer')[position-1]));
-console.log('todo: layerreihenfolge')
-		map.raiseLayer(map.layers[getOpenlayersIndex(layerid)],1);
-		validateArrows();
-		refresh();
-// Anzahl der Aktuellen Auswahl ausgeben
-function numOwnlayers(){
-	return $('#ownlist').find('.layer').length;
-// Funktioen zur Validierung der Anzeige:
-// Erneuern der Darstellung
-function refresh(){
-	$('#resultlist').listview('refresh');
-	$($('#ownlist').parent()).listview('refresh');
-	$('div[data-role=collapsible]').collapsible();
-	$('a[data-role=button]').button();
-// Layerauswahl kennntlich machen
-function validateLayers(){
-	layers=$('#resultlist').find('.layer');
-	$.each(layers, function(index,layer){
-		var position = layerInList($('#ownlist'),$(layer).attr('layerid'));
-		if(position>=0){
-			$(layer).find('.layer_icon').first().attr('class','layer_icon icon layer_remove');
-			$(layer).find('.collapsible').first().removeClass('unselected').addClass('selected');
-		} else {
-			$(layer).find('.layer_icon').first().attr('class','layer_icon icon layer_add');
-			$(layer).find('.collapsible').first().removeClass('selected').addClass('unselected');
-// Validierung der Pfeile zum verschieben der Layer
-function validateArrows(){
-	var movers=$('#ownlist').find('.move');
-	$(movers[0]).attr('class','icon move arrow_empty');
-	if(movers.length>1){
-		$(movers[1]).attr('class','icon move arrow_up');
-// Validierung der Queryable-Auswahl
-function query_check(item){
-	if($(item).hasClass('query_unchecked')){
-		$('#ownlist').find('.query_checked').addClass('query_unchecked').removeClass('query_checked');
-		$(item).addClass('query_checked').removeClass('query_unchecked');
-	} else {
-		$(item).addClass('query_unchecked').removeClass('query_checked');
-// Hinzufüge- + Entfernfunktionen:
-// Layer zur Auswahl hinzufügen
-function addLayer(layer){
-	if(numOwnlayers()>=maxlayers){
-		getInfo('Es können nicht mehr als '+maxlayers+' Ebenen zur Auswahl hinzugefügt werden.');
-		return false;
-	} else {
-		$.mobile.showPageLoadingMsg();
-		if(position<0){
-			// Layer hinzufügen
-			$('#ownlist').append(OwnLayer(layer.attr('layerid'),layer.attr('title'),layer.attr('name'),layer.attr('desc'),layer.parent().attr('title'),layer.parent().attr('desc'),layer.attr('previewUrl'),layer.attr('queryable')=='true',layer.attr('getMapUrl'),layer.attr('bbox'),layer.parent().attr('avail')));
-			validateLayers();
-			validateArrows();
-			refresh();
-			addOpenlayer(layer.attr('layerid'),layer.attr('name'),layer.attr('getMapUrl'));
-			$.mobile.hidePageLoadingMsg();
-			return true;
-		return false;
-// Layer entfernen
-function removeLayer(layer){
-	$($('#ownlist').find('.layer')[layerInList($('#ownlist'),$(layer).attr('layerid'))]).remove();
-	validateLayers();
-	validateArrows();
-	refresh();
-	removeOpenlayer($(layer).attr('layerid'));
-// Layer hinzfügen oder entfernen
-function switchLayer(layer){
-	if(position<0){
-		addLayer(layer);
-	} else {
-		removeLayer(layer);
-// Service mit allen Layern hinzufügen
-function addService(service){
-	var layers=service.find('.layer');
-		addLayer($(layers[i]));
-		if(numOwnlayers()>maxlayers){ break; }
-// Service mit allen Layern entfernen
-function removeService(service){
-	$.each(service.find('.layer'), function(index, layer){
-		removeLayer($(layer));
-// Sichtbarkeit eines Layers umschalten
-function switchVisibility(layer){
-	if($(layer).hasClass('layer')){ // Overlay
-		$(layer).find('.layer_visibility').toggleClass('layer_checked').toggleClass('layer_unchecked');
-		selectOpenlayer($(layer).attr('layerid'),$(layer).find('.layer_visibility').hasClass('layer_checked'));
-	} else {	// Baselayer
-		$('#baselayers').find('.base_checked').addClass('base_unchecked').removeClass('base_checked');
-		$(layer).addClass('base_checked').removeClass('base_unchecked');
-		setOpenBaselayer($(layer).attr('layerids'));
-// Validierung der Baselayer-Auswahl
-function base_check(item){
-	$(item).addClass('base_checked').removeClass('base_unchecked');
-// Daten Laden + Parsen:
-// Standardsuche
-function searchMaps(searchurl){
-	$('#search_results').empty();
-	$.getJSON(searchurl, function(data){
-		var datacollection=parseMapBenderJson(data);
-		appendData(datacollection.services,datacollection.layers,datacollection.nresults);
-		if(datacollection.nresults>maxresults){
-			getInfo('Es gab '+datacollection.nresults
-				+' Treffer, es können aber nur '
-				+maxresults+' Ergebnisse angezeigt werden.'
-				+'</br><b>Schränken Sie Ihre Suche weiter ein.</b>');
-// Suche über WMC-Dienste
-function searchWmc(wmcurl){
-	$.getJSON(wmcurl, function(data){
-		appendWmc(data);
-// Parst das JSON-Objekt von MapBender in ein Array [services,layers]
-function parseMapBenderJson(json){
-	// Daten generalisieren
-	var srvs=json.wms.srv;
-	var services=[];
-	var layers=[];
-	$.each(srvs, function(index,srv){
-		// Dienste zusammenfassen
-		var dublicated=false;
-		for(var i=0; i<services.length; i++){
-			if(services[i].id==srv.id){
-				dublicated=true;
-				break;
-		// Dienst freigegeben?
-		if(!srv.logged && !srv.nwaccess){
-			if(!dublicated){
-				services.push(srv);
-			// Layer aufnehmen
-			$.each(srv.layer, function(index, grplayer){
-				if(grplayer.layer){
-					$.each(grplayer.layer, function(index, lyr){
-						layers.push([srv.id,lyr]);
-				} else {
-					layers.push([srv.id,grplayer]);
-	return {"services": services, "layers": layers, "nresults":json.wms.md.nresults};
-// Fügt die Dienste und Layer in das DOM ein
-function appendData(services,layers,nresults){
-	$("#resultlist").empty();
-		var srv=services[i];
-		service=Service(srv.id,srv.title,$(srv).attr('abstract'),srv.getMapUrl,srv.status,(srv.logoUrl==""? 'mod_mapbender/img/defaulicon.png' : srv.logoUrl ),srv.symbolLink,srv.avail);
-		// Layer zuordnen
-		for(var j=0; j<layers.length; j++){
-			var layer=layers[j];
-			var serviceid=layer[0];
-			var lyr=layer[1];
-			if(serviceid==srv.id){
-				service.append(ResultLayer(lyr.id,lyr.title,lyr.name,$(lyr).attr('abstract'),lyr.previewURL,lyr.queryable=='1',srv.getMapUrl,lyr.bbox));
-		$('#resultlist').append(service);
-	$('#resultlist').prepend('<li data-theme="b">Suchergebnis: '+numServices()+' Dienste, '
-				+numResultLayers($('#resultlist'))+' Layer '
-				+'('+nresults+' Treffer) </li>');
-	validateLayers();
-	refresh();
-// Fügt die WMC-Layer in das DOM ein
-function appendWmcData(services,layers,layerlist,bbox,crs){
-	$("#ownlist").empty();
-	var ownlayers = [];
-		// Layer zuordnen
-			var lyr=layer[1];
-				ownlayers.push(OwnLayer(lyr.id,lyr.title,lyr.name,$(lyr).attr('abstract'),srv.title,$(srv).attr('abstract'),lyr.previewURL,lyr.queryable=='1',srv.getMapUrl,lyr.bbox,srv.avail));
-	// Layer richtig sortiert einfügen und selektieren
-	for(var i=0; i<layerlist.length; i++){
-		for(var j=0; j<ownlayers.length; j++){
-			if(layerlist[i].layerId==ownlayers[j].attr('layerid')){
-				var layer=ownlayers[j];
-				$('#ownlist').append(layer);
-				if(!layerlist[i].active){ // Auswahl umschalten
-					switchVisibility(layer);
-				break;
-	validateLayers();
-	validateArrows();
-	//zoom to wmc extent
-	var p1 = new OpenLayers.LonLat(extend[0],extend[1]).transform(crs,mapProj);
-	var p2 = new OpenLayers.LonLat(extend[2],extend[3]).transform(crs,mapProj);
-// Alle ausgewählten Overlays entfernen
-function clearOwnlist(){
-	var layers=$('#ownlist').find('.layer');
-		removeLayer(layers[i]);
-// WMC-Daten hinzufügen
-function appendWmc(json){
-	// Hintergrundkarte auswählen
-	for(var i=0; i<json.backGroundLayer.length; i++){
-		var layer=json.backGroundLayer[i];
-		if(layer.active){
-			var layers=$('#baselayers').find('.baselayer')
-				if($(layers[j]).attr('layerids')==layer.name){
-					switchVisibility(layers[j]);
-					break;
-	// Parsen der bbox aus wmc
-	//var bbox = json.wmc.bbox;
-	//var crs = json.wmc.crs;
-	// Alle ausgewählten overlays entfernen
-	clearOwnlist();
-	// Layerids für die Abfrage zusammenstellen
-	var layerids="";
-	$.each(json.layerList, function(index,layer){
-		layerids=layerids+","+layer.layerId;
-	layerids=layerids.substr(1,layerids.length);
-	// Overlays auswählen
-	$.getJSON(searchUrl+'&resourceIds='+layerids, function(data){
-		// Informationen sammeln und Parsen
-		appendWmcData(datacollection.services,datacollection.layers,json.layerList,json.wmc.bbox,json.wmc.crs);
-// Hintergrunddaten in Collapsible aufnehmen
-function addBaselayers(){
-	$("#baselayers").empty();
-	// Vektorlayer
-	vector_marker = new OpenLayers.Layer.Vector("Vector Layer", {});
-	// Hintergrund:Topographie ect.
-/*	var atkis_praes_tms = new OpenLayers.Layer.TMS(
-		"Hybrid",
-		"http://www.gdi-rp-dienste2.rlp.de/mapcache/tms/",
-			layername: 'test at UTM32',
-			type: "jpeg",
-			serviceVersion:"1.0.0",
-			gutter:0,
-			buffer:0,
-			isBaseLayer:true,
-			transitionEffect:'resize',
-			resolutions: [529.16666666670005270134,396.87500000000000000000,264.58333333330000414207,132.29166666669999585793,66.14583333330000414207,39.68750000000000000000,26.45833333330000058936,13.22916666669999941064,6.61458333329999970118,3.96875000000000000000,2.64583333330000014527,2.11666666670000003236,1.32291666670000007677,0.79375000000000000000,0.26458333330000001204,0.13229166670000001016],
-			units: projUnits,
-			projection: mapProj,
-			sphericalMercator: false
-	$('#baselayers').append(BaseLayer("RLP Zusammenstellung",atkis_praes_tms.name));
-	// Hintergrund: Luftbild
-/*	var luftbilder = new OpenLayers.Layer.WMS( "Luftbild",
-		"http://geo4.service24.rlp.de/wms/dop40_geo4.fcgi?",
-		layers: "dop",
-		format: "image/jpeg",
-		transparent: "false",
-		transitionEffect: 'resize'
-		units: projUnits,
-		singleTile: false,
-		alwaysInRange: true,
-		'isBaseLayer': true
-	$('#baselayers').append(BaseLayer("Luftbilder",luftbilder.name));
-/*	var grenze_leer = new OpenLayers.Layer.WMS( "grenze_leer",
-		"http://map1.naturschutz.rlp.de/service_basis/mod_wms/wms_getmap.php?mapfile=tk_rlp_gesamt&",
-		layers: "grenzen_land",
-		units: projUnits,
-		singleTile: true,
-	$('#baselayers').append(BaseLayer("Keine Hintergrundkarte",grenze_leer.name));
-	map.addLayers([atkis_praes_tms,luftbilder,grenze_leer,vector_marker]);
-	// Dynamische Hintergrundkarten hinzufügen
-	for(i in baseinfo){
-		var name=baseinfo[i][0]
-		var layerids=baseinfo[i][1];
-		$('#baselayers').append(BaseLayer(name,layerids));
-		addOpenBaselayer(name,layerids);
-	// Erste Hintergrundkarte auswählen
-	base_check($('#baselayers').find('.baselayer').first());
Deleted: trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search_proxy.php~
--- trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search_proxy.php~	2013-05-21 15:06:10 UTC (rev 8622)
+++ trunk/mapbender/http/extensions/mobilemap/mod_mapbender/search_proxy.php~	2013-05-21 15:08:21 UTC (rev 8623)
@@ -1,60 +0,0 @@
-<?php
-require_once(dirname(__FILE__)."/../../../../conf/mobilemap.conf");
-require_once(dirname(__FILE__)."/../../../../conf/mapbender.conf");
-// PHP Proxy
-// Erlaubte Hostnamen aus baseconfig
-$mapbenderurl = $catalogueInterface;
-$mapbenderurl = "http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?";
-//Url-Parameter
-$urlparam = $_SERVER['QUERY_STRING'];
-$url = $mapbenderurl.$urlparam ;
-//angefragtes Format GetMap
-if ((isset($_GET['FORMAT'])) && ($_GET['FORMAT'] != "")) {
-	$myformat = $_GET["FORMAT"];
-	// Open the Curl session
-	$session = curl_init($url);
-	// If it's a POST, put the POST data in the body
-	if ($_POST['yws_path']) {
-		$postvars = '';
-		while ($element = current($_POST)) {
-			$postvars .= urlencode(key($_POST)).'='.urlencode($element).'&';
-			next($_POST);
-		curl_setopt ($session, CURLOPT_POST, true);
-		curl_setopt ($session, CURLOPT_POSTFIELDS, $postvars);
-	//use proxy if proxy is given in mapbender.conf - from class_connector.php
-	$arURL = parse_url($url);
-	$host = $arURL["host"];
-	$NOT_PROXY_HOSTS_array = explode(",", NOT_PROXY_HOSTS);
-	if(CONNECTION_PROXY != "" AND (in_array($host, $NOT_PROXY_HOSTS_array)!= true)){
-		curl_setopt($session, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
-		if(CONNECTION_PASSWORD != ""){
-			curl_setopt ($session, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
-	// Don't return HTTP headers. Do return the contents of the call
-	curl_setopt($session, CURLOPT_HEADER, false);
-	curl_setopt($session, CURLOPT_RETURNTRANSFER, true);
-	// Make the call
-	$response = curl_exec($session);
-	//Content-Type
-	if($myformat == "image/jpeg"){
-		header("Content-Type: image/jpeg");
-	//Datenausgabe
-	echo $response;
-	curl_close($session);
Deleted: trunk/mapbender/http/extensions/mobilemap/mod_mapbender/wmc_proxy.php~
--- trunk/mapbender/http/extensions/mobilemap/mod_mapbender/wmc_proxy.php~	2013-05-21 15:06:10 UTC (rev 8622)
+++ trunk/mapbender/http/extensions/mobilemap/mod_mapbender/wmc_proxy.php~	2013-05-21 15:08:21 UTC (rev 8623)
@@ -1,41 +0,0 @@
-<?php
-// PHP Proxy
-$mapbenderurl = $wmcInterface;
-$mapbenderurl = "http://www.geoportal.rlp.de/mapbender/php/mod_exportWmc2Json.php?";
-//Url-Parameter
-// Open the Curl session
-$session = curl_init($url);
-//use proxy if proxy is given in mapbender.conf - from class_connector.php
-$arURL = parse_url($url);
-$host = $arURL["host"];
-$NOT_PROXY_HOSTS_array = explode(",", NOT_PROXY_HOSTS);
-if(CONNECTION_PROXY != "" AND (in_array($host, $NOT_PROXY_HOSTS_array)!= true)){
-// Don't return HTTP headers. Do return the contents of the call
-curl_setopt($session, CURLOPT_HEADER, false);
-curl_setopt($session, CURLOPT_RETURNTRANSFER, true);
-// Make the call
-$response = curl_exec($session);
-//Datenausgabe
-echo $response;
-curl_close($session);
Deleted: trunk/mapbender/http/extensions/mobilemap/query/proxy.php~
--- trunk/mapbender/http/extensions/mobilemap/query/proxy.php~	2013-05-21 15:06:10 UTC (rev 8622)
+++ trunk/mapbender/http/extensions/mobilemap/query/proxy.php~	2013-05-21 15:08:21 UTC (rev 8623)
@@ -1,79 +0,0 @@
-<?php
-// PHP Proxy
-define ('MAPPROXY_HOSTNAME', $mapproxyurl);
-define ('GETMAP_HOSTNAME',$getmapurl);
-define ('GETFEATURE_HOSTNAME', $getfeatureurl);
-//Url-Parameter
-$path = $_SERVER['QUERY_STRING'];
-	$url = GETMAP_HOSTNAME.$path;
-//angefragtes Format Featureinfo
-if ((isset($_GET['INFO_FORMAT'])) && ($_GET['INFO_FORMAT'] != "")) {
-	$myformat = $_GET["INFO_FORMAT"];
-	$url = GETFEATURE_HOSTNAME.$path;
-//Url ändern falls URL-Variable cache mitgegeben wird
-if ((isset($_GET['CACHE'])) && ($_GET['CACHE'] == "mapproxy")) {
-	$url = MAPPROXY_HOSTNAME.$path;
-if($useproxy){
-		$postvars = '';
-			next($_POST);
-	// Make the call
-	//Content-Type
-	else if($myformat == "image/png"){
-		header("Content-Type: image/png");
-	else if($myformat == "text/html"){
-		header("Content-Type: text/html");
-	else {
-		//header("Content-Type: text/plain");
-	//Datenausgabe
-	echo $response;
-else{
-	Header($url);
-	exit();
Deleted: trunk/mapbender/http/extensions/mobilemap/query/rasterquery.php~
--- trunk/mapbender/http/extensions/mobilemap/query/rasterquery.php~	2013-05-21 15:06:10 UTC (rev 8622)
+++ trunk/mapbender/http/extensions/mobilemap/query/rasterquery.php~	2013-05-21 15:08:21 UTC (rev 8623)
@@ -1,101 +0,0 @@
-<?php
-//Language config
-include_once('../config/language/check_lang.php');
-include_once('../config/language/language.'.$mylang.'.php');
-$coord = split(',',$_GET["coord"]);
-//Mapfile laden
-$map= ms_newMapObj($mapfilepath.'\map.map');
-//Punkt erzeugen
-$qPoint = ms_newPointObj();
-$qPoint->setXY($coord[0]*1,$coord[1]*1);
-//Layer festlegen
-$layer = $map->getLayerByName($rquerylayer);
-//Punktabfrage (Single)
-@$datQuery = $layer->queryByPoint($qPoint, MS_SINGLE, 1);
- // UMRECHNUNG  Eingabe koordinatensystem -> WGS84
-$projInObj = ms_newprojectionobj("init=epsg:$ggepsg");
-$projOutObj = ms_newprojectionobj("init=epsg:4326");
-$qPoint->project($projInObj, $projOutObj);
-$WGS_X = round($qPoint->x,6);
-$WGS_Y = round($qPoint->y,6);
-print '<div id="dhmqueryId" >';
-print ('<table border="0" cellspacing="0" cellpadding="1" class="normal">');
-//Wenn Query erfolgreich
-     if ($datQuery == MS_SUCCESS) {
-         for ($j=0; $j<$layer->getNumResults(); $j++) {
-            $result = $layer->getResult($j);
-			//Versionsüberprüfung
-			if (ms_GetVersionInt() < 50600){
-				$layer->open();
-			$shpobj = $layer->getShape($result->tileindex,$result->shapeindex);
-			else{
-			$shpobj = $layer->resultsGetShape($result->shapeindex,$result->tileindex);
-			$attr = $shpobj->values;
-			//echo round($attr["value_0"],2);
-			$hoehe = round($attr["value_0"],1);
-			if ($hoehe <0){
-			  print '<tr ><td colspan="3" ><strong>'.$maplang['rasterquery_nodata'].'</strong></td></tr>';
-			else{
-			print '<tr><td>'.$maplang['rasterquery_h'].'</td><td><span class="hilite">'.$hoehe.'</span></td><td>m NN</td></tr>';
-			$shpobj->free();
-				$layer->close();
-	 else{
-	    print '<tr ><td colspan="3" ><strong>'.$maplang['rasterquery_noh'].'</strong></td></tr>';
-		//echo "Kein Wert verfügbar!";
-print ('<tr bgcolor="#E6E6E6"><td colspan="3" >'.$maplang['rasterquery_gps'].'</td></tr>
-  <tr>
-    <td>Lat:</td>
-    <td colspan="2">'.$WGS_Y.'</td>
-  </tr>
-  <tr>
-    <td>Lon:</td>
-    <td colspan="2">'.$WGS_X.'</td>
-  </tr>
-  <tr bgcolor="#E6E6E6">
-    <td colspan="3" >'.$maplang['rasterquery_xy'].'</td>
-  </tr>
-  <tr>
-    <td>X</td>
-    <td colspan="2">'.round($coord[0],0).'</td>
-  </tr>
-  <tr>
-    <td>Y</td>
-    <td colspan="2">'.round($coord[1],0).'</td>
-  </tr>
-   <tr>
-    <td colspan="3" align="left"><a href="javascript:void(0);"  onClick="javascript:zoompoint('.round($coord[0],0).','.round($coord[1],0).');" ><img src="'.$applicationurl.'/img/ico_zoomin.png"  border="0" > '.$maplang['geocode_result4'].'</a></td>
-  </tr>
-  <tr>
-    <td colspan="3" align="right">');
-print('	</td></tr></table></div>');
Deleted: trunk/mapbender/http/extensions/mobilemap/query/searchproxy.php~
--- trunk/mapbender/http/extensions/mobilemap/query/searchproxy.php~	2013-05-21 15:06:10 UTC (rev 8622)
+++ trunk/mapbender/http/extensions/mobilemap/query/searchproxy.php~	2013-05-21 15:08:21 UTC (rev 8623)
@@ -1,48 +0,0 @@
-<?php
-// PHP Proxy
-// Erlaubter Hostname
-$getjsonurl = 'http://www.geoportal.rlp.de/mapbender/geoportal/gaz_geom_mobile.php?';
-//Url-Parameter
-$url = $getjsonurl.$path;
-$useproxy = true;
-if($useproxy){
-	// Make the call
-	//header("Content-Type: application/json");
-	//Datenausgabe
-	echo $response;
-else{
-	Header($url);
-	exit();
More information about the Mapbender_commits mailing list
