[Mapbender-commits] r9030 - trunk/mapbender/http/classes
    svn_mapbender at osgeo.org
    Wed Aug  6 07:07:40 PDT 2014
Author: armin11
Date: 2014-08-06 07:07:40 -0700 (Wed, 06 Aug 2014)
New Revision: 9030
   trunk/mapbender/http/classes/class_iso19139.php
Possibility to handle simple gml3 exterior rings to use them as bounding geometries of metadata sets.
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php	2014-08-05 14:13:04 UTC (rev 9029)
+++ trunk/mapbender/http/classes/class_iso19139.php	2014-08-06 14:07:40 UTC (rev 9030)
@@ -27,6 +27,8 @@
 	var $abstract;
 	var $metadata;
 	var $wgs84Bbox = array(); //minx, miny, maxx, maxy in EPSG:4326
+	var $polygonalExtentExterior; //Prototype: Two dimensional array of coordinates $polygonalExtentExterior[i]['x'],  $polygonalExtentExterior[i]['y']
+	//var $polygonalExtentExterior = boolean; //TODO maybe implemented somewhen, now only exterior (GML3) is supported, maybe we can use the GML classes themself?
 	var $datasetId;
 	var $datasetIdCodeSpace;
 	var $keywords = array();
@@ -73,6 +75,7 @@
 		$this->changeDate = "1900-01-01";
 		$this->metadata = "";
 		$this->wgs84Bbox = array(-180.0,-90.0,180.0,90.0); //minx, miny, maxx, maxy in EPSG:4326
+		$this->polygonalExtentExterior = array(); //initialize empty array
 		$this->datasetId = "";
 		$this->datasetIdCodeSpace = "";
 		$this->keywords = array();
@@ -294,6 +297,34 @@
 			$maxy = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/gmd:northBoundLatitude/gco:Decimal');
 			$maxy = $maxy[0];
 			$this->wgs84Bbox = array($minx,$miny,$maxx,$maxy);
+			//more info: https://geo-ide.noaa.gov/wiki/index.php?title=ISO_Extents
+			//look for GML3 polygon as exterior ring in two alternative encodings (see: http://www.galdosinc.com/archives/191 - all coords are interpreted as given in EPSG:4326 for the moment!!!):
+			if ($iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:geographicElement/gmd:EX_BoundingPolygon/gmd:polygon/gml:Polygon/gml:exterior/gml:LinearRing/gml:posList')) {
+				//read posList
+				$exteriorRingPoints = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:geographicElement/gmd:EX_BoundingPolygon/gmd:polygon/gml:Polygon/gml:exterior/gml:LinearRing/gml:posList');
+				if (count($exteriorRingPoints) > 0) {
+					//poslist is only space separated
+					$exteriorRingPointsArray = explode(' ',$exteriorRingPoints[0]);
+					for ($i = 0; $i <= count($exteriorRingPointsArray)/2-1; $i++) {
+						$this->polygonalExtentExterior[$i]['x'] = $exteriorRingPointsArray[2*$i];
+						$this->polygonalExtentExterior[$i]['y'] = $exteriorRingPointsArray[(2*$i)+1];
+			} else {
+				//try to read coordinates
+				$exteriorRingPoints = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:geographicElement/gmd:EX_BoundingPolygon/gmd:polygon/gml:Polygon/gml:exterior/gml:LinearRing/gml:coordinates');
+					//two coordinates of one point are comma separated
+					//problematic= ", " or " ," have to be deleted before
+					$exteriorRingPoints[0] = str_replace(', ',',',str_replace(' ,',',',$exteriorRingPoints[0]));
+					for ($i = 0; $i <= count($exteriorRingPointsArray)-1;$i++) {
+						$coords = explode(",",$exteriorRingPointsArray[$i]);
+						$this->polygonalExtentExterior[$i]['x'] = $coords[0];
+						$this->polygonalExtentExterior[$i]['y'] = $coords[1];
 			$this->hierachyLevel = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:hierarchyLevel/gmd:MD_ScopeCode');
 			$this->hierachyLevel = $this->hierachyLevel[0];
 			$this->tmpExtentBegin = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:beginPosition');
@@ -729,8 +760,55 @@
+	private function parseExteriorPolygon($gml3Polygon) {
+		//cause postgis gives back polygons without namspace, we have to add a namespace before parsing the xml again :-(
+		$gml3Polygon = "<?xml version=\"1.0\" encoding=\"utf-8\" ?>".$gml3Polygon;
+		libxml_use_internal_errors(true);
+		try {
+			$iso19139Xml = simplexml_load_string($gml3Polygon);
+			if ($iso19139Xml === false) {
+				foreach(libxml_get_errors() as $error) {
+        				$err = new mb_exception("class_Iso19139:".$error->message);
+				throw new Exception("class_Iso19139:".'Cannot parse Metadata XML!');
+				return false;
+		catch (Exception $e) {
+    			$err = new mb_exception("class_Iso19139:".$e->getMessage());
+			return false;
+		//if parsing was successful
+		if ($iso19139Xml !== false) {
+			//add ns as attribute
+			$iso19139Xml->addAttribute('xmlns:xmlns:gml', 'http://www.opengis.net/gml');
+			//reloadXML
+			$iso19139Xml = simplexml_load_string($iso19139Xml->asXML());
+			$iso19139Xml->registerXPathNamespace("gml", "http://www.opengis.net/gml");
+			$e = new mb_exception("class_iso19139.php: parsing successfull!");
+			//<gml:Polygon srsName="EPSG:4326"><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">
+			$posListArray = $iso19139Xml->xpath('/gml:Polygon/gml:exterior/gml:LinearRing/gml:posList');
+			if (count($posListArray) > 0) {
+				$e = new mb_exception("class_iso19139.php: found pos list!");
+				//read posList
+				$exteriorRingPoints = $posListArray;
+						$polygonalExtentExterior[$i]['x'] = $exteriorRingPointsArray[2*$i];
+						$polygonalExtentExterior[$i]['y'] = $exteriorRingPointsArray[(2*$i)+1];
+				$e = new mb_exception("class_iso19139.php: ". count($polygonalExtentExterior) . " point objects!");
+				return $polygonalExtentExterior;
+		return array();
 	public function createFromDBInternalId($metadataId){
-		$sql = "SELECT * , box2d(the_geom) as bbox2d from mb_metadata WHERE metadata_id = $1";
+		$sql = "SELECT * , box2d(the_geom) as bbox2d, st_asgml(3,bounding_geom) as bounding_polygon from mb_metadata WHERE metadata_id = $1";
 		$v = array($metadataId);
 		$t = array('i');
 		$res = db_prep_query($sql,$v,$t);
@@ -752,6 +830,14 @@
 				//$e = new mb_exception("class_iso19139.php: got bbox for metadata: ".$bbox);
 				$this->wgs84Bbox = explode(',',$bbox);
+			if (isset($row['bounding_polygon']) && $row['bounding_polygon'] != '') {
+				//extract coordinates from gml
+				//push them into array
+				//store them in object
+				//$bbox = str_replace(' ',',',str_replace(')','',str_replace('BOX(','',$row['bbox2d'])));
+				//$e = new mb_exception("class_iso19139.php: got bbox for metadata: ".$bbox);
+				$this->polygonalExtentExterior = $this->parseExteriorPolygon($row['bounding_polygon']);
 			//fill keywords and categories later cause they are stored in relations!
 			/*$this->keywords = array();
 			$this->keywordsThesaurusName = array();
@@ -1089,6 +1175,23 @@
 		return $postGisBbox;
+	private function createWktPolygonFromPointArray($pointArray) { //-180 -90 180 90
+		$postGisPolygon = "";
+		//"SRID=4326;POLYGON((-140 -80,-140 80,170 80,170 -80,-140 -80))"
+		$postGisPolygon = "SRID=4326;POLYGON((";
+		if (count($pointArray) == 0) {
+			return null;
+ 		} else {
+			foreach ($pointArray as $point) {
+				$postGisPolygon .= trim($point['x'])." ".trim($point['y']).",";
+			$postGisPolygon = rtrim($postGisPolygon,',');
+			$postGisPolygon .= "))";
+			$e = new mb_exception("class_iso19139.php: polygon: ".$postGisPolygon);
+			return $postGisPolygon;
 	public function insertKeywordsAndCategoriesIntoDB($metadataId,$resourceType,$resourceId){
 		//first delete old classifications - after that create new ones
 		$this->deleteKeywordsAndCategoriesFromDB($metadataId,$resourceType,$resourceId);
@@ -1378,7 +1481,7 @@
 	public function insertMetadataIntoDB() {
 		//insert an instance for iso19139 into mapbenders database
 		$sql = <<<SQL
-INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system, the_geom, datalinks, inspire_whole_area, inspire_actual_coverage, inspire_download)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30, $31, $32, $33, $34)
+INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system, the_geom, datalinks, inspire_whole_area, inspire_actual_coverage, inspire_download, bounding_geom)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30, $31, $32, $33, $34, $35)
 SQL;
 		$v = array(
 			$this->href,
@@ -1414,9 +1517,10 @@
 			$this->jsonEncodeDownloadLinks($this->downloadLinks),
 			$this->inspireWholeArea,
 			$this->inspireActualCoverage,
-			$this->inspireDownload
+			$this->inspireDownload,
+			$this->createWktPolygonFromPointArray($this->polygonalExtentExterior)
-			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s','s','s','i');
+			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s','s','s','i','POLYGON');
 			return $res;
@@ -1440,7 +1544,7 @@
 		$sql .= "linktype = $4, uuid = $5, title = $6, createdate = $7, changedate = $8, lastchanged = now(), ";
 		$sql .= "abstract = $9, searchtext = $10, type = $11, tmp_reference_1 = $12, tmp_reference_2 = $13, export2csw = $14, datasetid = $15, ";
 		$sql .= "datasetid_codespace = $16, randomid = $17, harvestresult = $20, harvestexception = $21, lineage = $22, inspire_top_consistence = $23, ";
-		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30, datalinks = $31, inspire_whole_area = $32, inspire_actual_coverage = $33, inspire_download = $34 WHERE metadata_id = $19";
+		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30, datalinks = $31, inspire_whole_area = $32, inspire_actual_coverage = $33, inspire_download = $34, bounding_geom = $35 WHERE metadata_id = $19";
 		$v = array(
 			$this->href,
@@ -1477,9 +1581,10 @@
 		return $res;
@@ -1576,7 +1681,7 @@
 		return true;
-	private function getExtentGraphic($layer_4326_box) {
+	public function getExtentGraphic($layer_4326_box) {
 		$area_4326_box = explode(',',EXTENTSERVICEBBOX);
 		if ($layer_4326_box[0] <= $area_4326_box[0] || $layer_4326_box[2] >= $area_4326_box[2] || $layer_4326_box[1] <= $area_4326_box[1] || $layer_4326_box[3] >= $area_4326_box[3]) {
 			if ($layer_4326_box[0] < $area_4326_box[0]) {
@@ -1605,47 +1710,10 @@
 			if ($new_miny < -90) $area_4326_box[1] = -90; else $area_4326_box[1] = $new_miny;
 			if ($new_maxy > 90) $area_4326_box[3] = 90; else $area_4326_box[3] = $new_maxy;
-		$getMapUrl = EXTENTSERVICEURL."VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=".EXTENTSERVICELAYER."&STYLES=&SRS=EPSG:4326&BBOX=".$area_4326_box[0].",".$area_4326_box[1].",".$area_4326_box[2].",".$area_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&minx=".$layer_4326_box[0]."&miny=".$layer_4326_box[1]."&maxx=".$layer_4326_box[2]."&maxy=".$layer_4326_box[3];
+		$getMapUrl = EXTENTSERVICEURL."VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=".EXTENTSERVICELAYER."&STYLES=&SRS=EPSG:4326&BBOX=".$area_4326_box[0].",".$area_4326_box[1].",".$area_4326_box[2].",".$area_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&minx=".$layer_4326_box[0]."&miny=".$layer_4326_box[1]."&maxx=".$layer_4326_box[2]."&maxy=".$layer_4326_box[3]."&metadata_uuid=".$this->fileIdentifier;
 		return $getMapUrl;
-/*	private function getExtentGraphic($layer_4326_box) {
-		$rlp_4326_box = array(6.05,48.9,8.6,50.96);
-		if ($layer_4326_box[0] <= $rlp_4326_box[0] || $layer_4326_box[2] >= $rlp_4326_box[2] || $layer_4326_box[1] <= $rlp_4326_box[1] || $layer_4326_box[3] >= $rlp_4326_box[3]) {
-			if ($layer_4326_box[0] < $rlp_4326_box[0]) {
-				$rlp_4326_box[0] = $layer_4326_box[0];
-			if ($layer_4326_box[2] > $rlp_4326_box[2]) {
-				$rlp_4326_box[2] = $layer_4326_box[2];
-			if ($layer_4326_box[1] < $rlp_4326_box[1]) {
-				$rlp_4326_box[1] = $layer_4326_box[1];
-			if ($layer_4326_box[3] > $rlp_4326_box[3]) {
-				$rlp_4326_box[3] = $layer_4326_box[3];
-			$d_x = $rlp_4326_box[2] - $rlp_4326_box[0];
-			$d_y = $rlp_4326_box[3] - $rlp_4326_box[1];
-			$new_minx = $rlp_4326_box[0] - 0.05*($d_x);
-			$new_maxx = $rlp_4326_box[2] + 0.05*($d_x);
-			$new_miny = $rlp_4326_box[1] - 0.05*($d_y);
-			$new_maxy = $rlp_4326_box[3] + 0.05*($d_y);
-			if ($new_minx < -180) $rlp_4326_box[0] = -180; else $rlp_4326_box[0] = $new_minx;
-			if ($new_maxx > 180) $rlp_4326_box[2] = 180; else $rlp_4326_box[2] = $new_maxx;
-			if ($new_miny < -90) $rlp_4326_box[1] = -90; else $rlp_4326_box[1] = $new_miny;
-			if ($new_maxy > 90) $rlp_4326_box[3] = 90; else $rlp_4326_box[3] = $new_maxy;
-		$getMapUrl = EXTENTSERVICEURL."VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=".EXTENTSERVICELAYER."&STYLES=&SRS=EPSG:4326&BBOX=".$rlp_4326_box[0].",".$rlp_4326_box[1].",".$rlp_4326_box[2].",".$rlp_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&minx=".$layer_4326_box[0]."&miny=".$layer_4326_box[1]."&maxx=".$layer_4326_box[2]."&maxy=".$layer_4326_box[3];
-		return $getMapUrl;
 	public function insertToDB($resourceType, $resourceId){
 		$result = array(); //value/message
 		switch ($this->origin) {
More information about the Mapbender_commits
