[Mapbender-commits] r8774 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Mon Feb 10 03:34:02 PST 2014
Author: armin11
Date: 2014-02-10 03:34:02 -0800 (Mon, 10 Feb 2014)
New Revision: 8774
trunk/mapbender/http/php/mod_exportISOMetadata.php
trunk/mapbender/http/php/mod_showMetadata.php
trunk/mapbender/http/php/wms.php
Some little bugfixes and possibility to export metadata based inspire dls to iso19139 xml.
Modified: trunk/mapbender/http/php/mod_exportISOMetadata.php
--- trunk/mapbender/http/php/mod_exportISOMetadata.php 2014-02-07 12:53:34 UTC (rev 8773)
+++ trunk/mapbender/http/php/mod_exportISOMetadata.php 2014-02-10 11:34:02 UTC (rev 8774)
@@ -153,6 +153,14 @@
$dlsOption = $option->type;
$dlsOptionId = $option->serviceId;
break;
+ case "downloadlink":
+ $generatorDlsUrl = $generatorBaseUrlDls."Id=".$row_metadata["uuid"]."&outputFormat=iso19139&generateFrom=metadata";
+ $dlsOption = $option->type;
+ //generate downloadservice uuid from metadata_uuid and hash of link
+ $mdPart = explode('-',$row_metadata["uuid"]);
+ $linkPart = md5($option->link);
+ $dlsOptionId = $mdPart[0]."-".$mdPart[1]."-".$mdPart[2]."-".substr($linkPart, -12, 4)."-".substr($linkPart, -8, 8);
+ break;
echo "<br>".$generatorDlsUrl."<br>";
//load the xml and store it to filesystem
Modified: trunk/mapbender/http/php/mod_showMetadata.php
--- trunk/mapbender/http/php/mod_showMetadata.php 2014-02-07 12:53:34 UTC (rev 8773)
+++ trunk/mapbender/http/php/mod_showMetadata.php 2014-02-10 11:34:02 UTC (rev 8774)
@@ -916,7 +916,7 @@
if ($layerAccessibility && WRAPPER_PATH != '' && ($resource == 'layer' or $resource == 'wms' )) {
- $showMapUrl = $mapbenderBaseUrl.WRAPPER_PATH."?LAYER[zoom]=1&LAYER[id]=".$resourceMetadata['contentid']."&LAYER[visible]=0&LAYER[queryable]=0";
+ $showMapUrl = $mapbenderBaseUrl.WRAPPER_PATH."?LAYER[zoom]=1&LAYER[id]=".$resourceMetadata['contentid']."&LAYER[visible]=0&LAYER[querylayer]=0";
//$html .= $t_a.$translation['addLayerToMap'].$t_b."<a href='".$showMapUrl."' target='_blank'><img src='../img/osgeo_graphics/layer-wms-add.png'></a>".$t_c;
$html .= $t_a."<button onclick='window.open(\"".$showMapUrl."\",
\"windowname1\",
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php 2014-02-07 12:53:34 UTC (rev 8773)
+++ trunk/mapbender/http/php/wms.php 2014-02-10 11:34:02 UTC (rev 8774)
@@ -960,7 +960,7 @@
//call function for sublayer element
-function createLayerElement ($doc, $wmsId, $layerRow, $wmsRow, $AuthorityName) {
+function createLayerElement ($doc, $wmsId, $layerRow, $wmsRow, $AuthorityName, $mapbenderMetadataUrlUrl) {
#Creating single layer node
$layer = $doc->createElement("Layer");
if($layerRow['layer_queryable'] <> "" AND $layerRow['layer_queryable'] <> NULL) {
@@ -1275,7 +1275,7 @@
-function createLayerTree($parent, $withChilds, $layerId, &$layer, $wmsId, $doc, $wms_row) {
+function createLayerTree($parent, $withChilds, $layerId, &$layer, $wmsId, $doc, $wms_row, $mapbenderMetadataUrlUrl) {
$sub_layer_sql = "SELECT * FROM layer WHERE fkey_wms_id = $1 AND layer_parent = $2 ORDER BY layer_pos";
$v = array($wmsId, $parent);
$t = array("i","s");
@@ -1287,9 +1287,9 @@
//$e = new mb_exception($sub_layer_sql);
$res_sub_layer_sql = db_prep_query($sub_layer_sql, $v, $t);
while ($sub_layer_row = db_fetch_array($res_sub_layer_sql)) {
- $subLayer = createLayerElement($doc, $wmsId, $sub_layer_row, $wms_row, $AuthorityName);
+ $subLayer = createLayerElement($doc, $wmsId, $sub_layer_row, $wms_row, $AuthorityName, $mapbenderMetadataUrlUrl);
//recursive creation
- createLayerTree($sub_layer_row['layer_pos'], $withChilds, $layerId, $subLayer, $wmsId, $doc, $wms_row);
+ createLayerTree($sub_layer_row['layer_pos'], $withChilds, $layerId, $subLayer, $wmsId, $doc, $wms_row, $mapbenderMetadataUrlUrl);
$layer->appendChild($subLayer);
@@ -1304,12 +1304,12 @@
//TODO: root layer is always there but the following pulls only the sublayer and not the requested layer by its own!! - todo: don't use the root layer every time!!! pull the requested layer instead but pull all srs and things which are inherited from the root layer or the parents from this layer - it is not always easy if the hirarchy is nested much - pull all parents - maybe a thing for class_administration!
if ($withChilds) {
//create layer itself first!
- $subLayer = createLayerElement($doc, $wmsId, $row, $wms_row, $AuthorityName);
+ $subLayer = createLayerElement($doc, $wmsId, $row, $wms_row, $AuthorityName, $mapbenderMetadataUrlUrl);
- createLayerTree($layerPos, $withChilds, $layerId, $subLayer, $wms_row['wms_id'], $doc, $wms_row);
+ createLayerTree($layerPos, $withChilds, $layerId, $subLayer, $wms_row['wms_id'], $doc, $wms_row, $mapbenderMetadataUrlUrl);
} else {
//only create one layer
header("Content-type: application/xhtml+xml; charset=UTF-8");
More information about the Mapbender_commits
