[Mapbender-commits] r8634 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 31 00:56:50 PDT 2013
Author: armin11
Date: 2013-05-31 00:56:50 -0700 (Fri, 31 May 2013)
New Revision: 8634
   trunk/mapbender/http/javascripts/mod_loadwmc.js
Alter loadwmc to delete divs when new divs are opened.
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js	2013-05-30 12:47:12 UTC (rev 8633)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js	2013-05-31 07:56:50 UTC (rev 8634)
@@ -238,6 +238,7 @@
 	this.hideWmcXml = function () {
 		if($('.wmcDisplayPopup').size() > 0) {
 			$('.wmcDisplayPopup').dialog('destroy');
+			$('.wmcDisplayPopup').remove();
 	//next function is obsolete
@@ -263,8 +264,8 @@
 	//following is added to give a window with an integrated link which can be included in external applications
 	this.showApiUrl = function (url) {
-		this.hideApiUrl();
-		var $wmcApiUrlPopup = $('<div id="api_url"><input size="35" type="text" value="' + url + '"/></div>');
+		that.hideApiUrl();
+		var $wmcApiUrlPopup = $('<div class="wmcApiUrlPopup" id="api_url"><input size="35" type="text" value="' + url + '"/></div>');
 		$wmcApiUrlPopup.dialog({
 			title: translatedI18nObject.labelOpenLayersUrl,
 			bgiframe: true,
@@ -278,8 +279,8 @@
 	this.hideApiUrl = function () {
 		if($('.wmcApiUrlPopup').size() > 0) {
-			$('.wmcApiUrlUrlPopup').dialog('destroy');
-			$('#api_url').remove();
+			$('.wmcApiUrlPopup').dialog('destroy');
+			$('.wmcApiUrlPopup').remove();
@@ -292,7 +293,7 @@
 		olUrl = mobileUrl + "php/mod_wmc2ol.php?wmc_id=" + id ;
 		mobileUrl = mobileUrl + "extensions/mobilemap/map.php?wmcid=" + id ;
 		//initialize dialog
-		var $wmcApiDialog = $('<div id="api_dialog"></div>');
+		var $wmcApiDialog = $('<div class="wmcApiDialog" id="api_dialog"></div>');
 		$wmcApiDialog.dialog({
 			title: translatedI18nObject.labelApi,
 			bgiframe: true,
@@ -300,7 +301,10 @@
 			modal: false,
 			width: 350,
 			height: 90,
-			pos: [600,40]
+			pos: [600,40],
+			close: function (){
+				that.hideDependendWindows();
 		//generate API options
 		$apiTable = $('<table>');
@@ -360,9 +364,8 @@
 	this.hideApiList = function () {
 		if($('.wmcApiDialog').size() > 0) {
 			$('.wmcApiDialog').dialog('destroy');
+			$('.wmcApiDialog').remove();//
-		$('#api_dialog').remove();//link to url
 	//end of the link-handle popup
More information about the Mapbender_commits mailing list
