[Mapbender-commits] r9047 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Wed Aug 13 01:43:01 PDT 2014
Author: hwbllmnn
Date: 2014-08-13 01:43:01 -0700 (Wed, 13 Aug 2014)
New Revision: 9047
trunk/mapbender/http/plugins/mb_digitize_widget.php
always extract style info from inputs when saving
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php 2014-08-13 08:16:56 UTC (rev 9046)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php 2014-08-13 08:43:01 UTC (rev 9047)
@@ -373,10 +373,13 @@
var url = $link.parent().parent().attr('title');
var feature = kml._kmls[url].data.features[idx];
var isline = false;
+ var ispoint = false;
kml.zoomToFeature(url, idx);
if(feature.geometry.type.match(/point/i)) {
+ ispoint = true;
editStyleDialog.find('input[name*="fill"],input[name*="stroke"],.opacity-slider').parent().parent().css('display', 'none');
editStyleDialog.find('input[name*="marker"]').parent().parent().css('display', 'table-row');
if(feature.properties['marker-type'] === 'custom') {
@@ -390,6 +393,7 @@
if(feature.geometry.type.match(/line/i)) {
+ isline = true;
editStyleDialog.find('input[name*="fill"],input[name*="marker"],.opacity-slider[data-name="fill-opacity"]').parent().parent().css('display', 'none');
editStyleDialog.find('input[name*="stroke"],.opacity-slider[data-name="stroke-opacity"]').parent().parent().css('display', 'table-row');
editStyleDialog.find('.digitize-style-custom').css('display', 'block');
@@ -439,6 +443,10 @@
return;
+ if(!ispoint && $(this).attr('name').match(/marker/)) {
+ return;
if($(this).attr('name') === 'stroke-width') {
var val = $(this).val();
if(!(!isNaN(parseFloat(val)) && isFinite(val)) || $(this).val() <= 0) {
@@ -483,7 +491,7 @@
editStyleDialog.find('input[name="fill"]').spectrum();
editStyleDialog.find('input[name="stroke"]').spectrum();
editStyleDialog.find('input[name="marker-color"]').spectrum();
- editStyleDialog.find('input[name="marker-symbol"]').change();
+ editStyleDialog.find('input').change();
if(menu)
menu.menu('destroy').remove();
More information about the Mapbender_commits
